MDF1R10MV2
MDF1R10MV2
    CROUZET(高诺斯)
    可编程(多功能) 延时继电器 SPDT(1 Form C) 0.05 秒 ~ 9999 小时 延时 10A @ 250VAC 可插
MDF1R10MV2 数据手册
Syr-line TMR48D Digital Timer Front Panel 48x48 (1/16 DIN) › › › › › › › › › › › › › Large LED or LCD Screen (13.2 mm) Multi-function and single-function Basic & Advance configuration modes Multi-range (0.05 s – 9999 h) Multi-voltage (24-240 V AC/DC) 1 or 2 relay outputs (Changeover) Memory option in event of a break in supply Lock function Up or down timing DIN Sized (48x48 mm) Housing Compact body (63 mm long) Water & Dust-proof (IP66) 8-Pins & 11-Pins connections Standard Version Performance Version (MDE1) (MDA2, MDF1, GDF1, GDS2) Product Selection Type Part Number Function Connections Output Supply Voltage Screen MDE1 MDE1R0524U A, B, C, H, D, Di 8-Pins 1 x 5A 24 V AC/DC LCD MDE1 MDE1R05MVA A, B, C, H, D, Di 8-Pins 1 x 5A 100-240 V AC/DC LCD MDA2 MDA2R10MV2 A 8-Pins 2 x 10A 24-240 V AC/DC LED MDF1 MDF1R10MV2 A, Ac, Ad, B, C, H, L, Li, D, Di 8-Pins 1 x 10A 24-240 V AC/DC LED GDF1 GDF1R10MV2 A, Ac, Ad, B, C, H, L, Li, D, Di 11-Pins 1 x 10A 24-240 V AC/DC LED GDS2 GDS2R10MV2 A, Ab, Ac, Ad, AMt, At, B, C, H, Ht, L, Li, T, W, D, Di 11-Pins 2 x 10A 24-240 V AC/DC LED Function A: ON-Delay E: Multifunction E F: Multifunction F S: Multifunction S GD S 2 Power Supply Output Type R: Relay R 10 MV2: 24-240 V AC/DC MVA: 100-240 V AC/DC 24U: 24 V AC/DC MV2 Type Output Quantity Output Power MD: Digital 8-Pins GD: Digital 11-Pins 1: 1 Output 2: 2 Outputs 10: 10 A 05: 5 A Description: The new Syr-line Digital Timers has higher precision and many programming features with the biggest screen ever seen in the timer relays’ market and the most intuitive programming for ease to use and fast configuration For more information about the Syr-line TMR48D Digital Timer please visit www.crouzet.com. Input Specifications Description Rated supply voltage Un MDE1…24U MDE1…MVA GDF1 MDF1 MDA2 GDS2 24 V AC/DC 100-240 V AC/DC 24-240 V AC/DC 24-240 V AC/DC 24-240 V AC/DC 24-240 V AC/DC MDA2 GDS2 -15 %, +10 % Voltage supply tolerance 50 / 60 Hz +/- 5% AC supply voltage frequency No Galvanic isolation of supply / inputs 2.5 VA (VAC) 1 W (VDC) Max power consumption @ Un 10 ms Immunity to power micro cuts Timing Specifications Description MDE1…24U Specified time ranges (10) IEC 1812-1: 0.001 s to 9.999 s, 0.01 s to 99.99 s, 0.1 s to 999.9 s, 1 s to 9999 s, 1 s to 99 min 59 s, 0.1 min to 999.9 min, 1 min to 9999min, 1 min to 99h 59 min, 0.1 h to 999.9 h, 1 h to 9999 h MDE1…MVA GDF1 MDF1 IEC 1812-1: 1 ms or 20 ms selectable Minimum control pulse duration IEC 1812-1: 120 ms Max Recovery time (after by de-energization) Repeatability IEC 1812-1: ≤ ± 0.03 % ± 20 ms (VDC) / 50 ms (VAC) Setting Accuracy IEC 1812-1: ≤ ± 0.03 % ± 20 ms (VDC) / 50 ms (VAC) Temperature drift ≤ ± 0.03 % ± 20 ms (VDC) / 50 ms (VAC) Voltage drift ≤ ± 0.03 % ± 20 ms (VDC) / 50 ms (VAC) Output Specifications Description Contact arrangement Maximum switching voltage