CFM-8020V-126-300-20
    CUIDEVICES
    FAN AXIAL 80X20MM 12VDC WIRE
CFM-8020V-126-300-20 数据手册
For more information, please visit the product page. date 09/12/2018 page 1 of 16 SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN FEATURES • • • • • omniCOOLTM bearing system 80 x 80 mm frame multiple speed options for different cooling needs tachometer signal and rotation detect options available auto restart protection standard on all models MODEL input voltage input current1 input power1 rated speed1 air flow2 static pressure3 noise4 rated (Vdc) range (Vdc) max (mA) max (W) typ (RPM±10%) (CFM) (inch H2O) max (dBA) CFM-8015V-124-308 12 4.5~13.8 104 1.25 2400 30.0 0.09 30.8 CFM-8015V-127-320 12 4.5~13.8 149 1.79 2700 33.6 0.11 32.0 CFM-8015V-130-347 12 4.5~13.8 188 2.26 3000 37.0 0.14 34.7 CFM-8015V-224-308 24 8~27.6 65 1.56 2400 30.0 0.09 30.8 CFM-8015V-227-320 24 8~27.6 75 1.80 2700 33.6 0.11 32.0 CFM-8015V-230-347 24 8~27.6 106 2.55 3000 37.0 0.14 34.7 CFM-8020V-126-300 12 6~13.8 86 1.04 2600 29.0 0.12 30.0 CFM-8020V-130-350 12 6~13.8 110 1.32 3000 33.0 0.16 35.0 CFM-8020V-133-380 12 6~13.8 150 1.80 3300 36.0 0.18 38.0 CFM-8020V-139-430* 12 6~13.8 225 2.70 3900 45.0 0.26 43.0 CFM-8020V-142-450* 12 6~13.8 265 3.18 4200 49.0 0.31 45.0 CFM-8020V-146-480* 12 6~12.6 328 3.94 4600 53.0 0.36 48.0 CFM-8020V-226-300 24 8~27.6 49 1.18 2600 29.0 0.12 30.0 CFM-8020V-230-350 24 8~27.6 59 1.42 3000 33.0 0.16 35.0 CFM-8020V-233-380 24 8~27.6 74 1.78 3300 36.0 0.18 38.0 CFM-8025V-120-204 12 4.5~13.8 48 0.58 2000 23.9 0.07 20.4 CFM-8025V-126-280 12 4.5~13.8 75 0.90 2600 33.0 0.11 28.0 CFM-8025V-129-300 12 4.5~13.8 106 1.28 2900 37.0 0.15 30.0 CFM-8025V-132-330 12 4.5~13.8 138 1.66 3200 41.0 0.18 33.0 CFM-8025V-142-415 12 6~13.8 230 2.76 4200 53.0 0.30 41.5 CFM-8025V-145-431 12 6~13.8 276 3.32 4500 57.0 0.35 43.1 CFM-8025V-148-447 12 6~13.8 357 4.29 4800 60.0 0.41 44.7 CFM-8025V-226-280 24 8~27.6 48 1.16 2600 33.0 0.11 28.0 CFM-8025V-229-300 24 8~27.6 58 1.40 2900 37.0 0.15 30.0 Notes: 1. 2. 3. 4. 5. *. At rated voltage, 25°C, 0 inch H20 static pressure, after 10 minutes As per AMCA 210 or DIN 24163, at rated voltage, stabilized RPM, 0 inch H20 static pressure As per AMCA 210 or DIN 24163, at rated voltage, stabilized RPM, 0 CFM airflow. Measured in a semi-anechoic chamber with background noise < 15 dBA at 1 m from the fan intake. All specifications are measured at 25°C, 65% relative humidity unless otherwise specified. Discontinued models cui.com For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN MODEL input voltage rated (Vdc) range (Vdc) date 09/12/2018 │ page 2 of 16 input current1 input power1 rated speed1 air flow2 static pressure3 noise4 max (mA) max (W) typ (RPM±10%) (CFM) (inch H2O) max (dBA) CFM-8025V-232-330 24 8~27.6 75 1.80 3200 41.0 0.18 33.0 CFM-8025V-242-435 24 10~27.6 158 3.80 4200 53.0 0.30 43.5 CFM-8025V-245-450 24 10~27.6 191 4.59 4500 57.0 0.35 45.0 CFM-8025V-442-435* 48 24~56.0 106 5.09 4200 53.0 0.30 43.5 CFM-8025V-445-450* 48 24~56.0 115 5.52 4500 57.0 0.35 45.0 Notes: 1. 2. 3. 4. 