DIN-Rail Terminal Blocks
Simplify Wiring, Power Distribution
& Circuit Protection
Bussmann
2
For product data sheets, www.cooperbussmann.com/DatasheetsIEC
Table of Contents
Bussmann
Terminal Blocks
Terminal Blocks Styles
4-5
Terminal Blocks Overview
5
Feed Through Blocks
DP Series
6-7
DS Series
8
Mini Feed Through Blocks
DM Series
9
Double Level Blocks
DDP Series
10
Disconnect Blocks
DIS Series
10
Grounding Blocks
DG Series
11 - 12
Fuse Holder Blocks
F520 Series
13 - 14
Internally Jumpered Blocks
DDNS Series
14
Test Blocks
DTST2 Series
15
Accessories
Top Screw-on Bridges
16
End Brackets
17
Partition Plates
17
Jumper Slides
18
Top Insertion Bridges
18
Side Insertion Bridges
19 - 20
Mounting Rails
Marking Systems
Marking System
22
Marking Label Ordering Method
23 - 25
DIN-Rail Complementary Range
Overview
26
Modular Fuse Holders
Compact Circuit Protectors
CH Series
27
Comb-Bus Bar
28
CH-PLC
29
CH14B Series
30
CH22B Series
31
CCP Series
32
NH Bases
33
Surge Protective Devices
34 - 35
3
Our terminal blocks are available in multiple colours for easy circuit identification, plus popular single and doublebridge shaft systems for maximum power distribution flexibility. Certifications include UL 1059 (UL File E62622),
cURus, VDE and IEC 60947-7. Blocks are Short-Circuit Current Rated (SCCR) from 10kA to 200kA.
Feed Through Terminal Blocks
Fuse Holder Terminal Blocks
Fuse terminal blocks protect
your sensors and relays.
Available in lever and screwcap style, with and without
LED indication. Uses standard
Cooper Bussmann 5x20mm
fuse links.
Single-level feed through
terminal blocks up to 1000V
and 232A for wire sizes AWG
22 to 2 (0.5mm2 to 35mm2).
See page 6 - 9
See page 13 - 14
Double Level Terminal Blocks
Internally Jumpered Terminal Blocks
High-density connectivity
using double-level terminal
blocks. Marking system, side
insertion bridge and
top screw-on bridge are
standard. Use bridges to
achieve any connection
topology.
Internally jumpered doublelevel terminal blocks provide
high-density power
distribution in 3-in/1-out or
2-in/2-out or 1-in/3-out
options with a single block.
See page 14
See page 10
Disconnect Terminal Blocks
Test Terminal Blocks
Test terminal blocks with
convenient test sockets,
plugs, jumpers and
accessories to make your
circuit troubleshooting easy.
Disconnect terminal blocks
offer an easy circuit
disconnection with just a flick
of a screwdriver.
See page 10
See page 15
Grounding Terminal Blocks
Jumper Bridges
Grounding terminal blocks
can convert DIN-Rail into a
grounding bar. For wire sizes
AWG 26 to 2 (0.13mm2 to
35mm2).
A variety of side insertion
bridge, top insertion bridge
and top screw-on bridge in
multiple pole options are
available to solve any power
distribution need.
See page 11 - 12
See page 16- 20
4
Terminal Blocks Styles and Overview
Bussmann
Marking System and Labels
Rail Products
An array of rail products are
offered to compliment the
product line. Products
available include 15mm,
35mm aluminium DIN-Rail;
and 35mm G-type DIN-Rail.
Open software, PC-based
plotter system can print
Cooper Bussmann labels as
well as most major competitor
labels. A decisive advantage.
Blank and pre-printed
marking labels are available.
See page 20
See page 21 - 25
Introducing a full range of single-level and two-level feed through screw connection DIN-Rail terminal blocks, test
and disconnect blocks, grounding blocks, plug-in and screw-on bridges, marking system and accessories.
High quality and high functionality for all wiring needs.
Partition Plate Assists
Wire Management
Single or Double Bridge
Shaft for Maximum
Flexibility
Recessed Screw Holes
Enhance Safety
Marking System for
Circuit Identification
Self-extinguishing
polyamide,
UL94V0 Material
Top Bridge
Side Bridge
Wire ready Captive
Screws, Fully Backed Out
High Strength
Zinc-Plated Steel
Screw and Wire Cage
for High Contact
Pressure
Universal Mounting
on 35mm DIN-Rail or
32mm G-type DIN-Rail
Low Resistance Tin-Plated
Copper Conductive Elements for
Low Voltage Drop
Legend
G-Type DIN-Rail
35mm DIN-Rail
15mm DIN-Rail
C-Rail
Jumper Bridge Connection
Wire Connection
5
Feed Through Blocks - DP Series
DP Series
DP25
The DP Series feature a generous
design allowing for more wiring
space and access. Additionally, this
series feature a larger wire contact
area and larger conducting
elements. Accessories include
marking labels, partition plates, side
insertion bridge and top screw-on
bridge for improved reliability.
Comes with matching shaped
grounding blocks. Designed for
35mm DIN and 32mm G-type rails.
Approval
IEC 60947-7-1 and UL 1059
compliant.
UL
IEC
Technical Data
UL
IEC
Technical Data
UL
IEC
600V
630V
Rated voltage
600V
630V
Rated voltage
600V
500V
Rated current
25A
24A
Rated current
35A
32A
Rated current
45A
41A
Conductor crosssection, solid
(AWG/mm2)
22~12 / 0.5~2.5
(AWG/mm2)
22~10 / 0.5~4
(AWG/mm2)
20~8 / 0.5~6
Conductor crosssection, flexible
(AWG/mm2)
22~12 / 0.5~2.5
(AWG/mm2)
22~10 / 0.5~4
(AWG/mm2)
20~8 / 0.5~6
Rated impulse
withstand voltage
8kV
Rated impulse
withstand voltage
8kV
Rated impulse
withstand voltage
8kV
Torque (N•m)
0.8
Torque (N•m)
0.8
Torque (N•m)
1.8
Torque (lb-in)
7.1
Torque (lb-in)
7.1
Torque (lb-in)
15.9
M3
Screw
M3
Screw
W x H x D (mm)
10~12
5.1 x 47.6 x 58.9
Wire strip length (mm)
W x H x D (mm)
10~12
6.1 x 47.6 x 58.9
8 x 47.6 x 58.9
Colours
Cat. No
Colours
Cat. No
Grey
DP25-GY
Grey
DP35-GY
Grey
DP45-GY
Blue
DP25-BU
Blue
DP35-BU
Blue
DP45-BU
Black
DP25-LK
Black
DP35-LK
Black
DP45-LK
Red
DP25-RD
Red
DP35-RD
Red
DP45-RD
Yellow
DP25-YW
Yellow
DP35-YW
Yellow
DP45-YW
Orange
DP25-OR
Orange
DP35-OR
Orange
DP45-OR
DP25-GN
Green
DP35-GN
Green
DP45-GN
Cat. No
Accessories
Cat. No
Accessories
Cat. No
Grey
DP25-GY-ND
