Semi-“FlexiForm” 50Ω RF Cables
ø0.047”, ø0.085” & ø0.141” Cable Options
Standard Connector Interfaces
Solutions up to 90GHz
Low VSWR & Insertion Loss
Operating Temps up to 125ºC
FEP Jacketed Cable
Formable Bending during installation
Ideal for Phase Matching & Precision Lengths
ConductRF Cable #
A33RFJ
A28RFJ
A29RFJ
Outer Shield Diemeter
ø0.047”
ø0.085”
ø0.141”
Centre Conductor Material
Silver Plated OFHC Solid Copper
Laminated PTFE
Dielectric Material
Outer Braid 1
Silver Plated OFHC Copper Foil
Outer Braid 2
Tin Plated OFHC Copper Braid
Cable Jacket
Black FEP
Capacitance
95pF/m
Available in 3 common cable diameters, with
the benefits of higher operating frequencies,
shielding effectiveness and stability
performance over traditional standard Hand
Formable cables, these solutions enhance any
application requiring higher performance.
71%
Velocity of Propagation
4.59ns/m
Electrical Delay
>100dB
Shielding to 18GHz
-55ºC to +125ºC
Operating Temp. Range
Jacket Diameter
ø0.067”
ø0.104”
ø0.168”
Max Op. Voltage
900Vrms
1,500Vrms
1,900Vrms
3mm
5mm
10mm
90GHz
60GHz
33GHz
Static Min. Bend Radius
Cable Max Frequency
ConductRF FPA Cable Assemblies use a unique,
Low Loss, high performance Semi-“FlexiForm”
Cable that is formable, but flexible, providing
system designers with a versatile solution for
High Frequency applications. The product also
allows for very tight phase matching to ±0.2º.
ConductRF’s FPA Cable Assemblies are
manufactured using the latest induction
soldering techniques to best ensure the highest
quality and performance because, Results
Count!
FPA28-D1D1-S06
FPAXX-YZYZ-YYY
XXX(Max Frequency)
A28 = 0.085”(Up to 60GHz)
A29 = 0.141”(Up to 33GHz)
A33 = 0.047”(Up to 90GHz)
Note: See individual drawings for
operating frequency variants available.
21A-FPA
Y(Max Frequency)
N = Type-N(18GHz)
S = SMA(27GHz)
E = 3.5mm(32GHz)
D = 2.92mm(40GHz)
C= 2.4mm(50Ghz)
B= 1.85mm(70GHz)
P= SMP(40GHz)
PM = SMPM(60GHz)
Z
1 = Straight Male
2 = R/A Male
3 = Bulkhead Mount
4 = Panel Mount
F = Straight Female
R= R/A Female
Sales@ConductRF.com - Tel: +1 978 374 6840 -
YYY
FYY = Length in ft.(F06 = 6ft)
SYY = Length in in.(S18 = 18”)
YMY = Length in M(2M5 = 2.5m)
CYY = Length in CM(C50 = 50cm)
www.ConductRF.com
很抱歉,暂时无法提供与“FPA3C-PMRPMR-S08”相匹配的价格&库存,您可以联系我们找货
