电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
PB-8
PB-8
    SENSATA(森萨塔)
    I/O 继电器模块机架 8 通道
PB-8 数据手册
I/O Modules DataSheet PB8 MOUNTING BOARD • Plug-compatible logic connections • Screw terminal barrier block for load connections • Resident pull-up resistors • 5 amp field-replaceable fuses (LITTELFUSE #251005 or equivalent) • LEDs indicate logic status te • All even-numbered logic connections are logic ground • Input and output modules accepted interchangeably • Operate with 5, 15 or 24 volt logic supplies • Captive-screw retaining system for standard-size modules MECHANICAL SPECIFICATIONS SCREW TERMINAL LOGIC SUPPLY BARRIER STRIP 6-32 SCREW TERMINAL POWER BARRIER STRIP (see note 2) 8.0 (203,2) DIMENSIONS: INCHES (MILLIMETERS) TOLERANCE:+- 0.020 ( +- 0,50) ole 7.5 (190,5) 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 REPLACEABLE 5 AMP LINE FUSE (8) (see note 4) - + 1 CRYDOM DIGITAL I/O MODULES SOLD SEPARATELY 0.3 (7,6) 0 1 2 3 4 5 6 7 PULL UP RESISTORS 3.3K OHM (8) 0.45 (11,4) 0.75 (19,1) SIGNAL INPUT/OUTPUT 50 TRACE (0.1" CENTERS) MALE CARD EDGE (see note 1) 2.2 (55,9) 3.5 (88,9) SWAGED STANDOFF THRU HOLE 0.15 (3,2) DIA. (4) 3.0 (76,2) 2.6 (66,0) 1.4 (35,6) LED STATUS INDICATORS (8) Ob s NOTES: 1) MATING CONNECTOR IS BERG 66317-150 OR EQUIVALENT. SPECIFY SUFFIX "V" FOR OPTIONAL CA26HM-2F-SR CIRCUIT ASSEMBLY OR EQUIVALENT 26 CONDUCTOR PERPENDICULAR-TO-THE-BOARD MALE PIN CONNECTOR. 2) 6-32 SCREW TERMINAL BARRIER STRIPS ACCEPT WIRE SIZES FROM 24 TO 12 AWG. 3) OPTIONAL JUMPERS ARE AVAILABLE TO INTERCONNECT BARRIER STRIP COMMONS. ORDER 1 EACH "JS8". 4) LITTELFUSE 251005 OR EQUIVALENT. LOGIC SUPPLY BARRIER STRIP 1 2 + BOTTOM ALL EVEN PINS “V” OR “C” OPTION EDGE CONN TOP + LOGIC 49 25 SIGNAL INPUT/OUTPUT 50 TRACE (0.1" CENTERS) MALE CARD EDGE OR OPTIONAL PIN CONNECTOR +LOGIC AGENCY APPROVALS 47 45 43 41 39 37 35 33 25 1 POWER BARRIER STRIP 3 4 5 6 7 8 9 10 1112 1314 15 16 5 AMP LINE FUSE 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2 2 3 3 3 3 3 3 3 3 4 4 4 4 4 4 4 4 5 5 5 5 5 5 5 5 23 21 19 17 15 13 11 9 1 CUSTOMER INSTALLED OPTIONAL JUMPERS FOR CONNECTING LOGIC SUPPLY THRU CARD EDGE CONNECTOR LED STATUS INDICATOR (8) PULL UP RESISTOR 3.3K OHM (8) UL E79183 CSA 38595 Do not forget to visit us at: www.crydom.com I/O MODULE PIN SOCKETS AMP #645979-1 OR EQUIVALENT Copyright © 2017 Crydom Inc. Specifications subject to change without notice. Rev. 083116 I/O Modules DataSheet DANGER / PELIGRO / DANGER /GEFAHR / PERICOLO / 危险 Failure to follow these instructions will result in death or serious injury. • Desconectar todos los suministros de energia a este equipo antes de trabajar con este equipo. • Verificar todas las conexiones y colocar todas las tapas antes de energizer el equipo. RISQUE DE DESCHARGE ELECTRIQUE OU EXPLOSION • Eteindre toutes les sources d'énergie de cet appareil avant de travailler dessus de cet appareil GEFAHR EINES ELEKTRISCHE N SCHLAGES ODER EINER EXPLOSION. • Stellen Sie jeglichen Strom ab, der dieses Gerät versorgt, bevor Sie an dem Gerät Arbeiten durchführen RISCHIO DI SCOSSA ELETTRICA O DELL’ESPLOSIONE. • Spenga tutta l'alimentazione che fornisce questa apparecchiatura prima di lavorare a questa apparecchiatura 存在电击、 爆炸或电弧 闪烁危险 • te • Verify all connections and replace all covers before turning on power. RIESGO DE DESCARGA ELECTRICA O EXPLOSION. • Vérifier tous connections, et remettre tous couverts en olace avant de mettre sous • Vor dem Drehen auf Energie alle Anschlüsse überprüfen und alle Abdeckungen ersetzen. 在操作此设 备之前请先 关闭电源。 若不遵守这些说明, 可能会导致严重的 人身伤害甚至死亡。 • Verificare tutti i collegamenti e sostituire tutte le coperture prima dell’accensione ole HAZARD OF ELECTRIC SHOCK, EXPLOSION, OR ARC FLASH. • Disconnect all power before installing or working with this equipment. El incumplimiento de estas instrucciones puede provocar la muerte o lesiones serias. De non-suivi de ces instructions provoquera la mort ou des lésions sérieuses sérieuses. Unterlassung dieser Anweisungen können zum Tode oder zu schweren Verletzungen führen. L'omissione di queste istruzioni provocherà la morte o lesioni serie Ob s WARNING / AVERTISSEMENT / WARNUNG /ADVERTENCIA / AVVERTENZA / 警告 RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE RISQUE DE DOMMAGE MATERIEL ET DE SURCHAUFFE DU BOITIER GEFAHR VON MATERIALSCHÄDEN UND GEHÄUSEERHITZUNG • The product's side panels may be hot, allow the product to cool before touching. • Follow proper mounting instructions including torque values. • Do not allow liquids or foreign objects to enter this product. • Les panneaux latéraux du produit peuvent être chauds. Laisser le produit refroidir avant de le toucher. • Respecter les consignes de montage, et notamment les couples de serrage. • Ne pas laisser pénétrer de liquide ni de corps étrangers à l'intérieur du produit. • Die Seitenwände können heiß sein. Lassen Sie das Produkt abkühlen, bevor Sie es berühren. • Beachten Sie die Montageanweisungen, • Führen Sie keine Flüssigkeiten oder Fremdkörper in das Produkt ein. Failure to follow these instructions can result in serious injury, or equipment damage. Le non-respect de cette directive peut entraîner, des lésions corporelles graves ou des dommages matériels. Die Nichtbeachtung dieser Anweisung kann Körperverletzung oder Materialschäden zur Folge haben. RIESGO DE DAÑOS MATERIALES Y DE SOBRECALENTAMIENTO DE LA UNIDAD RISCHIO DI DANNI MATERIALI E D'INVOLUCRO CALDO • Los paneles laterales del producto pueden estar calientes. Esperar que el producto se enfríe antes de tocarlo. • Respetar las instrucciones de montaje, y en particular los pares de apretado. • No dejar que penetren líquidos o cuerpos extraños en el producto. • I pannelli laterali dell'apparecchio possono scottare; lasciar quindi raffreddare il prodotto prima di toccarlo. • Seguire le istruzioni di montaggio corrette. • Non far entrare liquidi o oggetti estranei in questo apparecchio. Si no se respetan estas precauciones pueden producirse graves lesiones, daños materiales. La mancata osservanza di questa precauzione può causare gravi rischi per l'incolumità personale o danni alle apparecchiature. Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. 材料损坏和高温外壳的危险性 • 产品的一侧面板可能很热,在其冷却前请 不要触碰。 • 遵照正确的安装说明,包括扭矩值。 • 请勿让液体及其他异物进入本产品。 如不能正确执行这些操作说明, 极有可能造成严重人体伤害或者设备的损坏。 I/O Modules DataSheet ANNEX - ENVIROMENTAL INFORMATION The environmental information disclosed in this annex including the EIP Pollution logo are in compliance with People’s Republic of China Electronic Industry Standard SJ/T11364 – 2006, Marking for Control of Pollution Caused by Electronic Information Products. Toxic or hazardous Substance and Elements Lead (Pb) Mercury (Hg) Cadmium (Cd) Semiconductor die 附件 - 环保信息 Polybrominated biphenyls (PBB) ole Solder Hexavalent Chromium (Cr (VI)) Polybrominated diphenyl ethers (PBDE) te Part Name 此附件所标示的包括电子信息产品污染图标的环保信息符合中华人民共和国电子行业标准 SJ/T11364 - 2006, 电子信息产品污染控制标识要求。 部件 名称 铅 (Pb) 镉 (Hg) (Cd) (Cr (VI)) Ob s 半导体芯片 焊接点 汞 有毒有害物质或元素 六价铬 多溴联苯 50 Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. (PBB) 多溴二苯醚 (PBDE)
很抱歉,暂时无法提供与“PB-8”相匹配的价格&库存,您可以联系我们找货
  • 1+ 0.825 1+ 0
  • 200+ 0.5698 200+ 0
  • 1500+ 0.517 1500+ 0
  • 3000+ 0.484 3000+ 0
库存:1038
  • 1+ 0.9889 1+ 0
  • 200+ 0.7612 200+ 0
  • 1500+ 0.6611 1500+ 0
  • 3000+ 0.6149 3000+ 0
库存:3692
  • 1+ 1.0021 1+ 0
  • 100+ 0.7711 100+ 0
  • 1250+ 0.6534 1250+ 0
  • 2500+ 0.605 2500+ 0
库存:736
  • 1+ 1.3266 1+ 0
  • 100+ 1.0197 100+ 0
  • 1250+ 0.88902 1250+ 0
  • 2500+ 0.83952 2500+ 0
库存:3762
  • 1+ 1.639 1+ 0
  • 100+ 1.309 100+ 0
  • 750+ 1.166 750+ 0
  • 1500+ 1.1 1500+ 0
  • 3000+ 1.045 3000+ 0
库存:3073
    • 1+ 3.564 1+ 0
    • 100+ 2.97 100+ 0
    • 1250+ 2.695 1250+ 0
    • 2500+ 2.585 2500+ 0
    库存:3118
    • 1+ 5.104 1+ 0
    • 100+ 4.246 100+ 0
    • 1250+ 3.861 1250+ 0
    • 2500+ 3.718 2500+ 0
    库存:5194
    • 1+ 12.694 1+ 0
    • 100+ 10.934 100+ 0
    • 600+ 10.417 600+ 0
    • 1200+ 10.065 1200+ 0
    库存:506
    • 1+ 33.209 1+ 0
    • 100+ 30.195 100+ 0
    • 561+ 29.315 561+ 0
    • 1122+ 28.6 1122+ 0
    库存:458
    • 1+ 42.581 1+ 0
    • 10+ 38.027 10+ 0
    • 152+ 36.993 152+ 0
    库存:710