Grey
DP25-GY-ND
Grey
DP25-GY-ND
Blue
DP25-BU-ND
Blue
DP25-BU-ND
Blue
DP25-BU-ND
Black
DP25-LK-ND
Black
DP25-LK-ND
Black
DP25-LK-ND
Red
DP25-RD-ND
Red
DP25-RD-ND
Red
DP25-RD-ND
Yellow
DP25-YW-ND
Yellow
DP25-YW-ND
Yellow
DP25-YW-ND
Orange
DP25-OR-ND
Orange
DP25-OR-ND
Orange
DP25-OR-ND
Green
DP25-GN-ND
Green
DP25-GN-ND
Green
DP25-GN-ND
Partition
DKSPS-001
DKSPS-001
Small partition
DKSPS-002
DKSPS-002
Top screw-on bridge
W x H x D (mm)
M4
12~14
Cat. No
Green
Side insertion bridge
Colours
Accessories
End cover
Approval
Approval
Rated voltage
Block
DP45
Technical Data
Screw
DKSPS-001
DKSPS-002
2-pole
3-pole
4-pole
10-pole
CSC-2-502P
CSC-2-503P
CSC-2-504P
CSC-2-510P
2-pole
3-pole
4-pole
10-pole
CSC-402P
CSC-403P
CSC-404P
CSC-410P
2-pole
3-pole
4-pole
10-pole
CSC-602P
CSC-603P
CSC-604P
CSC-610P
2-pole
3-pole
4-pole
10-pole
DS2-5-02P
DS2-5-03P
DS2-5-04P
DS2-5-10P
2-pole
3-pole
4-pole
10-pole
DS4-02P
DS4-03P
DS4-04P
DS4-10P
2-pole
3-pole
4-pole
10-pole
DS6-02P
DS6-03P
DS6-04P
DS6-10P
TM26CB
TM27CB
TM28CB
Mounting rail
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
Tool
0.4 x 2.5mm
0.5 x 3mm
0.8 x 4mm
Marking label
6
DP35
1
2 3
4
5
6
7
Bussmann
DP60
DP100
Approval
Approval
Technical Data
UL
IEC
Technical Data
Rated voltage
600V
500V
Rated current
60A
57A
(AWG/mm2)
DP150
Approval
UL
IEC
Technical Data
Rated voltage
600V
1000V
Rated current
100A
101A
20~6 / 1.5~10
(AWG/mm2)
(AWG/mm2)
20~6 / 1.5~10
Rated impulse
withstand voltage
IEC
Technical Data
Rated voltage
600V
1000V
Rated current
150A
150A
14~3 / 1.5~25
(AWG/mm2)
14~3 / 1.5~25
8kV
Rated impulse
withstand voltage
Torque (N•m)
1.8
Torque (lb-in)
Screw
W x H x D (mm)
Approval
UL
(AWG/mm2)
DP230
UL
IEC
Rated voltage
600V
1000V
Rated current
230A
232A
12~1 / 2.5~50
(AWG/mm2)
2 / 35
(AWG/mm2)
12~1/0 / 2.5~50
(AWG/mm2)
2~4/0 / 35~95
8kV
Rated impulse
withstand voltage
8kV
Rated impulse
withstand voltage
8kV
Torque (N•m)
3.4
Torque (N•m)
6.9
Torque (N•m)
10.2
15.9
Torque (lb-in)
30.1
Torque (lb-in)
61.1
Torque (lb-in)
90.3
M4
Screw
M5
Screw
M6
Screw
12~14
10 x 47.6 x 58.9
W x H x D (mm)
13~15
12 x 52.2 x 46.7
W x H x D (mm)
16~18
16 x 61.2 x 52
W x H x D (mm)
M8
30~35
25 x 88.5 x 80
Colours
Cat. No
Colours
Cat. No
Colours
Cat. No
Colours
Cat. No
Grey
DP60-GY
Grey
DP100-GY
Grey
DP150-GY
Grey
DP230-GY
Blue
DP150-BU
Blue
DP230-BU
Accessories
Grey
Cat. No
DP25-GY-ND
Accessories
Grey
DKSPS-001
Cat. No
Accessories
Cat. No
Accessories
Cat. No
DP100-GY-ND
DKNSPS-003
DKNSPS-004
DKNSPS-004
DKSPS-002
1
2 3
4
5
6
7
2-pole
3-pole
4-pole
10-pole
CSC-1002P
CSC-1003P
CSC-1004P
CSC-1010P
2-pole
3-pole
4-pole
10-pole
CSC-1602P
CSC-1603P
CSC-1604P
CSC-1610P
2-pole
3-pole
4-pole
10-pole
CSC-3502P
CSC-3503P
CSC-3504P
CSC-3510P
2-pole
3-pole
4-pole
10-pole
CSC-9502P
CSC-9503P
N/A
N/A
2-pole
3-pole
4-pole
10-pole
DS10-02P
DS10-03P
DS10-04P
DS10-10P
2-pole
3-pole
4-pole
10-pole
DS16-02P
DS16-03P
DS16-04P
DS16-10P
2-pole
3-pole
4-pole
10-pole
DS35-02P
DS35-03P
DS35-04P
DS35-10P
2-pole
3-pole
4-pole
10-pole
N/A
N/A
N/A
N/A
TM28CB
TM28CB
TM28CB
TM28CB
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
0.8 x 4mm
1 x 5.5mm
7
Feed Through Blocks - DS Series
DS Series
DS20
The DS Series feature a compact
design that save wiring space on
the control panels. Accessories
include marking labels, partition
plates as well as side and top
insertion bridges. Designed for
Approval
IEC 60947-7-1 and UL 1059.
compliant
Technical Data
UL
IEC
Technical Data
UL
IEC
Rated voltage
600V
1000V
Rated voltage
600V
1000V
Rated voltage
600V
1000V
Rated current
20A
24A
Rated current
30A
32A
Rated current
50A
41A
22~10 / 0.5~4
(AWG/mm2)
22~12 / 0.5~2.5
(AWG/mm2)
22~10 / 0.5~4
(AWG/mm2)
(AWG/mm2)
22~12 / 0.5~2.5
(AWG/mm2)
22~10 / 0.5~4
(AWG/mm2)
20~8 / 0.5~6
Rated impulse
withstand voltage
6kV
Rated impulse
withstand voltage
6kV
Rated impulse
withstand voltage
8kV
Torque (N•m)
0.4
Torque (N•m)
0.6
Torque (N•m)
1.2
3.5
10.6
Torque (lb-in)
5.3
Torque (lb-in)
Screw
M2.5
Screw
M3
Screw
9~11
W x H x D (mm)
1
2 3
4
5
6
7
6.1 x 39.6 x 40.3
W x H x D (mm)
M4
12~14
8 x 45 x 41.7
Cat. No
Colours
Cat. No
Colours
Cat. No
DS20-GY
Grey
DS30-GY
Grey
DS50-GY
Blue
DS20-BU
Blue
DS30-BU
Blue
DS50-BU
Black
DS20-LK
Black
DS30-LK
Black
DS50-LK
Red
DS20-RD
Red
DS30-RD
Red
DS50-RD
Yellow
DS20-YW
Yellow
DS30-YW
Yellow
DS50-YW
Orange
DS20-OR
Orange
DS30-OR
Orange
DS50-OR
Green
DS20-GN
Green
DS30-GN
Green
DS50-GN
Cat. No
Accessories
Cat. No
Accessories
Cat. No
Grey
DS20-GY-ND
Grey
DS20-GY-ND
Grey
DS50-GY-ND
Blue
DS20-BU-ND
Blue
DS20-BU-ND
Blue
DS50-BU-ND
Black
DS20-LK-ND
Black
DS20-LK-ND
Black
DS50-LK-ND
Red
DS20-RD-ND
Red
DS20-RD-ND
Red
DS20-RD-ND
Yellow
DS20-YW-ND
Yellow
DS20-YW-ND
Yellow
DS20-YW-ND
Orange
DS20-OR-ND
Orange
DS20-OR-ND
Orange
DS20-OR-ND
Green
DS20-GN-ND
Green
DS20-GN-ND
Green
DS20-GN-ND
DKNSPS-001
DKNSPS-002
2-pole
3-pole
4-pole
10-pole
DSS2-5N-02P
DSS2-5N-03P
DSS2-5N-04P
DSS2-5N-10P
2-pole
3-pole
4-pole
10-pole
DSS4N-02P
DSS4N-03P
DSS4N-04P
DSS4N-10P
2-pole
3-pole
4-pole
10-pole
DSS6N-02P
DSS6N-03P
DSS6N-04P
DSS6N-10P
2-pole
3-pole
4-pole
10-pole
CSC-2-502PN
CSC-2-503PN
CSC-2-504PN
CSC-2-510PN
2-pole
3-pole
4-pole
10-pole
CSC-402PN
CSC-403PN
CSC-404PN
CSC-410PN
2-pole
3-pole
4-pole
10-pole
CSC-602PN
CSC-603PN
CSC-604PN
CSC-610PN
TM26CB
TM27CB
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
Tool
8
Grey
DKNSPS-001
Mounting rail
5.1 x 39.6 x 40.5
9~11
Colours
Small partition
Top insertion bridge
Approval
IEC
Accessories
End cover
Approval
UL
W x H x D (mm)
Block
DS50
Technical Data
Torque (lb-in)
Marking label
DS30
TM28CB
DRL32MMG
DRL35MMHI
DRL35MML0
Mini Feed Through Blocks - DM Series
Bussmann
DM Series
DM20
The DM Series is our low cost,
miniature feed through terminal
block design for 15mm DIN-Rail.
