| | 10/2020
››GNRS Smart Module Series
Essential Solid State Relays
DIN Rail - Module for GNR/GNR+
››Current range from 2 to 40 A
››Open Loads, Mains detection (and Partial Load braking)
››Under and Over current detection
››Current teaching function
››3 LED Status indicator
››IP20 touch-safe housing
››Spring Connector (84050043N)
84050040N
Current Monitoring
84050043N
Current Detection & Diagnostic
Product Selection
Rated Load Current
40A
32 Vc
24-45 Vc
Control Voltage
84050040N
4-32 Vc
84050043N
24-45 Vc
PART NUMBERING SYSTEM
Series
840: Single Phase
840
Default
0: N/A
5
Default
0: N/A
Input Voltage
0: 4-32 Vc
3: 24-45 Vc
Mounting Type
5: DIN Rail
1
N
Output Current
4: 40 A
Generation
N: New
Generation
GNR Smart
Module
Applications where loads are switched frequently
(ex: thermoset molding)
GNR Smart
Module
RÉFÉRENCEMENT
To detect load failures, blown fuses, heat zones status,
as well as damaged and interrupted SSRs
Série
Tension de sortie
8413: Monophasé
0: 280 Va / Synchrone
1: 660 Va / Synchrone
Do you need an adapted or customized solution? Contact us on www.crouzet.com
Applications where loads are switched frequently 2: 280 Va / Aléatoire
3: 660 Va / Aléatoire
Description:
8413
7
Génération
N: Nouvelle
génération
1
N
Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use,
To detect
load failures,
robust
and multipurpose.
For more information about Crouzet’s Solid State relays, please visit www.crouzet.com.
Couvercle/Disposition
7: Inclus
Courant de sortie
0: 10 A
1: 25 A
2: 50 A
3: 75 A
4: 100 A
Tension de contrôle
0: 4-32 Vc
1: 20-265 Va
2: 18-36 Vz
| | WWW.CROUZET.COM
|| 2
| | 10/2020
Power Supply Specifications
Description
40A
Supply voltage range
8-30 Vc
Nominal Supply current
20 mA
24-45 Vc
Input Specifications
Description
4-32 Vc
Minimum Input Current
0.3 mA
Maximum Input Current
20 mA
Maximum Turn-On Time (Ton)
15 ms
Maximum Turn-Off Time (Toff)
15 ms
24-45 Vc
1 mA
External Teach Specification
Description
40A
External Teach Voltage Range
4-32 Vc
24-45 Vc
0.3 mA
1.4 mA
3 mA
3.7 mA
Current sensing Specifications
Description
40A
Maximum Teach Current
40 A
Minimum Teach Current
2 A
Undercurrent Detection
Teach Current * 0.84 Arms
Overcurrent Detection (84050043N)
Teach Current * 1.16 Arms
Load Voltage Frequency Range
15-200 Hz
Load Voltage Range
Din Rail SSR voltage range
Number of Loads
1 to 5
General Specifications
Description
40A
Max. Turn Off time @ 50 Hz
15 ms
Max. Turn On time @ 50 Hz
15 ms
Ambient Operating Temperature Range
-40 °C to +80 °C
Ambient Storage Temperature Range
-40 °C to +100 °C
Weight (typical)
75 g
Housing Material
UL94 V-0
Humidity
40 to 85 %
LED Input Status Indicator
See LED Chart
Alarm Specifications
Description
40A
Output Voltage Range
4-32 Vc
Typical ON-state resistance
1 Ω
Maximum Ouput Current
100 mA
Minimum Output Current
3 mA
Maximum Number of Outputs Connected in Parallel
Up to 5
Alarm Delay
SeeLED Statut chart
No Mains Voltage/Open Load
40 ms
Detection Current Min/Max
0.5 A
24-45 Vc
| | WWW.CROUZET.COM
|| 3
| | 10/2020
General Notes
(1)
All parameters at 25 °C unless otherwise specified
Diagrams
Wiring
GNRS Smart
GNR
GNR SMART
Mains
Internal
power
supply
A1/+
+VDD
SSR
control
Input
A2/-
D
Us
Control
G
1
Uc
Programmable
logic control
S
2
Ic
3
44
Programmable
electronic
5
Load 5
Load 4
Load 3
Teaching pushbutton
Load 2
Load 1
GNRS
B
C
D
E
F
Supply +
Supply Control input
Diagnostic output
External teach input
Diagrams
Status Chart
LED Status 84050040N
LED Status 84050043N
LED INDICATOR
STATUS
Alarm
ON
INPUT
LED INDICATOR
Load
Current
Diagnostic
OUTPUT
STATUS
Alarm
ON
Input
Load
Current
Diagnostic
Output
No power
0A
Open (0V)
No power
0A
Closed (+VDD)
Normal Operation
=Iteach
Open (0V)
Normal Operation
=Iteach
Closed (+VDD)
Open Mains / Load
Blowed fuses
0A
Ton=100 ms
Toff=100 ms
Open Mains / Load
Blowed fuses
0A
Ton=2s
Toff=1s
Short Circuit
0A
Closed (+VDD)
Short Circuit SSR
0A
Ton=1s
Toff=1s
Partial Load Break
很抱歉,暂时无法提供与“84050040N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+905.644151+112.26550
- 5+845.298265+104.78490
- 10+794.4326910+98.47950
