B
NOTES:
B 1.
2.
3.
4.
5.
DCC-HD19T-310 SHOWN IN EXPLODED VIEW. (FIELD INSTALLABLE *HDMI-STYLE CABLE
PLUG WITH THREADED COUPLING.)
THE FIELD INSTALLABLE *HDMI-STYLE CABLE PLUG IS TYPE "A".
PARTS COME UNASSEMBLED AND INDIVIDUALLY BAGGED.
SEE SHEET 2 FOR ASSEMBLY INSTRUCTIONS.
UNLESS OTHERWISE SPECIFIED, DIMENSIONS WITH TWO DECIMAL PLACES HAVE
TOLERANCES OF 0.02
COUPLING TYPE
DCC-HD19B-310
QUICK CONNECT
DCC-HD19T-310
THREADED
SEALING NUT
MAT'L: UV PBT, BLACK
ELECTRICAL:
CONTACT RESISTANCE: 50 MILLIOHMS MAXIMUM
INSULATION RESISTANCE: 100 MEGAOHMS MINIMUM
WITHSTANDING VOLTAGE: 500V AC
CONTACT CURRENT RATING: 0.5 AMPS
COUPLING RING
OPTIONS: THREADED OR QUICK CONNECT
PRODUCT RATING:
IP67 & IP68, NEMA 250 (6P), WHEN MATED
CUSTOMER DRAWING
PART NUMBER
SEALING RING
MAT'L: RUBBER, BLACK
OTHER:
OPERATING TEMPERATURE: -20 C TO +80 C [-4 F TO +176 F]
RECOMMENDED CABLE TYPE: HDMI HIGH SPEED
RECOMMENDED CABLE O.D. RANGE:
0.197 TO 0.236 [ 5.0mm TO
PLUG HOUSING
6.0mm]
O-RING
MAT'L: SILICONE, RED
*HDMI-STYLE TYPE A CABLE PLUG
FRONT & BACK SHELL MAT'L: NICKEL PLATED
COPPER ALLOY
INSULATOR BODY: THERMOPLASTIC, BLACK
PCB MAT'L: FR-4
CONTACTS: GOLD PLATED COPPER ALLOY
INSERT
MAT'L: NYLON, BLACK
QUICK CONNECT COUPLING RING
PART
NUMBER:
DCC-HD19 SERIES
THREADED COUPLING RING
*HDMI-STYLE PLUG
*HDMI-STYLE PLUG
CABLE
(NOT INCLUDED)
CABLE
(NOT INCLUDED)
1.30
33
1.44
36.7
2.11
53.5
REF
2.11
53.5
REF
INDUSTRIAL *HDMI-STYLE CABLE PLUG
B (DCC-HD19B-310 SHOWN)
*HDMI IS A REGISTERED TRADEMARK OF HDMI LICENSING LLC CORPORATION
B
SS
07-26-21
DRAWING NUMBER WAS DCC-HDMI SERIES PER ECR 9593
MA
01-29-18
DRAWING RELEASED PER PDR 12003
A
JGK
10/13/15
UPDATED MODEL.
JGK
5/22/13
DRAWING CREATED PER PROJECT #12003.
REV. INIT.
THREADED COUPLING
B (DCC-HD19T-310 SHOWN)
DIMENSIONS IN BRACKETS [ ] ARE METRIC.
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
RoHS COMPLIANT
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
DESCRIPTION
ORIG. DRAWN BY:
DATE:
5/22/13
JGK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
NTS
B
FILE:
DCC-HD19 SERIES
INDUSTRIAL *HDMI-STYLE PLUG
CUSTOMER:
FIELD INSTALLABLE
DATA-CON-X
STANDARD PRODUCT
PART
NUMBER:
DCC-HD19 SERIES
SHEET
1 OF 3
DIRECTORY:
SLW
REV
B
O-RING
1
ASSEMBLY INSTRUCTIONS:
PLUG HOUSING
PLUG HOUSING RIDGE
BEFORE
AFTER
O-RING
1.
SLIDE THE O-RING ONTO THE FRONT END OF THE PLUG HOUSING UNTIL IT SEATS UP AGAINST THE RIDGE OF THE
PLUG HOUSING.
2.
SLIDE THE COUPLING RING OVER THE PLUG HOUSING.
NOTE: MAKE SURE THE FRONT OF THE COUPLING RING CAN SLIDE PAST THE RIDGE ON THE PLUG
HOUSING. IF NOT, IT IS INSERTED THE WRONG WAY.
3.
SLIDE THE SEALING NUT, SEALING RING, AND PLUG HOUSING/COUPLING RING OVER THE FRONT END OF THE
CABLE IN THE FOLLOWING ORDER:
1ST. SEALING NUT.
2ND. SEALING RING.
3RD. PLUG HOUSING/COUPLING RING.