Accessories include side insertion
bridge and marking labels.
Approval
Mounting Rail
1
2 3
4
5
6
7
Approval
IEC
Technical Data
UL
IEC
Technical Data
UL
IEC
Rated voltage
300V
500V
Rated voltage
300V
500V
Rated voltage
300V
500V
Rated current
20A
24A
Rated current
30A
32A
Rated current
50A
41A
20~8 / 0.5~6
22~12 / 0.5~2.5
(AWG/mm2)
22~10 / 0.5~4
(AWG/mm2)
(AWG/mm2)
22~12 / 0.5~2.5
(AWG/mm2)
22~10 / 0.5~4
(AWG/mm2)
20~8 / 0.5~6
Rated impulse
withstand voltage
5kV
Rated impulse
withstand voltage
5kV
Rated impulse
withstand voltage
6kV
Torque (N•m)
0.4
Torque (N•m)
0.6
Torque (N•m)
1.2
3.5
10.6
(AWG/mm2)
Torque (lb-in)
5.3
Torque (lb-in)
Screw
M2.5
Screw
M3
Screw
7~9
7~9
5.1 x 28 x 22
W x H x D (mm)
6.1 x 31.5 x 22
W x H x D (mm)
M4
9~11
8 x 37.4 x 30
Colours
Cat. No
Colours
Cat. No
Colours
Cat. No
Grey
DM20-GY
Grey
DM30-GY
Grey
DM50-GY
Blue
DM20-BU
Blue
DM30-BU
Blue
DM50-BU
Black
DM20-LK
Black
DM30-LK
Black
DM50-LK
Accessories
End Cover
Approval
UL
W x H x D (mm)
Block
DM50
Technical Data
Torque (lb-in)
Marking Label
DM30
Cat. No
Accessories
Cat. No
Accessories
Cat. No
Grey
DM20-GY-ND
Grey
DM30-GY-ND
Grey
DM50-GY-ND
Blue
DM20-BU-ND
Blue
DM30-BU-ND
Blue
DM50-BU-ND
Black
DM20-LK-ND
Black
DM30-LK-ND
Black
DM50-LK-ND
2-pole
3-pole
4-pole
10-pole
CSC-2-502PS
CSC-2-503PS
CSC-2-504PS
CSC-2-510PS
2-pole
3-pole
4-pole
10-pole
CSC-402PS
CSC-403PS
CSC-404PS
CSC-410PS
2-pole
3-pole
4-pole
10-pole
CSC-602PS
CSC-603PS
CSC-604PS
CSC-610PS
TM20CB
TM21CB
TM22CB
DRL15MM
DRL15MM
DRL15MM
9
Double Level Blocks
DDP Series
Disconnect Blocks
DIS Series
DDP30
The DDP30 is a two-tier feed
through terminal block for space
constrained applications with two
independent circuits (IEC 60947-7
and UL 1059 compliant). Marking
system, side insertion bridge and
top screw-on bridge are standard.
Approval
Technical Data
UL
IEC
Rated voltage
300V
400V
Rated current
30A
32A
(AWG/mm2)
6kV
Rated impulse
withstand voltage
6kV
Torque (N•m)
0.5
Torque (N•m)
0.8
* Not for use as a load break
disconnect.
4.4
M2.5
6
Cat. No
Grey
DDP30-GY
CSC-402P
CSC-403P
CSC-404P
CSC-410P
10
6
7
DS4-02P
DS4-03P
DS4-04P
DS4-10P
TM21CB
Mounting Rail
DRL32MMG
DRL35MMHI
DRL35MML0
Tool
0.4 x 2.5mm
7.1
Screw
M3
W x H x D (mm)
Block
Cat. No
DDP30-GY-ND
Torque (lb-in)
6.1 x 62.8 x 69.4
Colours
2-pole
3-pole
4-pole
10-pole
5
16A
Rated impulse
withstand voltage
Cat. No
Grey
DIS10-GY
Grey
Partition
Marking Label
9~10
5.1 x 46.7 x 59
Colours
Accessories
End Cover
Cat. No
DP25-GY-ND
DKSPS-002
2-pole
3-pole
4-pole
10-pole
4
800V
10A
26~14 / 0.5~2.5
2-pole
3-pole
4-pole
10-pole
2 3
300V
Rated current
(AWG/mm2)
Grey
1
Rated voltage
22~10 / 0.5~4
Accessories
Marking Label
IEC
(AWG/mm2)
W x H x D (mm)
Top Screw-on bridge
UL
26~14 / 0.5~2.5
Approval
Technical Data
22~10 / 0.5~4
Screw
End Cover
The DIS10 is a disconnect* terminal
block. Disconnect terminal blocks
offer easy circuit disconnection with
just a flick of a screwdriver. IEC
60947-7 and UL 1059 compliant.
(AWG/mm2)
Torque (lb-in)
Block
DIS10
1
2 3
4
Mounting Rail
Tool
5
6
7
CSC-2-502P
CSC-2-503P
CSC-2-504P
CSC-2-510P
TM26CB
DRL32MMG
DRL35MMHI
DRL35MML0
0.5 x 3mm
Grounding Blocks - DG Series
Bussmann
DG Series
DG25
The DG Series grounding DIN-Rail
Terminal blocks fit both standard
35mm DIN-Rail and 32mm G-Type
rails. Compliant with IEC 60947-7
and UL 1059 standards for
worldwide acceptance. These have
the same general shape as the DP
Series.
