››em4
Accessories
RS485 polarized interface, Modbus master / slave
Modbus RTU or ASCII RS485 master / slave standard
widely used in industry
››Useful to connect one or several em4 to a
programmable touch panel or a SCADA
››The removable connector allows to unplug em4
without cutting the network
› Include End Of Line resistor
› Direct connection with screw terminals without
the need external accessories
RS485 interface - Black
Specific characteristics
Part number
88 980 122
Finish
Glossy black
Color
Black RAL 9011
General characteristics
Protocol
Master and Slave Modbus
Compatible
Base 24 VDC power supply version
Protection rating (in accordance with IEC/EN 60529)
IP 20
Type
2 wires
transmission mode
RTU 8 bits / ASCII 7 bits
Parity
None, even, odd
Stop bit
1 or 2
Transmission rate
1200, 2400, 4800, 9600, 19200, 28800, 38400, 57600 bauds
Adressing
From 1 to 247
Line Terminaison
included, connectable by wiring
Line Polarization
Included
Compatible connector
Phoenix contact: 1916410 Dinkle: EC350V-04P-BK
Framatome connectors: 20020004-C042B01LF (Included with the interface)
Weight
Without packing: 13 g / With packing: 19 g
Dimensions
Without packing: 35 x 36 x 26 mm / 1.38 x 1.42 x 1.02 inch
With packing: 80 x 140 x 30 mm / 3.15 x 5.51 x 1.18 inch
Products certifications
CE,cURus
Conformity with the EMC directive
(in accordance with 2014/30/EU)
IEC/EN 61000-6-1 (Residential, commercial and light-industrial environments)
IEC/EN 61000-6-2 (Industrial)
IEC/EN 61000-6-3 (Residential, commercial and light-industrial environments)
IEC/EN 61000-6-4 (Industrial)
Operation temperature
-20 (-4 °F) => +60°C (140 °F) (+40°C (104 °F) in a non-ventilated enclosure)
Storage temperature
-40 (-40 °F) => +80°C (176 °F)
Relative humidity
Maximum utilization altitude
95% max. (no condensation or dripping water)
Operation: 2000 m / Transport: 3000 m
Resistance to electrostatic discharge
Immunity to ESD IEC/EN 61000-4-2, level 3
Resistance to HF interference
(Immunity)
Immunity to radiated electrostatic fields IEC/EN 61000-4-3, level 3
Immunity to fast transients (burst immunity) IEC/EN 61000-4-4, level 3
Immunity to shock waves IEC/EN 61000-4-5
Radio frequency in common mode IEC/EN 61000-4-6, level 3
Conducted and radiated emissions
(in accordance with EN 55022/11 group 1)
Class B
I em4
I 02
I www.crouzet.com
Diagrams
Dimensions
34.5 / 1.35
23.5 / 0.92
mm
inch
35.3 / 1.39
14.1 / 0.55
Connections
很抱歉,暂时无法提供与“88980122”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1470.936931+190.39185
- 国内价格 香港价格
- 1+1860.892331+240.86602
