HCMP0704R1-1R0-R
HCMP0704R1-1R0-R
    EATON(伊顿)
    INDUCTOR 1UH 18A 2 PADS SMT
HCMP0704R1-1R0-R 数据手册
8 7 6 5 4 3 2 1 RECOMMENDED PCB LAYOUT F A 7.60 P-Rx XXX wly R 2 F 1 B 3.50 6.80 E E 3.10 2.35 C DCR test at point a DCR test at point b D SCHEMATIC D E F 1 D 2 C C c d Notes: 1. Parts shall be fully coated with gray epoxy, except the terminals. 2. Minimum value is defined for dimension E. However, two terminals can not exceed lines c and d individually and must stay in the terminal slot of bottom core surface. 3. All soldering surfaces to be coplanar within 0.10 millimeters. B 4. Tolerances are +/- 0.3 millimeters unless stated otherwise. B 5. Marking: Inkjet marking in black. P stands for HCMP (XXX) The 3 characters = Inductance in uH. R=decimal point. If no R is present third character = # of zeros. wly = (Date Code, w is bi-weekly letter code, l is manufacturing location code, y is the last number of year) R= (Revision Level) 6. Environmental compliance requirement (Refer Division files: F306B-003-03 & CBA309A-001): (a) RoHS, (b) REACH, (c) PFOS & PFOA, (d) Halogen free, Sb2O3 and Red Phosphorus . . MODEL VERSION MODEL SOURCE DATA -- -- THIS DRAWING IS AN UNCONTROLLED COPY IF PRINTED OR SENT ELECTRONICALLY, DO NOT SCALE DRAWING -- DIMENSIONS AND TOLERANCES IN C 8 7 6 5 2012 Eaton Corporation, All Rights Reserved. 4 ONE PLACE X.X TWO PLACE X.X X ALL ANGLES X.X = ±0.3 mm = ±0.13 mm = ± 0.5 ° SPECIAL CHARACTERISTIC SIGNIFICANT CHARACTERISTIC --/--/---- ENGINEER ACCORDANCE WITH ASME - Y14.5M-1994 NOTICE TO PERSONS RECEIVING THIS DOCUMENT AND/OR TECHNICAL INFORMATION MILLIMETERS TOLERANCES TO BE THIS DOCUMENT, INCLUDING THE DRAWING AND INFORMATION CONTIANED THEREON, IS CONFIDENTIAL AND IS THE EXCLUSIVE PROPERTY OF EATON CORPORATION AND IS MERELY ON LOAN AND SUBJECT TO RECALL BY EATON AT ANY TIME. BY TAKING POSSESSION OF THE DOCUMENT, THE RECIPIENT ACKNOWLEDGES AND AGREES THAT THIS DOCUMENT CANNOT BE USED IN ANY MANNER ADVERSE TO THE INTERESTS OF EATON AND THAT NO PORTION OF THIS DOCUMENT MAY BE COPIED OR OTHERWISE REPRODUCED WITHOUT THE PRIOR WRITTEN CONSENT OF EATON. IN THE CASE OF CONFLICTING CONTRACTUAL PROVISIONS, THIS NOTICE SHALL GOVERN THE STATUS OF THIS DOCUMENT. DATE PRODUCT MANAGER ACCORDANCE WITH ASME - Y14.100-2004 EATON CORPORATION - CONFIDENTIAL AND PROPRIETARY UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN A F309A-05 SLA3_EATON_ELX_METRIC _REV_A APPROVALS GENERAL DRAWING PRACTICES IN -- --/--/---- -- --/--/---- MATERIAL (0) (0) TITLE Molded Power Inductor, 2Pins, SMT SIZE FINISH A3 N/A SCALE: THIRD ANGLE PROJECTION 3 A QUALITY 2 DWG NO. 6:1 REV HCMP0704Rx-R A SHEET 1 1 OF 1 Tue Oct 01, 2013 4:0X PM GPK
HCMP0704R1-1R0-R 价格&库存
很抱歉,暂时无法提供与“HCMP0704R1-1R0-R”相匹配的价格&库存,您可以联系我们找货
