Technical Data 10334
Effective October 2017
Supersedes October 2014
RL0607
Unshielded radial leaded drum core inductors
Applications
LED Drivers and lighting
Utility meters
Appliances and white goods
Motor drives
Power supplies
General purpose filtering
2
5
8
1
Environmental data
1
a
l
i
e
a
n
v
u d. HF a
J
Pb
t
e
e
t
n
v ple
i
e
t
c
m
e
e
e
f
f is d lac
e
d ry rep
e
u nto d
n
i
t ve
e
n
d
o in
n
c
e
s til
i
D un omm
or rec
No
e
bl
Product features
Unshielded, leaded drum core
Protective sleeving over winding
Inductance range from 6.8 μH to 1500 μH
Current range from 0.12 A to 2.23 A
5.7 mm OD x 7.3 mm through-hole
package
Ferrite core material
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
HALOGEN
FREE
RL0607
Product specifications
Part Number4
OCL¹
(μH) ±10%
Irms2
(A)
Isat3
(A)
DCR (Ω)
@ +20 °C max.
SRF
(MHz) typ.
RL0607-6R8-R
6.8 ± 20%
2.23
1.82
0.038
26
RL0607-100-R
10
1.82
1.51
0.058
21
RL0607-180-R
18
1.52
1.13
0.083
16
RL0607-330-R
33
1.08
0.840
0.171
11
RL0607-470-R
47
0.953
0.690
0.217
8
RL0607-820-R
82
0.686
0.530
0.426
6
RL0607-151-R
150
0.520
0.390
0.730
4
RL0607-221-R
220
0.423
0.320
1.10
3
RL0607-471-R
470
0.306
0.220
2.00
2
RL0607-821-R
820
0.219
0.170
4.13
RL0607-102-R
1000
0.205
0.150
RL0607-152-R
1500
0.166
0.120
18
4.76
7.20
2
e
bl
1
1
5
1
a
l
i
e
a
n
v
u d.
a
J
t
e
e
t
n
v
e
i
e
l
t
p
c
m
e
e
e
f
f is d lac
e
d ry rep
e
u nto d
n
i
t ve
e
n
d
o in
n
c
e
s til
i
D un omm
or rec
No
1. Open Circuit Inductance (OCL) Test Parameters: 10 kHz, 0.1 Vrms, 0.0Adc,
+25 °C
2. Irms: DC current for an approximate temperature rise of 40 °C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow, and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part not
exceed +125 °C under worst case operating conditions verified in the end
application.
3. Isat: Peak current for approximately 5% rolloff at +25 °C
4. Part Number Definition: RL0607-yyy-R
- RL0607 = Product code and size
- yyy= Inductance value in μH, R = decimal point,
if no R is present then third character = number of zeros.
- “-R” suffix = RoHS compliant
Dimensions - mm
Top view
Side view
Part marking: 1xxx
wly R
1 = RL0607
xxx = inductance in µH, R = decimal point; if there is no R, then third character = number of zeros
wly = date code, R = revision level
*Lead length is after the components are trimmed from the packaging tape roll.
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
Recommended pad layout
Schematic
RL0607
Packaging information - mm
2
5
8
1
e
bl
1
a
l
i
e
a
n
v
u d.
a
J
t
e
e
t
n
v
e
i
e
l
t
p
c
m
e
e
e
f
f is d lac
e
% of OCL vsp
% of I
d
y
e
e tor
120
r
u
n en
d
i
t
e
n nv
d
100
o
n
sc 80til i me
i
D un om
or 60rec
No
Supplied on cut tape roll packaging, 800 parts per roll.
Inductance characteristics
% of OCL
sat
40
60
80
100
120
140
160
180
200
% of Isat
3
RL0607
Wave solder profile
tp
Temperature
Tp
First Wave
Second Wave
Tsmax
Tstyp
Tsmin
Preheat area
Cool down area
Time
2
5
8
1
e
bl
1
a
l
i
e
a
n
v
u d.
a
J
t
e
e
t
n
v
e
i
e
l
t
p
c
m
e
e
e
f
f is d lac
e
d ry rep
e
u nto d
n
i
t ve
e
n
d
o in
n
c
e
s til
i
D un omm
or rec
No
Reference EN 61760-1:2006
Profile Feature
Preheat
Temperature min. (Tsmin)
Temperature typ. (Tstyp)
Temperature max. (Tsmax)
Time (Tsmin to Tsmax) (ts)
∆ preheat to max Temeperature
Peak temperature (Tp)
Time at peak temperature (t p)
Ramp-down rate
Time 25°C to 25°C
Standard SnPb Solder
Lead (Pb) Free Solder
100°C
120°C
130°C
70 seconds
100°C
120°C
130°C
70 seconds
150°C max.
235° C - 260° C
10 seconds max
5 seconds max each wave
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
4 minutes
150°C max.
250° C - 260° C
10 seconds max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
4 minutes
Manual solder
350°C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 10334 BU-SB14688
October 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“RL0607-180-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 800+3.48087800+0.45215
