53319-577
53319-577
    CCS
    EMBEDDED SERIAL BUS DEV KIT
53319-577 数据手册
Embedded Serial Busses Development Kit Sku: 53319-577 Development Kit Options Tools Included w/Compiler Just H/W Only PCB Compiler Software Programmer Prototyping board Power supply & cables Exercise book Price This kit gives users an introduction to SPI and I2C serial buses. The development kit includes the powerful PCW Integrated ® Development Environment with compiler support for Microchip's PIC PIC10, PIC12 and PIC16 families and an ICD-U64 in-circuit programmer/debugger that supports C-aware real time debugging. The prototyping board has two nodes and shares common I/O, memory and sensor components between two PIC16 MCUs. The first node has a PIC16F877A chip connected to a 74HC165 parallel-in/serial-out shift register, which allows its user to read a bank of eight DIP switches. Four 74HC595 serial-in/ parallel-out shift registers allow the user to display information on a four digit 7segment LED display. 2 The second node has a PIC16F876A chip, which shares an I C temperature sensor and a serial EEPROM with the first node. This allows for the investigation into data collision while accessing shared components. Both nodes have their own potentiometer, LEDs, pushbutton and RS-232 port. Embedded Serial Busses Prototyping Board (Size 4.5" x 3.25") includes: • • • • PIC16F877A PIC16F876A 30 I/O Pins (7 Can Be Analog) Two Nodes 2 • Common I C Bus Between Nodes • I2C EEPROM • • • • 2 I C Temperature Sensor SPI Bus to Real-Time Clock Three 7-Segment LEDs 8 DIP Switches Page 2 of 2 • Expansion I/O Bus • Connections Between MCU Nodes for custom communications Embedded Serial Busses Development Kit includes: • • • • Embedded Serial Busses Development Board In-Circuit Debugger/Programmer Exercise Tutorial 9V AC Adapter and Cables http://www.ccsinfo.com/product_info.php?products_id=embserkit 5/2/2014
53319-577 价格&库存
很抱歉,暂时无法提供与“53319-577”相匹配的价格&库存,您可以联系我们找货
