12THLEJ100
12THLEJ100
    EATON(伊顿)
    Cartridge,Non-Standard
    FUSE 12KV 100A 2.5"DIN
12THLEJ100 数据手册
MEDIUM VOLTAGE DIN Fuse-Links MV DIN 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps Standards/Approvals: DIN 43625, VDE 0670 part 4, VDE 0670 part 402 and IEC 60282-1 (2005) Description: Catalogue Symbol: 12TDLEJ(amp) 12THLEJ(amp) 12TKLEJ(amp) 12TXLEJ(amp) 12TFMSJ(amp) Class of Operation: Dimensional Data: Fuse Reference Back-up as IEC 60282-1 (2005) A C D Weight (Kg) 64 2.6 TDLEJ 292 54 51 TKLEJ 292 80 76 THLEJ 292 TXLEJ 67 292 TFMSJ 88 442 1.7 3.5 88 80 3.7 76 5.1 EJ Outline E = Spring Striker 80N to IEC 60282-1 designation “medium” Force x Travel diagram for 80N Din striker 100 All fuse-links are packed individually. MOQ: 3 Packaging 100% recyclable Technical Data: DIN fuse-links 12kV Rated voltage: Amps: 6.3A to 200A Rated breaking capacity: 50kA Rated frequency: 50 - 60Hz Suitable for outdoor and indoor use RoHS compliant S = Spring Striker 50N to DIN 43625 and IEC 60282-1 designation “medium” Force x Travel diagram for 50N Din striker 60 90 50 80 70 40 60 Force (N) Force (N) Packaging: SJ Outline Striker Diagrams: 50 30 40 20 30 20 10 10 0 A range of medium voltage DIN Fuses, complete with sealed striker, suitable for transformer protection. The fuses can be used even where there is no secondary LV protection, provided they are used with fuse switches fitted with instantaneous striker tripping. 0 4 8 12 16 20 Travel (mm) 24 28 32 36 0 0 REV B - 10/4/2007 4 8 12 16 Travel (mm) 20 24 28 32 Form No. 12kV DIN Page 1 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links MV DIN 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps Table of Ratings: Standard Approvals: Technical Data: Part Number In (A) 6.3 12TDLEJ16 16 12TDLEJ20 12TDLEJ25 12TDLEJ31.5 12TDLEJ40 12TDLEJ50 12TDLEJ63 12THLEJ80 12TFMSJ160 63 63 80 87 31.2 235 36 47 10.6 60 7.81 72 5.74 85 3.99 610 93 4.30 217 5.74 85 3.80 272 50 28 13.5 560 63 24 17.2 687 485 Minimum PreArcing 18 23.4 388 Joule Integral (I2t) 16 39.1 272 63 * Not compliant with VDE 0670 part 402 16 63 63 160 54.6 131 168 63 100 53 143 63 200 10 63 63 125 222 111 63 W 23 73 63 50 160 12THMEJ100 63 40 mΩ 35 63 31.5 12TXLEJ160* 12TXLEJ200* 63 25 Cold Resistance & Watts Loss in Free Air I3 (A) 63 20 100 12TKLEJ125 I1 (kA) 10 12THLEJ100 Minimum Breaking Capacity Breaking Capacity Current Rating 12TDLEJ6.3 12TDLEJ10 DIN 43625, VDE 0670 part 4, VDE 0670 part 402 and IEC 60282-1 (2005) 6.3, 10, 16, 20. 25, 31.5, 40, 50, 63, 80, 100, 125, 160 and 200 Amps 333 3.65 139 Length Diameter Weight 292 51 1.7 292 51 1.7 mm Maximum Operating 9.8 X 101 2.8 X 102 1.0 X 103 2.3 X 103 2.6 X 102 5.2 X 102 292 3.9 X 103 5.4 X 103 8.1 X 102 1.4 X103 7.9 X 103 2.0 X 104 4.0 X 104 1.1 X 105 1.5 X 105 2.0 X 104 5.0 X 104 1.7 51 292 1.7 51 292 1.7 51 292 1.7 64 292 2.6 64 292 2.6 76 292 3.5 88 292 1.4 X 105 3.5 X 105 1.7 51 292 5.0 X 105 6.5 X 105 1.7 51 292 9.1 X 104 1.4 X 105 3.5 