| | 10/2020
››GNR+ Series
Performance Solid State Relays
DIN Rail - AC Output Single Phase
››Output current of 30, 32 and 45 Amps
››Output voltage of 25-500 Va
››Control voltage of 4-32 Vc and 180-280 Va
››Special zero cross (resistive, inductive and capacitive loads)
››Integrated IP20 touch-safe removable covers
››High immunity levels & built-in overvoltage protection
››LED input status indicator
Multi Loads
Version 45 mm
Multi Loads
Version 22.5 mm
Product Selection - Special Zero Cross (Resistive, Capacitive, Inductive)(3)
Rated Load Current
30A
Operating Voltage
32A
24-500 Va
24-500 Va
45A
24-500 Va
Control Voltage
4-32 Vc
GNR30DCZP
180-280 Va
GNR30ACZP
GNR32DCZP
GNR45DCZP
PART NUMBERING SYSTEM
Series
GNR: Single Phase
GNR
Control Voltage
DC: 4-32 Vc
AC: 180-280 Va
30 DC
Output Current
30: 30 A
32: 32 A
45: 45 A
Z
Type
R: Random
Z: Zero Cross
P
Output Voltage
P: 500 Va
RÉFÉRENCEMENT
Série
GNR: Monophasé
Tension de contrôle
DC: 4-32 Vc
AC: 180-280 Va
Do you need an adapted or customized solution? Contact us on www.crouzet.com
Description:
GNR
30 DC
Z
P
Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use,
robust and multipurpose.
For more information about Crouzet’s Solid State relays, please visit www.crouzet.com.
Courant de sortie
Type
30: 30 A
R: Aléatoire
32: 32 A
Z: Synchrone
45: 45 A
Tension de sortie
P: 500 Va
| | WWW.CROUZET.COM
|| 2
| | GNR+ Series
| | 10/2020
Accessories
Type
Description
Label
Label for SSR identification
Part-Number
26532004
Output Specifications(1)
Description
30A
Maximum Load Current [Arms])
30
Minimum Load Current [mArms]
5
Operating Voltage
24-500 Va
Transient Voltage [Vpk](2)
1200 (950)
Maximum Off-State Leakage Current @ Rated Voltage
[mArms]
1
Minimum Off-State dV/dt @ Maximum Rated Voltage [V/µsec]
500
32A
32
45A
45
1 Second Surge Current (Apk. Ta=25 °C) 50/60 Hz
165
347
165
Maximum 1 Cycle Surge Current (50/60 Hz) [Apeak]
Typ @ 50 Hz
530/_ (min)
1100/_ (min)
530/_ (min)
580 (typ)
1200 (typ)
580 (typ)
Maximum On-State Voltage Drop @ Rated Current [Vpeak]
1.08
1.14
1.19
Thermal Resistance Junction to Case (Rjc) [°C/W]
0.55
0.4
0.55
Maximum 1/2 Cycle I² t for Fusing @ 50 Hz (min./typical) [A²
sec]
1404/1680
6000/7200
1404/1680
Minimum Heat Sink for Rated Current @ 40 °C [°C/W]
N/A (SSR with heatsink)
Input Specifications
Description
4-32 Vc
180-280 Va
Control Voltage Range
4-32 Vc
180-280 Va
Maximum Reverse Voltage
-32 Vc
N/A (no polarity)
Minimum Turn-On Voltage
3.5 Vc
180 Va
Must Turn-Off Voltage
2 Vc
5 Va
Minimum Input Current (for on-state)
10 mA
4 mA
Maximum Input Current [mA]
14 mA
8 mA
Nominal Input Impedance [Ohms]
Current Limited
Maximum Turn-On Time [msec]
1/2 Cycle
Maximum Turn-Off Time [msec]
1/2 Cycle(5)
39 KΩ
(5)
General Specifications
Description
30A
Dielectric Strength, Input to Output (50/60 Hz)
4000 Vrms
Dielectric Strength, Input/Output to Ground (50/60 Hz)
4000 Vrms
Minimum Insulation Resistance (@ 500 Vc)
109Ω
Maximum Capacitance, Input/Output
0.8 pF
