L6R09H-050U
L6R09H-050U
    TRI-MAG
    AC/DC WALL MOUNT ADAPTER 5V 9W
L6R09H-050U 数据手册
GR EEN POW ER Power Supplies L6R09H Series 9W Wall Mount Power Supply • DOE Level VI Efficiency Rating • Universal Input: 90 ~ 264Vac, 47/63 Hz • UL/cUL Safety Approved • Corded Output Connection • 5Vdc USB Connection Available • Light Weight and Compact Output Current Application Output Connector Output Voltage Min Rated Peak Voltage Accuracy Ripple Noise Line Reg. Load Reg. L6R09H-050 ITE Corded Jack +5.0V 0 1.80 — ±5% < ± 1% ± 1% ± 5% L6R09H-050U ITE USB Connector +5.0V 0 1.80 — ±5% < ± 1% ± 1% ± 5% L6R09H-070 ITE Corded Jack +7.0V 0 1.28 — ±5% < ± 1% ± 1% ± 5% L6R09H-090 ITE Corded Jack +9.0V 0 1.00 — ±5% < ± 1% ± 1% ± 5% L6R09H-120 ITE Corded Jack +12.0V 0 0.75 — ±5% < ± 1% ± 1% ± 5% L6R09H-150 ITE Corded Jack +15.0V 0 0.60 — ±5% < ± 1% ± 1% ± 5% L6R09H-180 ITE Corded Jack +18.0V 0 0.50 — ±5% < ± 1% ± 1% ± 5% L6R09H-190 ITE Corded Jack +19.0V 0 0.47 — ±5% < ± 1% ± 1% ± 5% L6R09H-240 ITE Corded Jack +24.0V 0 0.38 — ±5% < ± 1% ± 1% ± 5% Model No. • • • • • • Output voltages from 5.0Vdc to 24.0Vdc are available in increments of 0.1V. Please contact Tri-Mag, LLC for the part number and specifications for your output voltage requirement and application. The output voltage is verified to specs at 60 percent rated load condition. The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load. The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load. The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load and nominal line. The efficiency is measured at rated load and nominal line. 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com Power Supplies L6R09H Series Innovative, reliable, and inexpensive. That’s the L6R09H Series. This economical, DOE Level VI compliant power supply/charger is rated up to 9W when charging any mobile or wireless device. Plenty of voltage levels to choose from, too. From 5.0Vdc all the way up to 24.0Vdc (in increments of 0.1V), to match your need. Contact us (800-657-0853 or Sales@Tri-Mag.com) for the part number to match your specifications. Specifications Input Input Voltage Input Frequency No Load Input Power Input Current Inrush Current Leakage Current Input Connection Warranty • • • • • • • 90 Vac ~ 264 Vac 47 Hz to 63 Hz < 0.1W 1.2A Max. 40A Max. 0.25mA Max. US (others available) Output Voltage Range Output Current Range Minimum Load Line Regulation • • • • Load Regulation Ripple & Noise Overvoltage Protection Overload Protection Short Circuit Protection • • • • • 5.0 to 24.0 Vdc 375 - 1800mA, 9W Max. No min. load required. ± 1% at rated load across input voltage range ± 5% 100mVp-p Max. Auto recovery Auto recovery Auto recovery Output Warranty Period • 1 year Dimensions and Notes Dimensions in mm Tolerance • Size • Weight • Connectors • Cord length ± 0.2mm 56.0 x 45.0 x 26.0 mm 2.20 x 1.77 x 1.02 Inches Approx. 90g (3.17 oz.) Ref. AC input, US 2-prong inlet plug DC output, standard 5.5mm x 2.1mm corded dc output jack or per customer specification. • 1500 ± 20 mm (59 ± .8”) Mechanical Drawing General Insulation Resistance Efficiency MTBF • 50MΩ Min. • Level VI compliant • 50,000 hrs to MIL-HDBK-217F at +25°C Environmental Operating Temperature Operating Humidity Storage Temperature • 10°C to 40°C • 5% - 95% RH, Non-Condensing • -20°C to +80°C EMC & Safety Safety Approvals EMC Approvals • UL: UL60950-1 • cUL: UL60950-1 • FCC 2017-06 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
L6R09H-050U 价格&库存
很抱歉,暂时无法提供与“L6R09H-050U”相匹配的价格&库存,您可以联系我们找货
