Technical Data ELX1059
Effective June 2021
15BJ
Automotive grade 1500 W Transient voltage suppressor
Applications
Product features
Automotive chassis and safety systems
Advanced driver assistance systems (ADAS)
Communication and infotainment systems
Network systems and body electronics
Power Train controls
xEV and battery systems
Environmental compliance and general
specifications
Automotive grade (AEC-Q101 qualified)
Low profile SMBF package
Excellent clamping capability
High reliability application
1500 W peak pulse power capability at 10/1000
μs waveform
Typical IR less than 1 μA above 11 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0
flammability rating
Meets moisture sensitivity level (MSL) level 1
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
Terminal: tin plated, solderable per J-STD-002
For surface mounted applications in order to
optimize board space
UL 497B recognized.
File No. : E198449 Guide QVGQ2
PIN configuration
AEC-Q101 qualified
Ordering part number
15BJ 5-0 C A
Family name
VR voltage
(“-” indicates decimal point)
H
15BJ
Effective June 2021
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Symbol
Value
Unit
Storage operating junction temperature range
Parameter
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
5.0
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
1500
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5.0
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
200
A
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm/inches
Millimeters
Part marking
Inches
Dimension Minimum
Maximum
Minimum
Maximum
A
3.90
4.50
0.154
0.177
B
4.65
5.15
0.183
0.203
C
1.85
2.15
0.073
0.085
D
0.60
E
5.60
6.00
0.220
0.236
F
2.05
2.35
0.081
0.093
G
0.12
0.28
0.005
0.011
J
2.00
K
L
0.024
Cathode band (uni-polar only)
Part marking:
xxxx = Date code
yyy- Refer to marking designator listed in
Electrical characteristics table
0.079
3.20
2.30
YYYY
0.126
0.091
Packaging information- mm/inches
Drawing not to scale.
Dimensions
Millimeters
Inches
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel
(EIA-481 compliant)
A0
4.50 ± 0.3
0.177 ± 0.012
B0
6.10 ± 0.3
0.240 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
5.50 ± 0.2
0.217 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.315 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.472 ± 0.008
W1
15.7 ± 2.0
0.618 ± 0.079
2
www.eaton.com/electronics
15BJ
Effective June 2021
Electrical characteristics (+25 °C)
Part number
VR
IR @ VR
VBR @ IT
IT
VC @ IPP
IPP
Uni-polar
Bi-polar
Marking
Uni
Bi
(V)
(µA)
min (V)
max (V)
(mA)
max (V)
(A)
15BJ5-0AH
15BJ5-0CAH
GDE
BDE
5
300
6.4
7
10
9.2
163
15BJ6-0AH
15BJ6-0CAH
GDG
BDG
6
250
6.67
7.37
10
10.3
145.6
15BJ6-5AH
15BJ6-5CAH
GDK
BDK
6.5
150
7.22
7.98
10
11.2