Approval
Technical Data
UL
IEC
Technical Data
UL
IEC
Rated voltage
600V
630V
Rated voltage
600V
630V
Rated voltage
600V
500V
24A
Rated current
32A
Rated current
(AWG/mm2)
26~12 / 0.5~2.5
(AWG/mm2)
(AWG/mm2)
26~12 / 0.5~2.5
Rated impulse
withstand voltage
Torque (N•m)
26~10 / 0.5~4
16~8 / 1.5~10
(AWG/mm2)
26~10 / 0.5~4
(AWG/mm2)
16~8 / 1.5~10
8kV
Rated impulse
withstand voltage
8kV
Rated impulse
withstand voltage
8kV
0.8
Torque (N•m)
0.8
Torque (N•m)
1.8
Torque (lb-in)
7.1
Torque (lb-in)
7.1
Torque (lb-in)
15.9
Screw
M3
Screw
M3
Screw
Yellow/Green
Accessories
Marking Label
Mounting Rail
Tool
5
6
7
57A
(AWG/mm2)
Colours
4
Approval
IEC
W x H x D (mm)
2 3
Approval
UL
Rated current
Block
DG60
Technical Data
1
DG35
10~14
5.7 x 46.4 x 56
Cat. No
DG25-YG
Cat. No
W x H x D (mm)
Colours
Yellow/Green
Accessories
12~16
6.6 x 46.4 x 56
Cat. No
DG35-YG
Cat. No
W x H x D (mm)
Colours
Yellow/Green
Accessories
M4
12~16
10.4 x 46.4 x 56
Cat. No
DG60-YG
Cat. No
TM26CB
TM27CB
TM28CB
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
0.5 x 3mm
0.5 x 3mm
0.8 x 4mm
11
DG100
DG150
Approval
Approval
UL
IEC
Technical Data
UL
IEC
Technical Data
UL
IEC
Rated voltage
600V
1000V
Rated voltage
600V
1000V
Rated voltage
600V
1000V
76A
Rated current
125A
Rated current
(AWG/mm2)
14~6 / 2.5~16
(AWG/mm2)
(AWG/mm2)
14~6 / 2.5~16
Rated impulse
withstand voltage
12~2 / 4~35
2 / 35
(AWG/mm2)
12~2 / 4~35
(AWG/mm2)
2~4/0 /35~95
8kV
Rated impulse
withstand voltage
8kV
Rated impulse
withstand voltage
8kV
Torque (N•m)
3.4
Torque (N•m)
5.6
Torque (N•m)
18
Torque (lb-in)
30.1
Torque (lb-in)
49.6
Torque (lb-in)
159.3
Screw
M5
Screw
M6
Screw
W x H x D (mm)
Colours
Accessories
Marking Label
Mounting Rail
Tool
12
4
5
6
7
14~18
12 x 62.4 x 56
Cat. No
Yellow/Green
2 3
232A
(AWG/mm2)
1
Approval
Technical Data
Rated current
Block
DG230
DG100-YG
Cat. No
W x H x D (mm)
Colours
Yellow/Green
Accessories
14~18
16 x 62.4 x 56
Cat. No
DG150-YG
Cat. No
W x H x D (mm)
Colours
Yellow/Green
Accessories
M8
20~25
25 x 82.93 x 80
Cat. No
DG230-YG
Cat. No
TM28CB
TM28CB
TM28CB
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
1 x 5.5mm
1 x 5.5mm
Fuse Holders Blocks
Bussmann
F520 Series
F520ST
Fuse terminal blocks protect your
sensors and relays. Available in lever
and screw-cap style, with and
without LED indication.
Uses standard Cooper Bussmann
5x20mm fuse links.
Approval
UL
IEC
Rated voltage
300V
300V
Rated current
6.3A
(AWG/mm2)
Mounting Rail
Tool
2 3
4
5
6
7
300V
300V
UL
IEC
(1)
Rated voltage
300V
300V
Rated current
16A(2)
30A(3)
16A(2)
30A(3)
24~12 / 0.5~4
(AWG/mm2)
22~10 / 0.5~4
(AWG/mm2)
24~12 / 0.5~4
(AWG/mm2)
24~12 / 0.5~4
(AWG/mm2)
22~10 / 0.5~4
Rated impulse
withstand voltage
6kV
Rated impulse
withstand voltage
6kV
Rated impulse
withstand voltage
6kV
Torque (N•m)
0.8
Torque (N•m)
0.8
Torque (N•m)
0.67
Torque (lb-in)
7.1
Torque (lb-in)
7.1
Torque (lb-in)
Screw
M3
Screw
M3
Screw
10~12
8 x 55.7 x 56
W x H x D (mm)
6.3A
Technical Data
(AWG/mm2)
10~12
8 x 55.7 x 56
5.9
M3.5
W x H x D (mm)
10~12
8 x 60.5 x 72.5
Colours
Cat. No
Colours
Cat. No
Colours
Cat. No
Grey
F520ST-GY
Grey
5V
F520STLED5-GY
Grey
F520DDST-GY
Grey
12V
F520STLED12-GY
Grey
24V
F520STLED24-GY
Grey
48V
F520STLED48-GY
Grey
110V
F520STLED110-GY
Grey
220V
F520STLED220-GY
Grey
300V
F520STLED300-GY
2-pole
3-pole
4-pole
10-pole
1
IEC
24~12 / 0.5~4
Grey End Cover
Rated voltage
UL
6.3A
Accessories
End Cover
6.3A
Approval
Technical Data
Rated current
W x H x D (mm)
Block
F520DDST
Approval
Technical Data
Marking Label
F520TLED
Cat. No
F520-GY-ND
CSC-602PN
CSC-603PN
CSC-604PN
CSC-610PN
Voltage
Accessories
Grey End Cover
2-pole
3-pole
4-pole
10-pole
Cat. No
F520-GY-ND
Accessories
Grey
Cat. No
F520DD-GY-ND
CSC-602PN
CSC-603PN
CSC-604PN
CSC-610PN
TM28CB
TM28CB
TM28CB
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
DRL32MMG
DRL35MMHI
DRL35MML0
0.5 x 3mm
0.5 x 3mm
0.5 x 3mm
1) UL 600V/5A
2) Upper Level
3) Lower Level
13
Fuse Holder Blocks - F520 Series
DDNS Series
F520TOP
Approval
Technical Data
UL
IEC
Rated voltage
600V
660V
Rated current
6.3A
The DDNS10 is an internally
jumpered terminal block. Internally
jumpered double-level terminal
blocks provide high-density power
distribution in 3-in/1-out or 2-in/2out or 1-in/3-out options with a
single block. Add top and side
insertion bridges to achieve any
connection topology. IEC 60947-7
2 3
4
5
6
7
Rated voltage
300V
630V
Rated current
10A
17.5A
22~14 / 0.5~1.5
(AWG/mm2)
22~14 / 0.5~1.5
Rated impulse
withstand voltage
8kV
Torque (N•m)
0.4
Rated impulse
withstand voltage
6kV
Torque (N•m)
1.8
Torque (lb-in)
Torque (lb-in)
15.9
Screw
Screw
M4
12~16
W x H x D (mm)
12 x 47.2 x 61.6
Colours
Cat. No
Grey
F520TOP-GY
Colors
Block
IEC
(AWG/mm2)
22~6 / 1.5~10
Grey
3.5
M2.5
6~7
5.1 x 46.8 x 58.9
Cat. No
DDNS10-GY
Accessories
Cat. No
Grey
End Cover
1
UL
(AWG/mm2)
Accessories
TM20CB
Mounting Rail
DRL32MMG
DRL35MMHI
DRL35MML0
Tool
0.6 x 3.5mm
Top Screw-on bridge
Marking Label
1
2 3
4
5
Mounting Rail
Tool
14
Approval
Technical Data
22~6 / 1.5~10
W x H x D (mm)
Marking Label
6.3A
DDNS10
(AWG/mm2)
Block
6
7
DDNS10-GY-ND
2-pole
3-pole
4-pole
10-pole
CSC-2-502P
CSC-2-503P
CSC-2-504P
CSC-2-510P
2-pole
3-pole
4-pole
10-pole
DS2-5-02P
DS2-5-03P
DS2-5-04P
DS2-5-10P
TM26CB
DRL32MMG
DRL35MMHI
DRL35MMLO
0.4 x 2.5mm
Test Blocks
Bussmann
DTST2 Series
DTST2
Approval
Test terminal blocks with convenient
test sockets, plugs, jumpers and
accessories to make your circuit
Technical Data
UL
IEC
Rated voltage
300/600V
660V
Rated current
48A/5A
41A
(AWG/mm2)
20~8 / 0.5~6
(AWG/mm2)
20~8 / 0.5~6
Rated impulse
withstand voltage
6kV
Torque (N•m)
2
Torque (lb-in)
17.7
Screw
M4
