CFM-9225V-245-460-11
    CUIDEVICES
    FAN AXIAL 92X25MM 24VDC WIRE
CFM-9225V-245-460-11 数据手册
For more information, please visit the product page. date 03/18/2019 page 1 of 10 SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN FEATURES • • • • • omniCOOLTM bearing system 92 x 92 mm frame multiple speed options for different cooling needs tachometer signal and rotation detect options available auto restart protection standard on all models MODEL input voltage input current1 input power1 rated speed1 air flow2 static pressure3 noise4 rated (Vdc) range (Vdc) max (mA) max (W) typ (RPM±10%) (CFM) (inch H2O) max (dBA) CFM-9225V-117-177 12 4.5~13.8 54 0.65 17005 28.4 0.05 17.7 CFM-9225V-124-280 12 4.5~13.8 87 1.05 2400 39.5 0.10 28.0 CFM-9225V-127-320 12 4.5~13.8 121 1.46 2700 45.0 0.13 32.0 CFM-9225V-130-340 12 4.5~13.8 161 1.94 3000 51.5 0.15 34.0 CFM-9225V-139-416 12 6.0~13.8 265 3.18 3900 65.0 0.25 41.6 CFM-9225V-142-437 12 6.0~13.8 322 3.87 4200 70.0 0.30 43.7 CFM-9225V-145-455 12 6.0~13.8 426 5.12 4500 75.0 0.35 45.5 CFM-9225V-224-280 24 8.0~27.6 51 1.23 2400 39.5 0.10 28.0 CFM-9225V-227-320 24 8.0~27.6 64 1.54 2700 45.0 0.13 32.0 CFM-9225V-230-340 24 8.0~27.6 87 2.09 3000 51.5 0.15 34.0 CFM-9225V-239-420* 24 10.0~27.6 178 4.28 3900 65.0 0.25 42.0 CFM-9225V-242-440* 24 10.0~27.6 207 4.97 4200 70.0 0.30 44.0 CFM-9225V-245-460* 24 10.0~27.6 253 6.08 4500 75.0 0.35 46.0 CFM-9225V-339-420* 48 24.0~56.0 119 5.72 3900 65.0 0.25 42.0 CFM-9225V-342-440* 48 24.0~56.0 125 6.00 4200 70.0 0.30 44.0 CFM-9225V-345-460* 48 24.0~56.0 144 6.92 4500 75.0 0.35 46.0 Notes: 1. 2. 3. 4. 5. 6. *. At rated voltage, 25°C, 0 inch H20 static pressure, after 10 minutes As per AMCA 210 or DIN 24163, at rated voltage, stabilized RPM, 0 inch H20 static pressure As per AMCA 210 or DIN 24163, at rated voltage, stabilized RPM, 0 CFM airflow. Measured in a semi-anechoic chamber with background noise < 15 dBA at 1 m from the fan intake. Typical rated speed is measured as RPM±15% at rated voltage. All specifications are measured at 25°C, 65% relative humidity unless otherwise specified. Discontinued models. PART NUMBER KEY CFM-9225V-117-177 - XX - CXX Base Number Fan Signals “blank” = no signals 11 = rotation detector signal 20 = tachometer signal cui.com Reserved for Custom Configurations For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 2 of 10 INPUT parameter conditions/description min typ max units operating input voltage1 12 Vdc input models 24 Vdc input models 48 Vdc input models 4.5 10.0 24.0 12 24 48 13.8 27.6 56.0 Vdc Vdc Vdc starting voltage2 12 Vdc input models 24 Vdc input models 48 Vdc input models Note: 4.5 8 24 Vdc Vdc Vdc 1. See Model section on page 1 for specific input voltage ranges. 2. The starting voltage for models CFM-9225V-139-416, CFM-9225V-142-437, and CFM-9225V-145-455 is 6 Vdc. TThe starting voltage for models CFM-9225V-239-420, CFM-9225V-242-440, and CFM-9225V-245-460 is 10 Vdc. PERFORMANCE3 parameter conditions/description min rated speed at rated voltage, 25°C, after 10 minutes air flow at 0 inch H2O, see performance curves static pressure noise Note: typ max units 1700 4500 RPM 28.4 75.0 CFM at 0 CFM, see performance curves 0.05 0.35 inch H2O at 1 m 17.7 46.0 dBA 3. See Model section on page 1 for specific values. PROTECTIONS / FEATURES4 parameter conditions/description auto restart on all models rotation detector