KDS8051N
KDS8051N
    ATG
    GASKET FOR ADAPTER 5CC
KDS8051N 数据手册
CooperTools ® Kahnetics 005 56 753 00 / 03.02 WAL 5.0 CT01-9423 DISPENSING SYSTEMS Kahnetics® Table of Contents Contents Page No. Building a Dispensing System 2 Product Selection Guide 3 Dispensers - Shot Meters, and Accessories 4-6 Dispensers - Systems 7-9 Valves - Wands 10 - 11 Cartridge Dispensing Guns (Air Powered) and Accessories 12 - 13 Syringes 14 - 17 Syringe Adapters 16 - 17 Syringe Components 18 - 19 Tip Caps and Needle Scabbards 19 Needles 20 - 23 Flux Bottles, Finger Cots, Gloves, Misc. Accessories 24 - 25 Material Selection Chart 26 Kahnetics Numerical Index 27 Building a Dispensing System Needle Information Chart Stainless Steel, Anti-Static, Opaque Needles Blunt Tip, Plastic Threaded Hub, Disposable, Non-sterile Gauge I.D. 14 15 16 17 18 19 20 21 22 23 24 25 26 27 30 O.D. Hub Color Inch mm Inch mm 0.067 0.060 0.053 0.047 0.038 0.032 0.026 0.023 0.019 0.017 0.014 0.012 0.010 0.008 0.006 1.702 1.524 1.346 1.194 0.965 0.813 0.660 0.584 0.483 0.432 0.356 .0305 0.254 0.203 0.152 0.083 0.072 0.064 0.057 0.050 0.042 0.035 0.032 0.028 0.025 0.022 0.020 0.018 0.016 0.012 2.108 1.829 1.626 1.448 1.270 1.067 0.889 0.813 0.711 .0635 0.559 0.508 0.457 0.406 0.305 Dark Green Orange Purple White Pink Brown Yellow Green Black Light Blue Red Blue Tan Grey Lavender a a a a a a a a a a a a a a a Taper Tip Needles Teflon Needles Polyethylene Taper Tip Luer Lok; Overall Length = 1 1/4” (31.75mm) Polyethylene Taper Tip Luer Lok I.D. 2 I.D. Gauge Color Inch mm Gauge 14 16 18 20 22 24 Salmon Grey Green Pink Blue Red 0.063 0.048 0.034 0.024 0.017 0.013 1.600 1.219 .0864 0.610 0.432 0.330 15 18 20 22 23 26 30 Color Inch mm Orange Pink Yellow Black Light Blue Tan Lavender 0.059 0.042 0.034 0.028 0.026 0.018 0.012 1.499 1.067 .0864 0.711 0.660 0.457 0.305 SYSTEM800 SYSTEM500 SYSTEM300 SYSTEM240 SYSTEM230 SYSTEM225 SYSTEM100 KDS834AFS KDS834AD KDS834A KDS824AD KDS824A KDS808D KDS808 KDS806D(VD) KDS806(V) KDS2001HC Controller Handpiece X X X X X KDSDELUXEKIT X KDS807OP X KDS100CA X KDS100HCA X KDS100WCA Product Selection Guide X KDS2601HL X KDS760A X KDS805FS X KDS301 DISPENSING PRODUCTS 3 DISPENSERS KDS824A Deluxe Shot Meter • • • • • • • • • Controller KDS824A Input Voltage (Switchable) 115v 230v Output Voltage 24v 24v Air Input/Output 0-100 psi 0-6.9 Bar Vacuum 0-18” Hg -0.61 Bar Footprint 9.5”W x 7.75”D x 5”H 24.1cm x 19.7cm x 12.7cm Weight 7 lb, 7 oz 16.4 kg Timer Range .01 to 99.99 seconds Repeat Accuracy .5 ms (.0005 sec.) Recycle Time Setting Accuracy • • • • Digital timer control allows metered shot repeatability Shot time duration adjustable from 0.01 to 99.99 seconds Adjustable four position push button timer switch Vacuum feature prevents dripping Electrically actuated foot pedal Optional KDS805FS finger switch is available (see page 25) Accessory port for optional KDS301 vacuum pickup wand (see page 11) or for pressurizing an external cartridge or tank Two 0 - 100 PSI regulators and gauges with locking ring Benchtop unit for easy reading of dials and adjustment of air pressure and vacuum Low voltage unit for safety Slide switch easily changes unit from 115 to 230 volts Order syringe adapters, kits and other accessories separately KDS824AD includes KDSDELUXEKIT (see page 6) 12 ms (.012 sec.) ± 2% Cat No. UPC No. Order Number (Europe Only) Packed Description KDS824A 037103173720 005 31 636 99 Boxed Deluxe Shot Meter KDS824AD 037103173737 -- Boxed Deluxe Shot Meter w/Deluxe Starter Kit Pack Wt. lb g Pack Quantity 9.090 257.5 1 14.250 403.7 1 KDS834A Economy Shot Meter Controller KDS834A Input Voltage (Switchable) 115v 230v Output Voltage 24v 24v Air Input/Output 0-100 psi 0-6.9 Bar Vacuum 0-18” Hg -0.61 Bar Footprint 6.25”W x 7.75”D x 5”H 15.9cm x 19.7cm x 12.7cm Weight 5 lb, 10 oz 12.4 kg Timer Range .01 to 99.99 seconds Repeat Accuracy .5 ms (.0005 sec.) Recycle Time 12 ms (.012 sec.) ± 2% Setting Accuracy 4 Order Number (Europe Only) • • • • • • • • • • • • Digital timer control allows metered shot repeatability Shot time duration adjustable from 0.01 to 99.99 seconds Adjustable four position push button timer switch Vacuum feature prevents dripping Electrically actuated foot pedal Optional KDS805FS finger switch is available (see page 25) 0 - 100 PSI regulators and gauges with locking ring Benchtop unit for easy reading of dials an adjustment of air pressure and vacuum Low voltage unit for safety Slide switch easily changes unit from 115 to 230 volts Order syringe adapters, kits and other accessories separately KDS834AD includes KDSDELUXEKIT (see page 6) Cat No. UPC No. KDS834A 037103173744 005 31 656 99 Boxed Economy Shot Meter KDS834AD 037103173751 -- Boxed Economy Shot Meter w/Deluxe Starter Kit Packed Description Pack Wt. lb g Pack Quantity 8.140 230.6 1 12.800 362.6 1 DISPENSERS KDS808 Shot Meter with Vacuum • • • • • • • • • • • Basic low cost system Easy to set up and operate “Eyeball” accuracy Electrically actuated foot pedal Vacuum feature prevents dripping 0 - 100 PSI regulators and gauges with locking ring Benchtop unit for easy reading of dials an adjustment of air pressure and vacuum Low voltage unit for safety Slide switch easily changes unit from 115 to 230 volts Order syringe adapters, kits and other accessories separately KDS808D includes KDSDELUXEKIT (see page 6 for details) Controller KDS808 Input Voltage (Switchable) 115v Output Voltage 24v Air Input/Output 0-100 psi Vacuum 0-18” Hg Footprint 5”W x 7.75”D x 5”H Weight 5 lb, 1 oz Cat No. UPC No. Order Number (Europe Only) Packed Description KDS808 037103173706 005 31 616 99 Boxed Shot Meter w/Vacuum Only KDS808D 037103173713 -- Boxed Shot Meter w/Vacuum & Deluxe Starter Kit 230v 24v 0-6.9 Bar -0.61 Bar 12.7cm x 19.7cm x 12.7cm 11.1 kg Pack Wt. lb g Pack Quantity 7.340 207.9 1 12.060 341.7 1 KDS2001HC Shot Meter for CA Valves • Functions as a controller for high pressure cyanoacrylate valves • Adjustable four position push button timer switch • LED Indicator light • 0 - 100 PSI regulators and gauges with locking ring • Benchtop unit for easy reading of dials an adjustment of air pressure and vacuum • Low voltage unit for safety • Slide switch easily changes unit from 115 to 230 volts • Order syringe adapters, kits and other accessories separately Controller KDS2001HC Input Voltage (Switchable) 115v Output Voltage 24v 230v 24v Air Input/Output 0-100 psi 0-6.9 Bar Vacuum 0-18” Hg -0.61 Bar Footprint 8.5”W x 6.5”D x 3.625”H 21.6cm x 16.5cm x 9.2cm 8 lb, 1 oz 12.4 kg Weight Timer Range .01 to 99.99 seconds Repeat Accuracy .5 ms (.0005 sec.) Recycle Time 12 ms (.012 sec.) ± 2% Setting Accuracy Cat No. UPC No. Packed Description KDS2001HC 037103173645 Boxed Shot Meter for Cyanoacrylate Valves lb Pack Wt. g Pack Quantity 8.320 235.7 1 5 DISPENSERS KDS806(V) Foot Valve • • • • • • • • • • Controller Basic ON-OFF function “Eyeball” accuracy Foot actuated for excellent ergonomics Works on compressed air input only - no electricity required 0 - 100 PSI regulator and gauge Easy to set up and operate Sits on the floor, thus using no table space KDS806V includes drip-free vacuum accessory Order syringe adapters, kits and other accessories separately KDS806D and KDS806VD include KDSDELUXEKIT (see page 6 for details) KDS806/KDS806V Air Input/Output 0-100 psi Vacuum 0-18” Hg Footprint - KDS806 3.75”W x 7.25”D x 3.75”H Footprint - KDS806V 3.75”W x 8.5”D x 3.75”H Weight 3 lb, 5 oz 0-6.9 Bar -0.61 Bar 9.5cm x 18.4cm x 9.5cm 9.5cm x 21.6cm x 9.5cm 7.3 kg Cat No. UPC