5-0SMDJ40AH
5-0SMDJ40AH
    EATON(伊顿)
    SMC(DO-214AB)
    64.5V 夹子 78A Ipp TVS - 二极管 表面贴装型 SMC
5-0SMDJ40AH 数据手册
Technical Data ELX1056 Effective June 2021 5-0SMDJ Automotive grade 5000 W Transient voltage suppressor Applications Product features • Automotive grade (AEC-Q101 qualified) • Low profile SMC package • Excellent clamping capability • High reliability application • 5000 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 5 μA • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Tin plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • Automotive chassis and safety systems • Advanced driver assistance systems (ADAS) • Communication and infotainment systems • Network systems and body electronics • Power Train controls • xEV and battery systems Environmental compliance and general specifications • ISO16750-2 P5A: 12 V system (87 V/2 Ω/150 ms) • ISO16750-2 P5A: 24 V system (123 V/8 Ω/150 ms) • AEC-Q101 qualified Ordering part number 5-0SMDJ 15 C A H Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance High reliability application PIN configuration 5-0SMDJ Automotive grade 5000 W Transient voltage suppressor  Technical Data ELX1056 Effective June 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Storage operating junction temperature range Parameter TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 6.5 W Peak pulse power dissipation on 10/1000 μs waveform PPP 5000 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 300 A Typical thermal resistance junction to lead R JL 15 °C/W Typical thermal resistance junction to ambient R JA 75 °C/W 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm/inches Part marking Millimeters Inches Dimension Minimum Maximum Minimum Maximum A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 K L Cathode band (uni-polar only) Part marking: xxxx = Date code yyyy- Refer to marking designator listed in Electrical characteristics table 0.094 4.20 0.165 3.30 0.130 Packaging information- mm/inches Drawing not to scale. Dimensions Millimeters Inches Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) A0 6.05 ± 0.3 0.238 ± 0.012 B0 8.31 ± 0.3 0.327 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 7.50 ± 0.2 0.295 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.3145 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 16.0 ± 0.2 0.630 ± 0.008 W1 19.7 ± 2.0 0.776 ± 0.079 2 www.eaton.com/electronics Technical Data ELX1056 5-0SMDJ  Automotive grade 5000 W Transient voltage suppressor Effective June 2021  Electrical characteristics (+25 °C) Part number VR IR @ VR VBR @ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (µA) min (V) max (V) (mA) max (V) (A) 5-0SMDJ15AH 5-0SMDJ15CAH P15A P15C 15 5 16.7 18.5 5 24.4 205 5-0SMDJ16AH 5-0SMDJ16CAH P16A P16C 16 5 17.8 19.7 5 26 192 5-0SMDJ18AH 5-0SMDJ18CAH P18A P18C 18 5 20 22.1 5 29.2 171 5-0SMDJ20AH 5-0SMDJ20CAH P20A P20C 20 5 22.2 24.5 5 32.4 154 5-0SMDJ22AH 5-0SMDJ22CAH P22A P22C 22 5 24.4 26.9 5 35.5 141 5-0SMDJ24AH 5-0SMDJ24CAH P24A P24C 24 5 26.7 29.5 5 38.9 129 5-0SMDJ26AH 5-0SMDJ26CAH P26A P26C 26 5 28.9 31.9 5 42.1 119 5-0SMDJ28AH 5-0SMDJ28CAH P28A P28C 28 5 31.1 34.4 5 45.4 110 5-0SMDJ30AH 5-0SMDJ30CAH P30A P30C 30 5 33.3 36.8 5 48.4 103 5-0SMDJ33AH 5-0SMDJ33CAH P33A P33C 33 5 36.7 40.6 5 53.3 94 5-0SMDJ36AH 5-0SMDJ36CAH P36A P36C 36 5 40 44.2 5 58.1 86 5-0SMDJ40AH 5-0SMDJ40CAH P40A P40C 40 5 44.4 49.1 5 64.5 78 5-0SMDJ43AH 5-0SMDJ43CAH P43A P43C 43 5 47.8 52.8 5 69.4 72 www.eaton.com/electronics 3 Technical Data ELX1056 Effective June 2021 5-0SMDJ Automotive grade 5000 W Transient voltage suppressor  Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional Pulse waveform IPPM (% IRSM) Pulse derating curve t (ms) ISO16750-2 test pulse 5a 4 www.eaton.com/electronics ISO16750-2 test pulse 5a conditions Parameter 12 V system 24 V system Us 79 V to 101 V 151 V to 202 V Ri 0.5 Ω to 4 Ω 1 Ω to 8 Ω td 40 ms to 400 ms 100 ms to 350 ms tr 5 to 10 ms 5 to 10 ms Technical Data ELX1056 5-0SMDJ  Automotive grade 5000 W Transient voltage suppressor Effective June 2021  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
5-0SMDJ40AH 价格&库存
很抱歉,暂时无法提供与“5-0SMDJ40AH”相匹配的价格&库存,您可以联系我们找货
5-0SMDJ40AH
  • 1+20.930461+2.71712
  • 10+13.4388910+1.74459
  • 100+9.14070100+1.18662
  • 500+7.30095500+0.94779
  • 1000+6.709221000+0.87097
库存:2930
5-0SMDJ40AH
  • 201000+8.49231201000+1.10244
库存:2930