signal available on “11” models tachometer signal available on “20” models Notes: min typ max units min typ max units 4. See Application Notes for details. SAFETY & COMPLIANCE parameter conditions/description insulation resistance of frame at 500 Vdc between internal stator and positive lead wire dielectric strength apply 500 Vac for 1 minute between housing and positive lead wire safety approvals UL/cUL 507, TUV (EN 60950-1) EMI/EMC EN 61000-6-1:2007, EN 61000-6-3:2007+A1 life expectancy at 40°C, 65% RH RoHS 2011/65/EU 10 MΩ 70,000 hours ENVIRONMENTAL parameter max units operating temperature conditions/description min -10 70 °C storage temperature -40 70 °C cui.com typ For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 3 of 10 PERFORMANCE CURVES CFM-9225V-117-177 Air Flow (CMM) 0.84 0 0.05 1.25 0.04 1.00 0.03 0.75 0.02 0.50 0.01 0.25 10 15 20 Air Flow (CFM) 25 30 0.78 1.04 1.5 0.04 1 0.02 0.5 0 8 16 24 32 40 0 Air Flow (CMM) 1.3 0 0.12 3.04 0.09 2.28 0.06 1.52 0.03 0.76 9 0.06 18 27 Air Flow (CFM) 36 45 0.32 0.64 0.96 1.28 1.6 0.15 3.8 0.12 3.04 0.09 2.28 0.06 1.52 0.03 0.76 2 0.52 2 Air Flow (CMM) 3.8 0 2 CFM-9225V-130-340 0.15 0 2.5 Air Flow (CFM) Static Pressure (mm H O) 2 Static Pressure (inch H O) 0.26 1.2 0.08 0 0.00 CFM-9225V-127-320 0 0.96 0 0 cui.com Static Pressure (mm H O) 5 0.72 2 0 0.48 0.1 Static Pressure (inch H O) 0 0.24 2 0.7 Static Pressure (mm H O) 0.56 2 0.42 Static Pressure (inch H O) 0.28 2 Air Flow (CMM) Static Pressure (mm H O) 0.14 2 Static Pressure (inch H O) 0 CFM-9225V-124-280 0 11 22 33 Air Flow (CFM) 44 55 0 For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 4 of 10 PERFORMANCE CURVES (CONTINUED) CFM-9225V-139-416 CFM-9225V-142-437 Air Flow (CMM) Air Flow (CMM) 1.695 0 2.26 0.565 2.26 7.62 0.25 6.35 0.25 6.35 0.2 5.08 0.2 5.08 0.15 3.81 0.15 3.81 0.1 2.54 0.1 2.54 0.05 1.27 0.05 1.27 Static Pressure (inch H O) 40 Air Flow (CFM) 60 80 2 0 0 0 0 20 Air Flow (CMM) 2.26 0.3 7.5 0.2 5 0.1 2.5 0 20 40 60 Air Flow (CFM) 80 0.28 0.56 0.84 1.12 0.1 2 10 0 Static Pressure (inch H O) 1.695 2 1.13 0.4 0 80 CFM-9225V-224-280 Static Pressure (mm H O) 0.565 60 Air Flow (CFM) Air Flow (CMM) 0 40 2.5 0.08 2 0.06 1.5 0.04 1 0.02 0.5 0 0 0 0 cui.com 10 20 Air Flow (CFM) 30 40 2 20 7.62 2 2 0 CFM-9225V-145-455 2 1.695 0.3 0 Static Pressure (inch H O) 1.13 0.3 Static Pressure (mm H O) 1.13 Static Pressure (mm H O) 0.565 Static Pressure (mm H O) 2 Static Pressure (inch H O) 0 For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 5 of 10 PERFORMANCE CURVES (CONTINUED) 0.28 Air Flow (CMM) 0.56 0.84 1.12 1.4 0 1.4 1.68 3.04 0.12 3.04 0.09 2.28 0.09 2.28 0.06 1.52 0.06 1.52 0.03 0.76 0.03 0.76 0 20 30 Air Flow (CFM) 40 0 0 0 50 10 20 30 40 Air Flow (CFM) 50 60 CFM-9225V-242-440 mm H O 2 Static Pressure 0.30 6 0.15 3 9 0.30 6 3 0 30 60 0 0.85 1.70 Air Flow CFM CMM inch H O 2 10 2 2 2 Static Pressure (inch H O) Static Pressure (mm H O) 0.12 inch H O 2 mm H O 2 1.12 3.8 CFM-9225V-239-420 Static Pressure 0.84 0.15 0 0 Air Flow (CMM) 0.56 3.8 0 9 0.28 0.15 2 Static Pressure (inch H O) 0 CFM-9225V-230-340 Static Pressure (mm H O) CFM-9225V-227-320 0 0.15 0 30 60 0 0.85 1.70 Air Flow cui.com CFM CMM For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 6 of 10 PERFORMANCE CURVES (CONTINUED) Static Pressure 6 0.15 0 0 0 30 0.85 60 1.70 Air Flow CFM 30 0.85 60 1.70 CFM CFM Air Flow mm H O 2 inch H O 2 Static