No. Packed Description lb Pack Wt. g Pack Quantity KDS806 037103173805 Boxed Foot Valve 4.513 127.9 1 KDS806D 037103173812 Boxed Foot Valve w/Deluxe Starter Kit 10.170 288.1 1 KDS806V 037103173836 Boxed Foot Valve w/Vacuum 4.715 133.6 1 KDS806VD 037103173843 Boxed Foot Valve w/Vacuum & Deluxe Starter Kit 9.890 280.2 1 Deluxe Kit for Shot Meters/Foot Valves (dispenser not included) • A starter-kit for users who do not know which size syringe will be used or when size requirements change. Kit is available separately or as an option with most shot meters Kit contents: • Four plastic adapter assemblies (3, 5, 10 & 30cc) • Samples of Luer Lok™ and tapered syringes • Syringe tip caps • Needle samples (non-sterile, blunt) in stainless, Teflon, and plastic tapered tip • Syringe stand • Material line filter • 2-oz. squeeze bottle • Industrial vinyl gloves 6 Cat No. UPC No. Packed Description KDSDELUXEKIT 037103174451 Boxed Deluxe Starter Kit for Shot Meters and Foot Valves lb Pack Wt. g Pack Quantity 3.472 98.4 1 DISPENSERS - SYSTEMS System100 Solder Mask System • For water soluble and peelable solder masks • For a any one-part flowable material (i.e. conformal coating, oil, etc.) • One-gallon capacity tank (three gallon tank available - see page 13) • Lightweight finger-actuated wand and pinch tube eliminate need for cleanup • Eliminates the “squeeze bottle application” method • One central tank can accommodate up to four users • Tank acts as a material storage vessel, no need to purge system after each use • Use with Weller® Spot Mask SM15748BK Cat No. UPC No. Packed Description SYSTEM100 037103174468 Boxed One Gallon Tank System w/4 Wands lb Pack Wt. g Pack Quantity 14.160 401.2 1 System 225 Manual Wand Cyanoacrylate System • • • • • Wand has a manual activation lever Wand gives you fine adjustment control over shot size Eliminates squeeze bottle Ergonomic design Accomodates standard 1 lb. cyanoacrylate bottles Cat No. UPC No. Packed Description SYSTEM225 037103174482 Boxed Manual Cyanoacrylate System lb Pack Wt. g Pack Quantity 6.165 174.7 1 System 230 Hand Held Cyanoacrylate System • • • • • • • Uses KDS2001HC valve controller (see page 5) Digital timer control allows metered shot repeatability Shot time duration adjustable from 0.01 to 99.99 seconds Adjustable four position push button timer switch Ergonomic hand held valve Electrically actuated foot pedal Accommodates standard 1 lb. (500g) bottles Cat No. UPC No. Packed Description SYSTEM230 037103174499 Boxed Hand Held Cyanoacrylate System lb Pack Wt. g Pack Quantity 16.6 470.40 1 7 - DISPENSERS SYSTEMS System 240 Fixtured Cyanoacrylate System • • • • • • • Uses KDS2001HC valve controller (see page 5) Digital timer control allows metered shot repeatability Shot time duration adjustable from 0.01 to 99.99 seconds Adjustable four position push button timer switch Mounted valve for hands-free dispensing Electrically actuated foot pedal Accommodates standard 1 lb. (500g) bottles Cat No. UPC No. Packed Description SYSTEM240 037103174512 Boxed Fixtured Cyanoacrylate System lb Pack Wt. g Pack Quantity 16.6 470.40 1 System 300 3 Gallon Tank with Shot Meter • • • • • • • • • Digital timer control allows metered shot repeatability Valve’s vacuum “suck-back” feature prevents dripping Use with low to medium viscosity, one-component materials Excellent for solder masks, UV materials (black hose available), oil, etc. Comes with three-gallon tank, one-gallon tank available (see page 14) Electrically actuated foot pedal Optional KDS805FS finger switch is available (see page 25) Can be modified to accommodate multiple valves One in-house airline pressurizes both valve and tank Cat No. UPC No. Packed Description SYSTEM300 037103174529 Boxed 3 Gallon Tank with Shot Meter lb Pack Wt. g Pack Quantity 20.250 573.7 1 System 500 SMT Rework System • Use to dispense solder paste during SMT rework operations • Pickup wand to move and locate SMT components • Excellent for solder pastes as well as any syringe loaded material • Consists of a KDS824A Deluxe Shot Meter (see page 4), KDS301 Vacuum Pickup Wand (see page 11) and Deluxe Starter Kit (see page 6) 8 Cat No. UPC No. Packed Description SYSTEM500 037103174574 Boxed Vacuum Pick-up System lb Pack Wt. g Pack Quantity 13.290 376.5 1 DISPENSERS - SYSTEMS System 800 Gunstand with Foot Valve • For use with high viscosity sealant, caulk, and adhesive • Air operated with manual “ON-OFF” control • Comes with 6 ounce cartridge retainer (2.5 and 12 oz. sizes available - see page 12) • For use with loadable, disposable cartridges • Foot actuated valve with pressure gauge • Minimal waste and cleanup Cat No. UPC No. Packed Description SYSTEM800 037103174581 Boxed Gunstand with KDS806 Foot Valve lb Pack Wt. g Pack Quantity 13.120 371.7 1 KDS100CA Fixtured Cyanoacrylate Valve • Mounted valve for hands-free dispensing • Foot actuated and metered for reproducible deposits Cat No. UPC No. Packed Description KDS100CA 037103174161 Bagged Fixtured Cyanoacrylate Valve lb Pack Wt. g Pack Quantity 0.531 15.0 1 KDS100HCA Hand Held Cyanoacrylate Valve • Excellent for low to medium viscosity materials such as cyanoacrylates. • Use with a shot meter for reproducible deposits Cat No. UPC No. Packed Description KDS100HCA 037103174185 Bagged Hand Held Cyanoacrylate Valve lb Pack Wt. g Pack Quantity 0.530 15.0 1 KDS100WCA Hand Held Dispensing Wand • Excellent for dispensing “difficult to dispense” materials such as cyanoacrylate • For use with low to medium viscosity materials • Lightweight, ergonomic design • Finger lever has adjustable sensitivity level control • Can be attached to any reservoir or cartridge system • Multiple wands can be connected to one central tanks with the use of a manifold Cat No. UPC No. Packed Description KDS100WCA 037103174208 Bagged Hand Held Dispensing Wand lb Pack Wt. g Pack Quantity 0.535 15.2 1 9 VALVES / WANDS KDS100F Spray Valve with Flat Nozzle • Used for conformal coatings, silicones, adhesives, epoxies, UV materials, urethanes, paint, oil, or any fluid up to 100,000 centipoise in viscosity • Valve has an adjustable flow control to reduce over-spray and reduce material waste • A flat spray cap provides a fan-shaped spray pattern • Valve can be connected to a bulk tank so you can save money by purchasing materials in bulk containers • Compact in design and lightweight (6 oz) makes this valve easy to control • All wetted seals are Viton or Teflon so corrosive materials will not cause thevalve to leak • Spray viscosity up to 100,000 CPS Cat No. UPC No. Packed Description KDS100F 037103174178 Bagged Sprat Valve with Flat Nozzle lb Pack Wt. g Pack Quantity 0.700 19.8 1 KDS100SS Stainless Steel Valve • High pressure, stainless steel pneumatically controlled needle valve • Use with silicone, adhesive, epoxy, UV material, RTV, grease, oil, or any fluid up to two million centipoise in viscosity • Beads and dots are applied using Kahnetics Luer Lok™ dispensing needles (see pages 20 - 23) • Adjustable flow control allows total control over dispense rates and volume • Air and fluid chambers are separated to prevent contamination of the air section • Compact in design and lightweight (6 oz.) Cat No. UPC No. Packed Description KDS100SS 037103174192 Bagged Stainless Steel High Pressure Valve lb Pack Wt. g Pack Quantity 0.698 19.8 1 KDS200SS High Volume Stainless Steel Valve • High pressure, stainless steel pneumatically controlled needle valve • Use with silicone, adhesive, epoxy, UV material, RTV, grease, oil, or any fluid