Technical Data ELX1056
Effective June 2021
5-0SMDJ
Automotive grade 5000 W Transient voltage suppressor
Applications
Product features
Automotive grade (AEC-Q101 qualified)
Low profile SMC package
Excellent clamping capability
High reliability application
5000 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 5 μA
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0
flammability rating
Meets moisture sensitivity level (MSL) level 1
Terminal: Tin plated leads,
solderable per J-STD-002
For surface mounted applications in order to
optimize board space
Automotive chassis and safety systems
Advanced driver assistance systems (ADAS)
Communication and infotainment systems
Network systems and body electronics
Power Train controls
xEV and battery systems
Environmental compliance and general
specifications
ISO16750-2 P5A: 12 V system
(87 V/2 Ω/150 ms)
ISO16750-2 P5A: 24 V system
(123 V/8 Ω/150 ms)
AEC-Q101 qualified
Ordering part number
5-0SMDJ 15 C A H
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
PIN configuration
5-0SMDJ
Effective June 2021
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Symbol
Value
Unit
Storage operating junction temperature range
Parameter
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
6.5
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
5000
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5.0
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
300
A
Typical thermal resistance junction to lead
R
JL
15
°C/W
Typical thermal resistance junction to ambient
R
JA
75
°C/W
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm/inches
Part marking
Millimeters
Inches
Dimension Minimum
Maximum
Minimum
Maximum
A
5.75
6.25
0.226
0.246
B
6.90
7.40
0.272
0.291
C
2.75
3.25
0.108
0.128
D
0.95
1.52
0.037
0.060
E
7.70
8.20
0.303
0.323
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.15
2.62
0.085
0.103
J
2.40
K
L
Cathode band (uni-polar only)
Part marking:
xxxx = Date code
yyyy- Refer to marking designator listed in
Electrical characteristics table
0.094
4.20
0.165
3.30
0.130
Packaging information- mm/inches
Drawing not to scale.
Dimensions
Millimeters
Inches
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel
(EIA-481 compliant)
A0
6.05 ± 0.3
0.238 ± 0.012
B0
8.31 ± 0.3
0.327 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
7.50 ± 0.2
0.295 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.3145 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
16.0 ± 0.2
0.630 ± 0.008
W1
19.7 ± 2.0
0.776 ± 0.079
2
www.eaton.com/electronics
5-0SMDJ
Effective June 2021
Electrical characteristics (+25 °C)
Part number
VR
IR @ VR
VBR @ IT
IT
VC @ IPP
IPP
Uni-polar
Bi-polar
Marking
Uni
Bi
(V)
(µA)
min (V)
max (V)
(mA)
max (V)
(A)
5-0SMDJ15AH
5-0SMDJ15CAH
P15A
P15C
15
5
16.7
18.5
5
24.4
205
5-0SMDJ16AH
5-0SMDJ16CAH
P16A
P16C
16
5
17.8
19.7
5
26
192
5-0SMDJ18AH
5-0SMDJ18CAH
P18A
P18C
18
5
5
29.2
171
5-0SMDJ20AH
5-0SMDJ20CAH
P20A
P20C
22.2
24.5
5
32.4
154
5-0SMDJ22AH
5-0SMDJ22CAH
P22A
P22C
22
5
24.4
26.9
5
35.5
141
5-0SMDJ24AH
5-0SMDJ24CAH
P24A
P24C
24
5
26.7
29.5
5
38.9
129
5-0SMDJ26AH
5-0SMDJ26CAH
P26A
P26C
26
5
28.9
31.9
5
42.1
119
5-0SMDJ28AH
5-0SMDJ28CAH
P28A
P28C
28
5
31.1
34.4
5
45.4
110
5-0SMDJ30AH
5-0SMDJ30CAH
P30A
P30C
30
5
33.3
36.8
5
48.4
103
5-0SMDJ33AH
5-0SMDJ33CAH
P33A
P33C
33
5
36.7
40.6
5
53.3
94
5-0SMDJ36AH
5-0SMDJ36CAH
P36A
P36C
36
5
40
44.2
5
58.1
86
5-0SMDJ40AH
5-0SMDJ40CAH
P40A
P40C
40
5
44.4
49.1
5
64.5
78
5-0SMDJ43AH
5-0SMDJ43CAH
P43A
P43C
43
5
47.8
52.8
5
69.4
72
3
Effective June 2021
5-0SMDJ
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional
Pulse waveform
IPPM (% IRSM)
Pulse derating curve
t (ms)
ISO16750-2 test pulse 5a
4
ISO16750-2 test pulse 5a conditions
Parameter
12 V system
24 V system
Us
79 V to 101 V
151 V to 202 V
Ri
0.5 Ω to 4 Ω
1 Ω to 8 Ω
td
40 ms to 400 ms
100 ms to 350 ms
tr
5 to 10 ms
5 to 10 ms
5-0SMDJ
Effective June 2021
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“5-0SMDJ33CAH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+20.962311+2.71712
- 10+13.4593410+1.74459
- 国内价格 香港价格
- 201000+8.98001201000+1.16398
