L6R18-120
L6R18-120
    TRI-MAG
    AC/DC WALL MOUNT ADAPTER 12V 18W
L6R18-120 数据手册
GR EEN POW ER Power Supplies L6R18 Series 18W Wall Mount Power Supply • DOE Level VI Efficiency Rating • Universal Input: 90 ~ 264Vac, 47/63 Hz • Safety Approvals: UL/cUL, CE • Corded Output Connection • Lightweight & Compact Load (A) Model No.* Application Output Connector Output Voltage Peak Voltage Accuracy Ripple Noise Line Reg. Load Reg. Min Rated L6R18-050 ITE Corded Plug +5.0V 0 2.1 — ±5% 50mVpp ± 1% ±5% L6R18-090 ITE Corded Plug +9.0V 0 2.1 — ±5% 90mVpp ± 1% ± 5% L6R18-120 ITE Corded Plug +12.0V 0 1.5 — ±5% 120mVpp ± 1% ± 5% L6R18-150 ITE Corded Plug +15.0V 0 1.2 — ±5% 150mVpp ± 1% ± 5% L6R18-180 ITE Corded Plug +18.0V 0 1.0 — ±5% 180mVpp ± 1% ± 5% L6R18-240 ITE Corded Plug +24.0V 0 0.8 — ±5% 240mVpp ± 1% ± 5% L6R18-300 ITE Corded Plug +30.0V 0 0.6 — ±5% 240mVpp ± 1% ± 5% L6R18-360 ITE Corded Plug +36.0V 0 0.5 — ±5% 240mVpp ± 1% ± 5% * Model No. format: L6R18-YYY, where YYY=050 to 360 representing output voltage. Output voltages from 5.0Vdc to 36Vdc are available for Level VI compliance in increments of 0.1V. Please contact Tri-Mag, LLC for the part number and specifications for your output voltage and/or specific output connector requirements and application. • • • • • Output voltage is verified to specification at 60% rated load condition. Line Regulation is defined by changing ± 10% of input voltage from nominal line at rated load. Load Regulation is defined by changing ± 40% of measured output load from 60% rated load. The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope and terminated each output with a 10 μF electrolytic and a 0.1 μF capacitor at rated load and nominal line. Efficiency is measured at rated load and nominal line. 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com Power Supplies L6R18 Series Economical and dependable whether powering stationary or portable devices. choose from: 5.0Vdc to 36Vdc (in increments of 0.1V), to match your specific need. This DOE Level VI compliant power supply/charger is rated up to 19W, with plenty of voltage levels to Call us (800-657-0853) for the part number to match your particular need. Specifications Input Input Voltage Input Frequency No Load Input Power Input Current Inrush Current Leakage Current Input Connection Warranty • • • • • • • 90 VAC ~ 264 Vac 47 Hz to 63 Hz ≤ 0.1W 1.2A Max. 40A Max. 0.25mA Max. US (others available) Output Voltage Range Output Current Range Minimum Load Line Regulation • • • • Load Regulation Ripple & Noise Overvoltage Protection Overload Protection Short Circuit Protection • • • • • 5.0 ~ 36Vdc 500 - 2100mA, 19.2W Max. No min. load required. ± 1% at rated load across input voltage range. ± 5% 240mV p-p Max. Auto recovery Auto recovery Auto recovery • • • 50MΩ Min. Level VI compliant 50,000 Hrs to MIL-HDBK-217F at +25°C • • • 0°C to 40°C 5% - 95% RH, Non-Condensing -20°C to +80°C • • • cULus: UL60950-1 CE FCC Output Warranty Period • 1 year Dimensions Tolerance Size • • Weight Connectors ± 0.2mm 71.2 x 43.2 x 29.0 mm 2.80 x 1.70 x 1.14 Inches • Approx. 125g (4.4 oz.) • AC input, US 2-prong inlet plug • DC output, standard 5.5mm x 2.1mm x x 9.5mm corded dc output plug or per customer specification. Cord length • 1500 ± 20 mm (59 ± .8”) Mechanical Drawing General Insulation Resistance Efficiency MTBF Environmental Operating Temperature Operating Humidity Storage Temperature EMC & Safety Safety Approvals EMC Approvals: 2017-06 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
L6R18-120 价格&库存
很抱歉,暂时无法提供与“L6R18-120”相匹配的价格&库存,您可以联系我们找货
