HS271DR-D2425
HS271DR-D2425
    SENSATA(森萨塔)
    带散热器冰球式封装
    固态 SPST-NO(1 Form A) 带散热器冰球式封装
HS271DR-D2425 数据手册
DIN Rail Mount DataSheet HS271DR Series Assemblies e • 25 amp AC output @ 40°C • Single Channel output • 3 to 32 VDC input control voltage • DIN Rail mounted • uL, CSA, VDE, CE approved SSRs Control Voltage 3-32 VDC Control OUTPUT SPECIFICATIONS AC Output (1) Description INPUT SPECIFICATIONS (1) Description HS271DR-D2425 HS271DR-HD6025 24-280 600 10 500 25 0.04 250 1.6 260 0.5 48-660 1200 10 500 25 0.04 250 1.7 260 0.5 HS271DR-D2425 bs Control Voltage Range [Vdc] Minimum Turn-On Voltage [Vdc] Minimum Turn-Off Voltage [Vdc] Maximum Reverse Voltage [Vdc] Typical Input Current [Vdc] Nominal Input Impeadance Maximum Turn-On Time [msec] Maximum Turn-Off Time [msec] 25 A HS271DR-HD6025 ol Operating Voltage (47-63Hz) [Vrms] Transient Overvoltage [Vpk] Maximum Off-State Leakage Current @ Rated Voltage [mArms] Minimum Off-State dv/dt @ Maximum Rated Voltage [V/μsec] (2) Maximum Load Current [Arms] Minimum Load Current [Arms] Maximum Surge Current (16.6ms) [Apk] Maximum On-State Voltage Drop @ Rated Current [Vpk] Maximum I²t for Fusing (8.3 msec) [A² sec] Minimum Power Factor (with Maximum Load) 25 A HS271DR-D2425 et PRODUCT SELECTION 3-32 4.0 1.0 32 3.4 mA @ 5 VDC 1500 Ohms 1/2 Cycle 1/2 Cycle GENERAL SPECIFICATIONS Description Dielectric Strength, Input/Output/Base (50/60Hz) Minimum Insulation Resistance (@ 500 V DC) O Maximum Capacitance, Input/Output Ambient Operating Temperature Range Ambient Storage Temperature Range Status Indicator Display Weight (typical) Encapsulation Recommended Terminal Screw Torque Range: 4000 Vrms 109 Ohms 8 pF -40 to 80˚C -40 to 125˚C None 0.70 lb. (319g) Themally Conductive Epoxy 6-32 Screws - 10 in/lbs. 8-32 Screws - 20 in/lbs. (Screws dry without grease) Thermal pad installed GENERAL NOTES (1) All parameters at 25°C unless otherwise specified. (2) Off-State dv/dt test method per EIA/NARM standard RS-443, paragraph 13.11.1 (3) Input circuitry for DC control version incorporates active current limiter (HD model only) Do not forget to visit us at: www.crydom.com Parameters Copyright © 2017 Crydom Inc. Specifications subject to change without notice. Yes HS271DR-HD6025 3-32 4.0 1.0 32 2.0 mA (3) (3) 1/2 Cycle 1/2 Cycle DIN Rail Mount DataSheet MECHANICAL SPECIFICATIONS 2X 8-32 UNC-2B TAP .33 3.85 [97.8] 2X Ø0.18[Ø4.5] 1.61[41.0] 1.03[26.2] 1.77 [45.0] 3.52[89.64] 1.88 [47.7] et e New Din-Rail Clip 4.35 (110.5) 2.95 (75.0) ol 3.29 (83.6) THERMAL DERATE INFORMATION HS271DR w/25A SSR 20 15 10 5 20 30 40 50 O 0 bs Load Current (Amps) 25 60 70 80 Ambient Temperature (ºC) AGENCY APPROVALS Agency Approvals Designed in accordance with the requirements of IEC 62314 Agency approvals are for relay only. E116949 (D2425) E116950 (HD6025) LR81689 10143 UG Rev. 110411 Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. DIN Rail Mount DataSheet DANGER / PELIGRO / DANGER /GEFAHR / PERICOLO / 危险 • Verificar todas las conexiones y colocar todas las tapas antes de energizer el equipo. El incumplimiento de estas instrucciones puede provocar la muerte o lesiones serias. • Eteindre toutes les sources d'énergie de cet appareil avant de travailler dessus de cet appareil GEFAHR EINES ELEKTRISCHE N SCHLAGES ODER EINER EXPLOSION. • Stellen Sie jeglichen Strom ab, der dieses Gerät versorgt, bevor Sie an dem Gerät Arbeiten durchführen RISCHIO DI SCOSSA ELETTRICA O DELL’ESPLOSIONE. • Spenga tutta l'alimentazione che fornisce questa apparecchiatura prima di lavorare a questa apparecchiatura 存在电击、 爆炸或电弧 闪烁危险 • 在操作此设 备之前请先 关闭电源。 若不遵守这些说明, 可能会导致严重的 人身伤害甚至死亡。 • Vor dem Drehen auf Energie alle Anschlüsse überprüfen und alle Abdeckungen ersetzen. • Vérifier tous connections, et remettre tous couverts en olace avant de mettre sous • Verificare tutti i collegamenti e sostituire tutte le coperture prima dell’accensione De non-suivi de ces instructions provoquera la mort ou des lésions sérieuses sérieuses. Unterlassung dieser Anweisungen können zum Tode oder zu schweren Verletzungen führen. L'omissione di queste istruzioni provocherà la morte o lesioni serie ol Failure to follow these instructions will result in death or serious injury. • Desconectar todos los suministros de energia a este equipo antes de trabajar con este equipo. RISQUE DE DESCHARGE ELECTRIQUE OU EXPLOSION e • Verify all connections and replace all covers before turning on power. RIESGO DE DESCARGA ELECTRICA O EXPLOSION. et HAZARD OF ELECTRIC SHOCK, EXPLOSION, OR ARC FLASH. • Disconnect all power before installing or working with this equipment. bs WARNING / AVERTISSEMENT / WARNUNG /ADVERTENCIA / AVVERTENZA / 警告 RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE RISQUE DE DOMMAGE MATERIEL ET DE SURCHAUFFE DU BOITIER GEFAHR VON MATERIALSCHÄDEN UND GEHÄUSEERHITZUNG • The product's side panels may be hot, allow the product to cool before touching. • Follow proper mounting instructions including torque values. • Do not allow liquids or foreign objects to enter this product. • Les panneaux latéraux du produit peuvent être chauds. Laisser le produit refroidir avant de le toucher. • Respecter les consignes de montage, et notamment les couples de serrage. • Ne pas laisser pénétrer de liquide ni de corps étrangers à l'intérieur du produit. • Die Seitenwände können heiß sein. Lassen Sie das Produkt abkühlen, bevor Sie es berühren. • Beachten Sie die Montageanweisungen, • Führen Sie keine Flüssigkeiten oder Fremdkörper in das Produkt ein. Die Nichtbeachtung dieser Anweisung kann Körperverletzung oder Materialschäden zur Folge haben. RIESGO DE DAÑOS MATERIALES Y DE SOBRECALENTAMIENTO DE LA UNIDAD RISCHIO DI DANNI MATERIALI E D'INVOLUCRO CALDO 材料损坏和高温外壳的危险性 • Los paneles laterales del producto pueden estar calientes. Esperar que el producto se enfríe antes de tocarlo. • Respetar las instrucciones de montaje, y en particular los pares de apretado. • No dejar que penetren líquidos o cuerpos extraños en el producto. • I pannelli laterali dell'apparecchio possono scottare; lasciar quindi raffreddare il prodotto prima di toccarlo. • Seguire le istruzioni di montaggio corrette. • Non far entrare liquidi o oggetti estranei in questo apparecchio. O Le non-respect de cette directive peut entraîner, Failure to follow these instructions can result in des lésions corporelles graves ou des serious injury, or equipment damage. dommages matériels. Si no se respetan estas precauciones pueden producirse graves lesiones, daños materiales. La mancata osservanza di questa precauzione può causare gravi rischi per l'incolumità personale o danni alle apparecchiature. Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. • 产品的一侧面板可能很热,在其冷却前请 不要触碰。 • 遵照正确的安装说明,包括扭矩值。 • 请勿让液体及其他异物进入本产品。 如不能正确执行这些操作说明, 极有可能造成严重人体伤害或者设备的损坏。 DIN Rail Mount DataSheet ANNEX - ENVIROMENTAL INFORMATION The environmental information disclosed in this annex including the EIP Pollution logo are in compliance with People’s Republic of China Electronic Industry Standard SJ/T11364 – 2006, Marking for Control of Pollution Caused by Electronic Information Products. Toxic or hazardous Substance and Elements Lead (Pb) Mercury (Hg) Cadmium (Cd) Hexavalent Chromium (Cr (VI)) Semiconductor die Polybrominated diphenyl ethers (PBDE) et Solder Polybrominated biphenyls (PBB) e Part Name 附件 - 环保信息 部件 名称 铅 汞 镉 有毒有害物质或元素 六价铬 多溴联苯 (Pb) (Hg) (Cd) (Cr (VI)) bs 半导体芯片 焊接点 ol 此附件所标示的包括电子信息产品污染图标的环保信息符合中华人民共和国电子行业标准 SJ/T11364 - 2006, 电子信息产品污染控制标识要求。 O 50 Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. (PBB) 多溴二苯醚 (PBDE)
HS271DR-D2425 价格&库存
很抱歉,暂时无法提供与“HS271DR-D2425”相匹配的价格&库存,您可以联系我们找货