134
15BJ7-0AH
15BJ7-0CAH
GDM
BDM
7
100
7.78
8.6
10
12
125
15BJ7-5AH
15BJ7-5CAH
GDP
BDP
7.5
50
8.33
9.21
1
12.9
116.3
15BJ8-0AH
15BJ8-0CAH
GDR
BDR
8
30
8.89
9.83
1
13.6
110.3
15BJ8-5AH
15BJ8-5CAH
GDT
BDT
8.5
10.4
1
14.4
104.2
15BJ9-0AH
15BJ9-0CAH
GDV
BDV
9
10
10
11.1
1
15.4
97.4
15BJ10AH
15BJ10CAH
GDX
BDX
10
5
11.1
12.3
1
17
88.2
15BJ11AH
15BJ11CAH
GDZ
BDZ
11
2
12.2
13.5
1
18.2
82.4
15BJ12AH
15BJ12CAH
GEE
BEE
12
1
13.3
14.7
1
19.9
75.4
15BJ13AH
15BJ13CAH
GEG
BEG
13
1
14.4
15.9
1
21.5
69.8
15BJ14AH
15BJ14CAH
GEK
BEK
14
1
15.6
17.2
1
23.2
64.7
15BJ15AH
15BJ15CAH
GEM
BEM
15
1
16.7
18.5
1
24.4
61.5
15BJ16AH
15BJ16CAH
GEP
BEP
16
1
17.8
19.7
1
26
57.7
15BJ17AH
15BJ17CAH
GER
BER
17
1
18.9
20.9
1
27.6
54.4
15BJ18AH
15BJ18CAH
GET
BET
18
1
1
29.2
51.4
15BJ20AH
15BJ20CAH
GEV
BEV
22.2
24.5
1
32.4
46.3
15BJ22AH
15BJ22CAH
GEX
BEX
22
1
24.4
26.9
1
35.5
42.3
15BJ24AH
15BJ24CAH
GEZ
BEZ
24
1
26.7
29.5
1
38.9
38.6
15BJ26AH
15BJ26CAH
GFE
BFE
26
1
28.9
31.9
1
42.1
35.6
15BJ28AH
15BJ28CAH
GFG
BFG
28
1
31.1
34.4
1
45.4
33.1
15BJ30AH
15BJ30CAH
GFK
BFK
30
1
33.3
36.8
1
48.4
31
15BJ33AH
15BJ33CAH
GFM
BFM
33
1
36.7
40.6
1
53.3
28.2
15BJ36AH
15BJ36CAH
GFP
BFP
36
1
40
44.2
1
58.1
25.8
15BJ40AH
15BJ40CAH
GFR
BFR
40
1
44.4
49.1
1
64.5
23.3
15BJ43AH
15BJ43CAH
GFT
BFT
43
1
47.8
52.8
1
69.4
21.6
15BJ45AH
15BJ45CAH
GFV
BFV
45
1
50
55.3
1
72.7
20.6
15BJ48AH
15BJ48CAH
GFX
BFX
48
1
53.3
58.9
1
77.4
19.4
15BJ51AH
15BJ51CAH
GFZ
BFZ
51
1
56.7
62.7
1
82.4
18.2
15BJ54AH
15BJ54CAH
GGE
BGE
54
1
60
66.3
1
87.1
17.2
15BJ58AH
15BJ58CAH
GGG
BGG
58
1
64.4
71.2
1
93.6
16.1
15BJ60AH
15BJ60CAH
GGK
BGK
60
1
66.7
73.7
1
96.8
15.5
15BJ64AH
15BJ64CAH
GGM
BGM
64
1
71.1
78.6
1
103
14.6
15BJ70AH
15BJ70CAH
GGP
BGP
70
1
77.8
86
1
113
13.3
15BJ75AH
15BJ75CAH
GGR
BGR
75
1
83.3
92.1
1
121
12.4
15BJ78AH
15BJ78CAH
GGT
BGT
78
1
86.7
95.8
1
126
11.9
15BJ85AH
15BJ85CAH
GGV
BGV
85
1
94.4
104
1
137
11
15BJ90AH
15BJ90CAH
GGX
BGX
90
1
100
111
1
146
10.3
15BJ100AH
15BJ100CAH
GGZ
BGZ
100
1
111
123
1
162
9.3
15BJ110AH
15BJ110CAH
GHE
BHE
110
1
122
135
1
177
8.5
15BJ120AH
15BJ120CAH
GHG
BHG
120
1
133
147
1
193
7.8
15BJ130AH
15BJ130CAH
GHK
BHK
130
1
144
159
1
209
7.2
15BJ150AH
15BJ150CAH
GHM
BHM
150
1
167
185
1
243
6.2
15BJ160AH
15BJ160CAH
GHP
BHP
160
1
178
197
1
259
5.8
15BJ170AH
15BJ170CAH
GHR
BHR
170
1
189
209
1
275
5.5
15BJ180AH
15BJ180CAH
GHT
BHT
180
1
201
222
1
292
5.2
15BJ190AH
15BJ190CAH
GHU
BHU
190
1
211
234
1
307
4.9
15BJ200AH
15BJ200CAH
GHV
BHV
200
1
224
247
1
324
4.7
3
Effective June 2021
15BJ
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional
Pulse waveform
IPPM (% IRSM)
PPP derating in percentage (%)
Pulse derating curve
t (ms)
4
TJ (°C)
15BJ
Effective June 2021
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“15BJ58AH”相匹配的价格&库存,您可以联系我们找货
