RL0809-682-R
RL0809-682-R
    EATON(伊顿)
    Radial, Vertical Cylinder
    FIXED IND 6.8MH 123MA 17.3 OHM
RL0809-682-R 数据手册
Technical Data 10279 Effective October 2017 Supersedes June 2014 RL0809 Unshielded radial leaded drum core inductors Applications • LED Drivers and lighting • Utility meters • Appliance electronics • Motor drives • Power supplies • General purpose filtering 8 1 0 2 , 5 a l 1 i a e v n . a u d J t e n t e le Pb HF e v i t m p c e e e d ac f f s pl e i d ry re e o u d t n e n i t ve nd n o in e c l s ti mm i D un o or rec No . e bl Environmental data Product features • Unshielded, leaded drum core • Protective sleeving over winding • Inductance range from 10 μH to 33,000 μH • Current range from 0.042 A to 2.9 A • 7.9 mm OD x 9.0 mm through-hole package • Ferrite core material • Storage temperature range (Component): -40 °C to +125 °C • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) HALOGEN FREE Technical Data 10279 Effective October 2017 RL0809 Unshielded radial leaded drum core inductors Product specifications Part Number4 OCL¹ (μH) ±10% Irms2 (A) Isat3 (A) DCR (Ω) @ +20 °C max. SRF (MHz) typ. RL0809-100-R 9.65 2.90 2.47 0.031 18 RL0809-102-R 992 0.312 0.244 2.69 2 RL0809-152-R 1504 0.255 0.198 4.00 2 RL0809-182-R 1792 0.240 0.182 4.52 1 RL0809-222-R 2204 0.207 0.164 6.06 1 RL0809-332-R 3297 0.170 0.134 9.06 1 RL0809-682-R 6796 0.123 0.093 17.3 0.69 RL0809-822-R 8209 0.106 0.085 23.1 0.67 RL0809-103-R 10002 0.099 0.077 26.4 RL0809-123-R 12011 0.093 0.070 30.0 RL0809-223-R 21989 0.070 0.052 RL0809-333-R 32998 0.058 0.042 0 2 , 59.7 78.9 18 0.59 . e bl 0.52 0.39 0.31 5 a l 1 i a e v n . a u d J t e n t e le e v i t m p c e e e d ac f f s pl e i d ry re e o u d t n e n i t ve nd n o in e c l s ti mm i D un o or rec No 1. Open Circuit Inductance (OCL) Test Parameters: 10 kHz, 0.1 Vrms, 0.0 Adc, +25 °C 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. Dimensions - mm Do not route traces or vias underneath the inductor. 2 www.eaton.com/electronics 3. Isat: Peak current for approximately 5% rolloff at +25 °C 4. Part Number Definition: RL0809-yyy-R - RL0809 = Product code and size - yyy= Inductance value in μH, R = decimal point, if no R is present then third character = number of zeros. - “-R” suffix = RoHS compliant RL0809 Unshielded radial leaded drum core inductors Technical Data 10279 Effective October 2017 Packaging information - mm 8 1 0 2 , . e bl 5 a l 1 i a e v n . a u d J t e n t e le e v i t m p c e e e d ac f f s pl e i d ry re e o u d t n e n i t ve nd n o in e c l s ti mm i D un o or rec No Supplied on cut tape roll packaging, 800 parts per roll. Inductance characteristics % of OCL vs. % of Isat 120% 100% % of OCL 80% 60% 40% 20% 0% 0% 20% 40% 60% 80% 100% 120% 140% 160% 180% 200% % of Isat www.eaton.com/electronics 3 Technical Data 10279 Effective October 2017 RL0809 Unshielded radial leaded drum core inductors Wave solder profile tp Temperature Tp First Wave Second Wave Tsmax Tstyp Tsmin Preheat area Cool down area 8 1 0 2 , . e bl 5 a l 1 i a e v n . a u d J t e n t e le e v i t m p c e e e d ac f f s pl e i d ry re e o u d t n e n i t ve nd n o in e c l s ti mm i D un o or rec No Time Reference EN 61760-1:2006 Profile Feature Preheat Temperature min. (Tsmin) Temperature typ. (Tstyp) Temperature max. (Tsmax) Time (Tsmin to Tsmax) (ts) ∆ preheat to max Temeperature Peak temperature (Tp) Time at peak temperature (t p) Ramp-down rate Time 25°C to 25°C Standard SnPb Solder Lead (Pb) Free Solder 100°C 120°C 130°C 70 seconds 100°C 120°C 130°C 70 seconds 150°C max. 235° C - 260° C 10 seconds max 5 seconds max each wave ~ 2 K/s min ~3.5 K/s typ ~5 K/s max 4 minutes 150°C max. 250° C - 260° C 10 seconds max 5 seconds max each wave ~ 2 K/s min ~3.5 K/s typ ~5 K/s max 4 minutes Manual solder 350°C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended. ∆ Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/elx © 2017 Eaton All Rights Reserved Printed in USA Publication No. 10279 BU-SB14461 October 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
RL0809-682-R 价格&库存
很抱歉,暂时无法提供与“RL0809-682-R”相匹配的价格&库存,您可以联系我们找货
