15BJ36CAH
15BJ36CAH
    EATON(伊顿)
    SMB(DO-214AA)
    58.1V 夹子 25.8A Ipp TVS - 二极管 表面贴装型 SMBF
15BJ36CAH 数据手册
Technical Data ELX1059 Effective June 2021 15BJ Automotive grade 1500 W Transient voltage suppressor Applications Product features • Automotive chassis and safety systems • Advanced driver assistance systems (ADAS) • Communication and infotainment systems • Network systems and body electronics • Power Train controls • xEV and battery systems Environmental compliance and general specifications • Automotive grade (AEC-Q101 qualified) • Low profile SMBF package • Excellent clamping capability • High reliability application • 1500 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 11 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance • Terminal: tin plated, solderable per J-STD-002 High reliability application • For surface mounted applications in order to optimize board space • UL 497B recognized. File No. : E198449 Guide QVGQ2 PIN configuration • AEC-Q101 qualified Ordering part number 15BJ 5-0 C A Family name VR voltage (“-” indicates decimal point) H 15BJ Automotive grade 1500 W Transient voltage suppressor  Technical Data ELX1059 Effective June 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Storage operating junction temperature range Parameter TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 5.0 W Peak pulse power dissipation on 10/1000 μs waveform PPP 1500 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 200 A 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm/inches Millimeters Part marking Inches Dimension Minimum Maximum Minimum Maximum A 3.90 4.50 0.154 0.177 B 4.65 5.15 0.183 0.203 C 1.85 2.15 0.073 0.085 D 0.60 E 5.60 6.00 0.220 0.236 F 2.05 2.35 0.081 0.093 G 0.12 0.28 0.005 0.011 J 2.00 K L 0.024 Cathode band (uni-polar only) Part marking: xxxx = Date code yyy- Refer to marking designator listed in Electrical characteristics table 0.079 3.20 2.30 YYYY 0.126 0.091 Packaging information- mm/inches Drawing not to scale. Dimensions Millimeters Inches Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) A0 4.50 ± 0.3 0.177 ± 0.012 B0 6.10 ± 0.3 0.240 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 5.50 ± 0.2 0.217 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.315 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 2 www.eaton.com/electronics Technical Data ELX1059 15BJ Automotive grade 1500 W Transient voltage suppressor Effective June 2021 Electrical characteristics (+25 °C) Part number VR IR @ VR VBR @ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (µA) min (V) max (V) (mA) max (V) (A) 15BJ5-0AH 15BJ5-0CAH GDE BDE 5 300 6.4 7 10 9.2 163 15BJ6-0AH 15BJ6-0CAH GDG BDG 6 250 6.67 7.37 10 10.3 145.6 15BJ6-5AH 15BJ6-5CAH GDK BDK 6.5 150 7.22 7.98 10 11.2 134 15BJ7-0AH 15BJ7-0CAH GDM BDM 7 100 7.78 8.6 10 12 125 15BJ7-5AH 15BJ7-5CAH GDP BDP 7.5 50 8.33 9.21 1 12.9 116.3 15BJ8-0AH 15BJ8-0CAH GDR BDR 8 30 8.89 9.83 1 13.6 110.3 15BJ8-5AH 15BJ8-5CAH GDT BDT 8.5 20 9.44 10.4 1 14.4 104.2 15BJ9-0AH 15BJ9-0CAH GDV BDV 9 10 10 11.1 1 15.4 97.4 15BJ10AH 15BJ10CAH GDX BDX 10 5 11.1 