GNR30DCZP
GNR30DCZP
    CROUZET(高诺斯)
    模块
    固态 SPST-NO(1 Form A) 模块
GNR30DCZP 数据手册
| | 10/2020 ››GNR+ Series Performance Solid State Relays DIN Rail - AC Output Single Phase ››Output current of 30, 32 and 45 Amps ››Output voltage of 25-500 Va ››Control voltage of 4-32 Vc and 180-280 Va ››Special zero cross (resistive, inductive and capacitive loads) ››Integrated IP20 touch-safe removable covers ››High immunity levels & built-in overvoltage protection ››LED input status indicator Multi Loads Version 45 mm Multi Loads Version 22.5 mm Product Selection - Special Zero Cross (Resistive, Capacitive, Inductive)(3) Rated Load Current 30A Operating Voltage 32A 24-500 Va 24-500 Va 45A 24-500 Va Control Voltage 4-32 Vc GNR30DCZP 180-280 Va GNR30ACZP GNR32DCZP GNR45DCZP PART NUMBERING SYSTEM Series GNR: Single Phase GNR Control Voltage DC: 4-32 Vc AC: 180-280 Va 30 DC Output Current 30: 30 A 32: 32 A 45: 45 A Z Type R: Random Z: Zero Cross P Output Voltage P: 500 Va RÉFÉRENCEMENT Série GNR: Monophasé Tension de contrôle DC: 4-32 Vc AC: 180-280 Va Do you need an adapted or customized solution? Contact us on www.crouzet.com Description: GNR 30 DC Z P Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use, robust and multipurpose. For more information about Crouzet’s Solid State relays, please visit www.crouzet.com. Courant de sortie Type 30: 30 A R: Aléatoire 32: 32 A Z: Synchrone 45: 45 A Tension de sortie P: 500 Va | | WWW.CROUZET.COM || 2 | | GNR+ Series | | 10/2020 Accessories Type Description Label Label for SSR identification Part-Number 26532004 Output Specifications(1) Description 30A Maximum Load Current [Arms]) 30 Minimum Load Current [mArms] 5 Operating Voltage 24-500 Va Transient Voltage [Vpk](2) 1200 (950) Maximum Off-State Leakage Current @ Rated Voltage [mArms] 1 Minimum Off-State dV/dt @ Maximum Rated Voltage [V/µsec] 500 32A 32 45A 45 1 Second Surge Current (Apk. Ta=25 °C) 50/60 Hz 165 347 165 Maximum 1 Cycle Surge Current (50/60 Hz) [Apeak] Typ @ 50 Hz 530/_ (min) 1100/_ (min) 530/_ (min) 580 (typ) 1200 (typ) 580 (typ) Maximum On-State Voltage Drop @ Rated Current [Vpeak] 1.08 1.14 1.19 Thermal Resistance Junction to Case (Rjc) [°C/W] 0.55 0.4 0.55 Maximum 1/2 Cycle I² t for Fusing @ 50 Hz (min./typical) [A² sec] 1404/1680 6000/7200 1404/1680 Minimum Heat Sink for Rated Current @ 40 °C [°C/W] N/A (SSR with heatsink) Input Specifications Description 4-32 Vc 180-280 Va Control Voltage Range 4-32 Vc 180-280 Va Maximum Reverse Voltage -32 Vc N/A (no polarity) Minimum Turn-On Voltage 3.5 Vc 180 Va Must Turn-Off Voltage 2 Vc 5 Va Minimum Input Current (for on-state) 10 mA 4 mA Maximum Input Current [mA] 14 mA 8 mA Nominal Input Impedance [Ohms] Current Limited Maximum Turn-On Time [msec] 1/2 Cycle Maximum Turn-Off Time [msec] 1/2 Cycle(5) 39 KΩ (5) General Specifications Description 30A Dielectric Strength, Input to Output (50/60 Hz) 4000 Vrms Dielectric Strength, Input/Output to Ground (50/60 Hz) 4000 Vrms Minimum Insulation Resistance (@ 500 Vc) 109Ω Maximum Capacitance, Input/Output 0.8 pF Ambient Operating Temperature Range(7) -40 to 80 °C Ambient Storage