5. *. At rated voltage, 25°C, 0 inch H20 static pressure, after 10 minutes As per AMCA 210 or DIN 24163, at rated voltage, stabilized RPM, 0 inch H20 static pressure As per AMCA 210 or DIN 24163, at rated voltage, stabilized RPM, 0 CFM airflow. Measured in a semi-anechoic chamber with background noise < 15 dBA at 1 m from the fan intake. All specifications are measured at 25°C, 65% relative humidity unless otherwise specified. Discontinued models PART NUMBER KEY CFM-8015V-124-308 - XX - CXX Base Number Fan Signals “blank” = no signals 11 = rotation detector signal 20 = tachometer signal cui.com Reserved for Custom Configurations For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 3 of 16 INPUT parameter conditions/description min typ max units operating input voltage1 12 Vdc input models 24 Vdc input models 48 Vdc input models 4.5 8 24 12 24 48 13.8 27.6 56.0 Vdc Vdc Vdc starting voltage2 12 Vdc input models 24 Vdc input models 48 Vdc input models Note: 4.5 8 24 Vdc Vdc Vdc 1. See Model section on page 1 for specific input voltage ranges. 2. Starting voltage for models CFM-8020V-126-300, CFM-8020V-130-350, CFM-8020V-133-380, CFM-8020V-139-430, CFM-8020V-142-450, CFM-8020V-146-480, CFM-8025V-142-415, CFM-8025V-145-431, and CFM-8025V-148-447 is 6 Vdc. Starting voltage for models CFM-8025V-242-435 and CFM-8025V-245-450 is 10 Vdc. PERFORMANCE3 parameter conditions/description min rated speed at rated voltage, 25°C, after 10 minutes air flow at 0 inch H2O, see performance curves static pressure noise Note: typ max units 2400 4800 RPM 23.9 60.0 CFM at 0 CFM, see performance curves 0.07 0.41 inch H2O at 1 m 20.4 48.0 dBA 3. See Model section on page 1 for specific values. PROTECTIONS / FEATURES4 parameter conditions/description auto restart on all models rotation detector signal available on “11” models tachometer signal available on “20” models Notes: min typ max units min typ max units 4. See Application Notes for details. SAFETY & COMPLIANCE parameter conditions/description insulation resistance of frame at 500 Vdc between internal stator and positive lead wire dielectric strength apply 500 Vac for 1 minute between housing and positive lead wire safety approvals UL/cUL 507, TUV (EN 60950-1) EMI/EMC EN 61000-6-1:2007, EN 61000-6-3:2007+A1 life expectancy at 40°C, 65% RH RoHS 2011/65/EU 10 MΩ 70,000 hours ENVIRONMENTAL parameter max units operating temperature conditions/description min -10 70 °C storage temperature -40 70 °C cui.com typ For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 4 of 16 PERFORMANCE CURVES CFM-8015V-124-308 CFM-8015V-127-320 Air Flow (CMM) Air Flow (CMM) ıįĹ IJ ıįıķ IJįĶ ıįıĵ IJ ıįıij Static Pressure (inch H O) ij ıįĶ ı Ķ IJı IJĶ ijı ijĶ Ĵı ijįĶ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı ı ı Ķ IJı ijı ijĶ Ĵı ĴĶ CFM-8015V-224-308 ıįĵĶ ıįķ ıįĸĶ Air Flow (CMM) ıįĺ IJįıĶ IJįij ı ıįIJķ ĵ ıįIJĵ ĴįĶ ıįIJij Ĵ ıįij ıįĵ ıįķ ıįĹ IJ ıįIJ ijįĶ ijįĶ ıįIJ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı ı ı Ķ IJı IJĶ ijı ijĶ Ĵı ĴĶ ıįıĹ ij 2 Static Pressure (inch H O) 2 Static Pressure (mm H O) 2 Static Pressure (inch H O) IJĶ Air Flow (CFM) Air Flow (CMM) ıįĴ IJ ıįıĹ ĴĶ CFM-8015V-130-347 ıįIJĶ ıįĹ Ĵ Air Flow (CFM) ı ıįķ ıįIJ ı ı ıįĵ 2 2 ıįıĹ ıįij ıįIJij ijįĶ Static Pressure (mm H O) 2 Static Pressure (inch H O) ıįIJ ı 2 ıįķ Static Pressure (mm H O) ıįĵ ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı ĵı ı ı Air Flow (CFM) cui.com Ķ IJı IJĶ ijı ijĶ Air Flow (CFM) Ĵı ĴĶ 2 ıįij Static Pressure (mm H O) ı For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 5 of 16 PERFORMANCE CURVES (CONTINUED) CFM-8015V-227-320 CFM-8015V-230-347 Air Flow (CMM) ıįķ ıįĹ IJ Ĵ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįĶ ıįıij ı 2 Static Pressure (inch H O) ijįĶ 2 ıįIJ Static Pressure (mm H O) 2 Static Pressure (inch H O) ıįIJij ı Ķ IJı IJĶ ijı ijĶ Ĵı ıįĴ ıįĺ IJįıĶ IJįij ĴįĶ ıįIJij Ĵ ijįĶ ıįIJ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı ı ı Ķ IJı IJĶ ijı ijĶ Ĵı ĴĶ ĵı Air Flow (CFM) CFM-8020V-130-350 Air Flow (CMM) ıįĵ ıįķ ıįĹ Air Flow (CMM) IJ ı ıįij ıįĵ ıįķ ıįĹ IJ ĴįĶ ıįIJĹ ĵįĶ ıįIJij Ĵ ıįIJķ ĵ ıįIJĵ ĴįĶ ıįIJij Ĵ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı Static Pressure (inch H O) 2 ijįĶ 2 ıįIJ ı ı Ķ IJı IJĶ ijı ijĶ Ĵı 2 ıįIJĵ Static Pressure (mm H O) 2 Static Pressure (inch H O) ıįĸĶ ıįIJĵ ĴĶ CFM-8020V-126-300 ıįij ıįķ ĵ Air Flow (CFM) ı ıįĵĶ ıįIJķ ı ı ıįIJĶ 2 ıįĵ ijįĶ ıįIJ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı ı ĴĶ ı Air Flow (CFM) cui.com Static Pressure (mm H O) ıįij Static Pressure (mm H O) Air Flow (CMM) ı Ķ IJı IJĶ ijı ijĶ Air Flow (CFM) Ĵı ĴĶ For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 6 of 16 PERFORMANCE CURVES (CONTINUED) CFM-8020V-133-380 CFM-8020V-139-430 ıįķ ıįĹ IJ IJįij ıįIJķ ĵ ıįIJĵ ĴįĶ ıįIJij Ĵ ıįIJ ijįĶ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ıįijĹ ıįĴ ıįĶķ ıįĹĵ IJįIJij IJįĵ ĸįķij ıįijĶ ķįĴĶ ıįij ĶįıĹ ıįIJĶ ĴįĹIJ ıįIJ ijįĶĵ ıįıĶ IJįijĸ 2 ĵįĶ 2 ıįIJĹ Static Pressure (inch H O) Ķ Static Pressure (mm H O) ı ı ı ı Ķ IJı IJĶ ijı ijĶ Air Flow (CFM) Ĵı ĴĶ IJįIJij Ĵı ĵı Ķı Air Flow (CMM) ıįĴĶ IJįĵ ĹįĹĺ ıįĵ IJıįIJķ ıįĴ ĸįķij ıįĴĶ ĹįĹĺ ıįijĶ ķįĴĶ ıįĴ ĸįķij ıįijĶ ķįĴĶ ıįij ĶįıĹ ıįij ĶįıĹ ıįIJĶ ĴįĹIJ ıįIJ ijįĶĵ ıįıĶ IJįijĸ ı Static Pressure (inch H O) ıįĹĵ ĴįĹIJ ıįIJĶ ijįĶĵ ıįIJ IJįijĸ ıįıĶ ı 2 2 ıįĶķ Static Pressure (mm H O) 2 Static Pressure (inch H O) ijı CFM-8020V-146-480 Air Flow (CMM) ıįijĹ IJı Air Flow (CFM) CFM-8020V-142-450 ı ı ı ĵı IJı ijı Ĵı ĵı Air Flow (CFM) ıįķĹ IJįıij IJįĴķ IJįĸ ı ı ı ıįĴĵ Ķı ı ı cui.com IJı ijı Ĵı ĵı Air Flow (CFM) Ķı ķı Static Pressure (mm H O) 2 Static Pressure (inch H O) ıįij ı 2 ıįĵ 2 ıįij Static Pressure (mm H O) Air Flow (CMM) Air Flow (CMM) ı For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 7 of 16 PERFORMANCE CURVES (CONTINUED) CFM-8020V-230-350 Air Flow (CMM) ı IJ ĴįĶ ıįIJij Ĵ ıįIJ ijįĶ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı IJı IJĶ ijı ijĶ Ĵı ĵ ıįIJĵ ĴįĶ ıįIJij Ĵ ıįIJ ijįĶ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı ı ı Ķ IJı ıįĵ ıįķ ıįĹ IJ ıįIJĵ ĴįĶ ıįIJij Ĵ 2 ĵ Static Pressure (inch H O) ıįIJķ 2 ĵįĶ Static Pressure (mm H O) 2 Static Pressure (inch H O) 0.00 IJįij ıįIJĹ ıįIJ ijįĶ ıįıĹ ij ıįıķ IJįĶ ıįıĵ IJ ıįıij ıįĶ ı ijĶ Ĵı Air Flow (CFM) ĴĶ IJĶ ijı ijĶ Air Flow (CFM) Ĵı ĴĶ ĵı 0.70 2.0 0.06 1.5 0.04 1.0 0.02 0.5 cui.com 0 0.14 Air Flow (CMM) 0.08 0 ı IJı ijı 5 0.28 10 0.42 15 Air Flow (CFM) 0.56 20 25 0.0 2 Air Flow (CMM) Ķ Ķ IJĶ CFM-8025V-120-204 ıįij ı IJ ıįIJķ ĴĶ CFM-8020V-233-380 ıįij ıįĹ ĵįĶ Air Flow (CFM) ı ıįķ Static Pressure (mm H O) Ķ ıįĵ ıįIJĹ ı ı Air Flow (CMM) 2 ıįIJĵ ıįij 2 ıįĹ Static Pressure (inch H O) ıįķ 2 ıįĵ Static Pressure (mm H O) ıįij 2 Static Pressure (inch H O) ı Static Pressure (mm H