12.3 1 17 88.2 15BJ11AH 15BJ11CAH GDZ BDZ 11 2 12.2 13.5 1 18.2 82.4 15BJ12AH 15BJ12CAH GEE BEE 12 1 13.3 14.7 1 19.9 75.4 15BJ13AH 15BJ13CAH GEG BEG 13 1 14.4 15.9 1 21.5 69.8 15BJ14AH 15BJ14CAH GEK BEK 14 1 15.6 17.2 1 23.2 64.7 15BJ15AH 15BJ15CAH GEM BEM 15 1 16.7 18.5 1 24.4 61.5 15BJ16AH 15BJ16CAH GEP BEP 16 1 17.8 19.7 1 26 57.7 15BJ17AH 15BJ17CAH GER BER 17 1 18.9 20.9 1 27.6 54.4 15BJ18AH 15BJ18CAH GET BET 18 1 20 22.1 1 29.2 51.4 15BJ20AH 15BJ20CAH GEV BEV 20 1 22.2 24.5 1 32.4 46.3 15BJ22AH 15BJ22CAH GEX BEX 22 1 24.4 26.9 1 35.5 42.3 15BJ24AH 15BJ24CAH GEZ BEZ 24 1 26.7 29.5 1 38.9 38.6 15BJ26AH 15BJ26CAH GFE BFE 26 1 28.9 31.9 1 42.1 35.6 15BJ28AH 15BJ28CAH GFG BFG 28 1 31.1 34.4 1 45.4 33.1 15BJ30AH 15BJ30CAH GFK BFK 30 1 33.3 36.8 1 48.4 31 15BJ33AH 15BJ33CAH GFM BFM 33 1 36.7 40.6 1 53.3 28.2 15BJ36AH 15BJ36CAH GFP BFP 36 1 40 44.2 1 58.1 25.8 15BJ40AH 15BJ40CAH GFR BFR 40 1 44.4 49.1 1 64.5 23.3 15BJ43AH 15BJ43CAH GFT BFT 43 1 47.8 52.8 1 69.4 21.6 15BJ45AH 15BJ45CAH GFV BFV 45 1 50 55.3 1 72.7 20.6 15BJ48AH 15BJ48CAH GFX BFX 48 1 53.3 58.9 1 77.4 19.4 15BJ51AH 15BJ51CAH GFZ BFZ 51 1 56.7 62.7 1 82.4 18.2 15BJ54AH 15BJ54CAH GGE BGE 54 1 60 66.3 1 87.1 17.2 15BJ58AH 15BJ58CAH GGG BGG 58 1 64.4 71.2 1 93.6 16.1 15BJ60AH 15BJ60CAH GGK BGK 60 1 66.7 73.7 1 96.8 15.5 15BJ64AH 15BJ64CAH GGM BGM 64 1 71.1 78.6 1 103 14.6 15BJ70AH 15BJ70CAH GGP BGP 70 1 77.8 86 1 113 13.3 15BJ75AH 15BJ75CAH GGR BGR 75 1 83.3 92.1 1 121 12.4 15BJ78AH 15BJ78CAH GGT BGT 78 1 86.7 95.8 1 126 11.9 15BJ85AH 15BJ85CAH GGV BGV 85 1 94.4 104 1 137 11 15BJ90AH 15BJ90CAH GGX BGX 90 1 100 111 1 146 10.3 15BJ100AH 15BJ100CAH GGZ BGZ 100 1 111 123 1 162 9.3 15BJ110AH 15BJ110CAH GHE BHE 110 1 122 135 1 177 8.5 15BJ120AH 15BJ120CAH GHG BHG 120 1 133 147 1 193 7.8 15BJ130AH 15BJ130CAH GHK BHK 130 1 144 159 1 209 7.2 15BJ150AH 15BJ150CAH GHM BHM 150 1 167 185 1 243 6.2 15BJ160AH 15BJ160CAH GHP BHP 160 1 178 197 1 259 5.8 15BJ170AH 15BJ170CAH GHR BHR 170 1 189 209 1 275 5.5 15BJ180AH 15BJ180CAH GHT BHT 180 1 201 222 1 292 5.2 15BJ190AH 15BJ190CAH GHU BHU 190 1 211 234 1 307 4.9 15BJ200AH 15BJ200CAH GHV BHV 200 1 224 247 1 324 4.7 www.eaton.com/electronics 3 Technical Data ELX1059 Effective June 2021 15BJ Automotive grade 1500 W Transient voltage suppressor  Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional Pulse waveform IPPM (% IRSM) PPP derating in percentage (%) Pulse derating curve t (ms) 4 www.eaton.com/electronics TJ (°C) Technical Data ELX1059 15BJ Automotive grade 1500 W Transient voltage suppressor Effective June 2021  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
15BJ36CAH 价格&库存
很抱歉,暂时无法提供与“15BJ36CAH”相匹配的价格&库存,您可以联系我们找货
15BJ36CAH
  • 1+5.172061+0.67235
  • 10+3.3379310+0.43392
  • 100+2.91200100+0.37855
  • 500+2.58168500+0.33561
  • 1000+2.346991000+0.30510
  • 3000+2.181833000+0.28363
15BJ36CAH
    • 1+0.77901
    • 200+0.30143
    • 500+0.29085
    • 1000+0.28566
    15BJ36CAH
    • 1+4.80318
    • 10+3.09991
    • 100+2.70942
    • 500+2.40159
    • 1000+2.17880
    • 3000+2.02907
    15BJ36CAH
    • 501000+2.67586501000+0.34786