X 105 1.7 51 292 2.5 X 104 3.1 X 104 4.7 X 104 kg 51 292 8.4 X 103 1.5 X 104 2.4 X 103 2.8 X 103 4.3 X 103 mm 3.7 88 442 3.7 64 442 3.7 76 5.1 Cross-Reference MESA 12TDLEJ6.3 12TDLEJ10 12TDLEJ16 12TDLEJ20 12TDLEJ25 12TDLEJ31.5 12TDLEJ40 12TDLEJ50 12TDLEJ63 67120.0060 67120.0100 67120.0160 67120.0200 67120.0250 67120.0320 67120.0400 67120.0500 67120.0630 3000413 3000413 3000413 3000413 3000413 3000413 3000413 3000413 3001213 CF-12/6,3 CF-12/10 CF-12/16 CF-12/20 CF-12/25 CF-12/31,5 CF-12/40 CF-12/50 CF-12/63 12TXLEJ160 12TXLEJ200 67220.1600 67220.2000 3002013 3002014 N/A N/A 12THLEJ80 12THLEJ100 12TKLEJ125 67120.0800 67120.1000 67120.1250 3001213 3001213 3001213 (80N Striker) (50N Striker) 4236014 4236015 4236016 42350014 42350015 42350016 4236005 4236006 4236007 4236008 4236009 4236010 4236011 4236012 4236013 CF-12/80 CF-12/100 N/A Watts Loss Comparison 4235005 4235006 4235007 4235008 4235009 4235010 4235011 4235012 4235013 4236017 N/A 4235017 N/A 51006 511 M0 51006 512 M0 51006 513 M0 51006 514 M0 51006 515 M0 51006 516 M0 51006 517 M0 51006 518 M0 51006 519 M0 ES 6509 006 ES 6509 010 ES 6509 016 ES 6509 020 ES 6509 025 ES 6509 030 ES 6509 040 ES 6509 050 ES 6509 063 IB-D1 IB-D1 IB-D1 IB-D1 IB-D1 & IB-D2 IB-D1 & IB-D2 IB-D1 & IB-D2 IB-D2 IB-D2 1YMB531042M0001 1YMB531042M0002 1YMB531042M0003 1YMB531042M0004 1YMB531002M0004 1YMB531002M0014 1YMB531002M0005 1YMB531002M0006 1YMB531002M0007 N/A N/A N/A N/A N/A N/A N/A N/A 51006 520 M0 51006 521 M0 N/A ES 6509 080 ES 6509 100 N/A IB-D3 IB-D3 N/A 1YMB531002M0021 1YMB531002M0022 1YMB531043M0010 Lowest Watts Loss Part Number Watts Loss Watts Loss Watts Loss MESA Watts loss Watts Loss Watts Loss Watts Loss Watts Loss 12THLEJ80 12THLEJ100 12TKLEJ125 72 85 93 82 96 117 76 104 159 102 120 - 77 104 152 102 120 - 108 112 - 95 120 - 12TDLEJ6.3 12TDLEJ10 12TDLEJ16 12TDLEJ20 12TDLEJ25 12TDLEJ31.5 12TDLEJ40 12TDLEJ50 12TDLEJ63 12TXLEJ160 12TXLEJ200 10 16 16 18 24 28 36 47 60 217 333 * derating factor apply 19 29 21 25 31 39 46 62 60 217 333 14 23 28 23 29 38 50 56 63 173 292* 16 18 37 42 52 59 74 70 82 - 15 10 19 23 33 46 56 44 65 200 - 16 18 37 42 52 59 74 70 82 - 19 18 35 36 38 41 56 74 89 - 12 19 27 28 29 36 50 52 64 - Watts Loss 46 25 34 38 47 41 52 70 78 82 101 125 - Form No. 12kV DIN Page 2 of 13 Data sheet 720104 DRN APPD DATE VIRTUAL PRE-ARCING TIME IN SECONDS 0.01 0.1 1 10 100 1000 10000 10 APPD DATE DRN FUSE TYPES: TXL DRN DATE 10/4/07 MPJ RE-DRAWN ON EXCEL. ECN11268 APPD TEL. 01509 882600 FAX 01509 882786 PF 1197 100000 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps BURTON-ON-THE-WOLDS LEIC, LE12 5TH, UK. 100 1000 10000 R.M.S. SYMMETRICAL PROSPECTIVE CURENT IN AMPERES B 200A 160A CURVES RELATE TO MEAN PRE_ARCING TIMES WITH A TOLERANCE OF ±10% ON CURRENT TIME- CURRENT CHARACTERISTIC FOR 12kV FUSE-LINKS MEDIUM VOLTAGE DIN Fuse-Links MV DIN Time Current Characteristics Form No. 12kV DIN Page 3 of 13 Data sheet 720104 DATE DRN MBC added ECN11268 26/3/07 MPJ 