CF-TB-1AS3-155C-A
CF-TB-1AS3-155C-A
    NIDEC(尼得科)
    SWITCH TOGGLE
CF-TB-1AS3-155C-A 数据手册
CF-TB Miniature Power Toggle Switch RoHS Compliant ■    ■Features 1. Miniature toggle switch with small footprint. 15A 125VAC 8A 250VAC 2. Reinforced insulation by adopting resin frame & lever. Rating 3. C-US UL recognized. PSE Initial contact resistance 30mΩ max. 4. 90 A inrush current capability. Dielectric strength 1,500VAC 1 minute Insulation resistance 100MΩ min. Electrical life 50,000 cycles Locknut tightening torque 78.4N・cm max. Operating temperature range −10∼+65℃ Storage temperature range −20∼+85℃ C-US・UL 15 (15) A 127VAC 8 (8) A 250VAC (1A 2∼4VDC) (500VDC) ■Part Numbering CF−TB − 1 A S3 − 15 5 C Series code Number of poles Switching function A 1 1 pole Terminal style ON-OFF S3 Screw(M3.5×0.6) Current 15 15A − A Form of packaging C Cardboard box Blank Bulk Internal identification number A With accessories Blank Without accessories CF-TB CF-TB-1AS3 SPST Key way Switching function 12 ±1 26.3 ±0.5 (Unit:mm) 19.2 ±0.5 1.5 ±0.3 7.1 Part No. CF-TB-1AS3-155 .5 M12×1 7.5 ±0.2 R0 14 ±0.2 7.6 8 CF-TB-1AS3-155C ±6° 22.5 ±0.3 10 ±0.2 A 20° 18 - 1 +0.3 CF-TB-1AS3-155-A ON OFF 1−3 − 3 CF-TB-1AS3-155C-A 0.8±0.4 B 1.8±0.3 Key way Connecting terminals (INCOMPLETE THREAD) 2 M3.5×0.6 6 R4 Terminal numbers are shown on the bottom of the switch. 16.1 ■List of Part Numbers Part No. Accessories Pieces in package Form of packaging CF-TB-1AS3-155 Without 5pcs./pack Bulk CF-TB-1AS3-155C Without 1,000pcs./pack Cardboard box CF-TB-1AS3-155-A With 5pcs./pack Bulk CF-TB-1AS3-155C-A With 1,000pcs./pack Cardboard box ■Standard Accessories 《Supplied separately》 Part Name Screw Lockwasher Locknut Lockwasher Part No. 140000080993 140008030061 140008010286 140008030062 Ø 7.5 14 M12 ×1 Ø 15.2 ±0.6 0.5 0.5 2 0 Dimensions 0 - 0.5 5 - 0.6 2.3 Ø6 M3.5×0.6 ※This cannot be sold separately. ■Panel Cut-Out Dimensions ■     Panel thickness : 4 mm max. (Unit:mm) φ12.3 11.6 340 70 (Unit:mm) 500 210 1000 pcs. 1.5 60 60 5 pcs.
CF-TB-1AS3-155C-A 价格&库存
很抱歉,暂时无法提供与“CF-TB-1AS3-155C-A”相匹配的价格&库存,您可以联系我们找货
