PRGA48150
PRGA48150
    SENSATA(森萨塔)
    固态 SPST-NO(1 Form A) Hockey Puck
PRGA48150 数据手册
Panel Mount DataSheet PRG Series e • High current SSR rated to 150A @ 48-660 VAC • SCR output for heavy industrial loads • AC or DC control • Zero-crossing (resistive loads) or random-fire (inductive loads) output PRODUCT SELECTION Control Voltage 150 A 150 A PRGD24150 PRGA24150 150 A et 3-15 VDC 90-140 VAC 4-15 VDC AVAILABLE OPTIONS PRGA60150 PRGD60150 Load Current 150: 150 Amps Control Voltage A: AC (90-140 V) D: DC (4-15 V) ol Series PRGA48150 PRGD48150 PRG A 24 U 150 Operating Voltage 24: 24-280 VAC 48: 48-530 VAC U -10 Switching Mode Blank: Zero cross Turn-On -10: Random Turn-On bs Required for valid part number OUTPUT SPECIFICATIONS (1) Description O Operating Voltage [Vdc] (2) Transient Overvoltage [Vpk] Maximum Off-State Leakage Current @ Rated Voltage [mArms] Minimum Off-State dv/dt @ Maximum Rated Voltage [V/μsec] (2) Maximum Load Current (3) [Arms] Minimum Load Current [Arms] Maximum Surge Current (16.6ms) [Apk] Maximum On-State Voltage Drop @ Rated Current [Vpk] Thermal Resistance Junction to Case (Rjc) [°C/W] Maximum I2 t for Fusing (8.3 msec) [A2 sec] Minimum Power Factor (with Maximum Load) Do not forget to visit us at: www.crydom.com 24-48 VDC 600 5.0 500 150 0.15 1750 1.7 0.15 12700 0.5 Copyright © 2017 Crydom Inc. Specifications subject to change without notice. 48-530 1200 5.0 500 150 0.15 1750 1.7 0.15 12700 0.5 48-660 VDC 1200 1.0 500 150 0.15 1750 1.7 0.15 12700 0.5 Panel Mount DataSheet INPUT SPECIFICATIONS (2) Description 240 V Models 480 V Models 3-15 VDC 3.0 VDC 1.0 VDC 15 mA @5 VDC 300 Ohm 1/2 Cycle 1/2 Cycle 4-15 VDC 3.0 VDC 1.0 VDC 15 mA @ 5 VDC 300 Ohm 1/2 Cycle 1/2 Cycle Control Voltage Range Minimum Input Current @ min Control Voltage [mA] Maximum Input Current @ max Control Voltage [mA] Nominal Input Impedance Maximum Turn-On Time [msec] Maximum Turn-Off Time [msec] Maximum Turn-Off Time [msec] e GENERAL SPECIFICATIONS Description Parameters 4000 Vrms 109 Ohms 10 pF -30 to 80 °C -40 to 125 °C 12 oz (340g) Thermally conductive Epoxy MS Screws Furnished, Mounted .050 x .020 Square Pins et Dielectric Strength, Input/Output/Base (50/60Hz) Minimum Insulation Resistance (@ 500 VDC) Maximum Capacitance, Input/Output Ambient Operating Temperature Range Ambient Storage Temperature Range Weight (typical) Encapsulation Power Terminal Control Terminal GENERAL NOTES ol (1) All parameters at 25°C and per section unless otherwise specified. (2) Off-State dv/dt test method per EIA/NARM standard RS-443, paragraph 13.11.1 (3) Heat sinking required, see derating curves. (4) Turn-on time for Random turn-on versions is 0.02 msec (DC Control Models) MECHANICAL SPECIFICATIONS bs Tolerances: ±0.02 in / 0.5 mm All dimensions are in: inches [millimeters] .125 Cooper Base Plate (Integral Part of Package) .30 [7.6] .25 [6.3] MOUNTING HOLE/SLOTE 0.16(4.1) DIA. 1.66 [42.2] 2.50 [63.5] .95 [24.1] 1.17 [29.7] .20 [5.1] .65 [16.5] 2.50 [63.5] 3.60 [91.4] 4.00 [101.5] .20 [5.1] O .125 [3.2] 90-140 VAC 90 Vrms 10 Vrms 10 mA @ 120 VAC 14.1 K Ohm 10 40 PIN DETAIL .055 [1.4] CUT HERE FOR FASTON (AMP TYPE 61060-1 RECOMMEND) .110 x .020 THICK Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. .400 [10.2] Panel Mount DataSheet THERMAL DERATE INFORMATION 150 A 210 180 120 105 110 90 1 C/W 115 30 120 0 30 60 90 120 0 Load Current [Arms] 40 60 80 O bs ol AGENCY APPROVALS AGENCY APPROVALS 20 Max Ambient Temp. [˚C] et 60 e .2 C/W .5 C/W Base Plate Temp [˚C] 150 Power Dissipation 110 .4 C/W Rev.121710 Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. Panel Mount DataSheet DANGER / PELIGRO / DANGER /GEFAHR / PERICOLO / 危险 • Verificar todas las conexiones y colocar todas las tapas antes de energizer el equipo. El incumplimiento de estas instrucciones puede provocar la muerte o lesiones serias. • Eteindre toutes les sources d'énergie de cet appareil avant de travailler dessus de cet appareil GEFAHR EINES ELEKTRISCHE N SCHLAGES ODER EINER EXPLOSION. • Stellen Sie jeglichen Strom ab, der dieses Gerät versorgt, bevor Sie an dem Gerät Arbeiten durchführen RISCHIO DI SCOSSA ELETTRICA O DELL’ESPLOSIONE. • Spenga tutta l'alimentazione che fornisce questa apparecchiatura prima di lavorare a questa apparecchiatura 存在电击、 爆炸或电弧 闪烁危险 • 在操作此设 备之前请先 关闭电源。 • Vor dem Drehen auf Energie alle Anschlüsse überprüfen und alle Abdeckungen ersetzen. 若不遵守这些说明, 可能会导致严重的 人身伤害甚至死亡。 • Vérifier tous connections, et remettre tous couverts en olace avant de mettre sous • Verificare tutti i collegamenti e sostituire tutte le coperture prima dell’accensione De non-suivi de ces instructions provoquera la mort ou des lésions sérieuses sérieuses. Unterlassung dieser Anweisungen können zum Tode oder zu schweren Verletzungen führen. L'omissione di queste istruzioni provocherà la morte o lesioni serie ol Failure to follow these instructions will result in death or serious injury. • Desconectar todos los suministros de energia a este equipo antes de trabajar con este equipo. RISQUE DE DESCHARGE ELECTRIQUE OU EXPLOSION e • Verify all connections and replace all covers before turning on power. RIESGO DE DESCARGA ELECTRICA O EXPLOSION. et HAZARD OF ELECTRIC SHOCK, EXPLOSION, OR ARC FLASH. • Disconnect all power before installing or working with this equipment. WARNING / AVERTISSEMENT / WARNUNG /ADVERTENCIA / AVVERTENZA / 警告 RISQUE DE DOMMAGE MATERIEL ET DE SURCHAUFFE DU BOITIER GEFAHR VON MATERIALSCHÄDEN UND GEHÄUSEERHITZUNG • The product's side panels may be hot, allow the product to cool before touching. • Follow proper mounting instructions including torque values. • Do not allow liquids or foreign objects to enter this product. • Les panneaux latéraux du produit peuvent être chauds. Laisser le produit refroidir avant de le toucher. • Respecter les consignes de montage, et notamment les couples de serrage. • Ne pas laisser pénétrer de liquide ni de corps étrangers à l'intérieur du produit. • Die Seitenwände können heiß sein. Lassen Sie das Produkt abkühlen, bevor Sie es berühren. • Beachten Sie die Montageanweisungen, • Führen Sie keine Flüssigkeiten oder Fremdkörper in das Produkt ein. bs RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE Die Nichtbeachtung dieser Anweisung kann Körperverletzung oder Materialschäden zur Folge haben. RIESGO DE DAÑOS MATERIALES Y DE SOBRECALENTAMIENTO DE LA UNIDAD RISCHIO DI DANNI MATERIALI E D'INVOLUCRO CALDO 材料损坏和高温外壳的危险性 • Los paneles laterales del producto pueden estar calientes. Esperar que el producto se enfríe antes de tocarlo. • Respetar las instrucciones de montaje, y en particular los pares de apretado. • No dejar que penetren líquidos o cuerpos extraños en el producto. • I pannelli laterali dell'apparecchio possono scottare; lasciar quindi raffreddare il prodotto prima di toccarlo. • Seguire le istruzioni di montaggio corrette. • Non far entrare liquidi o oggetti estranei in questo apparecchio. Si no se respetan estas precauciones pueden producirse graves lesiones, daños materiales. La mancata osservanza di questa precauzione può causare gravi rischi per l'incolumità personale o danni alle apparecchiature. O Le non-respect de cette directive peut entraîner, Failure to follow these instructions can result in des lésions corporelles graves ou des serious injury, or equipment damage. dommages matériels. Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. • 产品的一侧面板可能很热,在其冷却前请 不要触碰。 • 遵照正确的安装说明,包括扭矩值。 • 请勿让液体及其他异物进入本产品。 如不能正确执行这些操作说明, 极有可能造成严重人体伤害或者设备的损坏。 Panel Mount DataSheet ANNEX - ENVIROMENTAL INFORMATION The environmental information disclosed in this annex including the EIP Pollution logo are in compliance with People’s Republic of China Electronic Industry Standard SJ/T11364 – 2006, Marking for Control of Pollution Caused by Electronic Information Products. Toxic or hazardous Substance and Elements Lead (Pb) Mercury (Hg) Cadmium (Cd) Hexavalent Chromium (Cr (VI)) Semiconductor die Polybrominated diphenyl ethers (PBDE) et Solder Polybrominated biphenyls (PBB) e Part Name 附件 - 环保信息 部件 名称 铅 汞 镉 有毒有害物质或元素 六价铬 多溴联苯 (Pb) (Hg) (Cd) (Cr (VI)) bs 半导体芯片 焊接点 ol 此附件所标示的包括电子信息产品污染图标的环保信息符合中华人民共和国电子行业标准 SJ/T11364 - 2006, 电子信息产品污染控制标识要求。 O 50 Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. (PBB) 多溴二苯醚 (PBDE)
PRGA48150 价格&库存
很抱歉,暂时无法提供与“PRGA48150”相匹配的价格&库存,您可以联系我们找货
