88980123
    CROUZET(高诺斯)
    选件卡,通信 Millenium 3 系列
88980123 数据手册
››em4 Accessories RS485 Interface, Modbus master / slave › Modbus RTU or ASCII RS485 master / slave standard widely used in industry ››Useful to connect one or several em4 to a programmable touch panel or a SCADA ››The removable connector allows to unplug em4 without cutting the network › Include End Of Line resistor › Direct connection with screw terminals without the need external accessories RS485 interface - Black Specific characteristics Part number 88 980 123 Finish Glossy black Color Black RAL 9011 General characteristics Protocol Master and Slave Modbus Compatible Base 24 VDC power supply version Protection rating (in accordance with IEC/EN 60529) IP 20 Type 2 wires transmission mode RTU 8 bits / ASCII 7 bits Parity None, even, odd Stop bit 1 or 2 Transmission rate 1200, 2400, 4800, 9600, 19200, 28800, 38400, 57600 bauds Adressing From 1 to 247 Line Terminaison included, connectable by wiring Line Polarization Without Compatible connector Phoenix contact: 1916410 Dinkle: EC350V-04P-BK Framatome connectors: 20020004-C042B01LF (Included with the interface) Weight Without packing: 13 g / With packing: 19 g Dimensions Without packing: 35 x 36 x 26 mm / 1.38 x 1.42 x 1.02 inch With packing: 80 x 140 x 30 mm / 3.15 x 5.51 x 1.18 inch Products certifications CE,cURus Conformity with the EMC directive (in accordance with 2014/30/EU) IEC/EN 61000-6-1 (Residential, commercial and light-industrial environments) IEC/EN 61000-6-2 (Industrial) IEC/EN 61000-6-3 (Residential, commercial and light-industrial environments) IEC/EN 61000-6-4 (Industrial) Operation temperature -20 (-4 °F) => +60°C (140 °F) (+40°C (104 °F) in a non-ventilated enclosure) Storage temperature -40 (-40 °F) => +80°C (176 °F) Relative humidity Maximum utilization altitude 95% max. (no condensation or dripping water) Operation: 2000 m / Transport: 3000 m Resistance to electrostatic discharge Immunity to ESD IEC/EN 61000-4-2, level 3 Resistance to HF interference (Immunity) Immunity to radiated electrostatic fields IEC/EN 61000-4-3, level 3 Immunity to fast transients (burst immunity) IEC/EN 61000-4-4, level 3 Immunity to shock waves IEC/EN 61000-4-5 Radio frequency in common mode IEC/EN 61000-4-6, level 3 Conducted and radiated emissions (in accordance with EN 55022/11 group 1) Class B I em4 I 02 I www.crouzet.com Diagrams Dimensions 34.5 / 1.35 23.5 / 0.92 mm inch 35.3 / 1.39 14.1 / 0.55 Connections
88980123 价格&库存
很抱歉,暂时无法提供与“88980123”相匹配的价格&库存,您可以联系我们找货
    • 1+1362.544051+169.10651
    库存:5
