12KPE33CAH
12KPE33CAH
    EATON(伊顿)
    轴向
    54.7V 夹子 219.4A Ipp TVS - 二极管 通孔 P600
12KPE33CAH 数据手册
Technical Data ELX1058 Effective June 2021 12KPE Automotive grade 12000 W Transient voltage suppressor Applications Product features • Automotive grade (AEC-Q101 qualified) • Excellent clamping capability • • • Automotive chassis and safety systems • Advanced driver assistance systems (ADAS) • Communication and infotainment systems • Network systems and body electronics • Power Train controls • xEV and battery systems Environmental compliance and general specifications • ISO16750-2 P5A: 12 V system (87 V/0.5 Ω/400 ms) High reliability application • 12000 W peak pulse power capability at 10/1000 μs waveform ISO16750-2 P5A: 24 V system (174 V/2 Ω/350 ms) • AEC-Q101 qualified • Typical IR less than 5 μA above 22 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • Plastic package meets UL 94 V-0 flammability rating • Terminal: tin plated, solderable per J-STD-002 • UL 497B recognized. File No. : E198449 Guide QVGQ2 Ordering part number 12KPE 20 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance High reliability application PIN configuration H 12KPE Automotive grade 12000 W Transient voltage suppressor  Technical Data ELX1058 Effective June 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Storage operating junction temperature range Parameter TSTG/ TJ -55 to +175 °C Steady state power dissipation at TL= +75 °C PM(AV) 8 W Peak pulse power dissipation on 10/1000 μs waveform PPP 12000 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 600 A Typical thermal resistance junction to lead R JL 8.0 °C/W Typical thermal resistance junction to ambient R JA 40 °C/W 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm/inches Millimeters Part marking Packaging information 300 parts per box 2 www.eaton.com/electronics Inches Dimension Minimum Maximum Minimum Maximum A 25.40 - 1.000 - B 8.60 9.40 0.339 0.370 C 1.20 1.40 0.047 0.055 D 8.60 9.10 0.339 0.358 Technical Data ELX1058 12KPE  Automotive grade 12000 W Transient voltage suppressor Effective June 2021  Electrical specifications (+25 °C) Part number VR IR @ VR VBR @ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (µA) min (V) max (V) (mA) max (V) (A) UL497B Recognized 12KPE20AH 12KPE20CAH 12KPE20AH 12KPE20CAH 20 15 22.2 24.5 5 34.3 349.9 x 12KPE22AH 12KPE22CAH 12KPE22AH 12KPE22CAH 22 10 24.4 26.9 5 37.1 323.5 x 12KPE24AH 12KPE24CAH 12KPE24AH 12KPE24CAH 24 5 26.7 29.5 5 40.7 294.9 x 12KPE26AH 12KPE26CAH 12KPE26AH 12KPE26CAH 26 5 28.9 31.9 5 44 272.8 x 12KPE28AH 12KPE28CAH 12KPE28AH 12KPE28CAH 28 5 31.1 34.4 5 47.5 252.7 x 12KPE30AH 12KPE30CAH 12KPE30AH 12KPE30CAH 30 5 33.3 36.8 5 50.7 236.7 x 12KPE33AH 12KPE33CAH 12KPE33AH 12KPE33CAH 33 5 36.7 40.6 5 54.7 219.4 x 12KPE36AH 12KPE36CAH 12KPE36AH 12KPE36CAH 36 5 40 44.2 5 59.8 200.7 x 12KPE40AH 12KPE40CAH 12KPE40AH 12KPE40CAH 40 5 44.4 49.1 5 65.8 182.4 x 12KPE43AH 12KPE43CAH 12KPE43AH 12KPE43CAH 43 5 47.8 52.8 5 69.8 171.9 x 12KPE48AH 12KPE48CAH 12KPE48AH 12KPE48CAH 48 5 53.6 58.7 5 77.7 154.5 12KPE58AH 12KPE58CAH 12KPE58AH 12KPE58CAH 58 5 64.4 71.2 5 93.6 128.2 12KPE64AH 12KPE64CAH 12KPE64AH 12KPE64CAH 64 5 71.1 78.6 5 103 116.5 12KPE72AH 12KPE72CAH 12KPE72AH 12KPE72CAH 72 5 80 88.5 5 116 103.4 www.eaton.com/electronics 3 12KPE Automotive grade 12000 W Transient voltage suppressor  Technical Data ELX1058 Effective June 2021 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional Pulse waveform IPPM (% IRSM) PPP derating in percentage (%) Pulse derating curve t (ms) 4 www.eaton.com/electronics TJ (°C) 12KPE  Automotive grade 12000 W Transient voltage suppressor Technical Data ELX1058 Effective June 2021  Wave solder profile tp Temperature Tp First Wave Second Wave Tsmax Tstyp Tsmin Preheat area Cool down area Time Reference EN 61760-1:2006 Profile feature Preheat Standard SnPb solder Lead (Pb) free solder • Temperature min. (Tsmin) 100 °C 100 °C • Temperature typ. (Tstyp) 120 °C 120 °C • Temperature max. (Tsmax) 130 °C 130 °C • Time (Tsmin to Tsmax) (ts) 70 seconds 70 seconds D preheat to max Temperature 150 °C max. 150 °C max. Peak temperature (TP)* 235 °C – 260 °C 250 °C – 260 °C Time at peak temperature (tp) 10 seconds max 5 seconds max each wave 10 seconds max 5 seconds max each wave Ramp-down rate ~ 2 K/s min ~3.5 K/s typ ~5 K/s max ~ 2 K/s min ~3.5 K/s typ ~5 K/s max Time 25 °C to 25 °C 4 minutes 4 minutes Manual solder +350 °C (4-5 seconds by soldering iron), generally manual/hand soldering is not recommended Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2021 Eaton All Rights Reserved Printed in USA Publication No. ELX1058 BU-ELX21058 June 2021 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
12KPE33CAH 价格&库存
很抱歉,暂时无法提供与“12KPE33CAH”相匹配的价格&库存,您可以联系我们找货
