Technical Data ELX1044
Effective June 2021
PTSAHT0805
Automotive high temperature SMD PTC fuses
Applications
• Infotainment
• In-vehicle navigation
• Telematics
• Car lighting
• Power window and seat control
• Instrument clusters
• PCB trace protection
Environmental compliance
Product features
• AEC-Q200 qualified
HALOGEN
Pb HF
FREE
• Positive temperature coefficient (PTC)
• Surface mount resettable fuse
• Compact 0805 (2012 metric) footprint
• High temperature
• Voltage rating 16 V
• Current rating from 0.10 A
• Fast time-to-trip
Part number system/ordering:
PTSAHT080516V010
• PT= PTC resettable fuse
• S= Surface mount
• AHT= Automotive with high operating temperature
• 0805= Dimension code
• 16V= Maximum voltage
• 010= Ihold current rating (010= 0.10 A)
PTSAHT0805
Effective June 2021
Product specifications
Vmax1
lmax2
lhold3
ltrip4
Pd5
Time-to-trip
(maximum)
Resistance6
Part number
(Vdc)
(A)
(A)
(A)
typical
(W)
(A)
(seconds)
Initial (Ri)
minimum (Ω)
Post trip (R1)
maximum
(Ω)
Part
marking
PTSAHT080516V010
16
40
0.10
0.60
1.00
2.50
1.50
1.00
10.00
1
1.
2.
3.
4.
Vmax: Maximum continuous voltage the device can withstand without damage at rated current
Imax: Maximum fault current the device can withstand without damage at rated voltage
Ihold: Maximum current the device will pass without interruption at +23 °C still air
Itrip: Minimum current that will transition the device from low resistance to high resistance at
+23 °C still air
5. Pd: Power dissipated from the device when in tripped state at +23 °C still air
6. Ri: Minimum resistance of the device at +23 °C
R1: Maximum resistance of the device one hour after tripping at +23 °C
Dimensions–mm
Recommended pad layout
Part number
A typ
A max
B typ
B max
C typ
C max
D min
E min
F
G
H
PTSAHT080516V010
2.25
2.50
1.50
1.60
0.60
0.80
0.25
0.076
1.2
1.0
1.5
Thermal derating chart - Ihold (A)
Part number
PTSAHT080516V010
2
Maximum ambient temperature (°C)
-40
-20
40
50
60
70
85
125
0.150
0.130
0.115
0.100
0.090
0.084
0.078
0.072
0.063
0.040
www.eaton.com/electronics
PTSAHT0805
Effective June 2021
General specifications
Operating temperature: -40 °C to + 125 °C (with derating)
Storage temperature: -10 °C to + 40 °C
Storage relative humidity: ≤70%
Storage conditon: Keep away form corrosive atmosphere and sunlight
Passive aging: IEC60738-1 , +60 °C, 1000 hours, ≤20%
IEC60738-1 , +85 °C, 1000 hours, ≤20%
Humidity aging: +85 °C, 85% RH, 100 hours, ≤20%
Thermal shock: IEC60738-1, +85 °C/ -40 °C, 20 cycles, ≤50%
Trip cycle life: UL1434, Vmax, Imax, 100 cycles, no arcing or burning
Trip endurance: UL1434, Vmax, Itrip ≤ I ≤ Imax, 2 hours, no arcing or burning
MSL test: J-STD-020, MSL=1, pass and no visible damage
Packaging information
Supplied in tape and reel packaging, 4000 parts per 7.0” (178 mm) diameter reel (EIA-481 compliant)
A
E1
P2
P0
D0
T
B
B
F
E2
D1
W
B0
A
P1
K0
SECTION A-A
A0
SECTION B-B
W
F
E1
E2
8.00 ± 0.30
3.50 ± 0.10
1.75 ± 0.10
P0
P1
P2
D0
4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.10/-0
D1
A0
B0
K0
1.68 ± 0.10 2.44 ± 0.10 1.04 ± 0.10
T
0.22 ± 0.05
3
PTSAHT0805
Effective June 2021
Solder reflow profile
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“PTSAHT080516V010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.82520
- 10+1.78200
- 30+1.76040
- 国内价格 香港价格
- 1+3.533161+0.45704
- 5+2.948225+0.38137
- 10+2.7187210+0.35169
- 50+2.2526950+0.29140
- 100+2.07795100+0.26880
- 250+1.86854250+0.24171
- 500+1.72376500+0.22298
- 1000+1.589681000+0.20564
- 国内价格 香港价格
- 4000+1.411944000+0.18265
- 8000+1.300428000+0.16822
- 12000+1.2389512000+0.16027
- 20000+1.1652020000+0.15073
- 28000+1.1187828000+0.14472
- 40000+1.1144340000+0.14416