Ambient Operating Temperature Range(7)
-40 to 80 °C
Ambient Storage Temperature Range
-40 to 100 °C
Weight (typical)
80 g
Housing Material
UL94 V-0
Baseplate Material
Aluminum
Input Terminal Screw Torque Range (in-lb/Nm)
3.5-4.4 /0.4-0.5
Load Terminal Screw Torque Range (in-lb/Nm)
18-26 / 2-3
SSR Mounting Screw Torque Range (in-lb/Nm)
11-16 /1.2-1.8
Humidity per IEC60068-2-78
40-85 %
32A
45A
| | WWW.CROUZET.COM
|| 3
| | GNR+ Series
| | 10/2020
Description
30A
LED Input Status Indicator
Yellow
MTBF (Mean Time Between Failures) at 40 °C ambient
temperature (years)(5)
85
MTBF (Mean Time Between Failures) at 60 °C ambient
56
32A
45A
General Notes
(1)
All parameters at 25 °C unless otherwise specified
(2)
Output will self trigger between 450-600 Vpk not suitable for capacitive loads
(3)
Allows to support multi loads such as resistive, capacitive and Inductive loads
(4)
Increase minimum voltage by 1 V for operations from -20 to -40 °C
(5)
All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report)
Diagrams
Wiring
GNR+
1 (a)
TERMINALS
4 (-/a)
Terminal Screw
Torque (N.m)
STRANDED
Input
18..14 AWG (0.75..2.5 mm²)
2 x 18..14 AWG (0.75..2.5 mm²)
26..12 AWG (0.2..2.5 mm²)
2 x 26..12 AWG (0.2..2.5 mm²)
0.4 - 0.5
Output
16..8 AWG (1.5..10 mm²)
2 x 16..8 AWG (1.5..10 mm²)
16..8 AWG (1.5..6 mm²)
2 x 16..10 AWG (1.5..6 mm²)
2-3
3 (+/a)
V
WIRE SIZE
SOLID
2 (a)
1
GNR+
B
Load
Diagrams
Equivalent Circuit Block
Input current vs Input Voltage
Standard Regulated AC inputs
14
12
10
Input Current (mA)
GNR+ series 4-32 Vc control
8
6
4
2
4
6
8
10
12
14
16
18
Input Voltage (V)
24
26
28
30
32
| | WWW.CROUZET.COM
|| 4
| | GNR+ Series
| | 10/2020
GNR+ series 180-280 Va control
Standard Regulated DC inputs
7
6
Input Current (mA)
5
4
3
2
1
2 2 ,5
17
60
80
100 120 140 160 180 200 220 240 260 280
-1
Input Voltage (V)
Diagrams
Dimensions (mm)
GNR+ 22.5 mm front view
GNR+ 22.5 mm side view
98
2 7 ,79 0
17
80
4 7 ,6
17
2 7 ,7
2 2 ,5
94
66
98
94
GNR+ 45 mm front view - GNR45DCZP
45
98
90
2 7 ,7
90
4 7 ,6
80
17
80
4 7 ,6
94
66
66
45
98
Curves
94
600
GNR+ - 32 A
4 7 ,6
80
GNR+ - 30 A
90
Surge Current Information
1200
1100
1000
900
66
400
Itsm ( Apeak)
Itsm ( Apeak)
500
300
200
800
700
600
500
400
300
100
200
100
0,1
No Repetitive Surge Current
T (s)
1
10
0,1
T (s)
1
10
| | WWW.CROUZET.COM
|| 5
| | GNR+ Series
| | 10/2020
GNR+ - 45 A
600
Itsm ( Apeak)
500
400
300
200
100
0,1
T (s)
1
10
Curves
Thermal Derating Curves
GNR+ - 30 A
GNR+ - 32 A
35
35
30
30
25
25
GNR+ - 45 A
50
45
15
10
35
30
Current (Arms)
Current (Arms)
Current (Arms)
40
15
10
25
10
5
5
5
40
50
Ambient Temperature (°C)
60
70
80
40
50
60
70
80
40
50
60
70
80
3
C°/W
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to
modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate
tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction
with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
很抱歉,暂时无法提供与“GNR45DCZP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1185.12849
- 10+991.99644