      • 1+ 4.792 1+ 0
      • 10+ 4.1854 10+ 0
      • 100+ 3.5789 100+ 0
      • 1000+ 3.0329 1000+ 0
      库存:112199
        • 1+ 4.9658 1+ 0
        • 10+ 4.3372 10+ 0
        • 100+ 3.7087 100+ 0
        • 1000+ 3.1429 1000+ 0
        库存:3780
          • 1+ 5.6113 1+ 0
          • 10+ 4.9011 10+ 0
          • 100+ 4.1907 100+ 0
          • 1000+ 3.5515 1000+ 0
          库存:20873
            • 1+ 5.6113 1+ 0
            • 10+ 4.9011 10+ 0
            库存:5619
              • 1+ 5.909 1+ 0
              • 10+ 5.1611 10+ 0
              • 100+ 4.4131 100+ 0
              • 1000+ 3.7399 1000+ 0
              库存:8364
                • 1+ 6.0684 1+ 0
                • 10+ 5.3002 10+ 0
                • 100+ 4.5321 100+ 0
                • 1000+ 3.8408 1000+ 0
                库存:2213
                  • 1+ 6.1824 1+ 0
                  • 10+ 5.3998 10+ 0
                  • 100+ 4.6173 100+ 0
                  • 1000+ 3.9129 1000+ 0
                  库存:2108
                    • 1+ 7.8705 1+ 0
                    • 10+ 6.8742 10+ 0
                    • 100+ 5.878 100+ 0
                    • 1000+ 4.9814 1000+ 0
                    库存:10308
                    • 1+ 28.0564 1+ 0
                    • 10+ 24.5049 10+ 0
                    • 100+ 20.9535 100+ 0
                    • 1000+ 17.7572 1000+ 0
                    库存:2233
                      • 50+ 66.1631 50+ 0
                      • 100+ 47.9443 100+ 0
                      • 500+ 43.1498 500+ 0
                      库存:1608
                        • 189+ 49.2228 189+ 0
                        库存:2313
                          • 160+ 94.3437 160+ 0
                          库存:12191
                            • 152+ 136.73 152+ 0
                            库存:3412
                            • 1+ 65.49439 1+ 0
                            • 3+ 59.18168 3+ 0
                            • 6+ 56.02532 6+ 0
                            库存:407
                            • 1+ 80.75012 1+ 0
                            • 2+ 73.03458 2+ 0
                            • 5+ 69.08913 5+ 0
                            库存:83
                              • 10+ 43.578 10+ 0
                              • 100+ 41.5476 100+ 0
                              • 300+ 40.3056 300+ 0
                              库存:612
                                • 5+ 74.8224 5+ 0
                                • 50+ 47.4012 50+ 0
                                • 150+ 43.5132 150+ 0
                                • 500+ 39.7548 500+ 0
                                库存:2000
                                  • 1+ 98.334 1+ 0
                                  • 10+ 93.8736 10+ 0
                                  • 30+ 86.13 30+ 0
                                  库存:1008
                                    • 1+ 163.81268 1+ 0
                                    • 3+ 146.3858 3+ 0
                                    • 5+ 128.95892 5+ 0
                                    • 30+ 124.77111 30+ 0
                                    库存:549
                                      • 6+ 201.7764 6+ 0
                                      • 180+ 191.6028 180+ 0
                                      库存:411
                                        • 1+ 285.768 1+ 0
                                        • 30+ 272.16 30+ 0
                                        库存:691
                                          • 1+ 307.7676 1+ 0
                                          • 30+ 292.2588 30+ 0
                                          库存:181
                                            • 1+ 408.4128 1+ 0
                                            • 30+ 389.6208 30+ 0
                                            库存:742
                                              • 1+ 503.5068 1+ 0
                                              • 30+ 479.2176 30+ 0
                                              库存:694
                                                • 1+ 536.1228 1+ 0
                                                • 10+ 518.4972 10+ 0
                                                库存:787