W x H x D (mm)
Colors
Grey
8
8 x 65.6 x 47.5
Cat. No
DTST2-GY
Accessories
Grey
Block
DKSPS-006
Partition
2-pole
3-pole
Jumper Slide
DS6A02
DS6A03
C002-0101-BK
C002-0101-RD
Test Plug
DS6S1-BK
DS6S1-OR
DS6S1-YW
DS6S1-RD
Screw
C002-0201
Connection Sleeve
C002-0301
Connection Socket
Top screw-on bridge
Marking Label
DTST-GY-ND
1
2 3
4
5
6
7
2-pole
3-pole
4-pole
10-pole
CSC-602P
CSC-603P
CSC-604P
CSC-610P
2-pole
3-pole
4-pole
10-pole
DS6-02P
DS6-03P
DS6-04P
DS6-10P
TM28CB
Mounting Rail
DRL32MMG
DRL35MMHI
DRL35MML0
Tool
0.6 x 3.5mm
15
Accessories
Top Screw-On Bridges
DS2-5-XXP
DS6-XXP
DS10-XXP
Use with
Use with
Poles (XX) 02,03,04,10
DP45
DTST2
Dimensions - mm
Dimensions - mm
Dimensions - mm
Dimensions - mm
DS16-XXP
DS35-XXP
Use with
DP25
DDNS10
Use with
DP100
DS4-XXP
DG25
Use with
Use with
DP35
DP150
Dimensions - mm
Dimensions - mm
16
DDP30
DP60
Accessories
Bussmann
End Brackets
BRKT-ND
Use with
BRKT-NDSCRW2
BRKT-NDSCRW
DRL35MMHI
DRL35MML0
Use with
DRL35MMHI
DRL35MML0
Torque (N•m)
Torque (lb-in)
Screw
Dimensions - mm
Use with
0.5
4.4
M3
DRL35MMHI
DRL35MML0
Torque (N•m)
Torque (lb-in)
Screw
BRKT-NDSCRW3
Dimensions - mm
Dimensions - mm
DKSPS-002
DKSPS-006
Use with
0.78
6.9
M3
DRL35MMHI
DRL35MML0
Torque (N•m)
Torque (lb-in)
Screw
1.8
15.9
M4
Dimensions - mm
Partition Plates
DKSPS-001
Use with
DP25
DP45
DP35
DP60
DKNSPS-001
Use with
DS20
Use with
DP25
DP45
DIS10
DKNSPS-002
DS30
Use with
DS50
DP35
DP60
Use with
DTST2
DKNSPS-003
Use with
DP100
DKNSPS-004
Use with
DP150
17
Accessories
Jumper Slides
DS6A02
Use with
Poles
DS6A03
DTST2
02
Dimensions - mm
Use with
DTST2
Poles
03
Dimensions - mm
DSS2-5N-XXP
DSS4N-XXP
DSS6N-XXP
Use with
Use with
Use with
DS20
DS30
DS50
Dimensions - mm
Dimensions - mm
Dimensions - mm
18
Accessories
Bussmann
CSC-2-5XXP
Use with
DP25
DDNS10
Poles (XX) 02, 03, 04, 10
DIS10
Use with
CSC-10XXP
CSC-6XXP
CSC-4XXP
DP35
DDP30
Use with
DTST2
DP45
Use with
DP60
Dimensions - mm
Dimensions - mm
Dimensions - mm
Dimensions - mm
CSC-16XXP
CSC-35XXP
CSC-95XXP
CSC-2-5XXPN
Use with
DP100
Use with
DP150
Use with
DP230
Use with
DS20
Dimensions - mm
Dimensions - mm
Dimensions - mm
Dimensions - mm
19
Accessories
CSC-4XXPN
Use with
DS30
CSC-6XXPN
Use with
DS50
CSC-2-5XXPS
Use with
DM20
CSC-4XXPS
Use with
DM30
Dimensions - mm
Dimensions - mm
Dimensions - mm
Dimensions - mm
CSC-6XXPS
Mounting Rails
Use with
DRL15MM*
(15MM DIN-Rail)
DRL32MMG*
(32MM Type G)
DRL35MML0*
DRL35MMHI*
(35MM DIN-Rail - Low-Profile)
(35MM DIN-Rail - High Profile)
DM50
Dimensions - mm
* Available in 1 Metre lengths only
Bussmann
MARKING SYSTEM
21
Marking System
DPLT-001SET
DPLT-SPLT
PLOTTER PEN
PLOTTER SET
SUPPORT PLATE
DPLT-PEN (Tip 0.25mm) / DPLT-PEN2 (Tip 0.35mm)
Description
Description
Description
• Pen is installed manually
• USB interface to PC
• 110-240Vac power suply
• WINDOWS® Operation system
Support plate adjustable to
accommodate various sizes of
marking labels. The support plate
is universal and suitable for
TM2xCB marking label series.
Disposable black ink pen.
System Kit Includes
• Plotter Pens
• Support Plate
• Software
• Plotter
• Power Supplies
• USB Cable
Single pen per pack.
Each plotter set includes one
support plate, additional plates are
available separately.
Marking Label Selection Chart
Part Number
22
Length (mm) Width (mm)
Line x Row
Number of
Tags
Applicable Block Part Numbers
TM20CB
5.8
5.1
20 x 10
200
F20T0P, DM20
TM21CB
5.8
6.1
20 x 10
200
DDP30, DM30
TM22CB
5.8
8
20 x 8
160
DM50
TM26CB
12
5.1
12 x 12
144
DS20, DP25, DG25, DDNS10, DIS10
TM27CB
12
6.1
12 x 10
120
DS30, DP35, DG35
TM28CB
12
8
12 x 7
84
DS50, DP45, DP60, DP100, DP150,
DP230, DG60, DG100, DG150, DG230,
F520ST, F520STLED, F520DDST, DTST2
Marking Label Ordering Method (typical)
Bussmann
Example: TM20CB-DH01, Horizontal Marking - L1, L2, L3, N, PE
TM20CB Series - mm
TM20CB
TM21CB
Part Numbers
Descriptions
Part Numbers
Descriptions
TM20CB
Marking label, blank
TM21CB
TM20CB-DH01
Marking label, horizontal (L1, L2, L3, N, PE repeated 40 times)
TM21CB-DH01
TM20CB-DH02
Marking label, horizontal (L1, L2, L3,N) repeated 40 times
TM21CB-DH02
TM20CB-FH01
Marking label, horizontal, 1 to 10, repeated in 20 lines
TM21CB-FH01
TM20CB-FH02
Marking label, horizontal, 11 to 20, repeated in 20 lines
TM21CB-FH02
TM20CB-FH03
Marking label, horizontal, 21 to 30, repeated in 20 lines
TM21CB-FH03
TM20CB-FH04
Marking label, horizontal, 31 to 40, repeated in 20 lines
TM21CB-FH04
TM20CB-FH05
Marking label, horizontal, 41 to 50, repeated in 20 lines
TM21CB-FH05
TM20CB-EH01
Marking label, horizontal, 1 to 50, repeated in 4 sets
TM21CB-EH01
TM20CB-EH02
Marking label, horizontal, 51 to 100, repeated in 4 sets
TM21CB-EH02
TM20CB-DV01
Marking label, vertical (L1, L2, L3, N, PE) repeated 40 times
TM21CB-DV01
TM20CB-DV02
Marking label, vertical, (L1, L2, L3, N) repeated 40 times
TM21CB-DV02
TM20CB-FV01
Marking label, vertical, 1 to 10, repeated in 20 lines
TM21CB-FV01
TM20CB-FV02
Marking label, vertical, 11 to 20, repeated in 20 lines
TM21CB-FV02
TM20CB-EV01
Marking label, vertical, 1 to 50, repeated in 4 sets
TM21CB-EV01
TM21CB Series - mm
23
TM22CB Series - mm
TM22CB
TM26CB
Part Numbers
Descriptions
Part Numbers
Descriptions
TM22CB
TM26CB
TM22CB-DH01
Marking label, horizontal (L1, L2, L3, N, PE repeated 30 times)
TM26CB-DH01
Marking label, horizontal (L1, L2, L3, N, PE) repeated 24 times
TM22CB-DH02
TM26CB-DH02
Marking label, horizontal (L1, L2, L3,N) repeated 36 times
TM22CB-FH01
Marking label, horizontal, 1 to 10, repeated in 16 lines
TM26CB-FH01
Marking label, horizontal, 1 to 10, repeated in 12 lines
TM22CB-FH02
Marking label, horizontal, 11 to 20, repeated in 16 lines