Switching current rate (resistive) Maximum switching power (resistive) Electrical life at nominal switching current rate (resistive) MDE1…24U MDE1…MVA GDF1 MDF1 1 CO (SPDT) 2 CO (SPDT) 250 VAC / 30 VDC 250 VAC / 10 A resistive / 125 VDC / 0.3 A resistive 250 VAC / 10 A resistive / 125 VDC / 0.3 A resistive NO/NC: 2x10 A @ 40 °C 250 V NO: 5A 250 VAC / 5 A 30 VDC NO / NC: 10 A 250 VAC / 10 A AC / 2x10 A @ 40 °C 30 VDC - NC: 3A 250 VAC / 3 A 30 30 VDC NO / NC: 2x8 A @ 60 °C 250 V VDC AC / 2x8A @ 60 °C 30 VDC NO: 1250 VA / 150 W – NC: 750 VA / 90 W 2500 VA / 300 W 2 x 2500 VA / 2 x 300 W 1x105 cycles NO 7x104 cycles NC 1x105 cycles (10 A 250 VAC resistive) 1x105 cycles (10 A 250 VAC resistive) 10 mA / 12 VDC Maximum rate (at max switching power) 360 cycles /hour Dielectric strength between open contacts GDS2 1 CO (SPDT) Minimum switching contact Mechanical life MDA2 10 x 106 cycles 1 kV / 1 min / 1 mA / 50 Hz Page 2 of 14 Insulation Specifications Description MDE1…24U MDE1…MVA GDF1 MDF1 MDA2 GDS2 IEC 60664-1: 300 V Rated Insulation voltage Insulation coordination IEC 60664-1: Overvoltage category III; pollution degree 2 Rated impulse voltage IEC 60664-1: 4 kV (1.2/50 μs) Clearance / Creepage distances IEC 60664-1: 3 mm / 3.2 mm Dielectric strength EN-61812-1: 2.5 kV / 1 min / 1 mA / 50 Hz Insulation Resistance NFC 93 050: > 500 MΩ / 250 VDC / 1min General Specifications Description Display Memory backup Casing Mounting position Mounting Housing material Degree of protection (Front Face) Degree of protection (Housing) Operating temperature Storage temperature Humidity Vibration resistance Shock resistance Drop to concrete floor Weight MDE1…24U 4 digits per value 7 segments LCD MDE1…MVA GDF1 MDF1 MDA2 GDS2 4 digits per value 7 segments LCD 4 digits per value 7 segments LCD with backlight 4 digits per value 7 segments LCD with backlight 4 digits per value 7 segments LCD with backlight 4 digits per value 7 segments LCD with backlight EEPROM (rewrite 1,000,000 times min, 40 years data hold min) 48x48 mm (1/16 DIN) All positions Mounting Front panel, by clip Mounting base-mounted on socket UL94: enclosure plastic type V0 IEC 60529: IP66 with front panel seal IEC 60529: IP20 IEC 60068-2: -10 °C to +60 °C IEC 60068-2: -30 °C to +70 °C IEC 60068-2-30: 93 % without condensation IEC 60068-2-6: ±0.15 mm 10 Hz - 60 Hz 2 g 60 Hz - 150 Hz IEC60068-2-27: 15 gn – 11 ms, 3 x 6 axis (Output non-energized) 5gn – 11 ms, 3 x 6 axis (Output energized) IEC 60068-2-32: Height: 0.75 m Approx. 105 g (150 g with packing) Page 3 of 14 Standards Specifications Description EU Directives Approvals / Marking Security standard Conformity with environmental directives Product standard Immunity to electrostatic discharges MDE1…24U MDE1…MVA GDF1 MDF1 MDA2 GDS2 2014/30/EU: EMC, 2014/35/EU: Low voltage CE, cULus Listed Industrial Control Equipment IEC 60664-1: Insulation coordination for equipment within low-voltage systems 2015/863/UE: RoHS 1907/2006: Reach 