up to two million centipoise in viscosity • The fluid inlet is three times larger than that of the KDS100SS, which makes it capable of dispensing large gaskets and beads with greater efficiency • The size of the bead can be altered by changing the size of the dispensing tip • Beads and dots are applied using Kahnetics Luer Lok™ dispensing needles (see pages 20 - 23) • Air and fluid chambers are separated to prevent contamination of the air section 10 Cat No. UPC No. Packed Description KDS200SS 037103174215 Bagged Stainless Steel Front Closing Valve lb Pack Wt. g Pack Quantity 1.652 46.8 1 VALVES / WANDS KDS2601HL Mask Dispensing Wand • Dispenses low to medium viscosity water soluble and peelable mask as well as other single component materials • Lightweight, low cost, ergonomic design replaces squeeze bottle • Can be used with any reservoir or cartridge system • Wands can be “ganged” together to run multiple operators from one tank Cat No. UPC No. Packed Description KDS2601HL 037103174246 Bagged Dispensing Wand with 5 ft. Material Hose lb Pack Wt. g Pack Quantity 0.236 6.7 1 KDS760A Suck-back Valve • Suck-back feature prevents dripping • Used with storage tanks, gun stands, and activated by any controller • Can be hand-held or fixtured depending on the application • Can be actuated with either the trigger or a foot switch • Use with either needles or plastic nozzles Cat No. UPC No. Packed Description KDS760A 037103174284 Bagged Suck-back Valve lb Pack Wt. g Pack Quantity 0.513 14.5 1 KDS301 Vacuum Pick-up Wand • Attaches to the air accessory port of either the KDS824A (page 4) or KDS2001HC (page 5) shot meters • A finger control on the wand allows you to easily pick up small components • Comes with three sizes of conductive suction cups Cat No. UPC No. Packed Description KDS301 037103174260 Bagged Vacuum Pick-up Wand lb Pack Wt. g Pack Quantity 0.223 6.3 1 11 CARTRIDGE DISPENSING Air Powered Dispensing Guns • Dispenses 600 gram solder paste cartridges (PG10260) • Used for dispensing solder paste, grease, oil, silicone, RTV, adhesive, ink, or any other medium to high viscosity liquid • Operates on a regulated air supply up to a maximum of 70 PSI • High impact Valox® gun body • Has a three foot air hose with 1/4” NPT fitting • Unique twist lock bayonet barrel mount • Patented trigger mechanism makes it easy to vary the amount of material being dispensed and reduces operator fatigue Cat No. UPC No. Packed Description lb Pack Wt. g Pack Quantity PG10225 037103173119 Bagged Pneumatic Aerospace Gun, 2.5 oz. 1.113 31.5 1 PG10260 037103173133 Bagged Pneumatic Aerospace Gun, 6 oz. 1.274 36.1 1 PG102120 037103173102 Bagged Pneumatic Aerospace Gun, 12 oz. 1.569 44.4 1 Accessories for Air Powered Dispensing Guns • Use the accessories to assemble a cartgidge dispensing system • Cartridges can be filled with your material and disposed after use • These accessories are also used with gunstands (see page 13) KDS432 KDS416 KDS8615 KDS2C KDS1P KDS60C KDS4P 102060 KDS216 KDS218 12 Cat No. UPC No. Packed Description Pack Wt. 102025 037103173454 Bagged Cartridge Retainer, 2.5 oz. 0.296 8.4 1 102060 037103173461 Bagged Cartridge Retainer, 6 oz. 0.460 13.0 1 102120 037103173478 Bagged Cartridge Retainer, 12 oz. 0.770 21.8 1 KDS25C 037103177681 Bagged Disposable Plastic Cartridge, 2.5 oz. 0.339 11.3 10 KDS60C 037103177711 Bagged Disposable Plastic Cartridge, 6 oz. 0.690 19.5 10 KDS120C 037103177629 Bagged Disposable Plastic Cartridge, 12 oz. 1.188 33.7 10 KDS2C 037103182500 Bagged Flange Cap for Disposable Plastic Cartridges 0.069 2.0 10 KDS4P 037103183163 Bagged Screw-on Plug for Disposable Plastic Cartridges 0.033 0.9 10 KDS1P 037103177643 Bagged Plunger for Disposable Plastic Cartridges 0.110 3.1 10 KDS1WP 037103177650 Bagged Wiper Plunger for Disposable Plastic Cartridges 0.104 2.9 10 KDS216 037103177667 Bagged Nozzle for Disposable Plastic Cartridges, 2”, 1/16” Orifice 0.070 2.0 10 KDS218 037103177674 Bagged Nozzle for Disposable Plastic Cartridges, 2”, 1/8” Orifice 0.066 1.9 10 KDS416 037103177698 Bagged Nozzle for Disposable Plastic Cartridges, 3 1/2”, 1/16” Orifice 0.090 2.5 10 KDS432 037103177704 Bagged Nozzle for Disposable Plastic Cartridges, 3 1/2”, 3/32” Orifice 0.090 2.5 10 KDS8615 037103177728 Bagged Nozzle for Disposable Plastic Cartridges, 4” Flat, 1/16” Orifice 0.150 4.2 10 lb g Pack Quantity CARTRIDGE DISPENSING Stainless Steel Tanks • • • • • Offered in 1 and 3 gallon capacity Pressure rated at 100PSI Material manifold available for up to four operators Built-in regulator and gauge Self-leveling, single component materials may be poured directly into tank KDS2501P Cat No. UPC No. Packed Description lb Pack Wt. g Pack Quantity KDS2501P 037103174314 Boxed 1 Gallon Stainless Steel Tank 11.470 324.9 1 KDS2503 037103174321 Boxed 3 Gallon Stainless Steel Tank 8.500 240.8 1 Reservoirs To Hold Materials in Bottles • Plexiglas reservoir with aluminum protective shield allows you to dispense directly from the material bottle in a pressurized environment • Accommodates one or two operators • For low to medium viscosity materials • Accommodates 1 lb. bottle Cat No. UPC No. Packed Description KDS260035PS 037103174413 Boxed Plexiglas Tank with Shield lb Pack Wt. g Pack Quantity 6.165 174.7 1 Gunstands • Dispenses materials from disposable 2.5oz., 6oz., or 12 oz. plastic cartridges (see page 12) • Used for dispensing solder paste, grease, oil, silicone, RTV, adhesive, ink, or any other medium to high viscosity liquid • Operates on a regulated air supply up to a maximum of 70 PSI (100 PSI for KDS8070) • Available with aluminum (KDS8070) or plastic (KDS807OP) head • Cartridges are easy to fill and replace • Can be used with pre-filled, store bought 300ml caulking cartridges • Can have a needle or nozzle at cartridge end Cat No. UPC No. Packed Description lb Pack Wt. g Pack Quantity KDS8070 037103174611 Boxed Gunstand with Metal Head Assembly 5.780 163.7 1 KDS807OP 037103174642 Boxed Gunstand with Plastic Head Assembly 5.760 163.2 1 13 SYRINGES Air-operated Syringes • • • • • A10LLPS Industrial syringes for micro-air dispensing Available in Luer Lok™ and tapered tip styles Unassembled and non-calibrated Available with rubber or plastic stoppers Includes barrel and stopper Cat No. UPC No. Packed Size Stopper lb Pack Wt. g Pack Quantity A3LL 037103176950 Bagged 3CC Rubber A3LLPS 037103176967 Bagged 3CC Plastic Luer Lok™ 0.144 4.1 20 Luer Lok™ 0.117 3.3 20 A5LL 037103176974 Bagged 5CC A5LLPS 037103178268 Bagged 5CC Rubber Luer Lok™ 0.206 5.8 20 Plastic Luer Lok™ 0.156 4.4 20 A6T 037103177537 Bagged 6CC Rubber Tapered 0.221 6.3 20 A10LL 037103178244 Bagged 10CC Rubber Luer Lok™ 0.232 6.6 15 A10LLPS 037103176912 Bagged 10CC Plastic Luer Lok™ 0.181 5.1 15 A30LL 037103176936 Bagged 30CC Rubber Luer Lok™ 0.370 10.5 10 A30LLPS 037103176943 Bagged 30CC Plastic Luer Lok™ 0.268 7.6 10 A30T 037103177490 Bagged 30CC Rubber Tapered 0.334 9.5 10 Tip Air-operated Black UV Protected Syringes • Opaque black to protect light sensitive materials • Unassembled and non-calibrated • Includes barrel and stopper A10LLUV 14 Cat No. UPC No. Packed Size Stopper lb Pack Wt. g Pack Quantity A3LLUV 037103177506 Bagged 3CC Rubber A5LLUV 037103177520 Bagged 5CC Rubber Luer Lok™ 0.172 4.9 20 Luer Lok™ 0.206 5.8 20 A10LLUV 037103176929 Bagged 10CC A30LLUV 037103182494 Bagged 30CC Rubber Luer Lok™ 0.267 7.6 15 Rubber Luer Lok™ 0.373 10.6 10 Tip SYRINGES Manual Unassembled Syringes • Includes barrel, rubber stopper, and plunger rod • Available