TM26CB-FH02
Marking label, horizontal, 11 to 20, repeated in 12 lines
TM22CB-FH03
Marking label, horizontal, 21 to 30, repeated in 16 lines
TM26CB-FH03
Marking label, horizontal, 21 to 30, repeated in 12 lines
TM22CB-FH04
Marking label, horizontal, 31 to 40, repeated in 16 lines
TM26CB-FH04
Marking label, horizontal, 31 to 40, repeated in 12 lines
TM22CB-FH05
Marking label, horizontal, 41 to 50, repeated in 16 lines
TM26CB-FH05
Marking label, horizontal, 41 to 50, repeated in 12 lines
TM22CB-EH01
Marking label, horizontal, 1 to 50, repeated in 3 sets
TM26CB-EH01
Marking label, horizontal, 1 to 50, repeated in 2 sets
TM22CB-EH02
Marking label, horizontal, 51 to 100, repeated in 3 sets
TM26CB-EH02
Marking label, horizontal, 51 to 100, repeated in 2 sets
TM22CB-DV01
Marking label, vertical (L1, L2, L3, N, PE) repeated 30 times
TM26CB-DV01
Marking label, vertical (L1, L2, L3, N, PE) repeated 24 times
TM22CB-DV02
TM26CB-DV02
Marking label, vertical, (L1, L2, L3, N) repeated 36 times
TM22CB-FV01
Marking label, vertical, 1 to 10, repeated in 16 lines
TM26CB-FV01
Marking label, vertical, 1 to 10, repeated in 12 lines
TM22CB-FV02
Marking label, vertical, 11 to 20, repeated in 16 lines
TM26CB-FV02
Marking label, vertical, 11 to 20, repeated in 12 lines
TM22CB-EV01
Marking label, vertical, 1 to 50, repeated in 3 sets
TM26CB-EV01
Marking label, vertical, 1 to 50, repeated in 2 sets
TM26CB Series - mm
24
Bussmann
TM27CB Series - mm
TM27CB
TM28CB
Part Numbers
Descriptions
Part Numbers
Descriptions
TM27CB
TM28CB
TM27CB-DH01
Marking label, horizontal (L1, L2, L3, N, PE repeated 24 times)
TM28CB-DH01
Marking label, horizontal (L1, L2, L3, N, PE) repeated 12 times
TM27CB-DH02
Marking label, horizontal (L1, L2, L3,N) repeated 24 times
TM28CB-DH02
Marking label, horizontal (L1, L2, L3,N) repeated 20 times
TM27CB-FH01
TM28CB-FH01
Marking label, horizontal, 1 to 10, repeated in 8 lines
TM27CB-FH02
TM28CB-FH02
Marking label, horizontal, 11 to 20, repeated in 8 lines
TM27CB-FH03
TM28CB-FH03
Marking label, horizontal, 21 to 30, repeated in 8 lines
TM27CB-FH04
TM28CB-FH04
Marking label, horizontal, 31 to 40, repeated in 8 lines
TM27CB-FH05
TM28CB-FH05
Marking label, horizontal, 41 to 50, repeated in 8 lines
TM27CB-EH01
TM28CB-EH01
Marking label, horizontal, 1 to 50, repeated in 1 set
TM27CB-EH02
TM28CB-EH02
Marking label, horizontal, 51 to 100, repeated in 1 set
TM27CB-DV01
TM28CB-DV01
Marking label, vertical (L1, L2, L3, N, PE) repeated 12 times
TM27CB-DV02
Marking label, vertical, (L1, L2, L3, N) repeated 24 times
TM28CB-DV02
Marking label, vertical, (L1, L2, L3, N) repeated 20 times
TM27CB-FV01
TM28CB-FV01
Marking label, vertical, 1 to 10, repeated in 8 lines
TM27CB-FV02
TM28CB-FV02
Marking label, vertical, 11 to 20, repeated in 8 lines
TM27CB-EV01
TM28CB-EV01
Marking label, vertical, 1 to 50, repeated in 1 set
TM28CB Series - mm
25
NH Bases
Modular fuse holders for
Class CC, 10x38 and
Class J fuse links for
remote PLC indication.
Also available in size
14x51 and 22x58mm.
Complete range of NH
Bases to be used with
400, 500 and 690V NH
gG and aM fuse links.
See page 27 - 31
See page 33
Compact Circuit Protectors (CCP)
Available as DIN-Rail
and/or screw mounting.
At 1/3 the space required
by a molded case circuit
breaker, the CCP saves
space in your panel. High
SCCR DIN-Rail mounted
electrical disconnect.
See page 32
Full range of SPDs for
Solar, IEC, UL high SCCR,
Wind and Low Voltage
AC/DC Power and Control
applications.
Industry’s only true, UL
1449 3rd Edition compliant
overvoltages protectors.
See page 34 - 35
26
Modular Fuse Holders - 10x38mm
Bussmann
CH Series
CHM
With a wide wire range and
industry leading ratings - up to
32A, 1000V, 200kA SCCR - the
new CH Series provide worldwide
acceptance and easy specification
- including the latest PV fuse
holder standard: IEC 60269-1, -2
and UL4248-18.
Use with midget, 10x38, PV or
Class CC fuse links. Also certified
to CCC standard (China
Compulsory Certificate).
CHPV
Approval
Approval
Technical Data
UL
IEC
Technical Data
Rated Voltage
600Vac
690Vac
Rated Voltage
Rated Current
30A
32A
Rated Current
Approval
UL
IEC
1000Vdc
30A
32A
Technical Data
UL
Rated Voltage
600Vac
Rated Current
30A
(mm2)
1 to 25
(mm2)
1 to 25
(mm2)
1 to 25
(mm2)
1 to 25
(mm2)
1 to 25
(mm2)
1 to 25
Torque (N•m)
See brochure MFBRO0312
CHCC
SCCR
W x H x D (mm)
Fuse
3.4
120kA
17.5 x 73.9 x 61.8
Torque (N•m)
SCCR
W x H x D (mm)
3.4
33kA
17.5 x 73.9 x 61.8
Midget
PV 10 x 38
10 x 38
10 x 38
Torque (N•m)
SCCR
W x H x D (mm)
3.4
200kA
17.5 x 73.9 x 61.8
Class CC
Multi-pole with
Indicator
1-pole
2-pole
3-pole
4-pole
CHM1DIU
CHM2DIU
CHM3DIU
CHM4DIU
1-pole
2-pole
3-pole
4-pole
CHPV1IU
CHPV2IU
N/A
N/A
1-pole
2-pole
3-pole
4-pole
CHCC1DIU
CHCC2DIU
CHCC3DIU
N/A
Multi-pole without
Indicator
1-pole
2-pole
3-pole
4-pole
CHM1DU
CHM2DU
CHM3DU
CHM4DU
1-pole
2-pole
3-pole
4-pole
CHPV1U
CHPV2U
N/A
N/A
1-pole
2-pole
3-pole
4-pole
CHCC1DU
CHCC2DU
CHCC3DU
N/A
With Neutral Pole
and Indicator
With Neutral Pole
and no Indicator
Neutral only
48Vdc/30A
Mounting Rail
1-pole + Neutral
3-pole + Neutral
CHM1DNIU
CHM3DNIU
1-pole + Neutral
3-pole + Neutral
N/A
N/A
2-pole
4-pole
N/A
N/A
1-pole + Neutral
3-pole + Neutral
CHM1DNU
CHM3DNU
1-pole + Neutral
3-pole + Neutral
N/A
N/A
1-pole + Neutral
3-pole + Neutral
N/A
N/A
1-pole
1-pole
N/A
N/A
1-pole
1-pole
1-pole
1-pole
CHM1DNXU
CHM1DI-48U
DRL35MMHI
DRL35MML0
DRL35MMHI
DRL35MML0
CHCC1DI-48U
N/A
DRL35MMHI
DRL35MML0
Tool
27
Comb-Bus Bar Specifications and Selection Guide
Specifications
Comb-Bus Bar
Easily distribute power in singlephase or three-phase configurations.
