BL12
BL12
    ATG
    TIP CONICAL,0.04687,BL60MP
BL12 数据手册
Product Information BL60MP Cordless Soldering Iron with Rechargeable Lithium-Ion Battery Solder on the go. Get a grip on this ergonomic cordless iron. Charged by lithium for endless soldering. Long-lasting battery ›› High performance lithium-ion battery stays on for 45 minutes or can provide up to 1,100 solder joints per charge ›› Averages 3 hours to recharge Ergonomic and safe ›› Round, co-molded handle designed for comfort ›› Convenient on/off switch ›› Easy tip change ›› Stable, heat-shielded base with built-in side tool stand Heating cycle ›› Reaches 536 °F / 280 °C, solder melting point, in 35 seconds (goes up to 950 °F / 510 °C) ›› Application flexibility LED illumination ›› Zero in on your solder joint with confidence with LED illumination on your application 7-year warranty*, an industry best! ›› Another reason to trust the Weller® brand! *7 year warranty does not cover battery Features and Benefits ›› ›› ›› ›› Long-lasting lithium ion battery charges quickly and lives on and on Comfortable co-molded handle and convenient on/off switch Heats up in 35 seconds Precise soldering with LED light Technical Data Dimensions of packaging (L x W x H) 11.61 x 5.31 x 4.53 in. 295 x 135 x 115 mm Dimensions of tool with tip 7.67 x 1.18 in.  /  195 x 30 mm  Power 12 W Weight 0.920 lbs / 0,417 kg Heat up time to solder melting point 35 seconds to 536 °F (280 °C) Temperature up to 950 °F / 510°C Voltage input at base charger 100–240 Vac, 50 / 60 Hz Voltage output 4.2 V 1000 mA Supplied tip BL10 Conical tip Application light One LED LED operating indicator Red = Power is on, Green = Ready to solder Duty Medium Industry Best Warranty 7 years (does not include battery) Product Information Applications ›› ›› ›› ›› ›› ›› ›› ›› Micro-components Electronic kits Low voltage wiring ● ›› ›› ›› ›› PCBs Radio-controlled Indoor lighting Hobby models Small appliance Small engine Repair Crafts Audio systems ◓ ›› ›› ›› ›› Electrical Marine Jewelry Automotive ◓ ● Recommended ◓ Acceptable ◓ *NOT RECOMMENDED FOR: heat sink, ground plane, metal art, plumbing Extra tips Additional tips available separately to expand your applications BL11 tip Rechargeable battery power supply 100–240 V, 50/60Hz Plug-in power supply to recharge your long life lithium-ion battery BL12 tip Safe base LED operating indicator Stable, heat-shielded base with built-in side tool stand Red = Power is on Green = Ready to solder Tip storage 3 convenient holes to store your tips Ergonomic BL10 tip Round, co-molded handle designed for comfort Convenient switch LED illumination Power on/off finger switch easy to operate Now you can see what you’re soldering BL60MP Kit Order no. Accessories Order no. BL60MP Cordless Soldering Iron BL60MP Conical tip 0.031 in / 0,8 mm BL10 Chisel tip 0.125 in / 3,1mm BL11 Conical tip 0.047 in / 1,2mm BL12 with rechargeable lithium-ion battery and BL10 conical tip 0.031 in / 0,8 mm www.weller-tools.com Weller® is a registered trademark of Apex Brands, Inc. | ATG-3416 Specifications subject to change without notice.
BL12
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出电路。
3. 引脚分配:共有6个引脚,分别为1脚发光二极管阳极,2脚发光二极管阴极,3脚光敏三极管集电极,4脚光敏三极管发射极,5脚光敏三极管基极,6脚光敏三极管集电极。
4. 参数特性:工作温度范围为-20℃至+85℃,输入电流为5mA,输出电流为10mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、仪器仪表等领域。
7. 封装信息:采用DIP6封装形式。
很抱歉,暂时无法提供与“BL12”相匹配的价格&库存,您可以联系我们找货
