USB 3.0 Series Data-Con-X® Sealed Connectors
NPB 643
Bayonet Quick Connect or Threaded
Coupling Options Available
Accepts cables in O.D. size range 0.171-0.208”
[4.34mm-5.28mm]
Durable housing is sealed to IP68 and
UV resistant with a UL F1 rating
Front
Back
Also accepts standard USB Type “A”
Connectors
User Installable connectors offer flexibility
Micro USB 3.0 Connector on back
(backwards compatible with 2.0)
USB 3.0 offer up to 10X the speed of USB 2.0
Part Number Ordering Code
Bayonet Quick-Connect Style
DCC-US3AB-180
Data-Con-X USB 3.0 Type “A” Cable End, Bayonet Style Latching
DCP-US3AB-US3C Data-Con-X USB 3.0 Type “A” to Micro Panel Mount, Bayonet Style Latching
Threaded Style
DCC-US3AT-180
Data-Con-X USB 3.0 Type “A” Cable End,Threaded Style Latching
DCP-US3AT-US3C
Data-Con-X USB 3.0 Type “A” to Micro Panel Mount, Threaded Style Latching
Optional Accessories
D24295-WA
Data-Con-X USB 3.0 IP68 Sealed Cap for Panel Mount
Specifications
• Current Rating: 1.0 A
• Dielectric Withstanding Voltage: 100V AC for 1 min
• Insulation Resistance: 100 megaohms Min
• Contact Resistance: 50 milliohms Max
• Temperature Limits: -25°C to 80°C
• Seal Rating (mated): IP68/IP67, NEMA 250 (6P)
• Recommended Panel Thickness:
Bayonet: 1/32” to 3/16” (0.8mm to 4.8mm)
Threaded: 1/32” to 5/32” (0.8mm to 3.9mm)
Materials
Housing: Thermoplastic, Black
Sealing Nut, Coupling Ring: Thermoplastic, Black
Hex Nut: Thermoplastic, Black
Insert: Thermoplastic, Black
Sealing Ring: Elastomer, Black
O-Ring Elastomer, Red
Gasket Elastomer, Black
PCB: FR-4
VISIT WWW.CONXALL.COM FOR DRAWINGS AND DETAILED SPECIFICATIONS
很抱歉,暂时无法提供与“DCC-US3AT-180”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+198.420651+25.68349