2012/19/UE: WEEE IEC 61812-1: Specified time relays for industrial use UL 508 (60947-4-1): Industrial Control Equipment (NRNT- Industrial Control Switches) Level III Air +/-8 KV / Contact +/-6 KV Immunity to radiated, radio-frequency, electromagnetic field IEC61000-4-3: Level III, 10 V/m (80 MHz to 1 GHz) 80% AM (1 kHz), 3 V/m (1.4 to 2 GHz) 80% AM (1 KHz), 1 V/m (2 to 2.7 GHz) 80% AM (1 KHz) Immunity to rapid transient bursts IEC 61000-4-4: Level IV, direct +/-4 kV (power supply) / capacitive coupling clamp +/-2 KV, (command input and outputs) Immunity to shock waves on power supply Immunity to radiofrequency in common mode Immunity to voltage dips and breaks IEC 61000-4-5: Level III, line-to-earth +/-2 kV / line-to-line +/-1 kV IEC 61000-4-6: Level III, 10 Vrms (0,15 to 80 MHz) 80% AM (1 kHz) IEC 61000-4-11: Industrial Class II, 0 % residual voltage during 1 cycle AC power ports, 70 % residual voltage during 25/30 cycles AC power ports, 0 % residual voltage, 250/300 cycles AC power ports. Residential: 0 % residual voltage during 10 cycle AC power ports, 40 % residual voltage during 10 cycles AC power ports, 70 % residual voltage during 10 cycles AC power ports, 0 % residual voltage, 250/300 cycles AC power ports AC/DC main port emissions EN55022 / CISPR22 Class B EN 55011 / CISPR11 Class B, Group 1 Radiated emissions EN55022 / CISPR22 Class B EN 55011 / CISPR11 Class B, Group 1 Page 4 of 14 Accessories Socket for DIN Rail or Panel Mount Socket for DIN Rail or Panel Mount Socket with Screw Terminal Plug-In 8-Pins Plug-In 11-Pins Plug-In 8-Pins 25 622 130 25 622 080 25 622 203 Solder Plug Solder Plug Socket with Screw Terminal Plug-In 8-Pins Plug-In 11-Pins Plug-In 11-Pins 25 622 301 25 622 076 79 694 002 Page 5 of 14 Diagrams Wiring Diagrams MDE1…24U MDE1…MVA MDF1 GDF1 MDA2 GDS2 Page 6 of 14 Dimensions in(mm) Side View Front View Mounting Panel Cut-Out Page 7 of 14 Function Diagrams Basic Time Chart Detailed Time Chart DETAILED TIME CHART FUNCTION A: On-Delay (Delay on make) U BASIC TIME CHART A R2 TIMED R1/R2 R2 INST R2 NOT USED Start U Reset R2 TIMED R1/R2 R2 INST R2 T T BASIC TIME CHART FUNCTION A + Memory Option T T t T DETAILED TIME CHART U U BASIC TIME CHART R2 TIMED R1/R2 R2 TIMED R2 INST R1/R2 NOT USED Start U R2 Reset T R2 INST R2 TIMED R1/R2 R2 INST R2 R2 T T T t1 t2 DETAILED TIME CHART FUNCTION Ab: Delayed Interval BASIC TIME CHART U U Start S Ab Reset R2 TIMED R1 / R2 R2 INST R2 BASIC TIME CHART R2 TIMED R1/R2 R2 INST R2 U T1 T2 T1 S T2 T1 t T1 t T1 T2 R1 / R2 Option FUNCTION R2 AbTIMED + Memory DETAILED TIME CHART U R2 INST R2 U T1 T2 Start S Reset R2 TIMED R1/R2 R2 INST R2 T1 R2 TIMED R1/R2 R2 INST R2 T2 T1 FUNCTION Ac: On/Off Delay (Delay on make/break) BASIC TIME CHART Ac R2 TIMED R2 INST Start S Reset R2 R2 TIMED BASIC TIME CHART U T1 R2 INST T2 T1 t1 t2 T1 t T1 T2 T1 T2 U U R1 / R2 T2 R1 / R2 R2 T1 t2 T2 t1 t1 T1 t1 T1 S R2 TIMED R2 INST R1 / R2 R2 T1 T2 Page 8 of 14 FUNCTION Ac + Memory Option U U Start