0.01 0.1 1 10 100 1000 10000 C 10 DATE DRN 26/3/07 MPJ Update ECN11237 APPD B HH 21/3/07 1st ISSUE ECN11220 APPD A BURTON-ON-THE-WOLDS LEIC, LE12 5TH, UK. 1000 10000 TEL. 01509 882600 FAX 01509 882786 R.M.S. SYMMETRICAL PROSPECTIVE CURENT IN AMPERES DATE DRN 100 6.3A 10A 16A 20A 25A 31.5A 40A 50A 63A 80A 100A 125A CURVES RELATE TO MEAN PRE_ARCING TIMES WITH A TOLERANCE OF ±10% ON CURRENT PF 1275 100000 FUSE TYPES: TDL/THL/TKL 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps APPD VIRTUAL PRE-ARCING TIME IN SECONDS TIME- CURRENT CHARACTERISTIC FOR 12kV FUSE-LINKS MEDIUM VOLTAGE DIN Fuse-Links MV DIN Time Current Characteristics Form No. 12kV DIN Page 4 of 13 Data sheet 720104 APPD DATE DRN VIRTUAL PRE-ARCING TIME IN SECONDS 0.01 0.1 1 10 100 1000 10000 10 16/4/07 MPJ M LENGTH ONLY ECN11268 APPD DATE DRN B HH 21/3/07 1st ISSUE ECN11220 APPD A BURTON-ON-THE-WOLDS LEIC, LE12 5TH, UK. 1000 TEL. 01509 882600 FAX 01509 882768 R.M.S. SYMMETRICAL PROSPECTIVE CURENT IN AMPERES DATE DRN 100 100A (THM) 125A (TKM) 160A (TFM) 10000 100000 FUSE TYPES: THM / TKM / TFM CURVES RELATE TO MEAN PRE_ARCING TIMES WITH A TOLERANCE OF ±10% ON CURRENT TIME- CURRENT CHARACTERISTIC FOR 12kV FUSE-LINKS PF 1280 MEDIUM VOLTAGE DIN Fuse-Links 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps MV DIN Time Current Characteristics Form No. 12kV DIN Page 5 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links MV DIN 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps Cut-Off Curves REF. No. PF 2275 CUT-OFF CURRENT CHARACTERISTIC FOR 12kV FUSE-LINKS FUSE TYPE TDL/THL/TKL NOTES 1. CURVES SHOW EXTREME MAXIMUM VALUES WHICH WILL NOT BE EXCEEDED UNDER CONDITIONS STATED IN 2 AND 3 BELOW. 2. FOR HIGH VALUES OF PROSPECTIVE CURRENT A SYMMETRICAL FAULT GIVES THE HIGHEST CUT-OFFCURRENT. FOR LOW VALUES OF PROSPECTIVE CURRENT, WHERE THERE IS LITTLE OR NO CURRENT LIMITATION, AN ASYMMETRICAL FAULT PASSES THE HIGHEST PEAKCURRENT. THE CURVES ARE THEREFORE BASED ON THE DEGREE OF ASYMMETRY WHICH GIVES THE MAXIMUM CUT-OFF CURRENT AT ANY PARTICULAR VALUE OF PROSPECTIVE CURRENT. 3. CURVES RELATE TO FREQUENCY OF 50 Hz AND A RECOVERY VOLTAGE EQUAL TO THE FUSE RATED VOLTAGE. 100000 PEAK CUT-OFF CURRENT IN AMPERE S 40A 63A 80A 100A 20A 25A 125A 10000 1000 10A 6.3A 100 100 DRN DATE APPD 50A C 1000 16A 31.5A 10000 100000 R.M.S. SYMMETRICAL PROSPECTIVE CURRENT IN AMPERES DRN DATE APPD B DRN MPJ DATE 21/3/07 APPD 1st ISSUE MPJ ECN11220 A PF2275 BURTON-ON-THE-WOLDS, LEICS., LE12 5TH, U.K. TEL +44 (0) 1509 882600 FAX +44 (0) 1509 882786 Form No. 12kV DIN Page 6 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links MV DIN 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps Cut-Off Curves REF. No. PF 2280 CUT-OFF CURRENT CHARACTERISTIC FOR 12kV FUSE-LINKS FUSE TYPE THM TKM TFM NOTES 1. CURVES SHOW EXTREME MAXIMUM VALUES WHICH WILL NOT BE EXCEEDED UNDER CONDITIONS STATED IN 2 AND 3 BELOW. 