82344934
82344934
    CROUZET(高诺斯)
    同步 交流电机 齿轮电机 12 RPM 3W 115VAC
82344934 数据手册
Single direction synchronous geared motors ➜ 0.5 Nm 3 Watts ■ ■ ■ ■ Mechanical strength : 0.5 Nm Constant speed, dependent on supply frequency Wide range of speeds available Direction of rotation controlled by long-life mechanical anti-return device ■ Permanent magnet rotor Specifications Type Voltage / Frequency Direction of rotation Output Ratios (i) speed 72 rpm 10 60 rpm 12 48 rpm 20 24 rpm 30 18 rpm 40 15 rpm 48 14.4 rpm 50 12 rpm 60 9 rpm 80 7.2 rpm 100 6 rpm 120 4.8 rpm 150 3.6 rpm 200 3 rpm 240 2.4 rpm 300 1.2 rpm 600 0.80 rpm 750 0.60 rpm 1200 0.40 rpm 1800 0.30 rpm 2400 0.24 rpm 3000 0.12 rpm 6000 6.00 rph 7200 4.80 rph 9000 3.60 rph 12000 3.00 rph 14400 1.20 rph 36000 0.60 rph 72000 1/10 rph 432000 1/240 rph 864000 General characteristics Motor Gearbox Maximum permitted torque from gearmotor under continuous conditions for 1 millions turns of the gearmotor Nm Axial load (static) daN Radial load (static) daN Absorbed power (W) Motor output (W) Maximum temperature rise (oC) Ambient temperature (oC) Weight (g) Wires length mm (approximately) Protection rating 3 Watts 3 Watts 3 Watts 3 Watts 82 344 0 115 V 60 Hz Counter-clockwise 82 344 0 115 V 60 Hz Clockwise 82 344 0 220 V 60 Hz Counter-clockwise 82 344 0 220 V 60 Hz Clockwise 82 344 0A20072MB 82 344 0A20060MB 82 344 0A20048MB 82 344 0A20024MB 82 344 0A20018MB 82 344 0A20015MB 82 344 0A214.4MB 82 344 0A20012MB 82 344 0A20009MB 82 344 0A207.2MB 82 344 0A20006MB 82 344 0A204.8MB 82 344 0A203.6MB 82 344 0A20003MB 82 344 0A202.4MB 82 344 0A201.2MB 82 344 0A200.8MB 82 344 0A200.6MB 82 344 0A200.4MB 82 344 0A200.3MB 82 344 0A20.24MB 82 344 0A20.12HB 82 344 0A20006HB 82 344 0A204.8HB 82 344 0A203.6HB 82 344 0A20003HB 82 344 0A201.2HB 82 344 0A200.6HB 82 344 0A200.1HB 82 344 0A20.05HB ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 82 344 0A10072MB 82 344 0A10060MB 82 344 0A10048MB 82 344 0A10024MB 82 344 0A10018MB 82 344 0A10015MB 82 344 0A114.4MB 82 344 0A10012MB 82 344 0A10009MB 82 344 0A107.2MB 82 344 0A10006MB 82 344 0A104.8MB 82 344 0A103.6MB 82 344 0A10003MB 82 344 0A102.4MB 82 344 0A101.2MB 82 344 0A100.8MB 82 344 0A100.6MB 82 344 0A100.4MB 82 344 0A100.3MB 82 344 0A10.24MB 82 344 0A10.12HB 82 344 0A10006HB 82 344 0A104.8HB 82 344 0A103.6HB 82 344 0A10003HB 82 344 0A101.2HB 82 344 0A100.6HB 82 344 0A100.1HB 82 344 0A10.05HB ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 82 344 0J20072MB 82 344 0J20060MB 82 344 0J20048MB 82 344 0J20024MB 82 344 0J20018MB 82 344 0J20015MB 82 344 0J214.4MB 82 344 0J20012MB 82 344 0J20009MB 82 344 0J207.2MB 82 344 0J20006MB 82 344 0J204.8MB 82 344 0J203.6MB 82 344 0J20003MB 82 344 0J202.4MB 82 344 0J201.2MB 82 344 0J200.8MB 82 344 0J200.6MB 82 344 0J200.4MB 82 344 0J200.3MB 82 344 0J20.24MB 82 344 0J20.12HB 82 344 0J20006HB 82 344 0J204.8HB 82 344 0J203.6HB 82 344 0J20003HB 82 344 0J201.2HB 82 344 0J200.6HB 82 344 0J200.1HB 82 344 0J20.05HB ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 82 344 0J10072MB 82 344 0J10060MB 82 344 0J10048MB 82 344 0J10024MB 82 344 0J10018MB 82 344 0J10015MB 82 344 0J114.4MB 82 344 0J10012MB 82 344 0J10009MB 82 344 0J107.2MB 82 344 0J10006MB 82 344 0J104.8MB 82 344 0J103.6MB 82 344 0J10003MB 82 344 0J102.4MB 82 344 0J101.2MB 82 344 0J100.8MB 82 344 0J100.6MB 82 344 0J100.4MB 82 344 0J100.3MB 82 344 0J10.24MB 82 344 0J10.12HB 82 344 0J10006HB 82 344 0J104.8HB 82 344 0J103.6HB 82 344 0J10003HB 82 344 0J101.2HB 82 344 0J100.6HB 82 344 0J100.1HB 82 344 0J10.05HB 82 340 0 81 021 0 0.5 82 340 0 81 021 0 0.5 82 340 0 81 021 0 0.5 82 340 0 81 021 0 0.5 1 8 3 0.16 55 1 8 3 0.16 55 1 8 3 0.16 55 1 8 3 0.16 55 -5 ➞ +60 160 250 -5 ➞ +60 160 250 -5 ➞ +60 160 250 -5 ➞ +60 160 250 IP40 IP40 IP40 IP40 Products and specifications subject to change without notice. Order/Technical Support - Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 4/84 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Products adaptations, available on request ■ ■ ■ ■ ■ ■ ■ ■ Special supply voltages Special lead lengths Special connectors Special output shafts Special gearbox ratios Special gear material Special output bearings Special mounting plate Curves Graph of torque versus speed 82 344 0 mN.m 500 400 300 200 150 100 80 60 40 30 20 1 2 3 4 56 10 15 30 60 B RPM Dimensions 82 344 0 2 3 1 4 B 2 fixing holes Ø 3.2 C (pushed-in shaft) D 3.5 across flat E Fixing clip 4 Options Shaft 79 200 967 Shaft 79 200 779 Shaft 70 999 421 SP1295-10 1 B (pushed-in shaft ← ) B (pushed-in shaft ← ) B Across flat Other information The speed of a motor powered by a 60 Hz supply is 20 % higher than that of a motor powered by a 50 Hz supply. Products and specifications subject to change without notice. Order/Technical Support - Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 4/85
82344934 价格&库存
很抱歉,暂时无法提供与“82344934”相匹配的价格&库存,您可以联系我们找货
