6KPE33AH
6KPE33AH
    EATON(伊顿)
    插件
    53.3V 夹子 123.8A Ipp TVS - 二极管 通孔
6KPE33AH 数据手册
Technical Data ELX1057 Effective June 2021 6KPE Automotive grade 6600 W Transient voltage suppressor Applications Product features • Automotive grade (AEC-Q101 qualified) • Excellent clamping capability • • • Automotive chassis and safety systems • Advanced driver assistance systems (ADAS) • Communication and infotainment systems • Network systems and body electronics • Power Train controls • xEV and battery systems Environmental compliance and general specifications • ISO16750-2 P5A: 12 V system (87 V/1 Ω/400 ms) High reliability application • 6600 W peak pulse power capability at 10/1000 μs waveform ISO16750-2 P5A: 24 V system (174 V/4 Ω/350 ms) • AEC-Q101 qualified • Typical IR less than 5 μA • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • Plastic package meets UL 94 V-0 flammability rating • Terminal: tin plated, solderable per J-STD-002 • UL 497B recognized. File No. : E198449 Guide QVGQ2 Ordering part number 6KPE 15 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance High reliability application PIN configuration H 6KPE Automotive grade 6600 W Transient voltage suppressor  Technical Data ELX1057 Effective June 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Storage operating junction temperature range Parameter TSTG/ TJ -55 to +175 °C Steady state power dissipation at TL= +75 °C PM(AV) 8.0 W Peak pulse power dissipation on 10/1000 μs waveform PPP 6600 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 3.5 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 600 A Typical thermal resistance junction to lead R JL 8.0 °C/W Typical thermal resistance junction to ambient R JA 40 °C/W 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm/inches Millimeters Part marking Packaging information 300 parts per box 2 www.eaton.com/electronics Inches Dimension Minimum Maximum Minimum Maximum A 25.40 - 1.000 - B 8.60 9.40 0.339 0.370 C 1.20 1.40 0.047 0.055 D 8.60 9.10 0.339 0.358 Technical Data ELX1057 6KPE  Automotive grade 6600 W Transient voltage suppressor Effective June 2021  Electrical specifications (+25 °C) Part number VR IR @ VR VBR @ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (µA) min (V) max (V) (mA) max (V) (A) 6KPE15AH 6KPE15CAH 6KPE15AH 6KPE15CAH 15 5 16.7 18.5 5 24.4 270.5 6KPE16AH 6KPE16CAH 6KPE16AH 6KPE16CAH 16 5 17.8 19.7 5 26 253.8 6KPE18AH 6KPE18CAH 6KPE18AH 6KPE18CAH 18 5 20 22.1 5 29.2 226 6KPE20AH 6KPE20CAH 6KPE20AH 6KPE20CAH 20 5 22.2 24.5 5 32.4 203.7 x 6KPE22AH 6KPE22CAH 6KPE22AH 6KPE22CAH 22 5 24.4 26.9 5 35.5 186 x 6KPE24AH 6KPE24CAH 6KPE24AH 6KPE24CAH 24 5 26.7 29.5 5 38.9 169.7 x 6KPE26AH 6KPE26CAH 6KPE26AH 6KPE26CAH 26 5 28.9 31.9 5 42.1 156.8 x 6KPE28AH 6KPE28CAH 6KPE28AH 6KPE28CAH 28 5 31.1 34.4 5 45.4 145.4 x 6KPE30AH 6KPE30CAH 6KPE30AH 6KPE30CAH 30 5 33.3 36.8 5 48.4 136.4 x 6KPE33AH 6KPE33CAH 6KPE33AH 6KPE33CAH 33 5 36.7 40.6 5 53.3 123.8 x 6KPE36AH 6KPE36CAH 6KPE36AH 6KPE36CAH 36 5 40 44.2 5 58.1 113.6 x 6KPE40AH 6KPE40CAH 6KPE40AH 6KPE40CAH 40 5 44.4 49.1 5 64.5 102.3 x 6KPE43AH 6KPE43CAH 6KPE43AH 6KPE43CAH 43 5 47.8 52.8 5 69.4 95.1 x UL497B recognized www.eaton.com/electronics 3 6KPE Automotive grade 6600 W Transient voltage suppressor  Technical Data ELX1057 Effective June 2021 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional Pulse waveform IPPM (% IRSM) PPP derating in percentage (%) Pulse derating curve t (ms) 4 www.eaton.com/electronics TJ (°C) 6KPE  Automotive grade 6600 W Transient voltage suppressor Technical Data ELX1057 Effective June 2021  Wave solder profile tp Temperature Tp First Wave Second Wave Tsmax Tstyp Tsmin Preheat area Cool down area Time Reference EN 61760-1:2006 Profile feature Preheat Standard SnPb solder Lead (Pb) free solder • Temperature min. (Tsmin) 100 °C 100 °C • Temperature typ. (Tstyp) 120 °C 120 °C • Temperature max. (Tsmax) 130 °C 130 °C • Time (Tsmin to Tsmax) (ts) 70 seconds 70 seconds D preheat to max Temperature 150 °C max. 150 °C max. Peak temperature (TP)* 235 °C – 260 °C 250 °C – 260 °C Time at peak temperature (tp) 10 seconds max 5 seconds max each wave 10 seconds max 5 seconds max each wave Ramp-down rate ~ 2 K/s min ~3.5 K/s typ ~5 K/s max ~ 2 K/s min ~3.5 K/s typ ~5 K/s max Time 25 °C to 25 °C 4 minutes 4 minutes Manual solder +350 °C (4-5 seconds by soldering iron), generally manual/hand soldering is not recommended Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2021 Eaton All Rights Reserved Printed in USA Publication No. ELX1057 BU-ELX21057 June 2021 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
6KPE33AH 价格&库存
很抱歉,暂时无法提供与“6KPE33AH”相匹配的价格&库存,您可以联系我们找货