Flexible cut-to-length solutions
without compromising on the
product’s finger-safe features.
Can be used with the CHM and
CHCC Series.
• Agency Information: UL 508. File E195399
• Pitch: 17.8mm
• SCCR: 10kA (default)
100kA (with upstream Class J 200A fuses)
• Max Current: 100A (power feed from end)
200A (power feed from center)
• Max Voltage: 600Vac/dc (three phase)
1000Vdc/600Vac (single phase)
Selection Guide
Part Number
BB1P100M3
BB1P100M6
BB1P100M9
BB1P100M12
BB1P100M15
BB1P100M57
BB3P100M6
BB3P100M9
BB3P100M12
BB3P100M15
BB3P100M57
ECAP1P
ECAPMP
PWR35MM
FSCVR
PWR1PLP
PWR50MM
Description
Single-phase 1000Vdc busbar, 100A, 3 pins, assembled endcap
Single-phase 1000Vdc busbar, 100A, 6 pins, assembled endcap
Single-phase 1000Vdc busbar, 100A, 9 pins, assembled endcap
Single-phase 1000Vdc busbar, 100A, 12 pins, assembled endcap
Single-phase 1000Vdc busbar, 100A, 15 pins, assembled endcap
Single-phase 1000Vdc cuttable busbar, 100A, 57 pins, without endcap
Three-phase 600V busbar, 100A, 6 pins, assembled endcap
Three-phase 600V busbar, 100A, 9 pins, assembled endcap
Three-phase 600V busbar, 100A, 12 pins, assembled endcap
Three-phase 600V busbar, 100A, 15 pins, assembled endcap
Three-phase 600V cuttable busbar, 100A, 57 pins, without endcap
Single-phase busbar endcap
Three-phase busbar endcap
35mm2 feeder terminal for three-phase busbar (115A, 1000Vac/dc)
Spare contact safety protection covers
Single-phase low-profile feeder terminal (115A, 1000Vac/dc)
50mm2 direct feed terminal (1000Vac/dc)
Typical Installation Example
Power Feed Terminals
Comb-Bus Bar
28
Remote Fuse Monitoring Accessory
Bussmann
Specifications
CH-PLC
Make it Simple with Cooper
Bussmann resettable three-phase
remote fuse monitor that integrates
with a Programmable Logic
Controller (PLC) or other
monitoring and control equipment.
CHCC Series.
• Power Input: 24Vdc / 5mA
• Sensing Voltage: 600V/30mA
• Output Signals: Digital 0Vdc (Low), 24Vdc (High)
- 0Vdc Low – Fuse is good
- 24Vdc High – Fuse has opened
When the fuse opens, the output signal is sent high and will remain high until
the unit is reset
• Rated Impulse Voltage: 8kV
• Local Indication: Two distinct LEDs indicate unit power (green) and open fuse
(red). Upon the replacement of the fuse, the actuation of the reset switch will
reset the open fuse LED
• Flammability Rating: UL 94V0
Wiring:
• For power, signal and ground connections use 22-24AWG (0.25mm2) 300V
rated wire
Electromagnetic Compatibility (EMC) Testing:
• Electrostatic Discharge Immunity IEC 61000-4-2
• Electrical Fast Transient/Burst Immunity IEC 61000-4-4
• Surge Immunity IEC 61000-4-5
Packaging:
• The CH-PLC is packaged individually
• A single unit monitors up to three phases
• Package includes 0.11” (2.8mm) quick connects for power, signal and ground
connections
Minimum Circuit Voltage:
• Minimum circuit voltage required across the CH holder is 100Vac for the
remote indication device to operate
Installation Technique:
• Mounts on the left side of the fuse holder and mechanically interlocks with the
fuse holder switch handle with hardware provided
IP20 Rating: Yes
Environmental Data:
• Storage and Operating Temperature: -20°C to 75°C
Agency Information:
• UL 508
• cULus to CSA Standard 22.2 No.14
PLC Programming:
• The CH-PLC signal line is designed to provide a digital input to a PLC I/O card.
• Programmable Logic Control program must be written to properly interpret the
input signal to the PLC.
• The PLC program should check for consecutive high signals before taking
action on a critical process.
De-energise all circuits before installing or removing any CH-PLC devices and follow all prescribed safety procedures.
29
Modular Fuse Holders - 14x51mm
CH14B Series
CH14B
industry leading ratings - up to 50A,
1500Vdc, 200kA SCCR - the
CH14B Series provide worldwide
acceptance and easy specification.
CH14B-PV
Approval
Approval
Technical Data
IEC
UL
Technical Data
IEC
Rated Voltage
690Vac
750Vac
Rated Voltage
1500Vdc
Rated Current
50A
50A
Rated Current
32A
Use with 14x51mm cylindrical fuse
links, PVA14F photovoltaic fuse
links and FW ferrule fuse links.
(mm2)
See data sheet 720148
(mm2)
Torque (N•m)
SCCR
W x H x D (mm)
Fuse
1.5-35mm2
(mm2)
1.5-35mm2
1.5-25mm2
(mm2)
1.5-25mm2
3
Torque (N•m)
200kA
SCCR
26.5 x 110 x 76
C14G and C14M
W x H x D (mm)
Fuse
3
200kA
26.5 x 110 x 49.5
PV-A14F
FW ferrule
1-pole
2-pole
3-pole
4-pole
CH141BI
CH142BI
CH143BI
CH144BI
Multi-pole without
Indicator
Multi-pole without
Indicator
1-pole
2-pole
3-pole
4-pole
CH141B
CH142B
CH143B
CH144B
Mounting Rail
With Neutral Pole
and Indicator
1-pole + Neutral
3-pole + Neutral
CH141BNI
CH143BNI
1-pole + Neutral
3-pole + Neutral
CH141BN
CH143BN
Multi-pole with
Indicator
With Neutral Pole
and no Indicator
Neutral only
1-pole
CH141BNX
With Microswitch
fuse operation only
1-pole
3-pole
CH141BMS
CH143BMS
With Microswitch
pre-breaking/
fuse operation/presence
1-pole
3-pole
CH141BMS-F
CH143BMS-F
With Microswitch
and Neutral
4-pole
4-pole
CH143DNMS
CH14BNMS-F*
Mounting Rail
1-pole
2-pole
Tool
DRL35MMHI
DRL35MMLO
Tool
* pre-breaking/fuse operation/presence microswitch
30
CH141B-PV
CH142B-PV
DRL35MMHI
DRL35MMLO
Modular Fuse Holders - 22x58mm
Bussmann
CH22B Series
CH22B
125A, 750Vac, 200kA SCCR - the
CH22B Series provide worldwide
Approval
Use with 22x58mm cylindrical fuse
See data sheet 720150
Technical Data
IEC
UL
Rated Voltage
690Vac
750Vac
Rated Current
125A
100A
(mm2)
1.5-50mm2
(mm2)
1.5-35mm2
Torque (N•m)
SCCR
W x H x D (mm)
4
200kA
35 x 126.5 x 76
C22G and C22M
Fuse
FW ferrule
Multi-pole without
Indicator
With Neutral Pole
Neutral only
With Microswitch
(fuse operation)
Mounting Rail
1-pole
2-pole
3-pole
4-pole
1-pole + Neutral
3-pole + Neutral
CH221B
CH222B
CH223B
CH224B
CH221BN
CH223BN
1-pole
CH221BNX
1-pole + Neutral
3-pole + Neutral
CH221BMS
CH223BMS
DRL35MMHI
DRL35MMLO
Tool
31
Compact Circuit Protectors (CCP) Series
Specifications
CCP Series
The revolutionary Cooper
Bussmann CCP is 1/3 the
footprint of a molded base circuit
breaker. The level of protection
provided by the CCP is up to three
times the Short-Circuit Current
Rating (SCCR) at full voltage than
a molded case circuit breaker
while providing disconnecting
means.
