G2 Series/ FORM B
Solid State Relays
Model Number
Parameters
Input Characteristics
Sym.
Test Conditions
Units
LED Forward Current - Turn on
IFon
IL = 100mA, t = 10ms
mADC
Max
Typ
LED Forward Current - Turn off
IFoff
IL = 0.2mA, VL = (Note 1)
mADC
Min
Typ
mADC
Min
Max
Recommended Forward Current
LED Forward Voltage
IF
VF
IF = 20mA
G2-1B01
G2-1B02
G2-DB01
1 Form B
1 Form B
Dual Form B
G2-DB02
Dual Form B
Max
5.0
3.0
0.1
1.8
10
30
1.1
1.4
5.0
3.0
0.1
1.8
10
30
1.1
1.4
5.0
3.0
0.1
1.8
10
30
1.1
1.4
5.0
3.0
0.1
1.8
10
30
1.1
1.4
mADC
Max
50
50
50
50
VDC
Max
10
10
10
10
V PEAK Max
350
250
350
250
165
330
200
400
170
120
200
140
0.1
1.4
0.07
1.0
1.0
5.0
1.0
200
13
3.25
0.1
1.4
0.07
1.0
1.0
5.0
1.0
170
25
0.2
n/a
0.1
1.4
0.07
1.0
1.0
5.0
1.0
200
13
n/a
0.1
1.4
0.07
1.0
1.0
5.0
1.0
170
25
0.2
3750
0.8
500
3750
0.8
500
3750
1.2
600
3750
1.2
600
VDC
Min
Maximum Input Ratings
LED Forward Current
IF
LED Reverse Voltage Withstand
VR
IR = 10mA
Switching Voltage
VL
IL = 50mA
Switching Current
IL
Output Characteristics
(Note 2)
mA
Max
(Note 3)
mA
Max
On Resistance (Note 2)
On Resistance (Note 4)
Ron
IF = 0mA, IL = 50mA
Ω
Max
Ron
IF = 0mA, IL = 50mA
Ω
Max
Off State Resistance
Roff
IF = 5mA, VL = 100V
GΩ
Min
Typ
Ioff
IF = 5mA, VL = 100V
µA
Ioff
IF = 5mA, VL = Max
µA
Max
Typ
Max
Ton
IF = 0mA, IL = 50mA
ms
Max
Toff
IF = 5mA, IL = 50mA
ms
Max
IF = 0mA, VL = 1V
pF
Typ
IF = 0mA, VL = 50V
pF
Typ
IF = 5mA
µV
Typ
t = 60sec
VRMS
pF
Min
Typ
mW
Max
Off State Leakage
Turn On Time
Turn Off Time
Capacitance - Across Output
Thermal Offset Voltage
General Characteristics
Dielectric Strength - Input to Output
Capacitance - Input to Output
Power Dissipation
Notes:
PDiss
1: VL for LED Forward Current - Turn off is 50 Volts less than "Switching
Voltage : Max"
2: For G2-1B01 and G2-1B02: Output connected to pins 4 and 6.
For G2-DB01 and G2-DB02: Each channel.
3: For G2-1B01 and G2-1B02: Output connected to pin 5(-) and pins 4 & 6(+).
For G2-DB01 and G2-DB02: Both channels switching simultaneously
4: For G2-1B01 and G2-1B02: Output connected to pin 5(-) and pins 4 & 6(+).
5: Specifications subject to change without notice
* IF = 10mA
Schematic Top View:
Mold mark on top of relay indicates Pin #1
For recommended applications and more information contact:
USA: Sales Support (877) 502-5500 Tech Support (877) 702-7700 FAX (619) 710-8540
Crydom Corp, 2320 Paseo de las Americas, Ste. 201, San Diego, CA 92154
Email: sales@crydom.com WEB SITE: http://www.crydom.com
UK: +44 (0)1202 365070 • FAX +44 (0)1202 365090 Crydom International Ltd., 7 Cobham
Road, Ferndown Industrial Estate, Ferndown, Dorset BH21 7PE, Email: intsales@crydom.com.
GERMANY: +49 (0)180 3000 506
Page 1 of 2
MOSFET Breakdown Voltage (Volts)
G2 Series/ FORM B
Load Current (mA)
200
150
100
G2-1B02
G2-DB02
I(F) = 0 mA
G2-1B01
50
G2-DB01
550
500
G2-1B02
G2-DB02
450
400
350
300
250
-40
-20
60
-40
80
-20
A. Load Current vs. Ambient Temperature
60
80
B. Output MOSFET BV vs. Ambient Temperature
350.00
50%
40%
G2-1B02
G2-DB02
G2-1B01
G2-DB01
20%
300.00
CapacitanceρF)
30%
10%
0%
-10%
I(F) = 0 mA
I(L) = 50 mA
-20%
G2-1B02
G2-DB02
I(F) = 5 mA
f = 1 MHz
T = 25 deg. C
250.00
200.00
G2-1B01
G2-DB01
150.00
100.00
50.00
-30%
-40%
0.00
-40
-20
60
80
60
Temperature (Deg. C)
80
100
120
Bias Voltage (Volts)
C. On-Resistance vs.Ambient Temperature
D. Output Capacitance vs. Applied Voltage
200%
120%
150%
G2-1B01
G2-1B02
G2-DB01
G2-DB02
100%
100%
Change in Turn Off Time (%
Normalized to 25 ˚ C
Change in Turn On Time (%)
40
Change in On Resistance (%)
G2-1B01
G2-DB01
I(F) = 5 mA
I(F) = 5 mA
I(L) = 50 mA
50%
0%
-50%
G2-1B02
G2-DB02
G2-1B01
G2-DB01
80%
60%
I(F) = 5 mA
I(L) = 50 mA
40%
20%
0%
-20%
-40%
-60%
-100%
-80%
-40
-20
60
80
-40
-20
E. On Time vs. Ambient Temperature
40
60
80
F. Turn Off Time vs. Ambient Temperature
9000
55
8000
6000
50
G2-1B02
G2-DB02
T = 25 deg. C
I(L) = 50 mA
7000
Turn Off Time (µSec.)
Turn On Time µ
( Sec.)
G2-1B01
G2-DB01
5000
4000
3000
2000
45
40
35
30
G2-1B02
G2-DB02
G2-1B01
G2-DB01
T = 25 deg. C
I(L) = 50 mA
25
15
10
15
30
35
40
45
LED Forward Current (mA)
G. Turn On Time vs. LED Forward Current
50
10
15
30
35
40
45
50
H. Turn Off Time vs. LED Forward Current
Page 2 of 2
很抱歉,暂时无法提供与“G2-DB02-SR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+32.200432000+4.14852
