WE1010EDU
WE1010EDU
    ATG
    WE1010 EDUCATION KIT
WE1010EDU 数据手册
Get ready to SOLDER Everything you need WE 1010 Professional Education Kit First education kit for professional needs WE 1010 Education Kit is the first professional soldering equipment custom-built for academic and educational purposes. Download & Explore Product Information WE Education Kit Everything you need Professional, safe and intuitive, the WE Education Kit empowers students by providing high efficiency and precision that is seen at the professional level. This all-in-one kit gives teachers and students the ability to take their ideas to reality quicker. Soldering Station WE 1010NA ›› Easy to handle high performance iron 70W ›› Temperature stability and temperature lock protects tips and components and allows reliably high quality, repeatable soldering results ›› Standby mode and auto setback conserves energy, protects equipment ›› ESD safe heat-resistant silicon cable ›› Password-protected to preserve settings Weller Xcelite 170MN Shearcutter ›› Low profile, general-purpose cutter ›› Greatly reduced mechanical shock delivered to the work ›› Flush cuts soft wire up to 20 AWG (0.8 mm) Spool of Lead-Free Solder Wire 0.8 mm ›› All purpose solder wire, use in a wide range of applications ›› Excellent wetting properties WE Education Kit Order no. Includes: WE1010EDU WE 1010NA Station 120 VAC WEP 70 Soldering Pencil PH70 Safety Rest and TC205 Sponge ETA Soldering Tip 0.062“ / 1.6 mm ETB Soldering Tip 0.094“ / 2.4 mm 170MN Shearcutter WSW SCN M1 Solder Wire 0.8 mm, 100 g ›› RoHS Compliant soldering wire - LEAD FREE ETB Soldering Tip 2.4 mm ›› Additional soldering tip with wider dimensions ›› Wide range of ET soldering tips available Also included Build Your Workbench Technical Data Dimensions L x W x H 150 x 125 x 100 mm 5.91 x 4.92 x 3.94 inches Order no. Description: Power supply 120 V / 60 Hz T0051502699N ESF120 Benchtop PCB Holder Power 70 W T0051301799N SD 1000 Solder Wire Holder Temperature range 200°F–850°F; 100°C – 450°C T0051303199 Tip Activator Temperature accuracy +/- 17°F , 9°C 7874B 7874B Desolder Pump Temperature stability +/- 10°F , 6°C weller-tools.com Weller® is a registered trademark of Apex Brands, Inc. | Wel-0002 Specifications subject to change without notice. ET Series Soldering Tips
WE1010EDU 价格&库存
很抱歉,暂时无法提供与“WE1010EDU”相匹配的价格&库存,您可以联系我们找货