in Luer Lok™ and tapered tip styles • Unassembled and non-calibrated Plunger Rod Stopper Barrel M10LL Cat No. UPC No. Packed Size Stopper Pack Wt. M1L 037103177032 Bagged 1CC Rubber Luer Slip™ 0.125 3.5 20 M3LL 037103177117 Bagged 3CC Rubber Luer Lok™ 0.500 14.2 20 M3LL100 037103177124 Bagged 3CC Rubber Luer Lok™ 0.843 23.9 100 M5LL 037103177223 Bagged 5CC Rubber Luer Lok™ 0.280 7.9 20 M6T 037103177612 Bagged 6CC Rubber Tapered 0.307 8.7 20 M10LL 037103176981 Bagged 10CC Rubber Luer Lok™ 0.317 9.0 15 M30LL 037103177087 Bagged 30CC Rubber Luer Lok™ 0.554 15.7 10 M30T 037103177575 Bagged 30CC Rubber Tapered 0.547 15.5 10 M50LL 037103177179 Bagged 50CC Rubber Tapered 0.459 13.0 5 Tip lb g Pack Quantity Manual Assembled Calibrated Syringes • Includes graduated barrel, rubber stopper, plunger rod, and tip cap • Available in Luer Lok™ and tapered tip styles (50cc only) M10LLASSM Cat No. UPC No. Packed Size Stopper lb Pack Wt. g Pack Quantity M1LASSM 037103177049 Bagged 1CC Rubber Luer Slip™ 0.152 4.3 20 M1BA 037103177056 Boxed 1CC M3LLASSM 037103177131 Bagged 3CC Rubber Luer Slip™ 16.000 453.3 3000 Rubber Luer Lok™ 0.179 5.1 20 M3LLASSM100 037103177148 Bagged 3CC Rubber Luer Lok™ 0.759 21.5 100 M3LLBA 037103177155 Boxed 3CC Rubber Luer Lok™ 13.700 388.1 1600 M5LLASSM 037103177230 Bagged 5CC Rubber Luer Lok™ 0.261 7.4 20 M5LLASSM100 037103177247 Bagged 5CC Rubber Luer Lok™ 1.192 33.8 100 M5LLBA 037103177254 Boxed 5CC Rubber Luer Lok™ 18.360 520.1 1400 M10LLASSM 037103176998 Bagged 10CC Rubber Luer Lok™ 0.294 8.3 15 M10LLASSM100 037103177001 Bagged 10CC Rubber Luer Lok™ 1.860 52.7 100 M10LLBA 037103177025 Boxed 10CC Rubber Luer Lok™ 16.650 471.7 850 M20LLASSM 037103177063 Bagged 20CC Rubber Luer Lok™ 0.358 10.1 10 M20LLBA 037103177070 Boxed 20CC Rubber Luer Lok™ 11.890 336.8 325 M30LLASSM 037103177094 Bagged 30CC Rubber Luer Lok™ 0.452 12.8 10 M30LLBA 037103177100 Boxed 30CC Rubber Luer Lok™ 11.160 316.2 225 M50LLASSM 037103178251 Bagged 50CC Rubber Luer Lok™ 0.412 11.7 5 M50LLBA 037103177193 Boxed 50CC Rubber Luer Lok™ 11.000 311.6 125 M50TASSM 037103177209 Bagged 50CC Rubber Tapered 0.419 11.9 5 M50TBA 037103177216 Boxed 50CC Rubber Tapered 11.140 315.6 125 Tip 15 SYRINGES & ADAPTERS Manual Black Syringes - UV Protected Plunger Rod Stopper • Opaque black to protect light sensitive materials • Includes barrel, rubber stopper, and plunge rod • Unassembled and non-calibrated Barrel M10LLUV Cat No. UPC No. Packed Size Pack Wt. M3LLUV 037103177605 Bagged 3CC Rubber Luer Lok™ 0.213 6.0 20 M10LLUV 037103177551 Bagged 10CC Rubber Luer Lok™ 0.420 11.9 15 M30LLUV 037103177568 Bagged 30CC Rubber Luer Lok™ 0.555 15.7 10 Stopper Tip lb g Pack Quantity Universal Syringe Adapters • Unique design works with all manufacturer’s syringes • Compatible with Luer Lok™, Luer Slip™, and tapered tip air operated syringes (see pages 14 & 15) • 360° swivel on adapter head for ease of motion • Use with single component, two part, self-leveling, and nonself-leveling materials • Unique design works with all manufacturer’s syringes • Compatible with Luer Lok™, Luer Slip™, and tapered tip air operated syringes (see pages 14 & 15) • 360° swivel on adapter head for ease of motion • Use with single component, two part, self-leveling, and nonself-leveling materials Metal Adapters Assemblies • Metal syringe adapter with 6’ air line and fitting • Plugs directly into any Kahnetics shot meter KDS830S6 Cat No. UPC No. Packed Size Airline Diameter Inch mm lb KDS801S6 037103173867 Bagged 1CC 3/32 KDS803S6 037103173928 Bagged 3CC KDS805S6 037103173966 Bagged 5CC KDS810S6 037103174017 Bagged KDS830S6 037103174048 Bagged Pack Wt. g Pack Quantity 2.4 0.109 3.1 1 3/32 2.4 0.112 3.2 1 3/32 2.4 0.143 4.1 1 10CC 3/32 2.4 0.152 4.3 1 30CC 3/32 2.4 0.216 6.1 1 g Pack Quantity Metal Adapter Heads • Syringe adapter head only - no air line KDS830S 16 Cat No. UPC No. Packed Size Pack Wt. KDS801 037103173850 Bagged 1CC Accomodates 1/4" Airline 0.063 1.8 1 KDS803 037103173874 Bagged 2.5/3CC Accomodates 1/4" Airline 0.062 1.8 1 KDS803S 037103173911 Bagged 3CC Accomodates 3/32" Airline 0.067 1.9 1 KDS805S 037103173959 Bagged 5CC Accomodates 3/32" Airline 0.095 2.7 1 KDS810S 037103174000 Bagged 10CC Accomodates 3/32" Airline 0.112 3.2 1 KDS830S 037103174031 Bagged 30CC Accomodates 3/32" Airline 0.165 4.7 1 lb SYRINGES Plastic Adapters Assemblies • Plastic syringe adapter with 6’ air line and fitting • Plugs directly into any Kahnetics shot meter KDS503S6 Cat No. UPC No. Packed Size Airline Diameter Inch mm lb KDS501S6 037103174086 Bagged 1CC 3/32 KDS503S6 037103174093 Bagged 3CC KDS505S6 037103174109 Bagged 5CC KDS510S6 037103174130 Bagged KDS530S6 037103174154 Bagged Pack Wt. g Pack Quantity 2.4 0.071 2.0 1 3/32 2.4 0.078 2.2 1 3/32 2.4 0.094 2.7 1 10CC 3/32 2.4 0.100 2.8 1 30CC 3/32 2.4 0.113 3.2 1 Plastic Adapter Heads • Syringe adapter head only - no air line KDS510S Cat No. UPC No. Packed Size Pack Wt. KDS503S 037103178947 Bagged 3CC KDS505S 037103178954 Bagged 5CC Accomodates 3/32" Airline 0.043 1.2 1 KDS510S 037103174123 Bagged 10CC Accomodates 3/32" Airline 0.049 1.4 1 KDS530S 037103174147 Bagged 30CC Accomodates 3/32" Airline 0.073 2.1 1 Accomodates 3/32" Airline lb g Pack Quantity 0.034 1.0 1 Bulk Syringe Components • Disposable un-assembled non-calibrated components • Plastic or lubricated rubber stoppers • Luer Slip™ (1cc), Luer Lok™, and tapered tip styles 17 SYRINGE COMPONENTS Bulk Syringe Components, continued 18 Cat No. UPC No. Packed Size Component Type Pack Wt. 1L1 037103176691 Bagged 1CC Barrel Luer Slip™ 3.300 93.5 1000 1L2 037103176707 Bagged 1CC Rubber Stopper Luer Slip™ 0.662 18.8 1000 1L4 037103176714 Bagged 1CC Plunger Rod Luer Slip™ 1.271 36.0 1000 3LL1 037103176790 Bagged 3CC Barrel Luer Lok™ 4.563 129.3 1000 3LL1B 037103183286 Bagged 3CC Barrel Luer Lok™ 12.900 365.5 2500 3LL2 037103178213 Bagged 3CC Rubber Stopper Luer Lok™ 1.120 31.7 1000 3LL2B 037103183279 Bagged 3CC Rubber Stopper Luer Lok™ 34.600 980.2 30,000 3LL2M 037103184542 Bagged 3CC Manual Stopper Luer Lok™ 0.422 12.0 1000 3LL2PS 037103177407 Bagged 3CC Plastic Stopper Luer Lok™ 0.290 8.2 1000 3LL4 037103176813 Bagged 3CC Plunger Rod Luer Lok™ 2.236 63.3 1000 3LL4B 037103183262 Bagged 3CC Plunger Rod Luer Lok™ 9.650 273.4 4000 5LL1 037103176868 Bagged 5CC Barrel Luer Lok™ 6.220 176.2 1000 5LL1B 037103183255 Bagged 5CC Barrel Luer Lok™ 11.750 332.9 1600 5LL2 037103176875 Bagged 5CC Rubber Stopper Luer Lok™ 2.570 72.8 1000 5LL2B 037103183248 Bagged 5CC Rubber Stopper Luer Lok™ 40.000 1133.2 15,000 5LL2M 037103176882 Bagged 5CC Manual Stopper Luer Lok™ 1.021 28.9 1000 5LL2MB 037103183231 Bagged 5CC Manual Stopper Luer Lok™ 23.100 654.4 20,000 5LL2PS 037103177445 Bagged 5CC Plastic Stopper Luer Lok™ 0.490 13.9 1000 5LL4 037103176899 Bagged 5CC Plunger Rod Luer Lok™ 5.050 143.1 1000 5LL4B 037103183224 Bagged 5CC Plunger Rod Luer Lok™ 13.250 375.4 3000 6T1 037103177452 Bagged 6CC Barrel Tapered 5.178 146.7 500 6T2 037103177469 Bagged 6CC Manual Stopper Tapered 0.695 19.7 500 6T4 037103177483 Bagged 6CC Plunger Rod Tapered 2.045 57.9 500 10LL1 037103176646 Bagged 10CC Barrel Luer Lok™ 10.350 293.2 1000 10T1 037103177308 Bagged 10CC Barrel Tapered 5.307 150.3 500 10LL2 037103176653 Bagged 10CC Rubber Stopper Luer Lok™ 3.995 113.2 1000 10LL2B 037103183217 Bagged 10CC Rubber Stopper Luer Lok™ 30.000 849.0 7000 10LL2M 037103176660 Bagged 10CC Manual Stopper Luer Lok™ 4.300 121.8 1000 10LL2PS 037103177285 Bagged 10CC Plastic Stopper Luer Lok™ 0.997 28.2 1000 10T2 037103177315 