MD-50FC
MD-50FC
    CUIDEVICES
    5 针位圆形连接器 插孔,母插口 焊接
MD-50FC 数据手册
Additional Resources: Product Page date 08/25/2017 page 1 of 4 SERIES: MD-FC │ DESCRIPTION: MINI DIN CONNECTOR PCB mount fully shielded right angle ground tabs ferrite filter U • • • • • ED FEATURES N RoHS TI PART NUMBER KEY N MD - XX FC O Base Number Pin Options 30 = 3 pins 40 = 4 pins 50 = 5 pins 60 = 6 pins 70 = 7 pins 80 = 8 pins IS C SPECIFICATIONS parameter conditions/description min rated input voltage rated input current typ at 100 Vac at 12 Vdc contact resistance at 250 Vdc for 1 minute ferrite performance at 25 MHz at 100 MHz 1 2 A A 30 mΩ 250 Vac MΩ 13 27 insertion force units Vac Vdc 50 D insulation resistance voltage withstand max 100 12 Ω Ω 1 4.5 kg withdrawal force 0.8 3 kg operating temperature -40 life 85 1,000 flammability rating UL94V-0 RoHS 2011/65/EU cui.com °C cycles Additional Resources: Product Page CUI Inc │ SERIES: MD-FC │ DESCRIPTION: MINI DIN CONNECTOR date 08/25/2017 │ page 2 of 4 MECHANICAL DRAWINGS units: mm[inches] TOLERANCE: ±0.2mm plastic PBT U N 6 4 2 3 1 6.5 0.26 2.8 0.11 5.5 0.22 8.5 0.33 11.0 0.43 MD-40FC 4 3 2 1 2 5.5 0.22 (2 PLCS) 5 3 5.5 0.22 (2 PLCS) 4.7 0.19 8.5 0.33 (2 PLCS) 0.7X2.2 (3 PLCS) 3 0.9 0.04 6.8 0.27 PCB LAYOUT TOP VIEW 2 13.5 0.53 11.0 0.43 (2 PLCS) 11.0 0.43 0.9 0.04 (3 PLCS) 4 3 1 13.5 0.53 2 1 MD-50FC 1 13.5 0.53 4.7 0.19 8.5 0.33 (2 PLCS) 0.3 0.01 (8 PLCS) 4.7 0.19 O IS C MD-30FC D 3.5 0.14 2.0 0.08 0.7 0.03 (8 PLCS) 13.8 0.54 0.7X2.2 (3 PLCS) Ferrite Spacer 0.3 0.01 N 3.7 0.15 0.3 0.01 (TYP) silver ferrite TI 5 13.0 0.51 tin phosphor bronze 13.2 0.52 14.1 0.56 7 PLATING brass contact terminals (1~8) spacer 8 MATERIAL ED earth terminal 1 2 3 4 0.9 0.04 (4 PLCS) 5.5 0.22 (2 PLCS) 4.7 0.19 8.5 0.33 (3 PLCS) 11.0 0.43 (2 PLCS) 2 0.7X2.2 (3 PLCS) 1 4 5 0.9 0.04 (5 PLCS) 6.8 0.27 PCB LAYOUT TOP VIEW cui.com 3 1.3 0.05 6.8 0.27 PCB LAYOUT TOP VIEW Additional Resources: Product Page CUI Inc │ SERIES: MD-FC │ DESCRIPTION: MINI DIN CONNECTOR date 08/25/2017 │ page 3 of 4 MECHANICAL DRAWINGS (CONTINUED) 5 4 7 2 1 5.5 0.22 (2 PLCS) 1 2 5 11.0 0.43 (3 PLCS) 3 0.7X2.2 (3 PLCS) 6 0.9 0.04 (6 PLCS) 5.5 0.22 (2 PLCS) 8.5 0.33 (4 PLCS) 4 5 1 2 6 4 7 6.8 0.27 PCB LAYOUT TOP VIEW PCB LAYOUT TOP VIEW D IS C O N TI 6.8 0.27 cui.com 3 1 6 4 11.0 0.43 (4 PLCS) 2 7 0.9 0.04 (8 PLCS) N 2.6 0.10 5.5 0.22 (2 PLCS) 4.7 0.19 8.5 0.33 (4 PLCS) 0.7X2.2 (3 PLCS) 0.9 0.04 0.9 0.04 (7 PLCS) 2.6 0.10 3 1 13.5 0.53 4.7 0.19 11.0 0.43 (2 PLCS) 4 2 1 6 7 5 13.5 0.53 4.7 0.19 8.5 0.33 (4 PLCS) 3 8 5 3 2 13.5 0.53 0.7X2.2 (3 PLCS) 6 4 3 MD-80FC U 6 MD-70FC ED MD-60FC 6.8 0.27 PCB LAYOUT TOP VIEW 5 8 0.9 0.04 2.6 0.10 Additional Resources: Product Page CUI Inc │ SERIES: MD-FC │ DESCRIPTION: MINI DIN CONNECTOR date 08/25/2017 │ page 4 of 4 REVISION HISTORY description date 03/12/2012 1.0 initial release 1.01 updated spec, added ferrite performance 1.02 updated datasheet ED rev. 07/23/2013 08/25/2017 D IS C O N TI N U The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
MD-50FC 价格&库存
很抱歉,暂时无法提供与“MD-50FC”相匹配的价格&库存,您可以联系我们找货