• Box Lug and Spade Terminal suitable for line, load or accessory connection
• Box Lug Connection:
- 18-6 AWG (1 to 16mm2) single or dual rated, solid or stranded – 75°C or
higher - Cu only
- 4 AWG (25mm2) single – 75°C or higher - Cu only
• Spade Terminal Connection:
- Max. 30A suitable for use with #8-32 UNC (M4) screw
• Torque:
- 18-10 AWG 20 Lb-In (1-6mm2/3.4N•m)
- 8-4 AWG 35 Lb-In (10-25mm2/5.8N•m)
• Lockout/tagout: 4mm shank lock or standard pin-out devices
• 35mm DIN-Rail mount
• Dimensionally compliant to DIN 43880
• Local indication minimum operating voltage:
– 90Vac for AC version
– 12Vdc for DC version
See data sheet 1157
Agency Information
UL Class CC fuse version
• UL 98 Listed, File E302370, Guide WHTY
• cULus to CSA Standard 22.2 No. 4-04, File 302370, Guide WHTY7
• CE Compliant
UL Midget fuse version
• UL 508 Listed
• cULus Certified 22.2 No. 14-05
• CE Compliant
10x38 IEC Class aM and gG/gL fuse version
• IEC 60947-3 AC23A
• IEC 60947-3 DC23A
• CE Compliant
Shipping Weight
• 2.84 lbs (1.29kg) per carton
32
NH Bases
Bussmann
Specifications
Catalogue Symbol:
SD(size)-D, SD(size)-S: 1-pole
TD(size)-D, TD(size)-DI: 3-pole
Size 4: SD4-S and SD4-S1600
NH Bases
NH fuse bases with thermoplastic
bodies, DIN-Rail and/or screw
mounting (size 4 screw mounting
only).
Range of accessories available
including phase barriers, IP20
finger-safe protection kits and
neutral links. Microswitch also
available for remote signaling of
fuse link operation.
Technical Data:
Rated Voltage:
690Vac
Rated Current:
160 - 1600A
Rated for Fuse Links with Breaking Capacity: 120kA
Features
Complies with IEC 60269-1 and 2 fuse system A (NH base), manufacturers’
type test certificates of compliance available.
3-Pole integral NH00 base available with reduced width.
Clip-in phase barriers, terminal shrouds and fuse covers available.
Vibration tested to IEC 60068-2-6 for marine use.
Full range of accessories available.
See data sheet 720136
Agency Information
• IEC 60269-1 and 2
• VDE 0636-1 and 2
33
SPD Series
Surge Protection Made Simple™
High performance lightening and
surge protection products for all
photovoltaic, IEC, wind and power
applications.
Modular 35mm DIN-Rail design
with colour-coding and rejection
features makes it easy to identify,
install and maintain.
SPD PV
Patented, Fast-Acting and Safe
Surge Protection Solutions for
Global Photovoltaic Solutions
High Performance Lightning and
Surge Protection Products for all
IEC Applications
• Patented, fast-acting ShortCircuit Interrupting (SCI)
technology responds efficiently to
overvoltage conditions.
• Vibration and shock resistant
according to EN 60068-2
standards.
• Built-in overcurrent protection
elminates the need for any
additional fuse installation and
wiring.
• easyID™ Visual indication and
optional remote contact signaling
make status monitoring simple.
• Modular DIN-Rail design with
color-coding and rejection feature
makes it easy to identify, install
and maintain.
For further details see data
sheets:
- Class I
• Lightning Arrester One-Pole #
2148
- Class II
• Surge Arrester Two modules
# 2145
• Surge Arrester Three Modules
# 2055
34
SPD IEC
• High surge discharge capacity
due to heavy-duty zinc oxide
varistor and spark gap
technology.
• Wide range of IEC Class I and
Class II SPD covering all the
major markets around the world.
sheets:
- Class I:
• 2-Pole # 1163
• 3-Pole # 1164
• 4-Pole # 1165
- Class II:
• 1-Pole # 1166
• 2-Pole # 1167
• 3-Pole # 1168
• 4-Pole # 1169
SPD UL SCCR
Comprehensive High SCCR
North American UL 508A
Applications
• UL 1449 3rdEdition
Recognised SPD devices provide
optimum surge protection for the
United States and Canadian
panel markets.
color coding and rejection feature
and maintain.
standards to withstand harsh
environments.
• IP20 Finger-safe design
improves electrical safety.
sheets:
• 1-Pole # 2149
• 2-Pole # 2150
• 3-Pole # 2151
• 4-Pole # 2152
Bussmann
SPD Wind
Advanced, Easy-to-Use Surge &
Lightning Protection Products
for Wind Power Systems
varistor and spark-gap
technology.
standards.
sheets:
- Class I:
• 1-Pole # 2091
- Class II:
• 1-Pole # 2092
• 2-Pole # 2093
• 3-Pole # 2094
• 4-Pole # 2095
SPD Low Voltage AC/DC
Power & Control
Efficient and reliable Network
Protection for Low Voltage and
Telecommunication
Applications.
and maintain.
provided by combination of
spark-gap and heavy-duty zinc
oxide varistor.
standards.
• Energy coordination with other
Cooper Bussmann DIN-Rail surge
protective devices
sheets:
- Type 2:
• 1-Pole Power # 2056
- Type 3:
• 2-Pole Control # 2057
35
Customer Assistance
Customer Satisfaction Team
Online Resources
The Cooper Bussmann Customer Satisfaction Team is
available to answer questions regarding Cooper Bussmann
products.
Visit www.cooperbussmann.com for the following
resources:
Product cross reference
Product profiles
Online catalogues for the latest United States and
European catalogues
Europe calls can be made between:
Monday - Thursday
7.30 a.m. - 5.30 p.m. GMT
Friday
7.30 a.m. - 5.00 p.m. GMT
The Customer Service Satisfaction Team can be reached
via:
Phone: 00 44 (0) 1509 882 600
Fax: 00 44 (0) 1509 882 786
Email: bulesales@cooperindustries.com
C3 Cooper Customer Center
The Cooper C3 portal supports the following Cooper
Divisions: Cooper B-Line, Cooper Bussmann, Cooper
Crouse-Hinds, Cooper Lighting, Cooper Power Systems,
Cooper Safety, and Cooper Wiring Devices.
Get started today at WWW.COOPERC3.COM by clicking
Request User ID and Password.
Application Engineering
Application Engineering assistance is available to all
customers. The Application Engineering team is staffed by
university-qualified electrical engineers who are available
with technical and application support.
Monday - Thursday
8.30 a.m. - 4.30 p.m. GMT
Friday
8.30 a.m. - 4.00 p.m. GMT
Application Engineering can be reached via:
Phone: 00 44 (0) 1509 882 699
Fax: 00 44 (0) 1509 882 794
Email: buletechnical@cooperindustries.com
Easy to Navigate
Simple to Use
Real-Time Data
© 2012 Cooper Bussmann (UK) Ltd
Melton Road
Burton-on-the-Wolds, LE12 5TH, United Kingdom
P: 00 44 (0) 1509 882 600
Your authorised Cooper Bussmann Distributor is
Cooper Industries plc.
Unit F10, Maynooth Business Campus
Maynooth, Ireland
www.cooperindustries.com
PDF Only
