T0050110599
T0050110599
    ATG
    RTPS 002 C MS TIP CONICAL 0.2
T0050110599 数据手册
www.weller-tools.com SMART Pico RTPS 002 C MS SOLDERING TIP CONICAL Ø 0,2 MM ORDER NO: T0050110599 Production within the electronics, medical technology and aerospace industries is moving faster than ever before, as components become more complex. With a new generation of RTMS MS Smart Tips, Weller meets these increasing demands with its Smart Tips that include an integrated chip in every soldering tip, which offer many new features to the user.The Micro Soldering Tips provide an optimized heat transfer with 40W maximum power, 12V performance for micro and standard components 0504 to 1608 (M to L). Lock functions make the soldering processes repeatable and transparent. Weller offers the world‘s largest selection of smart soldering tips for micro applications. KEY FEATURES > RTPS 002 C MS Soldering tip conical Ø 0,2 mm / 40 W > MIL-SPEC (IPC - TM-650 2.5.33) > TOOL COMPATIBILITY: For use with WXMPS MS smart soldering iron and WXsmart soldering station > PERFECT FOR ALL MICRO AND STANDARD SOLDERING APPLICATIONS:  Smart high performance active tips for micro and standard components: 0504 to 1608 (M to L)) > EXTREMELY FAST 3-SECOND HEAT-UP TIME FOR STANDARD APPLICATIONS  Weller´s active tip technology (cartridge) provides an optimized heat transfer with 40W maximum power, 12V performance. The extremely fast 3-second heat-up time delivers excellent heat transfer and recovery time during the soldering process for a high-performance continuous workflow. > MAXIMUM PRECISION Short tip-to-grip distance and optimized tip shape provide maximum precision during the soldering process. > WIDE TIP RANGE FOR EVERY APPLICATION More than 40 smart universal soldering tip shapes and sizes that are connectable to just one soldering iron, with no need for additional tools. > FULL PROCESS CONTROL WITH TIP LOCK FUNCTION Locked parameters on tip allows full process control and prevents for default during the soldering process > FULL TRACEABILITY WITH TIP ID NUMBER AND INTEGRATED DATA STORAGE Each smart soldering tip has a unique individual serial number for full traceability. The integrated data storage provides full traceability of calibration history > ACCURATE DATA RESULTS WITH TIP-OFFSET FUNCTION Using the Tip Offset Function, you can easily change the reference point of the sensor. Just add the measured positional offset value and the sensor’s origin will be translated and reset. Tip Offset provides a simple way to get the best results and achieve the highest degree of accuracy. > FAST, SAFE AND EASY TIP EXCHANGE The patented Weller RT MS smart cartridge tips can be changed quickly without the need of any additional tool, despite hot temperature conditions. > MAXIMUM PROTECTION The RTMS smart soldering tips are fully compliant with IPC industry standards (IPC - TM-650 2.5.33 Measurement of Electrical Overstress from Soldering Hand Tools) and are also MIL-SPEC compliant. This provides maximum protection to both the printed circuit board and components, achieving excellent results, while keeping operating costs low. > CLEAR IDENTIFICATION OF SMART TIPS The Weller WXsmart soldering station identifies each RTMS cartridge tip automatically weller-tools.com Weller® is a registered trademark of Apex Brands, Inc. © 2022 | Specifications subject to change without notice. www.weller-tools.com/wxsmart
T0050110599
物料型号:Weller RTPS 002 C MS
器件简介:Weller的新一代RTMS MS智能焊笔头,集成了芯片,提供全流程控制和尖端锁定功能,适用于电子、医疗技术和航空产业的生产。
引脚分配:文档未明确提及。
参数特性: - 圆锥形焊笔头,直径0.2毫米,40瓦最大功率 - 微焊笔头提供优化的热传递,适用于0504至1608(M至L)的微型和标准元件 - 尖端锁定功能实现可重复和透明的焊接过程
功能详解: - 全过程控制与尖端锁定功能 - 每个智能焊笔头具有独特的序列号,实现完全可追溯性 - 使用Tip Offset Function可以调整传感器的参考点以实现高精度
应用信息: - 适用于所有微型和标准焊接应用 - Weller的主动尖端技术(墨盒)提供优化的热传递和12V性能 - 极快的3秒热启动时间,实现高性能的连续工作流程
封装信息: - 智能焊笔头与WXMPS MS智能焊台和WXsmart焊接站兼容 - Weller WXsmart焊接站能自动识别每个RTMS墨盒焊笔头
T0050110599 价格&库存
很抱歉,暂时无法提供与“T0050110599”相匹配的价格&库存,您可以联系我们找货