S Reset R2 TIMED R1 / R2 R2 TIMED R2 INST R2 R2 INST T1 R1 / R2 R2 T2 t2A+t2B=T2 FUNCTION Ad: Delay on Start Ad R2 TIMED R2 INST T1 t2 U Start S Reset R1 / R2 R2 TIMED R2 INST R2 t t T1 t T1 T1 T2 R1 / R2 R2 T FUNCTION Ad + Memory Option t1 t1 T U U Start S R2 INST t2B U T R2 TIMED t2A Reset R1 / R2 R2 TIMED R2 INST R2 R1 / R2 R2 T T t1 t2 T T=t1+t2 FUNCTION At: Summation Time Relay U U Start S At R2 TIMED R2 INST Reset R1 / R2 R2 TIMED R2 R2 INST t1 t2 R1 / R2 R2 T=t1+t2 t1 t2 t1 T t2 T=t1+t2 FUNCTION At + Memory Option U U Start S R2 TIMED R2 INST Reset R1 / R2 R2 TIMED R2 R2 INST t1 T=t1+t2 t2 R1 / R2 R2 T=t1+t2 t1 t2 t1 t2 t1 t2 Page 9 of 14 FUNCTION AMt: On-Delay (Delay on make, Total memory: one delay) U NOT USED Start U Reset AMt R2 TIMED R1 / R2 R2 TIMED R2 INST R1 / R2 R2 T=t1+t2 t1 R2 INST t2 R2 t1 t2 T T=t1+t2 FUNCTION B: One-Shot U U Start S B Reset R2 TIMED R1 / R2 R2 TIMED R2 INST R2 R1 / R2 R2 INST R2 T T T t t t2 T T FUNCTION B + Memory Option U U Start S Reset R2 TIMED R2 INST R1 / R2 R2 TIMED R1 / R2 R2 INST R2 R2 T=t1+t2 T T t t1 T FUNCTION C: Off-Delay (Delay on break) U U Start S C Reset R2 TIMED R1 / R2 R2 TIMED R2 INST R2 R2 INST R1 / R2 R2 T T t t T FUNCTION C + Memory Option U U Start S Reset R2 TIMED R2 INST R1 / R2 R2 TIMED R2 INST R2 T R1 / R2 R2 T=t1+t2 T t t1 t2 t T Page 10 of 14 FUNCTION H: Interval U U Start R2 TIMED H NOT USED R1 / R2 Reset R2 INST R2 R2 TIMED R1 / R2 T R2 INST R2 T t T t T FUNCTION H + Memory Option U U Start R2 TIMED R2 INST R1 / R2 NOT USED Reset R2 R2 TIMED T R2 INST R1 / R2 R2 T T = t1 + t2 t T t1 t2 FUNCTION Ht: interval summation time relay U U Start S Ht Reset R2 TIMED R1 / R2 R2 TIMED R2 INST R2 R2 INST t1 t2 R1 / R2 R2 T=t1+t2 T=t1+t2 t1 t2 t1 t2 T t1 t2 t1 t2 FUNCTION Ht + Memory Option U U Start S Reset R2 TIMED R2 INST R1 / R2 R2 TIMED R2 R2 INST t1 t2 R1 / R2 R2 T=t1+t2 T=t1+t2 t1 t2 FUNCTION L: Recycler (OFF Start) U U Start R2 TIMED L R2 INST R1 / R2 NOT USED Reset R2 R2 TIMED T1 T2 T1 R1 / R2 T2 R2 INST R2 T1 T2 T1 T2 T1 T1 T2 T1 T1 Page 11 of 14 FUNCTION L + Memory Option U U Start R2 TIMED R2 INST R1 / R2 NOT USED Reset R2 R2 TIMED T1 T2 T1 R1 / R2 T2 R2 INST R2 T1 = t1 + t2 T1 T2 T1 T2 t1 t2 T2 T1 T1 t FUNCTION Li: Recycler (ON Start) U U Start R2 TIMED Li NOT USED R1 / R2 Reset R2 INST R2 R2 TIMED T1 T2 T1 R1 / R2 T2 R2 INST R2 T1 T2 T1 t T2 T1 T2 t T1 T1 FUNCTION Li + Memory Option U U Start R2 TIMED NOT USED R1 / R2 Reset R2 INST R2 R2 TIMED T1 T2 T1 R1 / R2 T2 R2 INST R2 T1 = t1 + t2 FUNCTION T: On-Delay (Delay on make): sum of times T2 T1 t2 t3 T2 t1 t2 T2 T1 t T1 t U Start U T T1 Reset S R2 TIMED R2 TIMED R2 INST R2 INST R1 / R2 R1 / R2 R2 T = t1 + t2 + t3 R2 T = t1 + t2 + t3 t1 t2 t1 t1 t1 t2 t3 t3 FUNCTION T + Memory Option U U Start S Reset R2 TIMED R2 INST R1 / R2 R2 TIMED R2 INST R2 T = t1 + t2 + t3 t1 t2 t3 R1 / R2 R2 T = t1 + t2 + t3 t2 = t2A + t2B t1 t2 t3 t1 t2A t2B t3 Page 12 of 14 FUNCTION W: Timing after pulse of control contact U Start