O) CFM-8020V-226-300 For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 8 of 16 PERFORMANCE CURVES (CONTINUED) Air Flow (CMM) 0.4 0.6 0.8 1 0.12 3 0.1 2 0.06 1.5 0.04 1 0.02 0.5 0 7 14 21 Air Flow (CFM) 28 35 0.2 0.48 0.72 0.96 1.2 3.8 0.12 3.04 0.09 2.28 0.06 1.52 0.03 0.76 0 0 8 16 24 32 40 1.36 1.7 Air Flow (CFM) 0 CFM-8025V-142-415 Air Flow (CMM) 0.4 Air Flow (CMM) 0.15 0 CFM-8025V-132-330 0 0.24 2 2 0.08 0 0.6 0.8 1 0 1.2 0.34 Air Flow (CMM) 0.68 1.02 0.3 7.62 0.15 3.75 0.25 6.35 2 2 Static Pressure (mm H O) 0.12 3 0.09 2.25 0.06 1.5 0.03 0.75 0 0 7 14 21 28 Air Flow (CFM) 35 2 4.5 Static Pressure (inch H O) 0.18 2 Static Pressure (inch H O) Static Pressure (inch H O) Static Pressure (mm H O) 2.5 2 Static Pressure (inch H O) 0 2 0.2 0 42 0.2 5.08 0.15 3.81 0.1 2.54 0.05 1.27 0 cui.com Static Pressure (mm H O) 0 CFM-8025V-129-300 Static Pressure (mm H O) CFM-8025V-126-280 0 12 24 36 48 Air Flow (CFM) 60 0 For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 9 of 16 PERFORMANCE CURVES (CONTINUED) 1.4 0.4 1.68 10 0.3 7.5 0.2 5 0.1 20 30 40 Air Flow (CFM) 50 60 0 0.2 Air Flow (CMM) 0.4 0.6 0.8 1 1.68 0.4 10.16 0.3 7.62 0.2 5.08 0.1 2.54 0.15 10 20 30 40 Air Flow (CFM) 50 0 60 2 0.08 2 0.06 1.5 0.04 1 0.02 0.5 14 21 Air Flow (CFM) 28 35 0 0.24 Air Flow (CMM) 0.48 0.72 0.96 1.2 3.8 3.04 0.12 2 Static Pressure (mm H O) 2.5 2 Static Pressure (inch H O) 0.1 7 1.4 12.7 0 3 0 1.12 CFM-8025V-229-300 0.12 0 0.84 0.5 0 CFM-8025V-226-280 0 0.56 2 10 Air Flow (CMM) 0.28 0 0.09 2.28 0.06 1.52 0.03 0.76 0 cui.com Static Pressure (mm H O) 0 Static Pressure (inch H O) 0 2.5 0 2 1.12 2 0.84 Static Pressure (inch H O) Air Flow (CMM) 0.56 2 0.28 Static Pressure (mm H O) 2 Static Pressure (inch H O) 0 CFM-8025V-148-447 Static Pressure (mm H O) CFM-8025V-145-431 0 8 16 24 Air Flow (CFM) 32 0 40 For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 10 of 16 PERFORMANCE CURVES (CONTINUED) 0.6 0.8 1 1.2 4.5 0.15 3.75 2 Static Pressure (mm H O) 0.18 0.12 3 0.09 2.25 0.06 1.5 0.03 0.75 0 7 14 21 28 Air Flow (CFM) 35 0 42 25 50 0 0.71 1.42 CFM CMM CFM-8025V-442-435 mm H O 2 inch H O 2 Static Pressure mm H O 2 Static Pressure 0 Air Flow 6 0 0.15 0 0.30 3 6 3 CFM-8025V-245-450 9 0.30 0.15 9 0.30 6 3 0 25 0 0.71 50 1.42 Air Flow CFM CMM cui.com inch H O 2 0 9 inch H O 2 Air Flow (CMM) 0.4 Static Pressure 0.2 2 Static Pressure (inch H O) 0 CFM-8025V-242-435 mm H O 2 CFM-8025V-232-330 0 0.15 0 25 50 0 0.71 1.42 Air Flow CFM CMM For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 11 of 16 PERFORMANCE CURVES (CONTINUED) Static Pressure 9 inch H O 2 mm H O 2 CFM-8025V-445-450 0.30 6 3 0 0.15 0 25 50 0 0.71 1.42 Air Flow CFM CMM cui.com For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 12 of 16 MECHANICAL parameter conditions/description motor 4 pole DC brushless min bearing system omniCOOLTM direction of rotation counter-clockwise viewed from front of fan blade dimensions CFM-8015V models: 80 x 80 x 15 CFM-8020V models: 80 x 80 x 20 CFM-8025V models: 80 x 80 x 25 material PBT (UL94V-0) weight CFM-8015V models CFM-8020V, 3900~4600 RPM models CFM-8020V, all other models CFM-8025V, 4200~4600 RPM models CFM-8025V, all other models typ max units mm mm mm 68 85 66 91 75 g g g g g MECHANICAL DRAWINGS units: mm MOUNTING