Pressure mm H O 2 Static Pressure 0 0 CMM CFM-9225V-345-460 0.30 6 0.15 3 0 0.15 CMM CFM-9225V-342-440 9 6 3 3 0 0.30 9 inch H O 2 Static Pressure 0.30 9 inch H O 2 mm H O 2 9 CFM-9225V-339-420 inch H O 2 mm H O 2 CFM-9225V-245-460 0.30 6 0.15 3 0 30 60 0 0.85 1.70 Air Flow CFM CMM cui.com 0 0 30 60 0 0.85 1.70 Air Flow CMM For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 7 of 10 MECHANICAL parameter conditions/description motor 4 pole DC brushless min bearing system omniCOOLTM direction of rotation counter-clockwise viewed from front of fan blade dimensions 92 x 92 x 25 material PBT (UL94V-0) weight 1700~3000 RPM models 12 Vdc input, 3900~4500 RPM models all other models typ max units mm 92 106 103 g g g MECHANICAL DRAWING units: mm MOUNTING SCREW (Pan Head) wire: UL 1007, 24 AWG Screw Type Size Machine Screw M4 Self-tapping Screw M5 WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin White1 RD Signal Yellow1 Tach Signal Notes: Notes: 1. Wires only present on versions with output signals. 2. 1700~3000 RPM models have 305 ±10 mm lead wires. 12 Vdc input, 3900~4500 RPM models have 300 ±20 mm lead wires. cui.com Standard Torque JIS B1111-1974 3~4 kgf-cm JIS B1122 Type 2 6~8 kgf-cm For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 8 of 10 APPLICATION NOTES Auto Restart Protection When the fan motor is locked by an external force, the device will temporarily turn off electrical power to the motor and restart automatically when the locked rotor condition is released. Input Current Figure 1: Auto Start Protection t Run Locked Rotation Detector Signal (White Wire) The rotation detector signal is used to detect if the fan motor is operating or stopped. The output will be logical low (VL) when fan is operating and be logical high (Vcc) when fan motor is locked. (See Figures 2~3 below). Figure 3: Rotation Detector Output Circuit Figure 2: Rotation Detector Output Waveform Vcc Vsig DC Fan Vcc Red (+) Ic RL Vsig White VL Black (-) t Run Locked Vcc ≤ max input voltage Ic ≤ 4 mA RL ≥ Vcc/Ic VL ≤ 0.5 V Customer Circuit Tachometer Signal (Yellow Wire) The tachometer signal is for detecting the rotational speed of the fan motor. The output will be a square wave when fan is operating and logical high (Vcc) when fan motor is locked (See Figures 4~5 below). The relationship between RPM & output pulses from the signal wire is as follows. 1 RPM = 2 Pulses Figure 4: Tachometer Output Waveform Figure 5: Tachometer Output Circuit Vcc Vsig 1 Pulse DC Fan Vcc Red (+) Yellow VL Ic RL Vsig Black (-) 1 RPM Run t Locked Vcc ≤ max input voltage Ic ≤ 4 mA RL ≥ Vcc/Ic VL ≤ 0.5 V cui.com Customer Circuit For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 9 of 10 SAFETY CONSIDERATIONS 1. Do not use or operate this fan in excess of the limitations set forth in this specification. CUI is not responsible for the non-performance of this fan and/or any damages resulting from its use, if it is not used or operated in accordance with the specifications. 2. CUI recommends adding a protection circuit to the product or application in which this fan is installed, such as a thermo-fuse, or current fuse or thermo-protector. The failure to use such a device may result in smoke, fire, electric shock by insulation degradation in cases of motor lead short circuit, overload, or over voltage, and/or other failure. 