MD-40SF
MD-40SF
    CUIDEVICES
    MINI DIN RECEPT RT ANG SHIELDED
MD-40SF 数据手册
For more information, please visit the product page. date 02/29/2012 page 1 of 3 SERIES: MD-XXSF │ DESCRIPTION: MINI DIN CONNECTOR ED FEATURES U • PCB mount • fully shielded • right angle N RoHS TI PART NUMBER KEY N MD - XX SF O Base Number Pin Options 30 = 3 pins 40 = 4 pins 50 = 5 pins 60 = 6 pins 80 = 8 pins SPECIFICATIONS conditions/description min IS C parameter at 100 Vac at 12 Vdc contact resistance insulation resistance at 250 Vdc voltage withstand for 1 minute max 100 12 rated input voltage rated input current typ Vac Vdc 1 2 A A 30 mΩ 50 insertion force units MΩ 1 250 Vac 4.5 kg 0.8 3 kg operating temperature -40 85 °C D withdrawl force life 1,000 cui.com cycles For more information, please visit the product page. CUI Inc │ SERIES: MD-XXSF │ DESCRIPTION: MINI DIN CONNECTOR date 02/29/2012 │ page 2 of 3 MECHANICAL DRAWINGS units: mm[inches] TOLERANCE: ±0.2mm MATERIAL PLATING brass tin ED earth terminal 4 2 U 6 3 1 6.5 0.26 0.3 0.01 3.5 0.14 (TYP) 0.3 0.01 (TYP) N 3.7 0.15 5.5 0.22 IS C O 2.0 0.08 8.5 0.33 11.0 0.43 MD-40SF 4 3 2 1 5.5 0.22 (2 PLCS) 4.7 0.19 D 0.9 0.04 (3 PLCS) 11.0 0.43 1 13.5 0.53 6.8 0.27 PCB LAYOUT TOP VIEW 2 13.5 0.53 5.5 0.22 (2 PLCS) 4.7 0.19 8.5 0.33 (2 PLCS) 0.7X2.2 (3 PLCS) 0.9 0.04 4 5 3 1 1 2 3 MD-50SF 3 2 13.5 0.53 8.5 0.33 (2 PLCS) 0.3 0.01 (8 PLCS) 4.7 0.19 2.0 0.08 (TYP) 0.7 0.03 (8 PLCS) MD-30SF 0.7X2.2 (3 PLCS) PBT N 5 13.0 0.51 housing silver TI 7 phosphor bronze 13.2 0.52 14.1 0.56 8 contact terminals (1~8) 0.9 0.04 (4 PLCS) 11.0 0.43 (2 PLCS) 1 2 3 4 6.8 0.27 PCB LAYOUT TOP VIEW cui.com 5.5 0.22 (2 PLCS) 4.7 0.19 8.5 0.33 (3 PLCS) 11.0 0.43 (2 PLCS) 2 0.7X2.2 (3 PLCS) 0.9 0.04 (5 PLCS) 1 4 3 5 1.3 0.05 6.8 0.27 PCB LAYOUT TOP VIEW For more information, please visit the product page. CUI Inc │ SERIES: MD-XXSF │ DESCRIPTION: MINI DIN CONNECTOR date 02/29/2012 │ page 3 of 3 MD-60SF 6 MD-80SF 5 4 8 3 1 2 13.5 0.53 5.5 0.22 (2 PLCS) 4.7 0.19 4.7 0.19 8.5 0.33 (4 PLCS) 11.0 0.43 (2 PLCS) 0.9 0.04 (6 PLCS) 2 4 6 5 0.7X2.2 (3 PLCS) 2.6 0.10 5.5 0.22 (2 PLCS) 11.0 0.43 (4 PLCS) 3 1 6 4 2 7 5 8 U 0.7X2.2 (3 PLCS) 1 3 1 13.5 0.53 8.5 0.33 (4 PLCS) 3 4 ED 2 6 7 5 0.9 0.04 0.9 0.04 (8 PLCS) 6.8 0.27 2.6 0.10 6.8 0.27 PCB LAYOUT TOP VIEW TI N PCB LAYOUT TOP VIEW REVISION HISTORY rev. 1.02 date initial release 02/23/2006 new template applied 02/23/2012 updated pin dimensions 02/29/2012 N 1.0 1.01 description D IS C O The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
MD-40SF 价格&库存
很抱歉,暂时无法提供与“MD-40SF”相匹配的价格&库存,您可以联系我们找货