SCREW (Pan Head) wire: UL 1007, 24 AWG CFM-8015V WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin White1 RD Signal Yellow1 Tach Signal CFM-8020V WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin White RD Signal Yellow1 Tach Signal 1 Notes: 1. Wires only present on versions with output signals. cui.com Screw Type Size Standard Torque Machine Screw M4 JIS B1111-1974 3~4 kgf-cm Self-tapping Screw M5 JIS B1122 Type 2 6~8 kgf-cm For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 13 of 16 MECHANICAL DRAWINGS (CONTINUED) units: mm MOUNTING SCREW (Pan Head) wire: UL 1007, 24 AWG CFM-8025V Screw Type Size Machine Screw M4 Self-tapping Screw M5 WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin White1 RD Signal Yellow1 Tach Signal Notes: 1. Wires only present on versions with output signals. 2. CFM-8025V-242-435, CFM-8025V-245-450, CFM-8025V-442-435, & CFM-8025V-445-450 have 300 ± 20 mm lead wires. cui.com Standard Torque JIS B1111-1974 3~4 kgf-cm JIS B1122 Type 2 6~8 kgf-cm For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 14 of 16 APPLICATION NOTES Auto Restart Protection When the fan motor is locked by an external force, the device will temporarily turn off electrical power to the motor and restart automatically when the locked rotor condition is released. Input Current Figure 1: Auto Start Protection t Run Locked Rotation Detector Signal (White Wire) The rotation detector signal is used to detect if the fan motor is operating or stopped. The output will be logical low (VL) when fan is operating and be logical high (Vcc) when fan motor is locked. (See Figures 2~3 below). Figure 3: Rotation Detector Output Circuit Figure 2: Rotation Detector Output Waveform Vcc Vsig DC Fan Vcc Red (+) Ic RL Vsig White VL Black (-) t Run Locked Vcc ≤ max input voltage Ic ≤ 4 mA RL ≥ Vcc/Ic VL ≤ 0.5 V Customer Circuit Tachometer Signal (Yellow Wire) The tachometer signal is for detecting the rotational speed of the fan motor. The output will be a square wave when fan is operating and logical high (Vcc) when fan motor is locked (See Figures 4~5 below). The relationship between RPM & output pulses from the signal wire is as follows. 1 RPM = 2 Pulses Figure 4: Tachometer Output Waveform Figure 5: Tachometer Output Circuit Vcc Vsig 1 Pulse DC Fan Vcc Red (+) Yellow VL Ic RL Vsig Black (-) 1 RPM Run t Locked Vcc ≤ max input voltage Ic ≤ 4 mA RL ≥ Vcc/Ic VL ≤ 0.5 V cui.com Customer Circuit For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 15 of 16 SAFETY CONSIDERATIONS 1. Do not use or operate this fan in excess of the limitations set forth in this specification. CUI is not responsible for the non-performance of this fan and/or any damages resulting from its use, if it is not used or operated in accordance with the specifications. 2. CUI recommends adding a protection circuit to the product or application in which this fan is installed, such as a thermo-fuse, or current fuse or thermo-protector. The failure to use such a device may result in smoke, fire, electric shock by insulation degradation in cases of motor lead short circuit, overload, or over voltage, and/or other failure. 