www.weller-tools.com
SMART Ultra
RTUS 004 C X MS
SOLDERING TIP CONICAL BENT
0,4 MM
ORDER NO: T0050112499
Production within the electronics, medical technology and aerospace industries is moving faster than ever before, as components become more powerful. With a new generation of RTUS MS Smart Tips, Weller meets these increasing demands with its
Smart Tips that include an integrated chip in every soldering tip, which offer many new features to the user. Lock functions
make the soldering processes repeatable and transparent. Weller offers high power smart soldering tips for heavy duty and
large applications. Multilayers can be soldered safely.
KEY FEATURES
> RTUS 004 C X MS
Soldering tip conical bent 0,4 mm / 150 W
> MIL-SPEC
(IPC - TM-650 2.5.33)
> TOOL COMPATIBILITY
For use with WXUPS MS smart soldering iron and
WXsmart soldering station
> PERFECT FOR HEAVY-DUTY SOLDERING APPLICATIONS
The WXUPS uses Thermal Core Technology for optimized heat
transfer through the joint, with 150W performance for maximum
power. It covers heavy-duty applications with large component
sizes from 1612 and bigger (XL to XXL)
> EXTREMELY FAST 7-SECOND HEAT-UP TIME FOR
HEAVY-DUTY APPLICATIONS
Weller’s active tip technology (cartridge) provide an optimized
heat transfer with 150 W maximum power, 24 V performance.
The extremely fast 7-second heat-up time delivers excellent heat
transfer and recovery time during the soldering process for a highperformance continuous workflow.
> MAXIMUM PRECISION
Short tip-to-grip distance and optimized shape provides maximum
precision during the soldering process.
> THERMAL CORE TECHNOLOGY PROVIDES HIGH POWER
AT THE TIP POINT
150 W delivers maximum power through the joint so even
multilayer boards can be soldered precisely
> FULL PROCESS CONTROL WITH TIP LOCK FUNCTION
Locked parameters on tip allows full process control and prevents
for default during the soldering process
> FULL TRACEABILITY WITH TIP ID NUMBER AND
INTEGRATED DATA STORAGE
Each smart soldering tip has a unique individual serial number
for full traceability. The integrated data storage provides full
traceability of calibration history
> ACCURATE DATA RESULTS WITH TIP-OFFSET FUNCTION
Using the Tip Offset Function, you can easily change the reference
point of the sensor. Just add the measured positional offset value
and the sensor’s origin will be translated and reset. Tip Offset provides a simple way to get the best results and achieve the highest
degree of accuracy.
> FAST, SAFE AND EASY TIP EXCHANGE
The patented Weller RT US smart cartridge tips can be changed
quickly without the need of any additional tool, despite hot
temperature conditions.
> MAXIMUM PROTECTION
The RTUS smart soldering tips are fully compliant with IPC industry standards (IPC - TM-650 2.5.33 Measurement of Electrical
Overstress from Soldering Hand Tools) and are also MIL-SPEC
compliant. This provides maximum protection to both the printed
circuit board and components, achieving excellent results, while
keeping operating costs low.
> CLEAR IDENTIFICATION OF SMART TIPS
The Weller WXsmart soldering station identifies each
RTUS cartridge tip automatically
weller-tools.com
Weller® is a registered trademark of Apex Brands, Inc. © 2022 | Specifications subject to change without notice.
www.weller-tools.com/wxsmart
很抱歉,暂时无法提供与“T0050112499”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+599.517361+77.92264
