PHV1245-5R4176-2B
PHV1245-5R4176-2B
    EATON(伊顿)
    CAPACITOR DOUBLE LAYER TH
PHV1245-5R4176-2B 数据手册
PowerStor Supercapacitors Special Capabilities Brochure PowerStor Supercapacitors Configurable Packs and Modules PowerStor PowerStor Supercapacitors Supercapacitors PowerStor Supercapacitor Capabilities Special Capabilities Brochure Brochure Configured Modules Application: Flash Server Backup P/N: PHV1245-5R4356-1 Base Cell: HV1245-2R7356-R Configuration: 2 series x 2 parallel Electronics: Active Balancing Module Ratings: 5.4V / 35F / 50mΩ 510 J, 146W max. power Connector: Molex 50-57-9406 Mating Connectors: Molex 70018, 70543, 70545, 70553, 70555, 70107, 70541, 70551, 70634, 74099 Application: Flash Server Backup P/N: PHV1245-5R4176-2 Base Cell: HV1245-2R7356-R Configuration: 2 series Electronics: Passive Balancing, Temp. Sensor Module Ratings: 5.4V / 17F / 170mΩ 248J, 43W max. power Connector: Molex 51021-0600 Mating Connectors: Molex 53261, 53047, 53398, 53048 Application: Flash Server Backup P/N: PHV1325-13R5305-1 Base Cell: HV1325-2R7156-R Configuration: 5 series Electronics: Passive Balancing Module Ratings: 13.5V / 3.0F / 200mΩ 273J, 228W max. power Connector: Molex 50-57-9406 Mating Connectors: Molex 70018, 70543, 70545, 70553, 70555, 70107, 70541, 70551, 70634, 74099 2 www.eaton.com/elx PowerStor Supercapacitors Special Capabilities Brochure Application: RAID Controller Card P/N: PHV1245-13R5685-1 Base Cell: HV1245-2R7356-R Configuration: 5 series Electronics: Active Balancing uprocess with EEPROM Module Ratings: 13.5V / 6.8F / 210mΩ 620J, 217W max. power Connector: Molex 50-57-9406 Mating Connectors: Molex 70018, 70543, 70545, 70553, 70555, 70107, 70541, 70551, 70634, 74099 Application: UPS/Volt. Sag/SEMI F47 P/N: XV3560-259R2425-1 Base Cell: XV3560-2R7407-R Configuration: 96 cells in series Electronics: Passive Balancing Fuse Module Ratings: 259.2V / 4.17F / 310mΩ 14.5 Wh, 55.9 kW max. power Common Platform with 300, 400 or 600F cells Application: Motor Driver, Concentrating Solar P/N: XBM3585-15R0207-1 Base Cell: XB3585-2R5607-R Configuration: 2 parallel x 5 series Electronics: Active Balancing Module Ratings: 15V / 130F / 50mΩ 6.3 Wh, 1100W max. power www.eaton.com/elx 3 PowerStor Supercapacitors Special Capabilities Brochure Sales and Customer Service Americas Email: busselx@eaton.com Phone: 561-998-4100 Taiwan Email: elx.tw@eaton.com Phone:+886 2 66006688 ext. 2794 Europe, Middle East, Africa Email: elx.emea@eaton.com Phone: +34-93-736-2813 Japan Email: elx.jp@eaton.com Phone:+86 20 38391977 ext. 864 China Email: elx.cn@eaton.com Phone:+86 20 38391977 ext. 860 Korea Email: elx.kr@eaton.com Phone:+82 2 6380 4831 South East Asia Email: elx.sea@eaton.com  Phone:+65-6645 9816 Online Resources www.eaton.com/elx View or Download Datasheets: www.eaton.com/elx-datasheets Technical Support: CapacitorTech@eaton.com For additional details on custom configurations, submit specifications or request a quote email CapacitorTech@eaton.com Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/elx © 2015 Eaton All Rights Reserved Printed in USA Publication No. 10381 - BU-SB15169 January 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
PHV1245-5R4176-2B
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款高速光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,包括输入、输出和电源引脚。
4. 参数特性:工作电压范围为3V-15V,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号隔离,适用于高速数字信号传输。
6. 应用信息:常用于工业控制系统、医疗设备和通信设备中。
7. 封装信息:采用DIP-6封装。
PHV1245-5R4176-2B 价格&库存
很抱歉,暂时无法提供与“PHV1245-5R4176-2B”相匹配的价格&库存,您可以联系我们找货
