ICD-U80 In-Circuit Programmer/Debugger
Sku: 53506-1648
ICD-U80 is a complete In-Circuit Programming and In-Circuit Debugging solution for Microchip's PIC®
MCUs and dsPIC® DSCs. ICD-U80 debug support covers all targets that have debug mode when used in
conjunction with the C-Aware IDE Compilers. The unit also provides in-circuit serial programming (ICSP)
support for all Flash chips.
ICD-U80 Advantages:
Accelerated programming speed using a 140MHz internal processor
Integrated Vdd generator to supply 1.5-5.5V and 400mA to target
Software controlled power to target - no jumpers to change
Fully integrated with the CCS C-Aware IDE or can be used stand-alone
Supports all Microchip PIC® MCU or Flash Devices
Powers and Connects with USB
Includes FREE CCSLOAD Software
Data Streaming - Obtain Real-time Diagnostic Data, and more...
RoHS Compliant
CCSLOAD FREE programmer control software supports the ICD-U80 and offers many new key
features including; powerful command line options in Windows/Linux, extensive diagnostics, easy to use
production interface, and enhanced security options.
Easy to use GUI interface
Include configuration fuses in the programming
Optionally can verify hex file CRC's to ensure the file was not corrupted
Optionally can verify chip is actually read protected after programming
Can program encrypted hex files to reduce the chance of reverse engineering
Serial numbering and logging built into the software
Connection to your target chip is easy using universally accepted connections:
RJ12 cable included
Tag-Connect cable for connector-less
PCB's
Third-party straight
connectors
http://www.ccsinfo.com/product_info.php?products_id=icd‐u80 5‐3‐17
很抱歉,暂时无法提供与“53506-1648”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1307.442231+169.15256
