Technical Data ELX1057
Effective June 2021
6KPE
Automotive grade 6600 W Transient voltage suppressor
Applications
Product features
Automotive grade (AEC-Q101 qualified)
Excellent clamping capability
Automotive chassis and safety systems
Advanced driver assistance systems (ADAS)
Communication and infotainment systems
Network systems and body electronics
Power Train controls
xEV and battery systems
Environmental compliance and general
specifications
ISO16750-2 P5A: 12 V system
(87 V/1 Ω/400 ms)
High reliability application
6600 W peak pulse power capability at
10/1000 μs waveform
ISO16750-2 P5A: 24 V system
(174 V/4 Ω/350 ms)
AEC-Q101 qualified
Typical IR less than 5 μA
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
Plastic package meets UL 94 V-0
flammability rating
Terminal: tin plated, solderable per J-STD-002
UL 497B recognized.
File No. : E198449 Guide QVGQ2
Ordering part number
6KPE 15 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
PIN configuration
H
6KPE
Effective June 2021
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Symbol
Value
Unit
Storage operating junction temperature range
Parameter
TSTG/ TJ
-55 to +175
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
8.0
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
6600
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
3.5
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
600
A
Typical thermal resistance junction to lead
R
JL
8.0
°C/W
Typical thermal resistance junction to ambient
R
JA
40
°C/W
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm/inches
Millimeters
Part marking
Packaging information
300 parts per box
2
www.eaton.com/electronics
Inches
Dimension Minimum
Maximum
Minimum
Maximum
A
25.40
1.000
B
8.60
9.40
0.339
0.370
C
1.20
1.40
0.047
0.055
D
8.60
9.10
0.339
0.358
6KPE
Effective June 2021
Electrical specifications (+25 °C)
Part number
VR
IR @ VR
VBR @ IT
IT
VC @ IPP
IPP
Uni-polar
Bi-polar
Marking
Uni
Bi
(V)
(µA)
min (V)
max (V)
(mA)
max (V)
(A)
6KPE15AH
6KPE15CAH
6KPE15AH
6KPE15CAH
15
5
16.7
18.5
5
24.4
270.5
6KPE16AH
6KPE16CAH
6KPE16AH
6KPE16CAH
16
5
17.8
19.7
5
26
253.8
6KPE18AH
6KPE18CAH
6KPE18AH
6KPE18CAH
18
5
5
29.2
226
6KPE20AH
6KPE20CAH
6KPE20AH
6KPE20CAH
22.2
24.5
5
32.4
203.7
x
6KPE22AH
6KPE22CAH
6KPE22AH
6KPE22CAH
22
5
24.4
26.9
5
35.5
186
x
6KPE24AH
6KPE24CAH
6KPE24AH
6KPE24CAH
24
5
26.7
29.5
5
38.9
169.7
x
6KPE26AH
6KPE26CAH
6KPE26AH
6KPE26CAH
26
5
28.9
31.9
5
42.1
156.8
x
6KPE28AH
6KPE28CAH
6KPE28AH
6KPE28CAH
28
5
31.1
34.4
5
45.4
145.4
x
6KPE30AH
6KPE30CAH
6KPE30AH
6KPE30CAH
30
5
33.3
36.8
5
48.4
136.4
x
6KPE33AH
6KPE33CAH
6KPE33AH
6KPE33CAH
33
5
36.7
40.6
5
53.3
123.8
x
6KPE36AH
6KPE36CAH
6KPE36AH
6KPE36CAH
36
5
40
44.2
5
58.1
113.6
x
6KPE40AH
6KPE40CAH
6KPE40AH
6KPE40CAH
40
5
44.4
49.1
5
64.5
102.3
x
6KPE43AH
6KPE43CAH
6KPE43AH
6KPE43CAH
43
5
47.8
52.8
5
69.4
95.1
x
UL497B
recognized
3
6KPE
Effective June 2021
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional
Pulse waveform
IPPM (% IRSM)
PPP derating in percentage (%)
Pulse derating curve
t (ms)
4
TJ (°C)
6KPE
Effective June 2021
Wave solder profile
tp
Temperature
Tp
First Wave
Second Wave
Tsmax
Tstyp
Tsmin
Preheat area
Cool down area
Time
Reference EN 61760-1:2006
Profile feature
Preheat
Standard SnPb solder
Lead (Pb) free solder
• Temperature min. (Tsmin)
100 °C
100 °C
• Temperature typ. (Tstyp)
120 °C
120 °C
• Temperature max. (Tsmax)
130 °C
130 °C
• Time (Tsmin to Tsmax) (ts)
70 seconds
70 seconds
D preheat to max Temperature
150 °C max.
150 °C max.
Peak temperature (TP)*
235 °C – 260 °C
250 °C – 260 °C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25 °C to 25 °C
4 minutes
4 minutes
Manual solder
+350 °C (4-5 seconds by soldering iron), generally manual/hand soldering is not recommended
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2021 Eaton
All Rights Reserved
Printed in USA
Publication No. ELX1057 BU-ELX21057
June 2021
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“6KPE24CAH”相匹配的价格&库存,您可以联系我们找货