Bagged 10CC Rubber Stopper Tapered 1.039 29.4 500 10LL4 037103176684 Bagged 10CC Plunger Rod Luer Lok™ 10.300 291.8 1000 10LL4B 037103183200 Bagged 10CC Plunger Rod Luer Lok™ 15.000 425.0 1500 10T4 037103177322 Bagged 10CC Plunger Stopper Tapered 4.172 118.2 500 20LL2 037103176721 Bagged 20CC Rubber Stopper Luer Lok™ 29.750 842.8 3500 30LL1 037103176738 Bagged 30CC Barrel Luer Lok™ 16.100 456.1 600 30LL1PS 037103176745 Bagged 30CC Barrel for Plastic Stopper Luer Lok™ 12.645 358.2 600 30T1 037103177353 Bagged 30CC Barrel Tapered 14.983 424.5 500 30LL2 037103176752 Bagged 30CC Rubber Stopper Luer Lok™ 10.970 310.8 1000 30LL2B 037103183194 Bagged 30CC Rubber Stopper Luer Lok™ 31.170 883.0 2700 30LL2M 037103176769 Bagged 30CC Rubber Stopper Luer Lok™ 4.410 124.9 1000 30LL2MB 037103183187 Bagged 30CC Manual Stopper Luer Lok™ 24.350 689.8 5000 30LL2PS 037103177346 Bagged 30CC Plastic Stopper Luer Lok™ 1.651 46.8 1000 30T2 037103176783 Bagged 30CC Manual Stopper Tapered 3.322 94.1 500 30T2A 037103177360 Bagged 30CC Dry Air-operated Stopper Tapered 2.263 64.1 500 30LL4 037103176776 Bagged 30CC Plunger Rod Luer Lok™ 35.250 998.6 1000 30T4 037103177384 Bagged 30CC Plunger Rod Tapered 12.555 355.7 500 30T3 037103177377 Bagged 30CC Tip Cap/30CC Tapered Barrel Tapered 0.194 5.5 100 50LL1 037103176820 Bagged 50CC Barrel Luer Lok™ 16.820 476.5 375 50LL1GRAD 037103178220 Bagged 50CC Barrel with Graduations Luer Lok™ 17.310 490.4 375 50LL2 037103176844 Bagged 50CC Rubber Stopper Luer Lok™ 17.550 497.2 1000 50LL4 037103178237 Bagged 50CC Plunger Rod Luer Lok™ 19.890 563.5 600 Tip Type lb g Pack Quantity SYRINGE COMPONENTS , TIP CAPS AND NEEDLE SCABBARDS Bulk Syringe Components with UV Protection • Opaque black to protect light sensitive materials • Lubricated rubber stoppers • Unassembled and non-calibrated Plunger Rod Stopper Barrel 10LL1UV Cat No. UPC No. Packed Size Component Type Tip Type lb Pack Wt. g Pack Quantity 3LL1UV 037103177391 Bagged 3CC Barrel Luer Lok™ 3.057 86.6 500 3LL2UV 037103179272 Bagged 3CC Rubber Stopper Luer Lok™ 0.540 15.3 500 3LL4UV 037103177421 Bagged 3CC Plunger Rod Luer Lok™ 1.083 30.7 500 10LL1UV 037103177278 Bagged 10CC Barrel Luer Lok™ 8.020 227.2 500 10LL2UV 037103176677 Bagged 10CC Rubber Stopper Luer Lok™ 1.625 46.0 500 10LL4UV 037103177292 Bagged 10CC Plunger Rod Luer Lok™ 5.570 157.8 500 Tip Caps and Needle Scabbards • Used to seal needles and syringes when not in use • Luer Lok™ and press fit styles available for all styles of syringes 982 Cat No. KDS18SC UPC No. Packed Description 982 037103176615 Bagged 15LT 037103176530 Bagged 15LTB 037103182517 5227K 037103176639 KDS1TC KDS1TCUV KDS1TC KDSNC lb Pack Wt. g Pack Quantity Rubber Tip Cap 0.095 2.7 100 Plastic Tip Cap 0.046 1.3 100 Bagged Plastic Tip Cap 2.500 71.1 5000 Bagged Plastic Tip Cap 0.053 1.5 100 037103176561 Bagged Luer Lok™ Tip Cap, Clear 0.039 1.1 100 037103176585 Bagged Luer Lok™ Tip Cap, Black 0.039 1.1 100 Tip Caps Needle Scabbards/Covers KDS16SC 037103176547 Bagged Needle Scabbard, 16 Gauge 0.042 1.2 100 KDS18SC 037103176554 Bagged Needle Scabbard, 18 Gauge 0.042 1.2 100 KDS20SC 037103176592 Bagged Needle Scabbard, 20 Gauge 0.039 1.1 100 KDS22SC 037103183552 Bagged Needle Scabbard, 22 Gauge 0.039 1.1 100 KDSNC 037103176608 Bagged Needle Cover, 1" Needles 0.100 3.9 100 KDSNCB 037103183170 Bagged Needle Cover, 1" Needles 0.800 23.2 1000 Needles (listing begins on page 20) • Large selection of sizes, gauges, and packaging options • Selection includes non-sterile blunt stainless steel needles with plastic hubs, Teflon® needles with plastic hubs, and one-piece plastic tapered tip needles • All needles lock on to Luer Lok™ style syringes • Bent needles, needle covers, and scabbards are also available 19 NEEDLES Stainless Steel Plastic Hub Dispensing Needles • Sizes range from 14 through 22 gauge (see page 21 for 23 gauge through 30 gauge) • Lengths range from 1/2” (12.7mm) to 1 1/2” (38.1mm) • 18 and 20 gauge available in 2” (50.8mm) lengths 20 Cat No. UPC No. Packed ID KDS141BT 037103174758 Bagged KDS141P 037103174765 Bagged KDS1412BT 037103174727 KDS1412P KDS14112BT Gauge OD mm Length Inch mm Pack Quantity Hub Color Pack Wt. lb g 1000 Dark Green 1.111 50 Dark Green 0.076 2.2 1000 Dark Green 0.746 21.1 50 Dark Green 0.076 2.2 1000 Dark Green 1.327 37.6 Inch mm Inch 14 0.067 1.70 0.083 2.11 1 25.40 14 0.067 1.70 0.083 2.11 1 25.40 Bagged 14 0.067 1.70 0.083 2.11 1/2 12.70 037103174734 Bagged 14 0.067 1.70 0.083 2.11 1/2 12.70 037103174697 Bagged 14 0.067 1.70 0.083 2.11 1 1/2 38.10 KDS14112P 037103174703 Bagged 14 0.067 1.70 0.083 2.11 1 1/2 38.10 50 Dark Green 0.076 2.2 KDS1512BT 037103174833 Bagged 15 0.060 1.52 0.072 1.83 1/2 12.70 1000 Orange 0.781 22.1 KDS1512P 037103174840 Bagged 15 0.060 1.52 0.072 1.83 1/2 12.70 50 Orange 0.049 1.4 KDS151P 037103174871 Bagged 15 0.060 1.52 0.072 1.83 1 25.40 50 Orange 0.065 1.8 KDS15112BT 037103181114 Bagged 15 0.060 1.52 0.072 1.83 1 1/2 38.10 1000 Orange 1.215 34.4 KDS15112P 037103174802 Bagged 15 0.060 1.52 0.072 1.83 1 1/2 38.10 50 Orange 0.076 2.2 KDS161BT 037103174987 Bagged 16 0.053 1.35 0.064 1.63 1 25.40 1000 Purple 0.892 25.3 KDS161P 037103174994 Bagged 16 0.053 1.35 0.064 1.63 1 25.40 50 Purple 0.056 1.6 KDS1612BT 037103174956 Bagged 16 0.053 1.35 0.064 1.63 1/2 12.70 1000 Purple 0.679 19.2 KDS1612P 037103174963 Bagged 16 0.053 1.35 0.064 1.63 1/2 12.70 50 Purple 0.048 1.4 KDS16112BT 037103174925 Bagged 16 0.053 1.35 0.064 1.63 1 1/2 38.10 1000 Purple 1.050 29.7 KDS16112P 037103174932 Bagged 16 0.053 1.35 0.064 1.63 1 1/2 38.10 50 Purple 0.064 1.8 KDS1712BT 037103181183 Bagged 17 0.045 1.14 0.060 1.52 1/2 12.70 1000 White 0.659 18.7 KDS1712P 037103175021 Bagged 17 0.045 1.14 0.060 1.52 1/2 12.70 50 White 0.045 1.3 KDS171BT 037103181190 Bagged 17 0.045 1.14 0.060 1.52 1 25.40 1000 White 0.780 22.1 KDS171P 037103178152 Bagged 17 0.045 1.14 0.060 1.52 1 25.40 50 White 0.060 1.7 KDS1812BT 037103175113 Bagged 18 0.038 0.97 0.050 1.27 1/2 12.70 1000 Pink 0.620 17.6 KDS1812P 037103175120 Bagged 18 0.038 0.97 0.050 1.27 1/2 12.70 50 Pink 0.048 1.4 KDS181BT 037103178176 Bagged 18 0.038 0.97 0.050 1.27 1 25.40 1000 Pink 0.725 20.5 KDS181P 037103175168 Bagged 18 0.038 0.97 0.050 1.27 1 25.40 50 Pink 0.048 1.4 KDS18112BT 037103175076 Bagged 18 0.038 0.97 0.050 1.27 1 1/2 38.10 1000 Pink 0.893 25.3 KDS18112P 037103178169 Bagged 18 0.038 0.97 0.050 1.27 1 1/2 38.10 50 Pink 0.053 1.5 KDS182BT 037103175199 Bagged 18 0.038 0.97 0.050 1.27 2 50.80 1000 Pink 1.050 29.7 KDS1912P 037103185877 Bagged 19 0.032 0.81 0.042 1.07 1/2 12.70 50 Brown 0.048 1.4 KDS191BT 037103175274 Bagged 19 0.032 0.81 0.042 1.07 1 25.40 1000 Brown 0.678 19.2 KDS191P 037103175281 Bagged 19 0.032 0.81 0.042 1.07 1 25.40 50 Brown 0.048 1.4 KDS19112BT 037103183149 Bagged 19 0.032 0.81 0.042 1.07 1 1/2 38.10 1000 Brown 0.800 22.7 KDS19112P 037103175212 Bagged 19 0.032 0.81 0.042 1.07 1 1/2 38.10 50 Brown 0.050 1.4 KDS2012BT 037103175342 Bagged 20 0.026 0.66 0.035 0.89 1/2 12.70 1000 Yellow 0.586 16.6 KDS2012P 037103175359 Bagged 20 0.026 0.66 0.035 0.89 1/2 12.70 50 Yellow 0.040 1.1 KDS201BT 037103175373 Bagged 20 0.026 0.66 0.035 0.89 1 25.40 1000 Yellow 0.637 18.0 KDS201P 037103175380 Bagged 20 0.026 0.66 0.035 0.89 1 25.40 50 Yellow 0.045 1.3 KDS20112BT 037103175304 Bagged 20 0.026 0.66 0.035 0.89 1 1/2 38.10 1000 Yellow 0.768 21.8 KDS20112P 037103175311 Bagged 20 0.026 0.66 0.035 0.89 1 1/2 38.10 50 Yellow 0.045 1.3 KDS202BT 037103181206 Bagged 20 0.026 0.66 0.035 0.89 2 50.80 1000 Yellow 