www.weller-tools.com
SMART Micro
RTMS 003 S NW MS
CHISEL TIP
0,3 X 0,1 MM
ORDER NO:T0050115299
Production within the electronics, medical technology and aerospace industries is moving faster than ever before, as components become more complex. With a new generation of RTMS MS Smart Tips, Weller meets these increasing demands with its
Smart Tips that include an integrated chip in every soldering tip, which offer many new features to the user.The Micro Soldering
Tips provide an optimized heat transfer with 40W maximum power, 12V performance for micro and standard components
0504 to 1608 (M to L). Lock functions make the soldering processes repeatable and transparent. Weller offers the world‘s
largest selection of smart soldering tips for micro applications.
KEY FEATURES
> RTMS 003 S NW MS
Chisel tip 0,3 X 0,1 mm / 40 W
> MIL-SPEC
(IPC - TM-650 2.5.33)
> TOOL COMPATIBILITY
For use with WXMPS MS smart soldering iron and
WXsmart soldering station
> PERFECT FOR ALL MICRO AND STANDARD
SOLDERING APPLICATIONS:
Smart high performance active tips for micro and standard
components: 0504 to 1608 (M to L)
> EXTREMELY FAST 5-SECOND HEAT-UP TIME
Weller’s active tip technology (cartridge) provide an optimized
heat transfer with 40W maximum power, 12V performance.
The extremely fast 5-second heat-up time delivers excellent
heat transfer and recovery time during the soldering process
for a high-performance continuous workflow. Short tip-to-grip
distance provides maximum precision during the soldering
process.
> MAXIMUM PRECISION
Short tip-to-grip distance and optimized tip shape provide
maximum precision during the soldering process.
> WIDE TIP RANGE FOR EVERY APPLICATION
More than 40 smart universal soldering tip shapes and sizes that
are connectable to just one soldering iron, with no need for additional tools.
> FULL PROCESS CONTROL WITH TIP LOCK FUNCTION
Locked parameters on tip allows full process control and prevents
for default during the soldering process
> FULL TRACEABILITY WITH TIP ID NUMBER AND
INTEGRATED DATA STORAGE
Each smart soldering tip has a unique individual serial number for
full traceability. The integrated data storage provides full
traceability of calibration history
> ACCURATE DATA RESULTS WITH TIP-OFFSET FUNCTION
Using the Tip Offset Function, you can easily change the reference
point of the sensor. Just add the measured positional offset value
and the sensor’s origin will be translated and reset. Tip Offset provides a simple way to get the best results and achieve the highest
degree of accuracy.
> FAST, SAFE AND EASY TIP EXCHANGE
The patented Weller RT MS smart cartridge tips can be changed
quickly without the need of any additional tool, despite hot temperature conditions.
> MAXIMUM PROTECTION
The RTMS smart soldering tips are fully compliant with IPC industry standards (IPC - TM-650 2.5.33 Measurement of Electrical
Overstress from Soldering Hand Tools) and are also MIL-SPEC
compliant. This provides maximum protection to both the printed
circuit board and components, achieving excellent results, while
keeping operating costs low.
> CLEAR IDENTIFICATION OF SMART TIPS
The Weller WXsmart soldering station identifies each
RTMS cartridge tip automatically
weller-tools.com
Weller® is a registered trademark of Apex Brands, Inc. © 2022 | Specifications subject to change without notice.
www.weller-tools.com/wxsmart
很抱歉,暂时无法提供与“T0050115299”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+527.713491+67.73831
