W6282-5SG-P-3DC
W6282-5SG-P-3DC
    SWITCHCRAFT
    5 针位圆形连接器 插头,母插口 焊杯
W6282-5SG-P-3DC 数据手册
NOTES: 1. ALL PARTS TO BE BULK PACKED 2. ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE WITH A TOLERANCE 3. DIMENSIONS IN BRACKETS [ ] ARE IN MILLIMETERS ASS'Y P/N GROMMET SIZE W6282-XPG-P-311 CABLE O.D. .09-.14 [2.3 - 3.6] W6282-XPG-P-315 ASSEMBLY P/N CONTACTS CABLE O.D. .15-.17 [3.8 - 4.3] W6282-2PG-P-3XX 2 #20 W6282-XPG-P-318 CABLE O.D. .18-.20 [4.6 - 5.1] W6282-3PG-P-3XX 3 #20 W6282-XPG-P-321 CABLE O.D. .21-.23 [5.3 - 5.8] W6282-4PG-P-3XX 4 #20 W6282-5PG-P-3XX 5 #20 W6282-6PG-P-3XX 6 #20 W6282-XPG-P-3XX .250 6.4 DAISY CHAIN GROMMETS FOR W6282-XPG-P-3DC .125 I.D. FOR CABLES .09-.14 [2.3 - 3.6] O.D. .188 I.D. FOR CABLES .18-.20 [4.6 - 5.1] O.D. .250 I.D. FOR CABLES .24-.26 [6.1 - 6.6] O.D. GROMMET SIZE FOR SINGLE GROMMET OR "DC" FOR DAISY CHAIN 1.325 33.7 NUMBER OF CONTACTS CUSTOMER PRINT .125 3.2 .188 4.8 .375 9.5 TYP .900 22.9 SHOWN ASSEMBLED FOR CUSTOMER REFERENCE ONLY .078 2 KEY .931 23.6 .430 10.9 .688 17.5 KEY WIRING END MATING FACE W6282-2PG-P-3XX SHOWN WITHOUT HARDWARE W6282-2PG-P-3XX SHOWN W6282-XPG-P-3XX PART NUMBER: GROMMET MAT'L: SANTOPRENE, BLACK CABLE-END HOUSING MAT'L: UV PBT, BLACK COUPLING RING MAT'L: UV PBT, BLACK O-RING MAT'L: SILICONE, RED SPRING MAT'L: STAINLESS STEEL KEY 1 KEY 2 1 3 WIRING END W6282-2PG-P-3XX (2-6) #20 PIN CONTACT, SOLDER MAT'L:COPPER ALLOY, GOLD PLATED KEY 2 WIRING END W6282-3PG-P-3XX 1 2 BACKSHELL MAT'L: UV PBT, BLACK KEY 4 3 KEY 1 5 4 2 3 WIRING END W6282-4PG-P-3XX WIRING END W6282-5PG-P-3XX 1 6 CUSTOMER APPROVAL 5 2 4 3 WIRING END W6282-6PG-P-3XX THIS DOCUMENT CONTAINS CONFIDENTIAL INFORMATION PROPRIETARY TO CONXALL CORPORATION. ANY REPRODUCTION, DISCLOSURE, OR USE OF THIS DOCUMENT /INFORMATION IS EXPRESSLY PROHIBITED UNLESS AUTHORIZED IN WRITING BY CONXALL CORPORATION. APPROVED BY: DATE: RoHS COMPLIANT A MA 03-02-20 RELEASED PER PDR 16014-7 PNK 11-25/19 BACKSHELL P/N 6284 CHANGES TO 6284V4 PNK 05-10-19 PDR 16014 DATE DESCRIPTION REV. INIT. ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. UNLESS OTHERWISE SPECIFIED TOLERANCES: 3 PLACE DECIMALS ±.010 ANGLES ±1° FRACTIONS ±1/16 = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX ORIG. DRAWN BY: DATE: 05-10-19 PNK CHECKED BY: 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: SCALE SIZE SHEET NTS B 1 OF 1 FILE: W6282-XPG-P-3XX DIRECTORY: SLW CABLE-END ASSEMBLY 2-6 #20 PIN CONTACTS, SOLDER INSTA-CLICK™ MINI-CON-X CUSTOMER: STANDARD PRODUCT PART NUMBER: W6282-XPG-P-3XX REV A
W6282-5SG-P-3DC 价格&库存
很抱歉,暂时无法提供与“W6282-5SG-P-3DC”相匹配的价格&库存,您可以联系我们找货