4.
TERMINATE THE *HDMI-STYLE PLUG TO THE CABLE.
NOTE: SEE FIGURE 1 FOR *HDMI-STYLE PLUG ASSEMBLY INSTRUCTIONS.
SEE FIGURE 3 FOR RECOMMENDED STRIPPING DETAIL.
5.
SLIDE THE *HDMI-STYLE PLUG INTO THE BACK END OF THE INSERT UNTIL IT SNAPS INTO PLACE.
NOTE: SEE FIGURE 2 FOR INSERT AND PLUG ALIGNMENT GUIDE.
6.
SLIDE THE INSERT/*HDMI-STYLE PLUG INTO THE FRONT END OF THE PLUG HOUSING UNTIL IT SNAPS INTO PLACE.
7.
PUSH THE SEALING RING INTO THE REAR OF THE PLUG HOUSING.
NOTE: NO PART OF THE SEALING RING SHOULD EXTEND PAST THE REAR OF THE PLUG HOUSING.
8.
SCREW THE SEALING NUT ONTO THE PLUG HOUSING. THE RECOMMENDED TIGHTENING TORQUE IS 10-12 IN-LBS
FORCE.
NOTE: MAKE SURE THAT THE SEALING RING SQUEEZES TIGHTLY AROUND THE CABLE O.D.
COUPLING RING
2
BEFORE
CUSTOMER DRAWING
SEALING RING
SEALING NUT
AFTER
CABLE (CUSTOMER SUPPLIED)
3
FRONT END OF CABLE
*HDMI-STYLE PLUG
4
INSERT
5
AFTER
6
BEFORE
AFTER
7
PART
NUMBER:
DCC-HD19 SERIES
BEFORE
BEFORE
AFTER
B
SS
07-26-21
MA
01-29-18
A
JGK
10/13/15
UPDATED MODEL.
JGK
5/22/13
REV. INIT.
DATE
8
BEFORE
AFTER
RoHS COMPLIANT
AND DECIMALS.
TOLERANCES:
ANGLES ±1°
FRACTIONS ±1/16
FLAG PER SPEC. XXXX
DESCRIPTION
ORIG. DRAWN BY:
DATE:
5/22/13
JGK
CHECKED BY:
TITLE:
APPROVED BY:
SCALE
SIZE
NTS
B
FILE:
DCC-HD19 SERIES
CUSTOMER:
FIELD INSTALLABLE
DATA-CON-X
STANDARD PRODUCT
PART
NUMBER:
DCC-HD19 SERIES
SHEET
2 OF 3
DIRECTORY:
SLW
REV
B
INSERT SNAPPING FEATURE
(EXTERNAL)
FIGURE 2
FIGURE 1
PLUG BODY TOP
A
2
1
CUSTOMER DRAWING
3
4
INSERT AND PLUG
ALIGNMENT GUIDE
DETAIL A
1. SOLDER THE CABLE WIRES TO THE PCB BODY. SEE FIGURE 3 FOR
RECOMMENDED CABLE STRIPPING DETAILS.
2. PLACE THE PCB BODY INTO THE FRONT SHELL AND PUSH
FORWARD UNTIL IT SITS FIRMLY INTO THE FRONT SHELL.
3. SNAP THE BACK SHELL ONTO THE FRONT SHELL.
4. CRIMP THE BACK SHELL CLAMP AROUND THE CABLE JACKET.
FIGURE 3
.375
OUTER CABLE JACKET
PLUG BODY TOP
1
19
INNER CABLE JACKET
CONDUCTOR
RECOMMENDED *HDMI-STYLE CABLE STRIPPING DETAIL
2
18
PART
NUMBER:
DCC-HD19 SERIES
.125
B
A
SS
07-26-21
MA
01-29-18
JGK
JGK
10/13/15
UPDATED MODEL.
5/22/13
REV. INIT.
DATE
AND DECIMALS.
RoHS COMPLIANT
TOLERANCES:
ANGLES ±1°
FRACTIONS ±1/16
FLAG PER SPEC. XXXX
DESCRIPTION
ORIG. DRAWN BY:
DATE:
5/22/13
JGK
CHECKED BY:
TITLE:
APPROVED BY:
SCALE
SIZE
NTS
B
FILE:
DCC-HD19 SERIES
CUSTOMER:
FIELD INSTALLABLE
DATA-CON-X
STANDARD PRODUCT
PART
NUMBER:
DCC-HD19 SERIES
SHEET
3 OF 3
DIRECTORY:
SLW
REV
B
很抱歉,暂时无法提供与“DCC-HD19B-310”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+307.867331+39.69004
- 10+261.6498810+33.73172
- 25+245.2701325+31.62005
- 50+233.5669950+30.11129
- 100+222.42844100+28.67532
- 250+208.51902250+26.88213