0.650 18.4 KDS2112BT 037103175441 Bagged 21 0.023 0.58 0.032 0.89 1/2 12.70 1000 Green 0.554 15.7 KDS2112P 037103175458 Bagged 21 0.023 0.58 0.032 0.89 1/2 12.70 50 Green 0.041 1.2 KDS211BT 037103175472 Bagged 21 0.023 0.58 0.032 0.89 1 25.40 1000 Green 0.620 17.6 KDS211P 037103175489 Bagged 21 0.023 0.58 0.032 0.89 1 25.40 50 Green 0.043 1.2 KDS21112BT 037103181237 Bagged 21 0.023 0.58 0.032 0.89 1 1/2 38.10 1000 Green 0.736 20.9 KDS21112P 037103175410 Bagged 21 0.023 0.58 0.032 0.89 1 1/2 38.10 50 Green 0.045 1.3 KDS2212BT 037103175526 Bagged 22 0.019 0.48 0.028 0.71 1/2 12.70 1000 Black 0.558 15.8 KDS2212P 037103175533 Bagged 22 0.019 0.48 0.028 0.71 1/2 12.70 50 Black 0.043 1.2 KDS221BT 037103175564 Bagged 22 0.019 0.48 0.028 0.71 1 25.40 1000 Black 0.650 18.4 KDS221P 037103175571 Bagged 22 0.019 0.48 0.028 0.71 1 25.40 50 Black 0.045 1.3 KDS22112BT 037103181251 Bagged 22 0.019 0.48 0.028 0.71 1 1/2 38.10 1000 Black 0.704 19.9 31.5 NEEDLES Stainless Steel Plastic Hub Dispensing Needles (cont.) • Sizes range from 23 through 30 gauge (see page 20 for 14 gauge through 22 gauge) • Lengths range from 1/2” (12.7mm) to 1 1/2” (38.1mm) Cat No. UPC No. Packed Gauge Inch ID mm Inch OD Hub Color Pack Wt. lb g KDS2312BT 037103175625 Bagged 23 0.017 0.43 0.025 0.64 1/2 12.70 KDS2312P 037103175632 Bagged 23 0.017 0.43 0.025 0.64 1/2 12.70 1000 Light Blue 0.565 50 Light Blue 0.042 KDS231BT 037103181282 Bagged 23 0.017 0.43 0.025 0.64 1 25.40 1.2 1000 Light Blue 0.620 17.6 KDS231P 037103175670 Bagged 23 0.017 0.43 0.025 0.64 1 KDS23112BT 037103181275 Bagged 23 0.017 0.43 0.025 0.64 1 1/2 25.40 50 Light Blue 0.043 1.2 38.10 1000 Light Blue 0.620 17.6 KDS2412BT 037103181718 Bagged 24 0.022 0.56 0.026 0.66 KDS2412P 037103175700 Bagged 24 0.022 0.56 0.026 0.66 1/2 12.70 1000 Red 0.525 14.9 1/2 12.70 50 Red 0.039 KDS241P 037103175724 Bagged 24 0.022 0.56 0.026 1.1 0.66 1 25.40 50 Red 0.040 1.1 KDS2512BT 037103175762 Bagged 25 0.012 0.30 KDS2512P 037103175779 Bagged 25 0.012 0.30 0.020 0.51 1/2 12.70 1000 Blue 0.519 14.7 0.020 0.51 1/2 12.70 50 Blue 0.040 KDS251BT 037103175793 Bagged 25 0.012 1.1 0.30 0.020 0.51 1 25.40 1000 Blue 0.556 15.8 KDS251P 037103175809 Bagged 25 KDS25112BT 037103181299 Bagged 25 0.012 0.30 0.020 0.51 1 25.40 50 Blue 0.041 1.2 0.012 0.30 0.020 0.51 1 1/2 38.10 50 Blue 0.638 18.1 KDS2612BT 037103175830 Bagged KDS2612P 037103175847 Bagged 26 0.010 0.25 0.018 0.46 1/2 12.70 1000 Tan 0.520 14.7 26 0.010 0.25 0.018 0.46 1/2 12.70 50 Tan 0.040 KDS261P 037103175878 1.1 Bagged 26 0.010 0.25 0.018 0.46 1 25.40 50 Tan 0.043 1.2 KDS27516BT KDS27516P 037103181336 Bagged 27 0.008 0.20 0.015 0.38 5/16 7.94 1000 Grey 0.496 14.4 037103175939 Bagged 27 0.008 0.20 0.015 0.38 5/16 7.94 50 Grey 0.035 1.0 KDS2712BT 037103181312 Bagged 27 0.008 0.20 0.015 0.38 1/2 12.70 1000 Grey 0.536 15.2 KDS271BT 037103181329 Bagged 27 0.008 0.20 0.015 0.38 1 25.40 1000 Grey 0.452 12.8 KDS271P 037103178183 Bagged 27 0.008 0.20 0.015 0.38 1 25.40 50 Grey 0.040 1.1 KDS27112BT 037103181350 Bagged 27 0.008 0.20 0.015 0.38 1 1/2 38.10 1000 Grey 0.500 14.2 KDS30516BT 037103181343 Bagged 30 0.006 0.15 0.012 0.30 5/16 7.94 1000 Lavender 0.420 11.9 KDS3012BT 037103175953 Bagged 30 0.006 0.15 0.012 0.30 1/2 12.70 1000 Lavender 0.483 13.7 KDS3012P 037103175960 Bagged 30 0.006 0.15 0.012 0.30 1/2 12.70 50 Lavender 0.039 1.1 KDS660 037103176004 Bagged - - - - - - - - Assorted 1.779 50.4 KDSSAMPLEPAC 037103176011 Bagged - - - - - - - - Assorted 0.012 mm Length Inch mm Pack Quantity 16.0 0.03 Stainless Steel Plastic Hub Dispensing Needles, 45° Bent Cat No. UPC No. Packed Gauge Inch ID mm Inch OD Hub Color Pack Wt. lb g KDS1512BBN45 037103179135 Bagged 15 0.060 1.52 0.072 1.83 1/2 12.70 KDS1512PBN45 037103178961 Bagged 15 0.060 1.52 0.072 1.83 1/2 12.70 1000 Orange 0.781 50 Orange 0.750 KDS151BBN45 037103179142 Bagged 15 0.060 1.52 0.072 1.83 1 21.2 25.40 1000 Orange 0.750 21.2 KDS1812BBN45 037103179159 Bagged 18 0.038 0.97 0.050 1.27 KDS1812PBN45 037103178978 Bagged 18 0.038 0.97 0.050 1.27 1/2 12.70 1000 Pink 0.604 17.1 1/2 12.70 50 Pink 0.650 KDS1912BBN45 037103179166 Bagged 19 0.032 0.81 0.042 18.4 1.07 1/2 12.70 1000 Brown 0.586 16.6 KDS2012BBN45 037103179173 Bagged 20 0.026 0.66 KDS2012PBN45 037103178985 Bagged 20 0.026 0.66 0.042 1.07 1/2 12.70 1000 Yellow 0.600 17.0 0.035 0.89 1/2 12.70 50 Yellow 0.050 KDS2112BBN45 037103179197 Bagged 21 0.023 1.4 0.58 0.032 0.81 1/2 12.70 1000 Green 0.650 18.4 KDS2212BBN45 037103179203 Bagged 22 KDS2212PBN45 037103179210 Bagged 22 0.019 0.48 0.028 0.71 1/2 12.70 1000 Black 1.450 41.1 0.019 0.48 0.028 0.71 1/2 12.70 50 Black 0.043 KDS2312BBN45 037103179234 Bagged 1.2 23 0.017 0.43 0.025 0.64 1/2 12.70 1000 Light Blue 0.450 12.7 KDS231BBN45 037103179241 KDS2512BBN45 037103179258 Bagged 23 0.017 0.43 0.025 0.64 1 25.40 1000 Light Blue 0.500 14.2 Bagged 25 0.012 0.30 0.020 0.51 1/2 12.70 1000 Blue 0.700 KDS261BBN45 037103179265 19.8 Bagged 26 0.010 0.25 0.018 0.46 1 25.40 1000 Tan 1.000 28.3 mm Length Inch mm Pack Quantity 22.1 21 NEEDLES Tapered Tip Needles • • • • 22 Cat. No. UPC No. KDS14TN25 037103176356 Bagged KDS14TNP KDS14TN Sizes range from 14 through 24 gauge Length is 1 1/2” (38.1mm) Taper reduces dripping from needle Plastic material won’t scratch delicate surfaces ID Hub Color Pack Wt. lb g 25 Salmon 0.015 0.4 1.60 50 Salmon 0.050 1.4 1.60 100 Salmon 0.062 1.8 0.063 1.60 1000 Salmon 0.500 14.2 0.048 1.22 25 Grey 0.015 0.4 16 0.048 1.22 50 Grey 0.050 1.4 16 0.048 1.22 100 Grey 0.060 1.7 037103179012 Bagged 16 0.048 1.22 1000 Grey 0.490 13.9 037103176424 Bagged 18 0.034 0.86 25 Green 0.015 0.4 KDS18TNP 037103176431 Bagged 18 0.034 0.86 50 Green 0.045 1.3 KDS18TN 037103176417 Bagged 18 0.034 0.86 100 Green 0.058 1.6 KDS18TNB 037103179029 Bagged 18 0.034 0.86 1000 Green 0.475 13.5 KDS20TN25 037103176455 Bagged 20 0.024 0.61 25 Pink 0.015 0.4 KDS20TNP 037103176479 Bagged 20 0.024 0.61 50 Pink 0.041 1.2 KDS20TN 037103176448 Bagged 20 0.024 0.61 100 Pink 0.058 1.6 KDS20TNB 037103179043 Bagged 20 0.024 0.61 1000 Pink 0.460 13.0 KDS22TN25 037103176493 Bagged 22 0.017 0.43 25 Blue 0.015 0.4 KDS22TNP 037103176509 Bagged 22 0.017 0.43 50 Blue 0.043 1.2 KDS22TN 037103176486 Bagged 22 0.017 0.43 100 Blue 0.058 1.6 KDS22TNB 037103179050 Bagged 22 0.017 0.43 1000 Blue 0.450 12.7 KDS24TNP 037103176523 Bagged 24 0.013 0.33 50 Red 0.040 1.1 KDS24TN 037103176516 Bagged 24 0.013 0.33 50 Red 0.059 1.7 Packed Gauge Inch mm 14 0.063 1.60 037103176363 Bagged 14 0.063 037103176349 Bagged 14 0.063 KDS14TNB 037103179005 Bagged 14 KDS16TN25 037103176387 Bagged 16 KDS16TNP 037103176400 Bagged KDS16TN 037103176370 Bagged KDS16TNB KDS18TN25 Pack Quantity NEEDLES Teflon Needles • • • • Sizes range from 14 through 30 gauge Lengths range from 1/2” (12.7mm) to 2” (50.8mm) Teflon® material won’t scratch delicate surfaces Teflon resists bonding of most adhesives Cat. No. UPC No. KDS1412T ID Packed Pack Quantity Hub Color Pack Wt. lb g 12.70 25 Dark Green 0.015 0.4 1 25.40 25 Dark Green 0.015 0.4 2 50.80 25 Dark Green 0.015 0.4 Gauge Inch mm 037103176332 Bagged 14 1/2 KDS141T 037103176066 Bagged 14 KDS142T 037103176073 Bagged 14 KDS1512T 037103176097 Bagged 15 1/2 12.70 25 Orange 0.015 0.4 KDS151T 037103176103 Bagged 15 1 25.40 25 Orange 0.015 0.4 KDS15112T 037103176080 Bagged 15 1 1/2 38.10 25 Orange 0.015 0.4 KDS162T 037103176110 Bagged 16 2 50.80 25 Purple 0.015 0.4 KDS1812T 037103176134 Bagged 18 1/2 12.70 25 Pink 0.015 0.4 KDS18112T 037103176127 Bagged 18 1 1/2 38.10 25 Pink 0.015 0.4 KDS182T 037103176141 Bagged 