GR EEN POW ER
Medical Power Supplies
L6R65DM Series
65W Medical Power Supply
DOE Level VI Efficiency Rating
Universal Input: 90 ~ 264Vac, 47/63 Hz
ANSI/AAMI/IEC/EN ES60601-1:2012 Approved
Means of Protection: 2xMOPP
Corded Output Connection
IEC 60320 C6 / C14, C8 / C18 AC input connectors
Light Weight and Compact
2-Year Warranty
Output Current (A)
Application
Output
Connector
Output
Voltage
Min
Rated
L6R65DM-120
Medical
Corded Connector
+12.0V
L6R65DM-150
Medical
Corded Connector
+15.0V
L6R65DM-180
Medical
Corded Connector
L6R65DM-190
Medical
L6R65DM-240
L6R65DM-480
Model No.1
Peak
Voltage
Accuracy
Ripple
Noise
Line
Reg.
Load
Reg.
5.00
±5%
< ± 2%
± 1%
± 5%
±5%
< ± 2%
± 1%
± 5%
+18.0V
±5%
< ± 2%
± 1%
± 5%
Corded Connector
+19.0V
±5%
< ± 2%
± 1%
± 5%
Medical
Corded Connector
+24.0V
±5%
< ± 2%
± 1%
± 5%
Medical
Corded Connector
+48.0V
±5%
< ± 2%
± 1%
± 5%
1. Add “C6”, C8, “C14” or “”C18” for the required AC input connector configuration.
The output voltage is verified to specs at 60 percent rated load condition.
The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load.
The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load.
The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load
and nominal line.
The efficiency is measured at rated load and nominal line.
1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
Power Supplies
L6R65DM Series
Innovative, inexpensive and medical reliability. This
to match your needs. Rated up to 65W when
economical DOE Level VI compliant medical power
powering either stationary or charging portable
supply/charger is available in a variety of voltage
devices for home healthcare and medical office/
levels, 12.0 to 48.0Vdc (per the model number table)
hospital applications.
Specifications
Input
Input Voltage
Input Frequency
No Load Input Power
Input Current
Inrush Current
Leakage Current
Input Connection
Environmental
90 Vac ~ 264 Vac, 100~240Vac Nominal
47 Hz to 63 Hz
< 0.15W
1.6A @ 120Vac / 0.7A @ 230Vac
60A Max. / 230Vac
< 100μA
IEC 60320 C6 / C14 or C8 / C18,
dependent upon output voltage and
resulting input current
Output Voltage Range
Output Current Range
Minimum Load
Line Regulation
Load Regulation
Ripple & Noise
Hold-up Time
Overvoltage Protection
Overload Protection
Short Circuit Protection
12.0 to 48.0Vdc
5.00 to 1.36A
No min. load required.
± 1% at rated load across input
voltage range
± 5% (typical)
2% Vp-p Max. @ full load
10mS @ Full Load
Auto recovery
Auto recovery
Auto recovery
Output
General
Dielectric Withstand
Efficiency
MTBF
• 4,000Vac Primary to Secondary
• DoE Level VI, ErP Stage 2 compliant
• 300,000 hrs. @ 25ºC per Telcordia SR-332
Operating Temperature
Operating Humidity
Storage Temperature
Storage Humidity
0°C to 40°C
20 to 80% RH, Non-Condensing
-20°C to +80°C
10 to 90%, Non-Condensing
EMC & Safety
Safety Approvals
• ANSI/AAMI ES60601-1:2012, edition 3.1
IEC/EN ES60601-1:2012, edition 3.1
EMC Approvals
• Radiated & Conducted Emissions:
EN55011 CISPR 11, Class B
Harmonic Current: EN61000-3-2, 3
EMC: IEC60601-1-2:2014, edition 4.0
Warranty
Warranty Period
• 2 years
Dimensions and Notes
Dimensions in mm
Tolerance
Size
Weight
Connectors
Output Cord length
• ± 0.2mm
• L 119 x W 60 x H 36 mm
L 4.69” x W 2.36” x H 1.42”
• Approx. 350g [0.77 lb.] (ref.)
• AC input: IEC 60320 C6 / C14 or
C8 / C18 connector
DC output: Standard 5.5mm x 2.1mm
corded dc output connector or
per customer specification.
• 1500 ±50 mm [59.1 ±2.0”]
Mechanical Drawing
2017-08
很抱歉,暂时无法提供与“L6R65DM-190-C14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+371.095741+48.00690
