SGE108CV-A-Z
SGE108CV-A-Z
    NIDEC(尼得科)
    SWITCH TRIGGER
SGE108CV-A-Z 数据手册
SGEL108/106CV Dustproof Speed Controllable Trigger Switches for AC Power With Variable Speed Control RoHS Compliant ■       ■Features 1. High-Current Trigger Switch With Speed Controller High current, compact trigger switch with speed control circuit for AC power. 2 . Junction Terminal For Easy Wiring Junction terminals and terminals for noise canceller capacitor are also provided, which makes wiring work easy and simple. 3. Variable Speed Control Rating 108CV type 8A 125V AC (Resistive or inductive load) 106CV type 6A 250V AC (Resistive or inductive load) Dielectric strength 2,000VAC 1 minute Insulation resistance 100MΩ min. Electrical life 50,000 operations 108CV type : 125VAC 48/8A P.f. 0.6/0.9 106CV type : 250VAC 36/6A P.f. 0.6/0.9 Available with or without speed adjustment knob. 4. For 100 VAC and 200 VAC 100~130 VAC and 220 V~240 VAC (50/60 Hz) are available to comply with the different voltage requirements of each countries throughout the world. Operating force 11.8∼24.5N Operating temperature range Storage temperature range −10∼+65℃ (500VDC) −20∼+80℃ 5. Dustproof The switch has no openings which assures excellent protection against dust. 6. High Reliability The sliding contact mechanism (wipe mechanism) assures high contact reliability.    ■Part Numbering SG  E    L  108CV  −  A  − Series code Dustproof Lock mechanism Applicable voltage range Actuator shape None Without 108CV AC100∼AC130V None Standard type L With 106CV AC220∼AC240V A With speed adjustment knob ※ It is all an inquiry product. Please consult us for ordering. Z SGEL 108/106CV Dustproof ■Table of Part Numbers Speed adjustment knob ■      Standard type Applicable voltage range Without lock mechanism AC100V∼130V With lock mechanism − SGE108CV−Z IT(AV) サITSM VRRM 8A 120A 600V :     Without − AC220V∼240V − AC100V∼130V SGE108CV−A−Z SGEL108CV−A−Z AC220V∼240V SGE106CV−A−Z SGEL106CV−A−Z With ■Wiring Diagram ■Circuit Diagram Trigger position A Control range From A pos. 1.2−7.3mm Short range From A pos. 7.3−9.2mm OFF ON ON Circuit diagram 1↑・2↑ :Terminals for power source C1・C2 :Terminals for capacitor M1・M2 :Terminals for motor load − ■Control Characteristics 108CV type (At 120VAC 60Hz) 106CV type (At 240VAC 50Hz) SGE 108 Dustproof SGE108CV−Z Standard type Dustproof SGEL108/106CV−A−Z With Speed Adjustment Knob 5E Dustproof ■Customizations ■Precautions ・Customization of colors, shapes, etc. of the trigger, knob, lever, etc. 1. Tightening torque for the terminal screw. are available.  :58.8N・cm max. 2. Lead Wire (1)Terminal portion for the motor load and power source.   (1↑・2↑・M1 ・M2)   : AWG18(Dia of covered wire = 3 mm max.) (2)Terminal portion for the capacitor.(C1 ・C2)   : AWG20∼24(Dia of covered wire = 2 mm max.) (3)Wire stripping   : 8∼8.5 mm
SGE108CV-A-Z 价格&库存
很抱歉,暂时无法提供与“SGE108CV-A-Z”相匹配的价格&库存,您可以联系我们找货