3. CUI recommends installing a protection device to the product or application in which this fan is installed if there is a possibility of reverse connection between Vdc (+) and GND (-). The failue to install such a device may result in smoke, fire, and/or destruction, although these conditions may not manifest immediately. 4. This fan mush be installed and used in compliance with all applicable safety standards and regulations. 5. Use proper care when handling and/or installing this fan. Improper handling of installation of this fan may cause damage that could result in unsafe conditions. 6. Use proper care during installation and/or wiring. Failure to use proper care may cause damage to certain components of the fan including, but not limited to, the coil and lead wires, which could result in smoke and/or fire. 7. Do not use power or ground PWM to control the fan speed. If the fan speed needs to be adjusted, please contact CUI to customize the product design for your application. 8. For critical or extreme environments, including non-stop operation, please contact CUI and we will gladly provide assistance with your product selection to ensure an appropriate cooling product for your application. 9. When building your device, please examine thouroughly any variation of EMC, temperature rise, life data, quality, etc. of this product by shock/drop/vibration testing, etc. If there are any problems or accidents in connection with this product, it should be mutually discussed and examined. 10. Use proper care when handling these fans. Components such as fan holders or bearings may be damaged, if touched with fingers or other objects. Additionally, static electricity (ESD) may damage internal circuits of the fan. 11. Do not operate these fans in proximity to hazardous materials such as organic silicon, cyanogens, formalin, phenol, or corrosive gas environments including, but not limited to, H2S, SO2, NO2, or Cl2. 12. CUI recommends that you protect these fans from exposure to outside elements such as dust, condensation, humidity, or insects. Exposure of this fan to such elements may affect its performance and my cause safety hazards. CUI does not warrant against damage to the product caused by outside elements. 13. The fans must be installed properly and securely. Improper mounting may cause harsh resonance, vibration, and noise. 14. Do not store these fans in an environment with high humidity. These fans must be stored in accordance with the specified storage temperature. 15. CUI reserves the right to use components from multiple sources at its discretion. The use of components from other sources will not affect the specifications as described herein. 16. The life expectancy of these fans has not been evaluated for use in combination with any end application. Therefore, the life expectancy that relate to these fans are only for reference. cui.com For more information, please visit the product page. CUI Inc │ SERIES: CFM-80V │ DESCRIPTION: DC AXIAL FAN date 09/12/2018 │ page 16 of 16 REVISION HISTORY rev. description date 1.0 initial release 07/26/2017 1.01 discontinued CFM-8020V-139-430, CFM-8020V-142-450, CFM-8020V-146-480, CFM-8025V-442-435, CFM-8025V-445-450 models 09/12/2018 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
CFM-8020V-126-300-20 价格&库存
很抱歉,暂时无法提供与“CFM-8020V-126-300-20”相匹配的价格&库存,您可以联系我们找货
