RL0607-152-R
RL0607-152-R
    EATON(伊顿)
    Radial, Vertical Cylinder
    FIXED IND 1.5MH 166MA 7.2 OHM TH
RL0607-152-R 数据手册
Technical Data 10334 Effective October 2017 Supersedes October 2014 RL0607 Unshielded radial leaded drum core inductors Applications • LED Drivers and lighting • Utility meters • Appliances and white goods • Motor drives • Power supplies • General purpose filtering 2 , 5 8 1 0 Environmental data 1 a l i e a n v u d. HF a J Pb t e e t n v ple i e t c m e e e f f is d lac e d ry rep e u nto d n i t ve e n d o in n c e s til i D un omm or rec No . e bl • Product features • Unshielded, leaded drum core • Protective sleeving over winding • Inductance range from 6.8 μH to 1500 μH • Current range from 0.12 A to 2.23 A • • 5.7 mm OD x 7.3 mm through-hole package Ferrite core material • Storage temperature range (Component): -40 °C to +125 °C Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) HALOGEN FREE Technical Data 10334 RL0607 Unshielded radial leaded drum core inductors Effective October 2017 Product specifications Part Number4 OCL¹ (μH) ±10% Irms2 (A) Isat3 (A) DCR (Ω) @ +20 °C max. SRF (MHz) typ. RL0607-6R8-R 6.8 ± 20% 2.23 1.82 0.038 26 RL0607-100-R 10 1.82 1.51 0.058 21 RL0607-180-R 18 1.52 1.13 0.083 16 RL0607-330-R 33 1.08 0.840 0.171 11 RL0607-470-R 47 0.953 0.690 0.217 8 RL0607-820-R 82 0.686 0.530 0.426 6 RL0607-151-R 150 0.520 0.390 0.730 4 RL0607-221-R 220 0.423 0.320 1.10 3 RL0607-471-R 470 0.306 0.220 2.00 2 RL0607-821-R 820 0.219 0.170 4.13 RL0607-102-R 1000 0.205 0.150 RL0607-152-R 1500 0.166 0.120 18 0 2 , 4.76 7.20 2 . e bl 1 1 5 1 a l i e a n v u d. a J t e e t n v e i e l t p c m e e e f f is d lac e d ry rep e u nto d n i t ve e n d o in n c e s til i D un omm or rec No 1. Open Circuit Inductance (OCL) Test Parameters: 10 kHz, 0.1 Vrms, 0.0Adc, +25 °C 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 3. Isat: Peak current for approximately 5% rolloff at +25 °C 4. Part Number Definition: RL0607-yyy-R - RL0607 = Product code and size - yyy= Inductance value in μH, R = decimal point, if no R is present then third character = number of zeros. - “-R” suffix = RoHS compliant Dimensions - mm Top view Side view Part marking: 1xxx wly R 1 = RL0607 xxx = inductance in µH, R = decimal point; if there is no R, then third character = number of zeros wly = date code, R = revision level *Lead length is after the components are trimmed from the packaging tape roll. Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics Recommended pad layout Schematic Technical Data 10334 RL0607 Unshielded radial leaded drum core inductors Effective October 2017 Packaging information - mm 2 , 5 8 1 0 . e bl 1 a l i e a n v u d. a J t e e t n v e i e l t p c m e e e f f is d lac e % of OCL vsp % of I d y e e tor 120 r u n en d i t e n nv d 100 o n sc 80til i me i D un om or 60rec No Supplied on cut tape roll packaging, 800 parts per roll. Inductance characteristics % of OCL sat 40 20 0 0 20 40 60 80 100 120 140 160 180 200 % of Isat www.eaton.com/electronics 3 Technical Data 10334 RL0607 Unshielded radial leaded drum core inductors Effective October 2017 Wave solder profile tp Temperature Tp First Wave Second Wave Tsmax Tstyp Tsmin Preheat area Cool down area Time 2 , 5 8 1 0 . e bl 1 a l i e a n v u d. a J t e e t n v e i e l t p c m e e e f f is d lac e d ry rep e u nto d n i t ve e n d o in n c e s til i D un omm or rec No Reference EN 61760-1:2006 Profile Feature Preheat Temperature min. (Tsmin) Temperature typ. (Tstyp) Temperature max. (Tsmax) Time (Tsmin to Tsmax) (ts) ∆ preheat to max Temeperature Peak temperature (Tp) Time at peak temperature (t p) Ramp-down rate Time 25°C to 25°C Standard SnPb Solder Lead (Pb) Free Solder 100°C 120°C 130°C 70 seconds 100°C 120°C 130°C 70 seconds 150°C max. 235° C - 260° C 10 seconds max 5 seconds max each wave ~ 2 K/s min ~3.5 K/s typ ~5 K/s max 4 minutes 150°C max. 250° C - 260° C 10 seconds max 5 seconds max each wave ~ 2 K/s min ~3.5 K/s typ ~5 K/s max 4 minutes Manual solder 350°C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended. ∆ Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 10334 BU-SB14688 October 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
RL0607-152-R 价格&库存
很抱歉,暂时无法提供与“RL0607-152-R”相匹配的价格&库存,您可以联系我们找货