18 2 50.80 25 Pink 0.015 0.4 KDS2012T 037103176165 Bagged 20 1/2 12.70 25 Yellow 0.015 0.4 KDS201T 037103176172 Bagged 20 1 25.40 25 Yellow 0.015 0.4 KDS20112T 037103178190 Bagged 20 1 1/2 38.10 25 Yellow 0.015 0.4 KDS202T 037103176189 Bagged 20 2 50.80 25 Yellow 0.015 0.4 KDS2112T 037103178206 Bagged 21 1/2 12.70 25 Green 0.015 0.4 KDS21112T 037103176196 Bagged 21 1 1/2 38.10 25 Green 0.015 0.4 KDS2212T 037103176226 Bagged 22 1/2 12.70 25 Black 0.015 0.4 KDS221T 037103176233 Bagged 22 1 25.40 25 Black 0.015 0.4 KDS22112T 037103176219 Bagged 22 1 1/2 38.10 25 Black 0.015 0.4 KDS222T 037103176240 Bagged 22 2 50.80 25 Black 0.015 0.4 KDS2312T 037103176257 Bagged 23 1/2 12.70 25 Light Blue 0.015 0.4 KDS2412T 037103176271 Bagged 24 1/2 12.70 25 Salmon 0.015 0.4 KDS24112T 037103176264 Bagged 24 1 1/2 38.10 25 Salmon 0.015 0.4 KDS2612T 037103176295 Bagged 26 1/2 12.70 25 Tan 0.015 0.4 KDS26112T 037103176288 Bagged 26 1 1/2 38.10 25 Tan 0.015 0.4 KDS2812T 037103176301 Bagged 28 1/2 12.70 25 - 0.015 0.4 KDS3012T 037103176325 Bagged 30 1/2 12.70 25 Lavender 0.015 0.4 KDS30112T 037103176318 Bagged 30 1 1/2 38.10 25 Lavender 0.015 0.4 23 ACCESSORIES Flux Bottles KDS5000A KDS5100LL KDS5200LL KDS5400LL Note: Bottles are shipped empty. Different colors shown here for illustration purposes only. Cat No. UPC No. Packed Size Description lb Pack Wt. g KDS5000A 037103177919 Bagged 1 oz. Accordion Style w/Luer Lok™ Cap 0.13 KDS5100LLDC 037103177933 Bagged 1 oz. Flux Bottle w/Luer Lok™ Cap 0.18 5.1 10 KDS5100LL 037103177926 Bagged 1 oz. Flux Bottle w/Luer Lok™ Cap & 18 Gauge 1/2" Needle 0.19 5.4 10 KDS5200LLDC 037103177988 Bagged 2 oz. Flux Bottle w/Luer Lok™ Cap 0.26 7.4 10 KDS5200LL 037103177940 Bagged 2 oz. Flux Bottle w/Luer Lok™ Cap & 18 Gauge 1/2" Needle 0.28 7.9 10 KDS5200LL2 037103177957 Bagged 2 oz. Bottle w/22 & 26 Gauge 1/2" Needles 0.29 8.2 10 KDS5200LL3 037103177964 Bagged 2 oz. Bottle w/18, 22 & 25 Gauge 1/2" Needles 0.31 8.9 10 KDS5400LLDC 037103178008 Bagged 4 oz. Flux Bottle w/Luer Lok™ Cap 0.35 9.9 10 KDS5400LL 037103177995 Bagged 4 oz. Flux Bottle w/Luer Lok™ Cap & 18 Gauge 1/2" Needle 0.32 9.1 10 3.7 Pack Quantity 10 Finger Cots • All cots come in Small, Medium, Large, and Extra Large • Three types are available: Powder-free, Anti-static, and conductive 24 Cat No. UPC No. Packed Size KDS5C500S 037103177759 Bagged Small Powder-free 1.420 40.2 10 Gross KDS5C500M 037103177742 Bagged Medium Powder-free 1.614 45.7 10 Gross KDS5C500L 037103177735 Bagged Large Powder-free 1.783 50.5 10 Gross KDS5C500XL 037103177766 Bagged Extra Large Powder-free 1.835 52.0 10 Gross KDS7C700S 037103177797 Bagged Small Anti-static 0.687 19.5 5 Gross KDS7C700M 037103177780 Bagged Medium Anti-static 0.745 21.1 5 Gross KDS7C700L 037103177773 Bagged Large Anti-static 0.838 23.7 5 Gross KDS7C700XL 037103177803 Bagged Extra Large Anti-static 0.860 24.4 5 Gross KDS8C800S 037103179111 Bagged Small Conductive 0.465 13.2 5 Gross KDS8C800M 037103179098 Bagged Medium Conductive 0.603 17.1 5 Gross KDS8C800L 037103179081 Bagged Large Conductive 0.740 21.0 5 Gross KDS8C800XL 037103179128 Bagged Extra Large Conductive 0.762 21.6 5 Gross KDSCOTS 037103183606 Bagged - Sample Finger Cot Assortment 0.406 11.5 - Description lb Pack Wt. g Pack Quantity MISCELLANEOUS ACCESSORIES Gloves • Nitrile gloves are 9” long and come in Small, Medium, Large, and Extra Large • Anti-static Cat No. UPC No. Packed Size KDSQ095S 037103177834 Bagged Small 100 Nitrile, 4 Mil 1.567 44.4 100 KDSQ095M 037103177827 Bagged Medium 100 Nitrile, 4 Mil 1.660 47.0 100 KDSQ095L 037103177810 Bagged Large 100 Nitrile, 4 Mil 1.750 49.6 100 KDSQ095XL 037103177841 Bagged Extra Large 100 Nitrile, 4 Mil 1.845 52.3 100 KDSQ096S 037103177872 Bagged Small 1000 Nitrile, 4 Mil 1.326 37.6 100 KDSQ096M 037103177872 Bagged Medium 1000 Nitrile, 4 Mil 1.575 44.6 100 KDSQ096L 037103177858 Bagged Large 1000 Nitrile, 4 Mil 1.650 46.7 100 KDSQ096XL 037103177889 Bagged Extra Large 1000 Nitrile, 4 Mil 1.938 54.9 100 KDSQ09BPFM 037103177902 Boxed Medium (9”) - Powder-free 1.698 48.1 100 KDSQ09BPFL 037103177896 Boxed Large (9”) Powder-free 1.831 51.9 100 KDSGLOVES 037103183590 Bagged Assortment of Sizes and Types 2.821 79.9 - Class - Type lb Pack Wt. g Pack Quantity Miscellaneous Accessories KDS805FS Finger Switch for Shot Meters • Plugs in to KDS808, KDS834, and KDS824 series Shot Meters • Replaces the foot pedal as method of actuation KDS805FS KDS816 Syringe Holder Stand • Compatible with all sizes of syringes and adapters • Keeps syringe upright - preventing accidental flow of material back up the air line • Keeps work bench neat and clean KDS816 Cat No. UPC No. Description lb Pack Wt. g Pack Quantity KDS75013P 037103178046 KDS805FS 037103178077 Plastic Luer Lok™ Needle Adapter 0.046 1.3 10 Finger Switch for Shot Meters 0.147 4.2 1 KDS816 037103178091 Syringe Holder Stand 0.620 17.2 1 25 MISCELLANEOUS ACCESSORIES Material Selection Chart Systems Materials 26 Syringe Cartridge Tank & Valve Solder Paste X X Solder Mask X X Epoxies X X Adhesives X X X Oil X X X Grease X X Silicones X X RTV’s X X Gels X X UV Materials X X X Cyanoacrylates X Inks X X X Self-leveling X X X Non-self-leveling X X Two-part Materials X X X INDEX Cat. No. Page 102025 . . . . . . . .12 102060 . . . . . . . .12 102120 . . . . . . . .12 10LL1 . . . . . . . . .18 10LL1UV . . . . . . .19 10LL2 . . . . . . . . .18 10LL2B . . . . . . . .18 10LL2M . . . . . . . .18 10LL2PS . . . . . . .18 10LL2UV . . . . . . .19 10LL4 . . . . . . . . .18 10LL4B . . . . . . . .18 10LL4UV . . . . . . .19 10T1 . . . . . . . . . .18 10T2 . . . . . . . . . .18 10T4 . . . . . . . . . .18 15LT . . . . . . . . . .19 15LTB . . . . . . . . .19 1L1 . . . . . . . . . . .18 1L2 . . . . . . . . . . .18 1L4 . . . . . . . . . . .18 20LL2 . . . . . . . . .18 30LL . . . . . . . . . .18 30LL1 . . . . . . . . .18 30LL1PS . . . . . . .18 30LL2 . . . . . . . . .18 30LL2M . . . . . . . .18 30LL2MB . . . . . . .18 30LL2PS . . . . . . .18 30LL4 . . . . . . . . .18 30T1 . . . . . . . . . .18 30T2 . . . . . . . . . .18 30T2A . . . . . . . . .18 30T3 . . . . . . . . . .18 30T4 . . . . . . . . . .18 3LL1 . . . . . . . . . .18 3LL1B . . . . . . . . .18 3LL1UV . . . . . . . .19 3LL2 . . . . . . . . . .18 3LL2B . . . . . . . . .18 3LL2M . . . . . . . . .18 3LL2PS . . . . . . . .18 3LL2UV . . . . . . . .19 3LL4 . . . . . . . . . .18 3LL4B . . . . . . . . .18 3LL4UV . . . . . . . .19 50LL1 . . . . . . . . .18 50LL1GRAD . . . . .18 50LL2 . . . . . . . . .18 50LL4 . . . . . . . . .18 5227K . . . . . . . . .19 5LL1 . . . . . . . . . .18 5LL1B . . . . . . . . .18 5LL2 . . . . . . . . . .18 5LL2B . . . . . . . . .18 5LL2M . . . . . . . . .18 5LL2MB . . . . . . . .18 5LL2PS . . . . . . . .18 5LL4 . . . . . . . . . .18 5LL4B . . . . . . . . .18 6T1 . . . . . . . . . . .18 6T2 . . . . . . . . . . .18 6T4 . . . . . . . . . . .18 982 . . . . . . . . . . .19 A10LL . . . . . . . . .14 A10LLPS . . . . . . .14 A10LLUV . . . . . . .14 Cat. No. Page A30LL . . . . . . . . .14 A30LLPS . . . . . . .14 A30LLUV . . . . . . .14 A30T . . . . . . . . . .14 A3LL . . . . . . . . . .14 A3LLPS . . . . . . . .14 A3LLUV . . . . . . . .14 A5LL . . . . . . . . . .14 A5LLPS . . . . . . . .14 A5LLUV . . . . . . . .14 A6T . . . . . . . . . . .14 KDS100CA . . . . . . .3 KDS100F . . . . . . .10 KDS100HCA . . . .3, 9 KDS100SS . . . . . .10 KDS100WCA . . .3, 9 KDS120C . . . . . . .12 KDS14112BT . . . .20 KDS14112P . . . . .20 KDS1412BT . . . . .20 KDS1412P . . . . . .20 KDS1412T . . . . . .23 KDS141BT . . . . . .20 KDS141P . . . . . . .20 KDS141T . . . . . . .23 KDS142T . . . . . . .23 KDS14TN . . . . . . .22 KDS14TN25 . . . . .22 KDS14TNB . . . . . .22 KDS14TNP . . . . . .22 KDS15112BT . . . .20 KDS15112P . . . . .20 KDS15112T . . . . .23 KDS1512BBN45 . .21 KDS1512BT . . . . .20 KDS1512P . . . . . .20 KDS1512PBN45 . .21 KDS1512T . . . . . .23 KDS151BBN45 . . .21 KDS151P . . . . . . .20 KDS151T . . . . . . .23 KDS16112BT . . . .20 KDS16112P . . . . .20 KDS1612BT . . . . .20 KDS1612P . . . . . .20 KDS161BT . . . . . .20 KDS161P . . . . . . .20 KDS162T . . . . . . .23 KDS16SC . . . . . . .19 KDS16TN . . . . . . .22 KDS16TN25 . . . . .22 KDS16TNB . . . . . .22 KDS16TNP . . . . . .22 KDS1712BT . . . . .20 KDS1712P . . . . . .20 KDS171BT . . . . . .20 KDS171P . . . . . . .20 KDS18112BT . . . .20 KDS18112P . . . . .20 KDS18112T . . . . .23 KDS1812BBN45 . .21 KDS1812BT . . . . .20 KDS1812P . . . . . .20 KDS1812PBN45 . .21 KDS1812T . . . . . .23 KDS181BT . . . . . .20 KDS181P . . . . . . .20 Cat. No. Page KDS182BT . . . . . .20 KDS182T . . . . . . .23 KDS18SC . . . . . . .19 KDS18TN . . . . . . .22 KDS18TN25 . . . . .22 KDS18TNB . . . . . .22 KDS18TNP . . . . . .22 KDS19112BT . . . .20 KDS19112P . . . . .20 KDS1912BBN45 . .21 KDS1912P . . . . . .20 KDS191BT . . . . . .20 KDS191P . . . . . . .20 KDS1P . . . . . . . . .12 KDS1TC . . . . . . . .19 KDS1TCUV . . . . . .19 KDS1WP . . . . . . .12 KDS2001HC . . . . . .5 KDS200SS . . . . . .10 KDS20112BT . . . .20 KDS20112P . . . . .20 KDS20112T . . . . .23 KDS2012BBN45 . .21 KDS2012BT . . . . .20 KDS2012P . . . . . .20 KDS2012PBN45 . .21 KDS2012T . . . . . .23 KDS201BT . . . . . .20 KDS201P . . . . . . .20 KDS201T . . . . . . .23 KDS202BT . . . . . .20 KDS202T . . . . . . .23 KDS20SC . . . . . . .19 KDS20TN . . . . . . .22 KDS20TN25 . . . . .22 KDS20TNB . . . . . .22 KDS20TNP . . . . . .22 KDS21112BT . . . .20 KDS21112P . . . . .20 KDS21112T . . . . .23 KDS2112BBN45 . .21 KDS2112BT . . . . .20 KDS2112P . . . . . .20 KDS2112T . . . . . .23 KDS211BT . . . . . .20 KDS211P . . . . . . .20 KDS216 . . . . . . . .12 KDS218 . . . . . . . .12 KDS22112BT . . . .20 KDS22112T . . . . .23 KDS2212BBN45 . .21 KDS2212BT . . . . .20 KDS2212P . . . . . .20 KDS2212PBN45 . .21 KDS2212T . . . . . .23 KDS221BT . . . . . .20 KDS221P . . . . . . .20 KDS221T . . . . . . .23 KDS222T . . . . . . .23 KDS22SC . . . . . . .19 KDS22TN . . . . . . .22 KDS22TN25 . . . . .22 KDS22TNB . . . . . .22 KDS22TNP . . . . . .22 KDS23112BT . . . .21 KDS2312BBN45 . .21 KDS2312BT . . . . .21 Cat. No. Page KDS2312P . . . . . .21 KDS2312T . . . . . .23 KDS231BBN45 . . .21 KDS231BT . . . . . .21 KDS231P . . . . . . .21 KDS24112T . . . . .23 KDS2412BT . . . . .21 KDS2412P . . . . . .21 KDS2412T . . . . . .23 KDS241P . . . . . . .21 KDS24TN . . . . . . .22 KDS24TNP . . . . . .22 KDS2501P . . . . . .13 KDS2503 . . . . . . .13 KDS25112BT . . . .21 KDS2512BBN45 . .21 KDS2512BT . . . . .21 KDS2512P . . . . . .21 KDS251BT . . . . . .21 KDS251P . . . . . . .21 KDS25C . . . . . . . .12 KDS260035PS . . .13 KDS2601HL . . .3, 11 KDS26112T . . . . .23 KDS2612BT . . . . .21 KDS2612P . . . . . .21 KDS2612T . . . . . .23 KDS261BBN45 . . .21 KDS261P . . . . . . .21 KDS27112BT . . . .21 KDS2712BT . . . . .21 KDS271BT . . . . . .21 KDS271P . . . . . . .21 KDS27516BT . . . .21 KDS27516P . . . . .21 KDS2812T . . . . . .23 KDS2C . . . . . . . . .12 KDS301 . . . . . .3, 11 KDS30112T . . . . .23 KDS3012BT . . . . .21 KDS3012P . . . . . .21 KDS3012T . . . . . .23 KDS30516BT . . . .21 KDS416 . . . . . . . .12 KDS432 . . . . . . . .12 KDS4P . . . . . . . . .12 KDS5000A . . . . . .24 KDS501S6 . . . . . .17 KDS503S . . . . . . .17 KDS503S6 . . . . . .17 KDS505S . . . . . . .17 KDS505S6 . . . . . .17 KDS5100LL . . . . .24 KDS5100LLDC . . .24 KDS510S . . . . . . .17 KDS510S6 . . . . . .17 KDS5200LL . . . . .24 KDS5200LL2 . . . .24 KDS5200LL3 . . . .24 KDS5200LLDC . . .24 KDS530S . . . . . . .17 KDS530S6 . . . . . .17 KDS5400LL . . . . .24 KDS5400LLDC . . .24 KDS5C500L . . . . .24 KDS5C500M . . . .24 KDS5C500S . . . . .24 Cat. No. Page KDS5C500XL . . . .24 KDS60C . . . . . . . .12 KDS660 . . . . . . . .21 KDS75013P . . . . .25 KDS760A . . . . .3, 11 KDS7C700L . . . . .24 KDS7C700M . . . .24 KDS7C700S . . . . .24 KDS7C700XL . . . .24 KDS801 . . . . . . . .16 KDS801S6 . . . . . .16 KDS803S . . . . . . .16 KDS803S6 . . . . . .16 KDS805FS . . . .3, 25 KDS805S . . . . . . .16 KDS805S6 . . . . . .16 KDS806 . . . . . . . . .6 KDS806D . . . . . . . .6 KDS806V . . . . . . . .6 KDS806VD . . . . . . .6 KDS8070 . . . . . . .13 KDS807OP . . . .3, 13 KDS808 . . . . . . . . .5 KDS808D . . . . . . . .5 KDS810S . . . . . . .16 KDS810S6 . . . . . .16 KDS816 . . . . . . . .25 KDS824A . . . . . . . .4 KDS824AD . . . . . . .4 KDS830S . . . . . . .16 KDS830S6 . . . . . .16 KDS834A . . . . . . . .4 KDS834AD . . . . . . .4 KDS8615 . . . . . . .12 KDS8C800L . . . . .24 KDS8C800M . . . .24 KDS8C800S . . . . .24 KDS8C800XL . . . .24 KDSCOTS . . . . . . .24 KDSDELUXEKIT .3, 6 KDSGLOVES . . . .25 KDSNC . . . . . . . . .19 KDSNCB . . . . . . . .19 KDSQ095L . . . . . .25 KDSQ095M . . . . .25 KDSQ095S . . . . . .25 KDSQ095XL . . . . .25 KDSQ096L . . . . . .25 KDSQ096M . . . . .25 KDSQ096S . . . . . .25 KDSQ096XL . . . . .25 KDSQ09BPFL . . . .25 KDSQ09BPFM . . .25 KDSSAMPLEPAC .21 M10LL . . . . . . . . .15 M10LLASSM . . . .15 M10LLASSM100 .15 M10LLBA . . . . . . .15 M10LLUV . . . . . . .16 M1BA . . . . . . . . . .15 M1L . . . . . . . . . . .15 M1LASSM . . . . . .15 M20LLASSM . . . .15 M20LLBA . . . . . . .15 M30LL . . . . . . . . .15 M30LLASSM . . . .15 M30LLBA . . . . . . .15 Cat. No. Page M30LLUV . . . . . . .16 M30T . . . . . . . . . .15 M3LLASSM . . . . .15 M3LLASSM100 . .15 M3LL . . . . . . . . . .15 M3LL100 . . . . . . .15 M3LLBA . . . . . . . .15 M3LLUV . . . . . . . .16 M50LL . . . . . . . . .15 M50LLASSM . . . .15 M50LLBA . . . . . . .15 M50TASSM . . . . .15 M50TBA . . . . . . . .15 M5LL . . . . . . . . . .15 M5LLASSM . . . . .15 M5LLASSM100 . .15 M5LLBA . . . . . . . .15 M6T . . . . . . . . . . .15 PG102120 . . . . . .12 PG10225 . . . . . . .12 PG10260 . . . . . . .12 SYSTEM100 . . . . . .7 SYSTEM225 . . . . . .7 SYSTEM230 . . . . . .7 SYSTEM240 . . . . . .8 SYSTEM300 . . . . . .8 SYSTEM500 . . . . . .8 SYSTEM800 . . . . . .9 27 U N I T E D S T A T E S CooperTools P.O. Box 728 Apex, NC 27502-0728 AIRETOOL® APEX® • BUCKEYE® CAMPBELL® • CLECO® COOPER AUTOMATION™ • CRESCENT® DGD® • DOLER® • DOTCO® • EREM® GARDNER-DENVER® • GARDOTRANS ™ GETA™ • KAHNETICS® • LUFKIN® • MASTER POWER® • METRONIX™ •NICHOLSON® •PLUMB® • H.K. PORTER® • QUACKENBUSH™ • RECOULES™ • ROTOR™ • UTICA® WELLER® • WIRE-WRAP® WISS® • XCELITE® East Coast (Northeast & South) Phone: 919-362-7541 Fax: 800-854-5139 Midwest Phone: 919-362-7542 Fax: 800-854-5138 West Coast (Southwest) Phone: 919-362-1709 Fax: 800-546-7312 G E R M A N Y Cooper Tools GmbH Carl-Benz-Str. 2, 74354 Besigheim, Postfach 1351, 74351 Besigheim Germany F R A N C E CooperTools S.A. 76 Rue François de Tessan B.P. 46 77831 Ozoir La Ferrière France I T A L Y Cooper Italia S.p.A. Viale Europa 80 20090 Cusago (MI) Italy G R E A T B R I T A I N CooperTools Suite 15, Coniston House Town Centre Washington, Tyne and Wear NE 38 7RN, Great Britain www.coopertools.com 005 56 753 00 / 03.02 WAL 5.0 CT01-9423 Specifications subject to change without notice. GARDNER-DENVER IS A REGISTERED TRADEMARK OF GARDNER-DENVER MACHINERY, INC., USED UNDER LICENSE. © 2002 COOPER INDUSTRIES, INC.
KDS8051N 价格&库存
很抱歉,暂时无法提供与“KDS8051N”相匹配的价格&库存,您可以联系我们找货
