GR EEN POW ER
Medical Power Supplies
L6R300DM Series
300W Medical Power Supply
DOE Level VI Efficiency Rating
Universal Input: 90 ~ 264Vac, 47/63 Hz
ANSI/AAMI/IEC/EN ES60601-1:2012 Approved
Means of Protection: 2xMOPP
Corded Output Connection
IEC 60320 C14 or C18 AC input connector
Light Weight and Compact
2-Year Warranty
Output Current (A)
Application
Output
Connector
Output
Voltage
Min
Rated
L6R300DM-120
Medical
8-Pin Rectangular
+12.0V
L6R300DM-150
Medical
6-Pin Rectangular
+15.0V
L6R300DM-240
Medical
6-Pin Rectangular
L6R300DM-480
Medical
6-Pin Rectangular
Model No.1
Peak
Voltage
Accuracy
Ripple
Noise
Line
Reg.
Load
Reg.
25.00
±5%
< ± 2%
± 1%
± 5%
±5%
< ± 2%
± 1%
± 5%
+24.0V
±5%
< ± 2%
± 1%
± 5%
+48.0V
±5%
< ± 2%
± 1%
± 5%
1. Add “C14” or “C18” for the required AC input connector configuration.
The output voltage is verified to specs at 60 percent rated load condition.
The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load.
The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load.
The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load
and nominal line.
The efficiency is measured at rated load and nominal line.
1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
Power Supplies
L6R300DM Series
Innovative, inexpensive and medical reliability. This
economical DOE Level VI compliant medical power
supply/charger is available in a variety of voltage
levels, 12.0 to 48.0Vdc (per the model number table)
to match your needs. Rated up to 300W when
powering either stationary or charging portable
devices for home healthcare and medical office/
hospital applications.
Specifications
Input
EMC & Safety
90 Vac ~ 264 Vac, 100~240Vac Nominal
47 Hz to 63 Hz
< 0.15W
3.4A @ 120Vac / 1.6A @ 230Vac
60A Max. / 230Vac
< 100μA
Safety Approvals
Harmonic Currents
EMI
ESD Immunity
Output Voltages
Output Current
Minimum Load
Line Regulation
Radiated Immunity
Load Regulation
Ripple & Noise
Hold-up Time
Overvoltage Protection
Overload Protection
Short Circuit Protection
12.0, 15.0, 24.0 and 48.0Vdc
25.00 to 6.25A
No min. load required.
± 1% at rated load across input
voltage range
± 5% (typical)
2% Vp-p Max. @ full load
10mS @ Full Load
Auto recovery
Auto recovery
Auto recovery
Input Voltage
Input Frequency
No Load Input Power
Input Current
Inrush Current
Leakage Current
Input Connection
Output
General
Dielectric Withstand
Efficiency
MTBF
EMC Approvals
EFT Burst
Surge
Conducted Immunity •
Magnetic Fields
Dips & Interruptions •
ANSI/AAMI ES60601-1:2012, edition 3.1
IEC/EN ES60601-1:2012, edition 3.1
• Radiated & Conducted Emissions:
EN55011 CISPR 11, Class B
Harmonic Current: EN61000-3-2, 3
EMC: IEC60601-1-2:2014, edition 4.0
EN 61000-3-2 Class A
EN 55022/CISPR 22 Class B; EN 61000-3-3
EN 61000-4-2, ±15kV/Air
Criterion A
± 8kV/Contact
Criterion A
EN 61000-4-3, 10V/m with
80% AM @ 1kH
Criterion A
EN 61000-4-4, ±2kV
Criterion A
EN 61000-4-5, ±1kV/L-L, ±2kV/L-G Criterion A
EN 61000-4-6, 3Vrms, 80% AM,1kHz Criterion A
EN 61000-4-8, 30A/m
Criterion A
EN 61000-4-11, 100% dips 10ms Criterion A
100% dips 20ms Criterion A
30% dips 500ms Criterion B
Warranty
Warranty Period
2 years
Dimensions and Notes
4,000Vac Primary to Secondary
DoE Level VI, ErP Stage 2 compliant
300,000 hrs. @ 25ºC per Telcordia SR-332
Environmental
Operating Temperature
Operating Humidity
Storage Temperature
Storage Humidity
0°C to 40°C
20 to 80% RH, Non-Condensing
-20°C to +80°C
10 to 90%, Non-Condensing
Dimensions in mm
Tolerance
Size
Weight
Connectors
Output Cord length
± 0.2mm
L 254 x W 116 x H 47 mm
L 10.00” x W 4.57” x H 1.85”
Approx. 1600g [3.52 lbs.] (ref.)
AC input: IEC 60320 C14 / C18 Connector
DC output; Standard 6-pin (2x3) Molex
P/N: 39-01-2060 or equivalent connector.
See Mechanical Drawing below for mating
connector information.
L6R300DM-120: 1000 ±50 mm [39.37 ±2.0”]
All others:
1200 ±50 mm [47.2 ±2.0”]
Mechanical Drawing
Output Connector Housing:
-120: Molex P/N: 39-01-2080 or equiv.
All Others: Molex P/N: 39-01-2060 or equiv.
Mating connectors: Molex 5559, 5566, 5569
42404, 42440 or equiv.
L6R300DM-120
L6R300DM-150
L6R300DM-240
L6R300DM-480
2019-03
很抱歉,暂时无法提供与“L6R300DM-480-C14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1876.693361+242.77894