Temperature Range -40 to 100 °C Weight (typical) 80 g Housing Material UL94 V-0 Baseplate Material Aluminum Input Terminal Screw Torque Range (in-lb/Nm) 3.5-4.4 /0.4-0.5 Load Terminal Screw Torque Range (in-lb/Nm) 18-26 / 2-3 SSR Mounting Screw Torque Range (in-lb/Nm) 11-16 /1.2-1.8 Humidity per IEC60068-2-78 40-85 % 32A 45A | | WWW.CROUZET.COM || 3 | | GNR+ Series | | 10/2020 General Specifications Description 30A LED Input Status Indicator Yellow MTBF (Mean Time Between Failures) at 40 °C ambient temperature (years)(5) 85 MTBF (Mean Time Between Failures) at 60 °C ambient temperature (years)(5) 56 32A 45A General Notes (1) All parameters at 25 °C unless otherwise specified (2) Output will self trigger between 450-600 Vpk not suitable for capacitive loads (3) Allows to support multi loads such as resistive, capacitive and Inductive loads (4) Increase minimum voltage by 1 V for operations from -20 to -40 °C (5) All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report) Diagrams Wiring GNR+ 1 (a) TERMINALS 4 (-/a) Terminal Screw Torque (N.m) STRANDED Input 18..14 AWG (0.75..2.5 mm²) 2 x 18..14 AWG (0.75..2.5 mm²) 26..12 AWG (0.2..2.5 mm²) 2 x 26..12 AWG (0.2..2.5 mm²) 0.4 - 0.5 Output 16..8 AWG (1.5..10 mm²) 2 x 16..8 AWG (1.5..10 mm²) 16..8 AWG (1.5..6 mm²) 2 x 16..10 AWG (1.5..6 mm²) 2-3 3 (+/a) V WIRE SIZE SOLID 2 (a) 1 GNR+ B Load Diagrams Equivalent Circuit Block Input current vs Input Voltage Standard Regulated AC inputs 14 12 10 Input Current (mA) GNR+ series 4-32 Vc control 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 Input Voltage (V) 20 22 24 26 28 30 32 | | WWW.CROUZET.COM || 4 | | GNR+ Series | | 10/2020 Input current vs Input Voltage GNR+ series 180-280 Va control Standard Regulated DC inputs 7 6 Input Current (mA) 5 4 3 2 1 2 2 ,5 0 2 7 ,7 17 0 20 40 60 80 100 120 140 160 180 200 220 240 260 280 -1 Input Voltage (V) Diagrams Dimensions (mm) GNR+ 22.5 mm front view GNR+ 22.5 mm side view 98 2 7 ,79 0 17 80 4 7 ,6 17 2 7 ,7 2 2 ,5 94 66 98 94 GNR+ 45 mm front view - GNR45DCZP GNR+ 45 mm front view 45 98 90 2 7 ,7 90 4 7 ,6 80 17 80 4 7 ,6 94 66 66 45 98 Curves 94 600 GNR+ - 32 A 4 7 ,6 80 GNR+ - 30 A 90 Surge Current Information 1200 1100 1000 900 66 400 Itsm ( Apeak) Itsm ( Apeak) 500 300 200 800 700 600 500 400 300 100 200 100 0 0,01 0,1 No Repetitive Surge Current Repetitive Surge Current T (s) 1 10 0 0,01 0,1 No Repetitive Surge Current Repetitive Surge Current T (s) 1 10 | | WWW.CROUZET.COM || 5 | | GNR+ Series | | 10/2020 GNR+ - 45 A 600 Itsm ( Apeak) 500 400 300 200 100 0 0,01 0,1 T (s) 1 10 No Repetitive Surge Current Repetitive Surge Current Curves Thermal Derating Curves GNR+ - 30 A GNR+ - 32 A 35 35 30 30 25 25 20 20 GNR+ - 45 A 50 45 15 10 35 30 Current (Arms) Current (Arms) Current (Arms) 40 15 10 25 20 15 10 5 5 5 0 0 10 20 30 40 50 Ambient Temperature (°C) 60 70 80 0 0 10 20 30 40 50 Ambient Temperature (°C) 60 70 80 0 0 10 20 30 40 50 60 70 80 Ambient Temperature (°C) 3 C°/W Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
GNR30DCZP 价格&库存
很抱歉,暂时无法提供与“GNR30DCZP”相匹配的价格&库存,您可以联系我们找货
GNR30DCZP
  • 1+928.895371+116.18353
库存:1