U W Reset S R2 TIMED R2 TIMED R1 / R2 R2 INST R2 INST R1 / R2 R2 R2 T T t T t T FUNCTION W + Memory Option U U Start S Reset R2 TIMED R2 INST R1 / R2 R2 TIMED R2 R2 INST T R2 T1 = t1 + t2 FUNCTION D: Symmetrical flashing (OFF start) T t t1 t2 T U Start U D R1 / R2 NOT USED Reset R2 TIMED R1 / R2 R2 TIMED R2 INST R1 / R2 R2 T T T T R2 INST R2 T T T T T T T T T1 FUNCTION D + Memory Option U U Start R2 TIMED R2 INST R1 / R2 Reset R2 R2 TIMED T T T R1 / R2 T R2 INST R2 T = t1 + t2 FUNCTION Di: Symmetrical flashing (ON start) Di Start T T T t1 t2 T T T t NOT USED Reset R1 / R2 R2 TIMED R2 INST T U U R2 TIMED NOT USED R1 / R2 R2 T T T T R2 INST R2 T T T T t T T T t T Page 13 of 14 FUNCTION Di + Memory Option U U Start R2 TIMED NOT USED R1 / R2 Reset R2 INST R2 R2 TIMED T T T R1 / R2 T R2 INST R2 T = t1 + t2 T T T T t1 t2 T T t T t Keys Function Set Time Check Configured Time and Function Reset Time Programming Mode Page 14 of 14 Programming Mode Programming Main Menu # 1 Parameter Value 0000 Pass If "Lock" function is on, pass needs to be entered 2 Basic Prog Enter to Basic Programming Mode 3 Advanced Prog Enter to Advanced Programming Mode 4 Test Enter to Test Mode Basic Prog Menu # Parameter Value A 1 Function Select the timing function 2 Time Range Select the timing range 3 Count Select the timing count up or down 4 Memory Activate memory option (save timing after power off) 5 Output 2 Select if Out 2 works timed or instantaneous (MDA2, GDS2) Ab H Ht Ac L Ad Li D AMt Di T At B W -.---s --.--s ---.-s ----s --m--s ---.-m ----m --h--m ---.-h ----h Up C Down Off On Timed Instantaneous Advanced Prog Menu # 1 2 3 Parameter Value Input Time Select input time wave 0.020s Input Type Select input to work with a NPN or PNP signal PNP Time Limit Select upper time limit 9999 0.001s NPN 0000 Page 15 of 14 4 5 6 6.1 6.2 7 7.1 7.2 100% Brightness Select screen brightness Sleep After Select the time needed to turn off the screen Off Lock Select security level 1 (lock configuration) or 2 (lock all) Off Pass Set password for lock option 50% 5s 1 10s 30s 60s 2 0000 Done Indication that the lock is on Default Settings Reset settings to default values No Yes Sure Confirm if reset settings to default values No Yes Done Indication that settings have been reset Test Mode Menu # 1 2 3 4 4.1 4.2 Parameter Value Out 1 Turn on/off Relay Output 1 Off On Out 2 Turn on/off Relay Output 2 (MDA2, GDS2) Off On Display Turn on/off all display segments Off On Memory Test the memory of the timer Off Test Good Indication that the memory is working properly Error Indication that the memory is not working properly All specifications in this document are subject to change without written notice. Actual product may differ from pictures provided in this document. Page 16 of 14
MDF1R10MV2 价格&库存
很抱歉,暂时无法提供与“MDF1R10MV2”相匹配的价格&库存,您可以联系我们找货
MDF1R10MV2
  • 1+2371.393831+283.64807
库存:30
MDF1R10MV2
  • 1+2072.84325
  • 2+2035.36114
  • 3+1998.08267
  • 5+1923.43664
库存:14
