CH14-IP20
CH14-IP20
    EATON(伊顿)
    KIT IP20 CABLE TERM PROTECTOR
CH14-IP20 数据手册
Technical Data 10080 Effective September 2016 Supersedes April 2016 BUSSMANN SERIES Bussmann series 14 x 51 mm Modular fuse holders Product description Eaton’s Bussmann series 14 x 51 mm modular fuse holders are suitable for use with standard cylindrical fuse links and FW type ferrule fuse links. Their compact dimensions helps reduce space, allows for higher cable bending radius. Low watts loss and wide range of accessories make them ideally suited for most industrial applications. Standard features • Compact dimensions • Ventilation zones optimised for a better heat dissipation • Inbuilt padlcocking facility • IP20 degree of protection (see details page 3) • Photovoltaic version rated at 1500 V d.c. (IEC only) for use with gPV fuse links • Flexibility to mount on DIN-Rail and/or screw mounting • Toolless DIN-Rail mounting, improves ease of use and reduces installation time and costs. Technical Data 10080 Bussmann series 14 x 51 mm Modular fuse holders Effective September 2016 Catalogue symbol • Mounting 35 mm DIN-Rail or 2 x M4 panel mounting screws • CH14 (# of poles)DU: standard fuse holder • Self-extinguishable UL 94-V0 rated polyester material • CH141DNXU: neutral fuse holder • Storage & operating temperature range • CH14(# of poles)DNU: standard fuse holder and neutral CH14D range: • CH14(# of poles)DIU: fuse holder with neon indicator • Storage temperature -40ºC to +80ºC • CH14(# of poles)DNIU: fuse holder with neutral and neon indicator • Operating temperature -20ºC to +70ºC • CH14(# of poles)DMSU-F: fuse holder with microswitch (prebreaking/fuse operation) • CH14(# of poles)DNMSU-F: fuse holder with neutral and microswitch (pre-breaking/fuse operation) • CH141DI-48U: fuse holder with LED Indicator • CHPV14(# of poles)U: suitable for photovoltaic fuse links Compatible fuse links • C14G and C14M: 14 x 51 mm fuse links • PV-(amp rating)A14F: Photovoltaic gPV Fuse links • FW Ferrule fuse links Maximum continuous fuse current FWH-5A14F FWH-10A14F FWH-15A14F FWH-20A14F FWH-25A14F FWH-30A14F FWX-5A14F FWX-10A14F FWX-15A14F FWX-20A14F FWX-25A14F FWX-30A14F 5A 10 A 15 A 20 A 25 A 24 A 5A 10 A 15 A 20 A 25 A 30 A Catalogue number Maximum continuous fuse current FWP-5A14F FWP-10A14F FWP-15A14F FWP-20A14F FWP-25A14F FWP-30A14F FWP-32A14F FWP-40A14F FWP-50A14F 5A 10 A 15 A 20 A 25 A 30 A 32 A 40 A 49 A Technical data • Number of poles: 1 to 4 • Rated voltage IEC UL CH14DU 690 V a.c / 750 V d.c. 700 V a.c. CHPV14U 1500 V d.c. 1500 V d.c. • Rated current • IEC: 50 A (a.c. and d.c.) • UL: 50 A • Rated power acceptance: 5 W to IEC 60269-2 • Maximum power acceptance: 6.2 W • Protection index: IP20 • Rated impulse withstand voltage (Uimp): 6 kV • SCCR Rating: 120 kA ac, 10 kA dc for CHPV14U • Cable size: 1.5 - 50 mm2 • Torque settings: 2 • • -20oC to +90oC (indicating) • -20oC to +120oC (non indicating) RoHS compliant. Standards/Approvals • IEC 60269-1 and 60269-2 • UL listed: file numbers E14853 for general purpose only; E348242 for photovoltaic gPV CHPV14 modular fuse holders • CCC Packaging Table 1. FW Ferrule fuse links Catalogue number CHPV14 range - storage and operating temperature: • Recommended torque setting 3.5 N•m • Maximum torque setting: 3.5 N•m EATON www.eaton.com • 1-pole: 6 per pack / 2-pole: 3 per pack • 3-pole: 2 per pack / 4-pole: 1 per pack Bussmann series 14 x 51 mm Modular fuse holders Technical Data 10080 Effective September 2016 Table 2. Technical Data Old Catalogue number New Catalogue number Number of poles Description CH141DNXU 1 Neutral cylindrical fuse holder 1 2 3 4 1-pole cylindrical fuse holder 2-pole cylindrical fuse holder 3-pole cylindrical fuse holder 4-pole cylindrical fuse holder 1-pole + neutral cylindrical fuse holder 2-pole + neutral cylindrical fuse holder Neutral only CH141BNX Fuse holder only CH141B CH142B CH143B CH144B CH141DU CH142DU CH143DU CH144DU Fuse holder and neutral CH141BN CH141DNU 2 CH143BN CH143DNU 4 Fuse holder with neon indicator CH141BI CH141DIU 1 CH142BI CH142DIU 2 CH143BI CH143DIU 3 CH144BI CH144DIU 4 1-pole cylindrical fuse holder with neon indicator 2-pole cylindrical fuse holder with neon indicator 3-pole indicator fuse holder with neon indicator 4-pole indicator fuse holder with neon indicator Fuse holder with neon indicator and neutral CH141BNI CH141DNIU 2 CH143BNI CH143DNIU 4 1-pole + neutral cylindrical fuse holder with neon indicator 3-pole + neutral cylindrical fuse holder with neon indicator Fuse holder with microswitch CH141BMS & CH141BMS-F CH141DMSU-F 1 CH143BMS CH143BMS-F CH143DMSU-F 3 1-pole cylindrical fuse holder with microswitch for remote fuse indication operation 3-pole cylindrical fuse holder with microswitch for remote fuse indication operation Fuse holder with microswitch and neutral CH143BNMS-F CH143DNMSU-F 4 & CH143BNMS 3-pole + neutral cylindrical fuse holder with microswitch for remote fuse indication operation Fuse holder with LED Indicator N/A CHPV141DI-48U 1 1-pole cylindrical fuse holder with LED indicator Fuse holder for Photovoltaic applications CH141D-PV N/A CHPV141U CHPV141IU 1 1 N/A N/A CHPV142U CHPV142IU 2 2 1-pole cylindrical fuse holder 1-pole cylindrical fuse holder with neon indicator 2-pole cylindrical fuse holder 2-pole cylindrical fuse holder with neon indicator Table 3. Accessories Catalogue number Description Unit packing JV-L CH14-SPS CH14-TPS CH14-CTP Multi-pole connector kit. One kit will gang up to 4-poles together Microswitch to work on CH141D(I)U, 1 n/o + 1 n/c changeover type Microswitch to work on CH143D(I)U, 1 n/o + 1 n/c changeover type IP20 Protection accessory, provides IP20 protection to terminals with 10mm2 or less cable 12 3 3 12 EATON www.eaton.com 3 Technical Data 10080 Bussmann series 14 x 51 mm Modular fuse holders Effective September 2016 Dimensional data - mm Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Eaton.eu © 2016 Eaton All Rights Reserved Publication No. 10080 September 2016 Eaton is a registered trademark. All other trademarks are property of their respective owners.
CH14-IP20 价格&库存
很抱歉,暂时无法提供与“CH14-IP20”相匹配的价格&库存,您可以联系我们找货
