CH22-MS3
CH22-MS3
    EATON(伊顿)
    AUX SWITCH FOR CH223D
CH22-MS3 数据手册
Technical Data 10115 Effective September 2016 Supersedes April 2016 BUSSMANN SERIES Bussmann series 22 x 58 mm Modular fuse holders Product description Eaton’s Bussmann series 22 x 58 mm modular fuse holders are suitable for use with standard cylindrical fuse links and FW type ferrule fuse links. Their compact dimensions helps reduce space, allows for higher cable bending radius. Low watts loss and wide range of accessories make them ideally suited for most industrial applications. Standard features • Compact dimensions • Ventilation zones optimised for a better heat dissipation • Inbuilt padlocking facility • IP20 degree of protection (see page 2) • Flexiblity to mount on DIN Rail and/or screw mounting • Toolless DIN-Rail mounting, improves ease of use and reduces installation time and costs Technical Data 10115 Bussmann series 22 x 58 mm Modular fuse holders Effective September 2016 Catalogue Symbol Standards/Approvals • CH221DNXU: neutral fuse holder • IEC 60269-1 and 60269-2 • CH22(# of poles)DU: standard fuse holder • UL listed file number E14853 • CCC • CH22(# of poles)DIU: fuse holder with neon indicator • CH221(# of poles)DNU: standard fuse holder and neutral • CH221(# of poles)DNIU: standard fuse holder and neutral and neon indicator Packaging • CH221(# of poles)DMSU-F: fuse holder with microswitch (pre-breaking/fuse operation) • 1-pole: 6 per pack • 2-pole: 3 per pack • 3-pole: 2 per pack • 4-pole: 1 per pack • CH221(# of poles)DNMSU-F: fuse holder with neutral and microswitch (pre-breaking/fuse operation) • CH221DI-48U: fuse holder with LED indicator Table 2. Technical Data Compatible fuse links • C22G and C22M: 22 x 58 mm gG and gM fuse links • FWP-A22F, see maximum continuous fuse current below Table 1. FWP Ferrule fuse links Catalogue number Maximum continuous fuse current FWP-20A22F 20 A FWP-25A22F 25 A FWP-32A22F 32 A FWP-40A22F 38 A FWP-50A22F 44 A FWP-63A22F 55 A FWP-80A22F 73 A FWP-100A22F 86 A Technical data • Number of poles: 1 to 4 • Rated voltage • • IEC: CH22DU Series 690 V a.c. / 1000 V d.c. • UL: 700 V a.c. Rated current • IEC: CH22DU Series 125 A (a.c. and d.c.) • UL: 100 A (a.c.) • SCCR: 120 kA (a.c.) / 50 kA (d.c.) • Microswitch (IEC): 250 V a.c. / 5 A • Rated power acceptance: 9.5 W to IEC 60269-2 • Protection index: IP20 Finger-safe • Rated impulse withstand voltage (Uimp): 6 kV • Cable size (Copper only): 2.5 mm2 - 70 mm2 • Torque settings: • Recommended torque setting 4 N•m • Maximum torque setting: 5 N•m Old part number CH221BNX CH221B CH222B CH223B CH224B N/A CH222DIU 2 N/A CH223DIU 3 N/A CH224DIU 4 CH221BN CH223BN CH221DNU CH223DNU 2 4 1-pole + neutral fuse holder 3-pole + neutral fuse holder Fuse holder and neutral and neon indicator N/A CH221DNIU 2 N/A CH223DNIU 4 1-pole + neutral fuse holder + neon indicator 3-pole + neutral fuse holder + neon indicator Fuse holder with microswitch CH221BMS CH221DMSU-F 1 CH223BMS CH223DMSU-F 3 1-pole fuse holder with microswitch (pre-breaking/fuse operation) 3-pole fuse holder with microswitch (pre-breaking/fuse operation) Fuse holder with neutral and microswitch CH223BNMS CH223DNMSU-F 3 3-pole cylindrical fuse holder + neutral + microswitch (pre-breaking/ fuse operation) Fuse holder with LED Indicator N/A CH221DI-48U 1 1-pole fuse holder with LED Indicator Table 3. Accessories Part number Description Unit packing Multi-pole connector kit. One kit will gang up to 4-poles together IP20 protection accessory, provides IP20 protection to terminals with 10mm2 or less cable Microswitch to work on CH221D(I)U, 1 n/o + 1 n/c changeover type Microswitch to work on CH223D(I)U, 1 n/o + 1 n/c changeover type 12 CH22-CTP EATON www.eaton.com 1-pole fuse holder with neon indicator 2-pole fuse holder with neon indicator 3-pole fuse holder with neon indicator 4-pole fuse holder with neon indicator Fuse holder and neutral Storage & operating temperature range 2 1-pole fuse holder 2-pole fuse holder 3-pole fuse holder 4-pole fuse holder 1 • RoHS compliant. 1 2 3 4 CH221DU CH222DU CH223DU CH224DU CH221DIU Self-extinguishable UL 94-V0 rated polyester material Operating temperature -20ºC to +70ºC Neutral holder N/A • • 1 Fuse holder with neon indicator JV-L • CH221DNXU Fuse holder only Mounting: 35mm DIN-Rail or 2 x M4 Panel mounting screws Storage temperature -40ºC to +80ºC Number of poles Description Neutral only • • New part number CH22-SPS CH22-TPS 12 3 3 Technical Data 10115 Bussmann series 22 x 58 mm Modular fuse holders Effective September 2016 Dimensional data - mm Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Eaton.eu © 2016 Eaton All Rights Reserved Publication No. 10115 September 2016 Eaton is a registered trademark. All other trademarks are property of their respective owners.
CH22-MS3 价格&库存
很抱歉,暂时无法提供与“CH22-MS3”相匹配的价格&库存,您可以联系我们找货