2. FOR HIGH VALUES OF PROSPECTIVE CURRENT A SYMMETRICAL FAULT GIVES THE HIGHEST CUT-OFFCURRENT. FOR LOW VALUES OF PROSPECTIVE CURRENT, WHERE THERE IS LITTLE OR NO CURRENT LIMITATION, AN ASYMMETRICAL FAULT PASSES THE HIGHEST PEAKCURRENT. THE CURVES ARE THEREFORE BASED ON THE DEGREE OF ASYMMETRY WHICH GIVES THE MAXIMUM CUT-OFF CURRENT AT ANY PARTICULAR VALUE OF PROSPECTIVE CURRENT. 3. CURVES RELATE TO FREQUENCY OF 50 Hz AND A RECOVERY VOLTAGE EQUAL TO THE FUSE RATED VOLTAGE. 100000 PEAK CUT-OFF CURRENT IN AMPERE S 100A (THM) 160A (TFM) 10000 1000 100 100 DRN DATE APPD 125A (TKM) C 1000 10000 100000 R.M.S. SYMMETRICAL PROSPECTIVE CURRENT IN AMPERES DRN MPJ DATE 16/4/07 APPD B M LENGTH ONLY MPJ ECN11268 DRN MPJ DATE 21/3/07 APPD 1st ISSUE MPJ ECN11220 A PF2280 BURTON-ON-THE-WOLDS, LEICS., LE12 5TH, U.K. TEL +44 (0) 1509 882600 FAX +44 (0) 1509 882786 Form No. 12kV DIN Page 7 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links MV DIN 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps Cut-Off Curves REF. No. PF 2197 CUT-OFF CURRENT CHARACTERISTIC FOR 12kV FUSE-LINKS FUSE TYPE TXL NOTES 1. CURVES SHOW EXTREME MAXIMUM VALUES WHICH WILL NOT BE EXCEEDED UNDER CONDITIONS STATED IN 2 AND 3 BELOW. 2. FOR HIGH VALUES OF PROSPECTIVE CURRENT A SYMMETRICAL FAULT GIVES THE HIGHEST CUT-OFFCURRENT. FOR LOW VALUES OF PROSPECTIVE CURRENT, WHERE THERE IS LITTLE OR NO CURRENT LIMITATION, AN ASYMMETRICAL FAULT PASSES THE HIGHEST PEAKCURRENT. THE CURVES ARE THEREFORE BASED ON THE DEGREE OF ASYMMETRY WHICH GIVES THE MAXIMUM CUT-OFF CURRENT AT ANY PARTICULAR VALUE OF PROSPECTIVE CURRENT. 3. CURVES RELATE TO FREQUENCY OF 50 Hz AND A RECOVERY VOLTAGE EQUAL TO THE FUSE RATED VOLTAGE. 100000 PEAK CUT-OFF CURRENT IN AMPERE S 160A 10000 1000 100 100 DRN DATE APPD 200A C 1000 10000 100000 R.M.S. SYMMETRICAL PROSPECTIVE CURRENT IN AMPERES DRN DATE APPD B DRN MPJ DATE 20/4/07 APPD 1st ISSUE MPJ ECN11268 A PF2197 BURTON-ON-THE-WOLDS, LEICS., LE12 5TH, U.K. TEL +44 (0) 1509 882600 FAX +44 (0) 1509 882786 Form No. 12kV DIN Page 8 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps MV DIN ASTA Certificate Form No. 12kV DIN Page 9 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps MV DIN KEMA Certificate Form No. 12kV DIN Page 10 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps MV DIN KEMA Certificate Form No. 12kV DIN Page 11 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps MV DIN KEMA Report This report of performance details 12kV DIN rated fuse-links tested in accordance with IEC60282-1:2005 to demonstrate correct operation on a 7.2kV system Form No. 12kV DIN Page 12 of 13 Data sheet 720104 MEDIUM VOLTAGE DIN Fuse-Links 12kV, Current Limiting Back-Up Fuse-Links, 6.3 to 200 Amps MV DIN KEMA Report This report of performance details tests to IEC60282-1:2005 clause 7.6.3 to demonstrate the fuse-links ability to withstand arcing for greater than 0.1 seconds Form No. 12kV DIN Page 13 of 13 Data sheet 720104
12THLEJ100 价格&库存
很抱歉,暂时无法提供与“12THLEJ100”相匹配的价格&库存,您可以联系我们找货