3. CUI recommends installing a protection device to the product or application in which this fan is installed if there is a possibility of reverse connection between Vdc (+) and GND (-). The failue to install such a device may result in smoke, fire, and/or destruction, although these conditions may not manifest immediately. 4. This fan mush be installed and used in compliance with all applicable safety standards and regulations. 5. Use proper care when handling and/or installing this fan. Improper handling of installation of this fan may cause damage that could result in unsafe conditions. 6. Use proper care during installation and/or wiring. Failure to use proper care may cause damage to certain components of the fan including, but not limited to, the coil and lead wires, which could result in smoke and/or fire. 7. Do not use power or ground PWM to control the fan speed. If the fan speed needs to be adjusted, please contact CUI to customize the product design for your application. 8. For critical or extreme environments, including non-stop operation, please contact CUI and we will gladly provide assistance with your product selection to ensure an appropriate cooling product for your application. 9. When building your device, please examine thouroughly any variation of EMC, temperature rise, life data, quality, etc. of this product by shock/drop/vibration testing, etc. If there are any problems or accidents in connection with this product, it should be mutually discussed and examined. 10. Use proper care when handling these fans. Components such as fan holders or bearings may be damaged, if touched with fingers or other objects. Additionally, static electricity (ESD) may damage internal circuits of the fan. 11. Do not operate these fans in proximity to hazardous materials such as organic silicon, cyanogens, formalin, phenol, or corrosive gas environments including, but not limited to, H2S, SO2, NO2, or Cl2. 12. CUI recommends that you protect these fans from exposure to outside elements such as dust, condensation, humidity, or insects. Exposure of this fan to such elements may affect its performance and my cause safety hazards. CUI does not warrant against damage to the product caused by outside elements. 13. The fans must be installed properly and securely. Improper mounting may cause harsh resonance, vibration, and noise. 14. Do not store these fans in an environment with high humidity. These fans must be stored in accordance with the specified storage temperature. 15. CUI reserves the right to use components from multiple sources at its discretion. The use of components from other sources will not affect the specifications as described herein. 16. The life expectancy of these fans has not been evaluated for use in combination with any end application. Therefore, the life expectancy that relate to these fans are only for reference. cui.com For more information, please visit the product page. CUI Inc │ SERIES: CFM-92V │ DESCRIPTION: DC AXIAL FAN date 03/18/2019 │ page 10 of 10 REVISION HISTORY rev. description date 1.0 initial release 07/31/2017 1.01 discontinued CFM-9225V-242-440, CFM-9225V-339-420, CFM-9225V-342-440, CFM-9225V-345-460 models 09/12/2018 1.02 discontinued CFM-9225V-239-420, CFM-9225V-245-460 models 03/18/2019 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
CFM-9225V-245-460-11 价格&库存
很抱歉,暂时无法提供与“CFM-9225V-245-460-11”相匹配的价格&库存,您可以联系我们找货
